Salesforce Plat-Admn-301 Prfungsinformationen & Plat-Admn-301 Examengine
Posted at 1/15/2026 07:11:51
View237
Replies5
Die Prfungsfragen und Antworten von It-Pruefung Salesforce Plat-Admn-301 bieten Ihnen alles, was Sie zur Prfungsvorbereitung brauchen. Fr Salesforce Plat-Admn-301 Prfung können Sie auch Lernhilfe aus anderen Websites oder Bchern finden. Aber Hauptsache ist es, sie mssen logisch verbinden. Unsere Salesforce Plat-Admn-301 Zertifizierungsantworten ermöglichen es Ihnen, mhelos die Prfung zum ersten Mal zu bestehen. Zugleich können Sie auch viele wertvolle Zeit sparen.
Salesforce Plat-Admn-301 Prfungsplan:| Thema | Einzelheiten | | Thema 1 | - Data and Analytics Management: This section of the exam measures skills of Salesforce Data Analyst and covers data quality assessment, data enrichment, and duplicate management. It explains how to choose appropriate reporting and analytics tools for advanced requirements, including custom report types, snapshots, formulas, joined reports, and dashboard configurations. It also covers methods for connecting external data sources using big objects, external objects, data warehouses, data lakes, and Salesforce Connect. Finally, it describes the suitable tools and methods for importing data, including Data Loader, Data Import Wizard, and external IDs.
| | Thema 2 | - Environment Management and Deployment: This section of the exam measures skills of Salesforce Administrator and covers moving metadata between environments using tools such as sandboxes, change sets, and managed or unmanaged AppExchange packages. It explains the capabilities and best practices related to deploying changes through change sets to ensure smooth and controlled migrations.
| | Thema 3 | - Security and Access: This section of the exam measures the skills of Salesforce Administrator and covers how record-level access, field access, and sharing models impact data visibility across the system. It focuses on understanding controlled-by-parent relationships, territory management, role hierarchies, and access to reports, dashboards, and email folders. It also includes comparing custom profiles, permission sets, and delegated administration, along with evaluating different authentication methods. The section also addresses the structure of business models such as person accounts, standard accounts, contacts, and contact-to-multiple-account relationships.
| | Thema 4 | - Cloud Applications: This section of the exam measures skills of Salesforce Consultant and covers the standard Salesforce capabilities that support sales and service operations. It includes features such as products, price books, schedules, orders, quotes, and the tools that help with forecasting and territory management. The section also describes how to create Salesforce Knowledge articles, manage entitlements, support service workflows, and enable interactions through chat, case feed, Omni-Channel, console apps, and Experience Cloud sites. It also introduces the broader Salesforce suite that extends core platform functionality.
| | Thema 5 | - Auditing and Monitoring: This section of the exam measures skills of a Salesforce Support Specialist and covers the tools used to monitor system behavior and review user activity. It includes understanding debug logs, setup audit trail, and methods for ensuring sensitive data is handled correctly in both production and sandbox environments. It also explains how to review and troubleshoot security settings, including recognizing pending updates that might affect system access.
| | Thema 6 | - Process Automation: This section of the exam measures skills of Salesforce Consultant and covers choosing the right automation tools to solve complex business problems. It focuses on understanding the capabilities and limitations of declarative tools, identifying the right troubleshooting methods, and applying automation correctly within Salesforces order of execution. This section emphasizes designing efficient, scalable automation using workflow tools, flows, and other declarative features.
Plat-Admn-301 Examengine, Plat-Admn-301 MusterprfungsfragenEs gibt ein Sprichwort, das Spiel beendet, wenn Sie es aufgeben. Die Prfung ist ähnlich wie das Spiel. Viele geben die Salesforce Plat-Admn-301 Zertifizierungsprfungen auf, wenn sie nicht genug Zeit haben. Aber Sie können Plat-Admn-301 Prfung mit guter Note bestehen, wenn Sie die richtige exam Fragen benutzen trotz kurzer Zeit. Glauben Sie nicht? Dann mssen sie die Plat-Admn-301 Prfungsunterlagen von It-Pruefung probieren.
Salesforce Certified Platform Administrator II Plat-Admn-301 Prfungsfragen mit Lösungen (Q24-Q29):24. Frage
Cloud Kicks users need to link multiple Case records to multiple Outcome records stored in a custom object.
Any user that can view the Case record must be able to create a link. The administrator creates a Case Outcome custom object.
What is the recommended option to use when adding a field to Case Outcome?
- A. Master-detail relationship with Read-Only sharing setting.
- B. Mater-detail relationship with Read/Write sharing setting
- C. Lookup relationship with Ready-Only sharing setting.
- D. Lookup relationship with Read/Write sharing setting
Begrndung:
A lookup relationship with Read/Write sharing setting is the recommended option to use when adding a field to Case Outcome custom object. A lookup relationship is a type of relationship that links two objects together and allows users to associate one record with another. A lookup relationship does not affect the security or deletion of either record and can be optional or required. In this case, you can create a lookup relationship field on Case Outcome object that references Case object and allows users to link multiple Case records to multiple Case Outcome records. You can also set the sharing setting for the lookup field to Read/Write, which means that users who have access to the parent record can also access and edit the child record. References:
https://help.salesforce.com/s/ar ... okup.htm&type=5 https://help.salesforce.com
/s/articleView?id=sf.relationships_considerations_lookup.htm&type=5
25. Frage
DreamHouse Realty wants better insights into potential revenue in the next quarter and is considering using Collaborative Forecasts.
What should the administrator consider when setting up Collaborative Forecasts?
- A. The default forecast categories cannot be customized.
- B. Opportunity Split data cannot be viewed in a forecast.
- C. A single org can have up to six different types of forecasts.
- D. A forecast can be either revenue-based or quantity-based.
Begrndung:
A forecast is a projection of how much revenue or quantity you can generate from your sales pipeline for a given period of time. A forecast can be either revenue-based or quantity-based, depending on what you want to measure and track. A revenue-based forecast shows the amount of money expected from closed sales, while a quantity-based forecast shows the number of units expected from closed sales. You can choose the forecast type that best suits your business needs and goals when you set up Collaborative Forecasts in Salesforce.
References: https://help.salesforce.com/s/ar ... view.htm&type=5 https://help.
salesforce.com/s/articleView?id=sf.forecasts3_forecast_types.htm&type=5
26. Frage
AW Computing sells a variety of software programs for Its customers to choose from. Management wants to ensure that the customer automatically receives phone support when they purchase photo editing. software.
how should an administrator meet these retirements?
- A. Create a flow to attach an entitlement to the asset upon purchase.
- B. Configure a flow to create a milestone co the asset upon purchase.
- C. Add an entitlement template to the pressure conduct for phone support.
- D. Include a milestone to the product with a term of 365 days for phone support.
Begrndung:
An entitlement is a record that represents a customer's right to receive support or service based on the terms of a contract or agreement. An asset is a record that represents a product that a customer has purchased. To automatically provide phone support to customers who purchase photo editing software, the administrator can create a flow that attaches an entitlement to the asset upon purchase. The entitlement can have a term of 365 days and a service contract that specifies the phone support details. References: https://help.salesforce.com/s
/articleView?id=sf.entitlements_overview.htm&type=5 https://help.salesforce.com/s/articleView?id=sf.
assets_overview.htm&type=5
27. Frage
Cloud Kicks wants its sales reps to always use the same full zip code format with a hyphen where applicable.
What should the administrator implement to help ensure consistent formatting?
- A. Create a REGEX function to use in a validation rule on the field.
- B. Edit the standard field length to five characters.
- C. Add a help text instructing the sales rep on how to enter this field.
- D. Add a quick create function for the sales reps to use.
Begrndung:
REGEX is a function that allows administrators to check whether a text value matches a regular expression pattern. Regular expressions are a way to define complex patterns of characters using symbols and operators.
REGEX can be used to enforce consistent formatting for a field value by specifying the required length, characters, and separators.
28. Frage
An administrator created a new custom object. When trying to upload new records to the custom object using.
Date Loader, they are unable to see the new custom object in the list of available objects.
What should the administrator do to resolve the issue?
- A. Check the Field-Level Security of the new custom object's Name field.
- B. Ensure Allow Sharing is checked on the custom object.
- C. Assign a permission set to give them access to the new object.
- D. Confirm the object us marked as deployed and not in development.
Begrndung:
Confirm the object is marked as deployed and not in development is what the administrator should do to resolve the issue. A custom object can be marked as deployed or in development depending on its readiness for use. A custom object that is marked as in development is not visible to users or available for data import or export. A custom object that is marked as deployed is visible to users and available for data import or export. Therefore, the administrator should make sure that the new custom object is marked as deployed before using Data Loader to upload records to it
29. Frage
Zurzeit ist Salesforce Plat-Admn-301 Zertifizierungsprfung eine sehr populäre Prfung. Wollen die Plat-Admn-301 Zeritifizierungsprfung ablegen? Tatsächlich ist diese Prfung sehr schwierig. Aber es bedeutet nicht, dass Sie diese Prfung mit guter Note bestehen können. Wollen Sie die Methode, die Plat-Admn-301 Prfung sehr leicht zu bestehen, kennenzulernen? Das ist Salesforce Plat-Admn-301 dumps von It-Pruefung.
Plat-Admn-301 Examengine: https://www.it-pruefung.com/Plat-Admn-301.html
- Plat-Admn-301 Prfungsfragen Prfungsvorbereitungen 2026: Salesforce Certified Platform Administrator II - Zertifizierungsprfung Salesforce Plat-Admn-301 in Deutsch Englisch pdf downloaden 🛩 Suchen Sie jetzt auf ➠ [url]www.zertpruefung.ch 🠰 nach Plat-Admn-301 um den kostenlosen Download zu erhalten 🙎
lat-Admn-301 Testengine[/url] - Plat-Admn-301 Übungsmaterialien - Plat-Admn-301 Lernressourcen - Plat-Admn-301 Prfungsfragen 🛄 Suchen Sie jetzt auf [url]www.itzert.com nach ✔ Plat-Admn-301 ️✔️ und laden Sie es kostenlos herunter 🙌
lat-Admn-301 Testking[/url] - Kostenlose gltige Prfung Salesforce Plat-Admn-301 Sammlung - Examcollection 📋 Geben Sie ➥ [url]www.zertsoft.com 🡄 ein und suchen Sie nach kostenloser Download von ▷ Plat-Admn-301 ◁ 🎿
lat-Admn-301 Prfungsvorbereitung[/url] - Plat-Admn-301 Dumps Deutsch 📧 Plat-Admn-301 Examsfragen 🌗 Plat-Admn-301 Zertifikatsfragen 👫 Suchen Sie auf [url]www.itzert.com nach ☀ Plat-Admn-301 ️☀️ und erhalten Sie den kostenlosen Download mhelos 🕚
lat-Admn-301 Deutsche[/url] - Plat-Admn-301 Bestehen Sie Salesforce Certified Platform Administrator II! - mit höhere Effizienz und weniger Mhen 👮 Suchen Sie auf ➠ [url]www.zertpruefung.ch 🠰 nach ▛ Plat-Admn-301 ▟ und erhalten Sie den kostenlosen Download mhelos 🗳
lat-Admn-301 Fragen Und Antworten[/url] - Plat-Admn-301 Bestehen Sie Salesforce Certified Platform Administrator II! - mit höhere Effizienz und weniger Mhen 🧴 Öffnen Sie [ [url]www.itzert.com ] geben Sie Plat-Admn-301 ein und erhalten Sie den kostenlosen Download 🌜
lat-Admn-301 Demotesten[/url] - Wir machen Plat-Admn-301 leichter zu bestehen! 🥊 Suchen Sie jetzt auf de.fast2test.com nach ➥ Plat-Admn-301 🡄 um den kostenlosen Download zu erhalten 🦞
lat-Admn-301 Lernressourcen - Plat-Admn-301 Exam 🎵 Plat-Admn-301 Fragenpool 📰 Plat-Admn-301 Zertifikatsfragen 🛕 Sie mssen nur zu [url]www.itzert.com gehen um nach kostenloser Download von ➥ Plat-Admn-301 🡄 zu suchen 🥨
lat-Admn-301 Probesfragen[/url] - Kostenlose gltige Prfung Salesforce Plat-Admn-301 Sammlung - Examcollection 📹 Öffnen Sie ▛ [url]www.pruefungfrage.de ▟ geben Sie Plat-Admn-301 ein und erhalten Sie den kostenlosen Download ⏫
lat-Admn-301 Schulungsunterlagen[/url] - Wir machen Plat-Admn-301 leichter zu bestehen! 🦎 Suchen Sie einfach auf ➤ [url]www.itzert.com ⮘ nach kostenloser Download von ⮆ Plat-Admn-301 ⮄ 🤖
lat-Admn-301 Zertifizierungsfragen[/url] - Plat-Admn-301 Fragenpool 🧶 Plat-Admn-301 Testengine 🛀 Plat-Admn-301 Fragenpool 🐯 Geben Sie [url]www.zertfragen.com ein und suchen Sie nach kostenloser Download von Plat-Admn-301 🧦Plat-Admn-301 Lernressourcen[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, acupressurelearning.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
