[General] High-quality Juniper New JN0-336 Exam Format | Try Free Demo before Purchase
95
【General】 High-quality Juniper New JN0-336 Exam Format | Try Free Demo before Purchase
Posted at 1/17/2026 06:58:59      View:145 | Replies:1        Print      Only Author   [Copy Link] 1#
ActualVCE is obliged to give you three months of free update checks to ensure the validity and accuracy of the Security, Specialist (JNCIS-SEC) (JN0-336) exam dumps. We also offer you a 100% money-back guarantee, in the very rare case of failure or unsatisfactory results. This puts your mind at ease when you are Security, Specialist (JNCIS-SEC) (JN0-336) exam preparing with us.
We provide you with two kinds of consulting channels if you are confused about some questions on our JN0-336 study materials. You can email us or contact our online customer service. We will reply you as soon as possible. You are free to ask questions about JN0-336 training prep at any time since that we are working 24/7 online. Our staff is really very patient and friendly. They are waiting to give you the most professional suggestions on our JN0-336 exam questions.
Reliable JN0-336 Exam Sims & JN0-336 Test Cram PdfAS the most popular JN0-336 learning braindumps in the market, our customers are all over the world. So the content of JN0-336 exam questions you see are very comprehensive, but it is by no means a simple display. In order to ensure your learning efficiency, we have made scientific arrangements for the content of the JN0-336 Actual Exam. Our system is also built by professional and specilized staff and you will have a very good user experience.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q85-Q90):NEW QUESTION # 85
Which method does the loT Security feature use to identify traffic sourced from IoT devices?
  • A. The SRX Series device identifies loT devices from metadata extracted from their transit traffic.
  • B. The SRX Series device streams transit traffic received from the IoT device to Juniper ATP Cloud.
  • C. The SRX Series device identifies loT devices using their MAC address.
  • D. The SRX Series device streams metadata from the loT device transit traffic to Juniper ATP Cloud Juniper ATP Cloud.
The metadata is used to identify the type of device, its associated activities and its threat profile. This information is used to determine the appropriate security policy for the device. For more information on loT Security, please refer to the Juniper Security, Specialist (JNCIS-SEC) study guide.
NEW QUESTION # 86
Which two statements are correct about a reth LAG? (Choose two.)
  • A. Links must have the same speed and duplex setting.
  • B. You must have a "minimum-links" statement value of two.
  • C. You should have two or more interfaces.
  • D. Links must use the same cable type
A reth LAG is a redundant Ethernet link aggregation group that combines multiple physical interfaces into a single logical interface in a chassis cluster. A reth LAG provides load balancing and redundancy for traffic within or between redundancy groups. Two statements that are correct about a reth LAG are:
Links must have the same speed and duplex setting: To form a reth LAG, the physical interfaces must have the same speed and duplex setting. This ensures that the links can operate at the same capacity and avoid performance issues or errors.
You should have two or more interfaces: To create a reth LAG, you need to have at least two physical interfaces. One interface should be connected to node 0 and the other interface should be connected to node 1. You can also have more than two interfaces in a reth LAG for increased bandwidth and redundancy.
Reference: = Configuring Redundant Ethernet Interfaces, [Understanding Redundant Ethernet Interfaces]
NEW QUESTION # 87
Which two statements are correct about JSA data collection? (Choose two.)
  • A. The Event Collector parses logs
  • B. The Event Collector collects information using BGP FlowSpec.
  • C. The Flow Collector parses logs.
  • D. The Flow Collector can use statistical sampling
Answer: A,D
The Flow Collector can use statistical sampling to collect and store network flow data in the JSA database. The Event Collector collects information from various sources including syslog, SNMP, NetFlow, and BGP FlowSpec. Both the Flow Collector and the Event Collector parse logs to extract useful information from the logs.
NEW QUESTION # 88
Which two statements are true about the vSRX? (Choose two.)
  • A. UNIX is the base OS.
  • B. It does not have VMXNET3 vNIC support.
  • C. Linux is the base OS.
  • D. It has VMXNET3 vNIC support.
NEW QUESTION # 89
When a security policy is modified, which statement is correct about the default behavior for active sessions allowed by that policy?
  • A. The active sessions allowed by the policy will be dropped.
  • B. The active sessions allowed by the policy will continue unchanged.
  • C. Only policy changes that involve modification of the action field will cause the active sessions affected by the change to be dropped.
  • D. Only policy changes that involve modification of the application will cause the active sessions affected by the change to be dropped.
When you modify a security policy on the SRX Series device, the default behavior is that the existing sessions that match the policy will continue unchanged. This means that the policy modification will only affect new sessions that are initiated after the change. However, you can change this behavior by using the clear-policy-session command, which will clear all the sessions that match the modified policy and force them to re-evaluate the new policy. Reference: = JNCIS-SEC Certification, Open Learning - Security, Specialist (JNCIS-SEC), Security Policies (Advanced)
NEW QUESTION # 90
A certificate means a lot for people who want to enter a better company and have a satisfactory salary. JN0-336 exam dumps of us will help you to get a certificate as well as improve your ability in the processing of learning. JN0-336 study materials of us are high-quality and accurate. We also pass guarantee and money back guarantee if you fail to pass the exam. We offer you free demo to have a try. If you have any questions about the JN0-336 Exam Dumps, just contact us.
Reliable JN0-336 Exam Sims: https://www.actualvce.com/Juniper/JN0-336-valid-vce-dumps.html
and APP version of JN0-336 exam guide supports any electronic device, Then just trying JN0-336 learning materials of us, with the pass rate is 98.95%, we help the candidates to pass the exam successfully, Juniper New JN0-336 Exam Format I promise you will have no regrets about reading our introduction, Also, ActualVCE provides free updates of Juniper JN0-336 exam questions for up to 365 days.
You will also find any confirmed errata for a product on the product's catalog page, The tiny black triangle, and APP version of JN0-336 Exam Guide supports any electronic device.
Then just trying JN0-336 learning materials of us, with the pass rate is 98.95%, we help the candidates to pass the exam successfully, I promise you will have no regrets about reading our introduction.
Free PDF Quiz 2026 Juniper JN0-336 Updated New Exam FormatAlso, ActualVCE provides free updates of Juniper JN0-336 exam questions for up to 365 days, Choose JN0-336 exam cram, success, the tentacles can be!
Posted at 1/18/2026 06:32:54        Only Author  2#
The content is so good, I’m liking it immediately. Thanks to the Actual JN0-232 test pdf, I was able to earn a promotion and raise. It’s now free to all. Wishing you all the best for your promotion!
