[Linux] RS485 port does not support serial_rs485?
75
Linux RS485 port does not support serial_rs485?
Posted at 7/9/2023 07:41:44      View3420 | Replies3        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: Buildroot 20221212
  • Modification Content: my package
  • Log: log.zip
Device=iHC-3308GW. I have built firmware using your official instructions. My application gives errno 25 'Inappropriate ioctl for device' for setting ttysWK0 and ttysWK1 ports with serial_rs485 using TIOCSRS485 IOCTL. Is RS-485 a true genuine RS-485 port, or some clone of RS-232 to RS-485 conversion without proper transmitter control? I am interested in setting delay_rts_before_send and delay_rts_after_send.
log.zip
155 Bytes, Down times: 2
Posted at 7/10/2023 10:31:40        Only Author  2#
It is not a clone, these 4 serial ports are isolated on hardware and are independent serial ports.
Posted at 7/10/2023 10:43:10        Only Author  3#
The reply to the forum post may not be timely, you can send the question to my mailbox
email:
hjc@t-chip.com.cn
restricted members
Posted at 1/25/2026 13:28:56        Only Author  4#
Truly an impressive article, Im grateful for your share. With Valid test cram 78202T sheet file, you can access abundant resources free of charge to help you.
