[Hardware] Pass Guaranteed 2026 Pegasystems Professional PEGACPRSA22V1 Exam Paper Pdf
86
Hardware Pass Guaranteed 2026 Pegasystems Professional PEGACPRSA22V1 Exam Paper Pdf
Posted at 1/18/2026 18:57:22      View235 | Replies3        Print      Only Author   [Copy Link] 1#
Exam-Killer has built customizable Pegasystems PEGACPRSA22V1 practice exams (desktop software & web-based) for our customers. Users can customize the time and Certified Pega Robotics System Architect 22 (PEGACPRSA22V1) questions of Pegasystems PEGACPRSA22V1 Practice Tests according to their needs. You can give more than one test and track the progress of your previous attempts to improve your marks on the next try.
The PEGACPRSA22V1 Exam is suitable for professionals who have experience in software development, automation, and IT. Certified Pega Robotics System Architect 22 certification exam is a vendor-neutral certification that validates the knowledge and skills of the candidates in Pega Robotics technology. Certified Pega Robotics System Architect 22 certification exam is a combination of multiple-choice questions and practical exercises that test the candidate's ability to design, develop, and deploy Pega Robotics solutions. Certified Pega Robotics System Architect 22 certification exam is a valuable credential for professionals who want to enhance their career opportunities in the field of Pega Robotics technology.
The Certified Pega Robotics System Architect 22 certification exam is a vendor-neutral certification offered by Pegasystems, a leader in digital process automation technologies. Certified Pega Robotics System Architect 22 certification demonstrates a candidate's knowledge of robotics and automation technology and validates their skills in developing intelligent solutions that can improve business processes.
PEGACPRSA22V1 Latest Study Guide & New PEGACPRSA22V1 Exam NotesOriginating the PEGACPRSA22V1 exam questions of our company from tenets of offering the most reliable backup for customers, and outstanding results have captured exam candidates heart for their functions. Our PEGACPRSA22V1 practice materials can be subdivided into three versions. All those versions of usage has been well-accepted by them. There is not much disparity among these versions of PEGACPRSA22V1 simulating practice, but they do helpful to beef up your capacity and speed up you review process to master more knowledge about the exam, so the review process will be unencumbered.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q99-Q104):NEW QUESTION # 99
The Automation Playback window allows you to ______________.
  • A. replay your last Runtime session where the applications are provided with the same account numbers automatically
  • B. open a log file and step through it as if you were running your solution in debug mode
  • C. open a log file and debug any exceptions
  • D. rerun the last automation that ran with the same values as inputs automatically entered
NEW QUESTION # 100
While interrogating a web application, you come across a hidden menu item: AddressType. The AddressType menu item activates when the pointer hovers over the control; the menu displays a drop-down list.
How do you interrogate this hidden drop-down list control?
  • A. Choose Select Element from the Interrogation Form dialog box.
  • B. Access the Virtual Controls tab on the adapter tab.
  • C. From the Web Controls tab, select the browser and frame, then select List Web controls.
  • D. Choose HTML Table Editor from the Interrogation Form dialog box.
NEW QUESTION # 101
You can adjust how users interact with a robotics project on their desktops. Which file stores the settings that control user functions and desktop robotic access?
  • A. PegaConfig.xml
  • B. PegaRuntimeConfig.xml
  • C. CommonConfig.xml
  • D. PegaStudioConfig.xml
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
The PegaRuntimeConfig.xml file contains configuration settings that control how users interact with Pega Robot Runtime on their desktops.
These settings define parameters such as:
* Robot tray icon visibility
* Notification preferences
* Runtime startup behavior
* Access permissions for attended automation
According to the Pega Robotics System Design and Implementation Guide, section "Runtime Configuration Settings":
"The PegaRuntimeConfig.xml file defines user interaction settings and behavior of Pega Robot Runtime on end-user desktops.
It specifies configurations related to user access, tray icon visibility, notification pop-ups, and desktop automation permissions." Detailed Reasoning:
* A. PegaConfig.xml - Not a valid configuration file in Pega Robotics.
* B. CommonConfig.xml - Used for shared system-wide connectivity and Robot Manager settings.
* C. PegaStudioConfig.xml - Stores configuration data for Pega Robot Studio (developer-specific).
* D. PegaRuntimeConfig.xml - Correct. Defines desktop-level user interaction and Runtime behavior.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Runtime Configuration File Overview section (Pega Robotics 19.1 and later).
NEW QUESTION # 102
While setting up Start My Day, the user makes some changes in the Manage Applications window to prioritize and manage the applications that are configured to launch using the Start My Day functionality.
Which of the following applications does the user see on the desktop after using the Start My Day functionality?
  • A. CRM, Notepad, BankerInsight
  • B. CRM, BankerInsight
  • C. Pega Finance, CRM, Notepad, BankerInsight
  • D. Pega Finance, Notepad, BankerInsight
In Pega Robot Studio, the Start My Day (SMD) functionality allows a user to define and launch all required applications at once when starting work. The configuration of these applications is performed in the Manage Applications window, where each application can be individually enabled or disabled for automatic startup.
According to the Pega Robotics System Design and Implementation Guide, in the section "Start My Day Configuration and Manage Applications", the documentation specifies the following:
"Applications configured for Start My Day will launch automatically when the Start My Day feature is invoked.
The Manage Applications dialog lists all project applications and determines which ones are launched using the 'Enabled' checkbox.
Only applications marked as enabled will be started when the user initiates Start My Day. Applications that are listed but not enabled remain closed." The screenshot in the question shows the following configuration under the Manage Applications window:
Application
Enabled
Type
Path
Pega Finance
Yes
Adapter
BankerInsight
Yes
Adapter
Crogram Files (x86)CRM SetupCRM.exe
CRM
No
Exe
Notepad
Yes
Exe
C:Windowsotepad.exe
From this configuration, the Enabled column indicates that the following applications will start automatically when Start My Day is triggered:
* Pega Finance
* BankerInsight
* Notepad
The CRM application is not enabled and therefore will not launch.
Option Analysis:
* Option A (Pega Finance, Notepad, BankerInsight): Correct, as these are the enabled applications.
* Option B (CRM, BankerInsight): Incorrect, because CRM is not enabled.
* Option C (CRM, Notepad, BankerInsight): Incorrect, because CRM is not enabled.
* Option D (Pega Finance, CRM, Notepad, BankerInsight): Incorrect, because CRM is not enabled.
Therefore, the correct answer is A. Pega Finance, Notepad, BankerInsight.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Start My Day (SMD) Configuration and Application Management section (Pega Robotics 19.1 and later).
NEW QUESTION # 103
The Adapter Match Rules tab provides the developer the access to resolve match rule issues during interrogation of an application and during maintenance of the solution. The Match Rules tab contains four areas.
Drag each Area on the left to the correct Area Description.
NEW QUESTION # 104
Your life will take place great changes after obtaining the PEGACPRSA22V1 certificate. Many companies like to employ versatile and comprehensive talents. What you have learnt on our PEGACPRSA22V1 study materials will meet their requirements. So you will finally stand out from a group of candidates and get the desirable job. Also, learning our PEGACPRSA22V1 Study Materials will fulfill your dreams. Nothing will stop you as long as you are rich. Also, respect and power is gained through knowledge and skills. If you want to get a higher position in the company, you must have the ability to defeat other excellent colleagues.
PEGACPRSA22V1 Latest Study Guide: https://www.exam-killer.com/PEGACPRSA22V1-valid-questions.html
Posted at 1/20/2026 03:18:26        Only Author  2#
Your article is brilliant, thank you for providing this amazing share! This CEDP latest real exam helped me get promoted and earn more. Now, its free for everyone. Wishing you all success in reaching your promotions!
Posted at 2/6/2026 10:22:00        Only Author  3#
What a remarkable article, I truly appreciate you sharing it. Im facing the Latest exam FCP_FWF_AD-7.4 certification cost exam. Lets hope for a good result!
Posted at 3/6/2026 15:22:11        Only Author  4#
Thank you for your insightful article, it really left a mark. CDFOM valid test camp pdf played a major role in my promotion and salary increaseget it for free today!
