[Linux] PWM problems
154
Linux PWM problems
Posted at 5/12/2023 22:32:00      View3241 | Replies5        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: rk356x_linux_release_v1.3.0b_20221213
  • Modification Content: LVDS with PWM configuration
  • Log: no log.zip
I have a custom board based on RK3568jq.
I made Linux minimal image using Yocto:
https://wiki.t-firefly.com/en/Fi ... e/manual_yocto.html
I added PWM control and it works fine using next command:echo 100 > /sys/class/backlight/backlight/brightness
but as i can see using oscilloscope , the frequency of PWM signal is about 40 seconds instead of 20 kHz !
my dtsi-file modifications:
rk3568-firefly-roc-pc.dtsi
backlight:backlight {
        status = "okay";
        compatible = "pwm-backlight";
        pwms = <&pwm4 0 50000 0>;
lvds_panel: lvds-panel {
        compatible = "simple-panel";
        status = "okay";
        backlight = <&backlight>;
what im doing wrong about frequency?
The third paramenter 50000 is frequency in nanoseconds ?
no log.zip
22 Bytes, Down times: 0
Posted at 5/15/2023 17:45:54        Only Author  2#
The 50000 is means 50000ns.
If you need to set the maximum clock frequency, please use 'echo 255 > /sys/class/backlight/backlight/brightness'.
Posted at 1/12/2026 09:21:27        Only Author  3#
Wollen Sie The Open Group OGA-032 Zeritifizierungsprfung ablegen? Wollen Sie die The Open Group OGA-032 Zertifizierung bekommen? Wie können Sie ohne sehr gute Vorbereitung diese Prfung ablegen? Tatsächlich gibt es eine Weise fr Sie, in sehr beschränkter Zeit die The Open Group OGA-032 Prfung leicht zu bestehen. Was können Sie machen? Es ist erreichbar, dass Sie die The Open Group OGA-032 Dumps von ZertPruefung benutzen.
Posted at 1/14/2026 20:16:41        Only Author  4#
Your article is simply remarkable, thank you for sharing! Preparing for the CITM cuttin g-edge resources exam. Hope it goes smoothly!
Posted at 1/18/2026 07:14:17        Only Author  5#
What a great source of motivation, thank you for sharing this article! Enhance your IT skills with free Valid test PDII-JPN cram pdf. Best wishes for your exams!
Posted at 2/5/2026 01:30:42        Only Author  6#
Tip: the author has been banned or deleted automatically shield
