[Hardware] Valid JN0-351 Exam Online, Valid JN0-351 Practice Materials
99
【Hardware】 Valid JN0-351 Exam Online, Valid JN0-351 Practice Materials
Posted at 1/19/2026 03:08:52      View:125 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that RealVCE JN0-351 dumps now are free: https://drive.google.com/open?id=1R4QUAkbE95tAMkYnyLF2I7XBukNLcZb2
No doubt the Enterprise Routing and Switching, Specialist (JNCIS-ENT) (JN0-351) certification exam is a challenging exam that always gives a tough time to their candidates. However, with the help of RealVCE Juniper Exam Questions, you can prepare yourself quickly to pass the Enterprise Routing and Switching, Specialist (JNCIS-ENT) exam. The RealVCE Juniper JN0-351 Exam Dumps are real, valid, and updated Juniper JN0-351 practice questions that are ideal study material for quick Enterprise Routing and Switching, Specialist (JNCIS-ENT) exam dumps preparation.
Allowing for the different bents of exam candidate, we offer three versions of our JN0-351 learning braindumps for you. They are app, software and pdf versions of our JN0-351 training questions. All crucial points are included in the JN0-351 Exam Materials with equivocal contents for your reference with stalwart faith. And we also have the according three free demos of the JN0-351 practice engine for you to download before your purchase.
Valid JN0-351 Exam Online - Juniper Valid JN0-351 Practice Materials: Enterprise Routing and Switching, Specialist (JNCIS-ENT) Pass CertifyOur JN0-351 exam Braindumps are available in PDF, software, and online three modes, which allowing you to switch learning materials on paper, on your phone or on your computer, and to study anywhere and anytime. And in any version of JN0-351 practice materials, the number of downloads and the number of people used at the same time are not limited. You can practice repeatedly for the same set of JN0-351 Questions and continue to consolidate important knowledge points.
Juniper Enterprise Routing and Switching, Specialist (JNCIS-ENT) Sample Questions (Q37-Q42):NEW QUESTION # 37
Which two events cause a router to advertise a connected network to OSPF neighbors? (Choose two.)
  • A. When an OSPF adjacency is established.
  • B. When an interface has the OSPF passive option enabled.
  • C. When a static route to the 224.0.0.5 address is created.
  • D. When a static route to the 224.0.0.6 address is created.
A is correct because when an OSPF adjacency is established, a router will advertise a connected network to OSPF neighbors. An OSPF adjacency is a logical relationship between two routers that agree to exchange routing information using the OSPF protocol1. To establish an OSPF adjacency, the routers must be in the same area, have compatible parameters, and exchange hello packets1. Once an OSPF adjacency is formed, the routers will exchange database description (DBD) packets, which contain summaries of their link-state databases (LSDBs)1. The LSDBs include information about the connected networks and their costs2. Therefore, when an OSPF adjacency is established, a router will advertise a connected network to OSPF neighbors through DBD packets.
D is correct because when a static route to the 224.0.0.5 address is created, a router will advertise a connected network to OSPF neighbors. The 224.0.0.5 address is the multicast address for all OSPF routers3. A static route to this address can be used to send OSPF hello packets to all OSPF neighbors on a network segment3. This can be useful when the network segment does not support multicast or when the router does not have an IP address on the segment3. When a static route to the 224.0.0.5 address is created, the router will send hello packets to this address and establish OSPF adjacencies with other routers on the segment3. As explained above, once an OSPF adjacency is formed, the router will advertise a connected network to OSPF neighbors through DBD packets.
NEW QUESTION # 38
What is the default hello interval on an OSPF interface?
  • A. 20 seconds
  • B. 30 seconds
  • C. 10 seconds
  • D. 60 seconds
NEW QUESTION # 39
You want to use filter-based forwarding (FBF) on your Internet peering router to load-balance traffic to two directly connected ISPs based on the source address. Which two statements are correct in this scenario? (Choose two.)
  • A. RIB groups are used to copy routes from the inet. 0 routing table.
  • B. FBF uses the no-forwarding routing instance type.
  • C. FBF uses the forwarding routing instance type.
  • D. RIB groups are used to hide routes in the inet. 0 routing table.
Option B is correct. Filter-based forwarding (FBF), also known as Policy Based Routing (PBR), uses the forwarding routing instance type.
Option C is correct. Routing Information Base (RIB) groups are used to copy routes from one routing table to another. In the context of FBF, RIB groups can be used to copy routes from the inet.0 routing table.
Option A is incorrect. FBF does not use the no-forwarding routing instance type. Option D is incorrect. RIB groups are not used to hide routes in the inet.0 routing table. They are used to share or copy routes between different routing tables.
NEW QUESTION # 40
A new network requires multiple topology support. You decide to use IS-IS in this situation. Which three protocol topologies are supported in this scenario? (Choose three.)
  • A. IPsec
  • B. IPv4
  • C. IPv6
  • D. multicast
  • E. anycast
Answer: B,C,D
IS-IS (Intermediate System to Intermediate System) is a routing protocol that is designed to move information efficiently within a computer network12. It supports multiple protocol topologies, including IPv4, IPv6, and multicast12. Therefore, options C, E, and D are correct.
NEW QUESTION # 41
You have configured OSPF routing as shown in the exhibit. You notice that all interfaces have formed full adjacencies, with the exception of the interfaces connecting R3 and R4 with a status of 2Way.
What is the reason for this status?
  • A. The interface-type is not configured as p2p.
  • B. DROther routers will not form a full adjacency with each other.
  • C. The two routers must be configured in different areas.
  • D. The two routers must both be configured as DR routers.
NEW QUESTION # 42
We have developed three versions of our JN0-351 exam questions. So you can choose the version of JN0-351 training guide according to your interests and habits. And if you buy the value pack, you have all of the three versions, the price is quite preferential and you can enjoy all of the study experiences. This means you can study JN0-351 Practice Engine anytime and anyplace for the convenience these three versions bring.
Valid JN0-351 Practice Materials: https://www.realvce.com/JN0-351_free-dumps.html
Juniper Valid JN0-351 Exam Online This is a change in one's own mentality and it is also a requirement of the times, Juniper Valid JN0-351 Exam Online One of the significant factors to judge whether one is competent or not is his or her certificates, Our Valid JN0-351 Practice Materials - Enterprise Routing and Switching, Specialist (JNCIS-ENT) test for engine can assist you go through the examination surely, meanwhile, our service will 100% satisfy you, Juniper Valid JN0-351 Exam Online And we also welcome to your further purchase to become one of our regular customers to deal with other exams effectively and successfully.
By sharing a common approach, these audiences get a common vocabulary, Latest JN0-351 Test Prep This applies to all areas of my life, not just computing, This is a change in one's own mentality and it is also a requirement of the times!
RealVCE Juniper JN0-351 PDF QuestionsOne of the significant factors to judge whether one is competent or not is his Valid JN0-351 Practice Materials or her certificates, Our Enterprise Routing and Switching, Specialist (JNCIS-ENT) test for engine can assist you go through the examination surely, meanwhile, our service will 100% satisfy you.
And we also welcome to your further purchase to become one of our JN0-351 regular customers to deal with other exams effectively and successfully, Now, our company is specialized in design, development, manufacturing, marketing and retail of the JN0-351 test question, aimed to provide high quality product, solutions based on customer's needs and perfect service of the JN0-351 exam braindump.
P.S. Free 2026 Juniper JN0-351 dumps are available on Google Drive shared by RealVCE: https://drive.google.com/open?id=1R4QUAkbE95tAMkYnyLF2I7XBukNLcZb2
Posted at 2/15/2026 15:56:47        Only Author  2#
I’m grateful for your article, it truly stood out to me. Free Workday-Pro-Compensation latest exam materials exam resources—wishing you all the best in your exams!
