AZ-800 Exam Prep | AZ-800 Test Answers
72
Posted at 1/20/2026 15:33:26      View:101 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Lead1Pass AZ-800 dumps from Cloud Storage: https://drive.google.com/open?id=1EjGbLVL6mas-OwLnAGDRuEfR5EUH43RB
There are different versions of our AZ-800 learning materials: the PDF, Software and APP online versions. Whether you like to study on the computer or like to read paper materials, our AZ-800learning materials can meet your needs. If you are used to reading paper with our AZ-800 Study Materials for most of the time, you can eliminate your concerns. Our AZ-800 exam quiz takes full account of customers' needs in this area.
Earning the Microsoft AZ-800 certification demonstrates to potential employers that an individual has the skills necessary to manage and maintain a hybrid infrastructure. It also helps IT professionals stand out in a competitive job market and provides them with a deeper understanding of Microsoft's server technologies. Overall, the AZ-800 Exam is a valuable certification for IT professionals who want to enhance their skills and advance their careers in managing Windows Server Hybrid Core Infrastructure.
Providing You High Hit Rate AZ-800 Exam Prep with 100% Passing GuaranteeThe Lead1Pass wants to win the trust of Administering Windows Server Hybrid Core Infrastructure (AZ-800) certification exam candidates. To achieve this objective Lead1Pass is presenting Valid, Real, and Updated Administering Windows Server Hybrid Core Infrastructure (AZ-800) exam questions in three different formats. These formats have high demand in the market and offer the easiest and quick way for Administering Windows Server Hybrid Core Infrastructure (AZ-800) exam preparation.
Microsoft Administering Windows Server Hybrid Core Infrastructure Sample Questions (Q230-Q235):NEW QUESTION # 230
Your network contains an Active Directory Domain Services (AD DS) domain named adatum.com The domain contains a server named Server1 and the users shown In the following table.
Server1 contains a folder named D:Folder1. The advanced security settings for Folder 1 are configured as shown in the Permissions exhibit. (Click the Permissions lab.)
Folder1 is shared by using the following configurations
User1 can read the files in Share1. Yes
User3 can delete files in Share1. No
If User2 connects to Server1.adatum.com from File Explorer, (Share1 will be visible). Yes In Windows file sharing, effective access over SMB = the most restrictive result of Share permissions AND NTFS permissions. The AZ-800 materials emphasize that a user must have sufficient permission on both layers to perform an action. In Folder1, NTFS ACLs grant Group1 = Read, Group2 = Write, and no entry for Group3. The share "Share1" grants Group1 = Change and Group3 = Full Control.
* User1 (Group1): Share permission "Change" would allow modify over SMB, but NTFS grants only Read. Because the effective permission is the lower of the two, User1 is effectively Read and therefore can read the files.
* User3 (Group3): Although the share grants Full Control, there is no NTFS entry for Group3 (inheritance is disabled), so NTFS denies access. Without NTFS rights (e.g., Modify/Delete), delete is not possible.
* User2 (Group2): NTFS grants Write, but there is no share permission for Group2, so User2 cannot access content through the share. However, the share's FolderEnumerationMode = Unrestricted (i.e., Access-Based Enumeration is off). As covered in the hybrid core guide, when ABE is disabled, users can see items even if they lack permissions. Thus, when User2 browses Server1.adatum.com, Share1 is visible (opening it will result in Access Denied).
Therefore: Yes (User1 read), No (User3 delete), Yes (User2 sees Share1).
NEW QUESTION # 231
Task 9
You need to replicate a read-only copy of a DNS zone named contosoxom to SRV2.
See the solution of this Task below.
Objective:
Create a read-only copy of the DNS zone contoso.com on SRV2.
Step-by-Step Guide: Using a Secondary Zone
# Step 1: Log in to SRV2
* Log in to SRV2 (where you want to host the secondary zone) using an account with local administrative privileges.
# Step 2: Open DNS Manager
* Press Windows + R, type dnsmgmt.msc, and press Enter.
# Step 3: Create a Secondary Zone
* In the DNS Manager, expand the server node for SRV2.
* Right-click Forward Lookup Zones and select New Zone.
* The New Zone Wizard opens.
# Step 4: Configure the Secondary Zone
* Zone Type:
* Select Secondary zone and click Next.
* Zone Name:
* Type contoso.com and click Next.
* Master DNS Servers:
* Enter the IP address of the master DNS server that hosts the primary zone (e.g., SRV1's IP).
* Click Next.
* Finish:
* Review the settings and click Finish.
# Step 5: Allow Zone Transfers on the Primary Server
On SRV1 (or the DNS server hosting the primary zone):
* Open DNS Manager.
* Right-click the contoso.com zone and select Properties.
* Go to the Zone Transfers tab.
* Check Allow zone transfers.
* Specify SRV2's IP address (or allow to any server if needed).
# Step 6: Verify Zone Replication
* On SRV2, refresh the Forward Lookup Zones in DNS Manager.
* The contoso.com zone should now appear as a Secondary zone.
* Check the Zone Transfer status to ensure it successfully replicated.
NEW QUESTION # 232
You have on-premises servers that run Windows Server as shown in the following table.
You have an Azure subscription that contains a virtual machine named VMV You need to ensure that you can manage all the servers by using Azure Arc. The solution must minimize administrative effort.
On which servers should you install the Azure Connected Machine agent?
  • A. Server1 only
  • B. VM1 and VM2 only
  • C. Server1 and VM2 only
  • D. VM2only
  • E. VM1 only
  • F. Server1, VM1, and VM2
NEW QUESTION # 233
Your network contains an Active Directory Domain Services (AD DS) forest. The forest contains two domains named contoso.com and east.contoso.com. Contoso.com contains two users named CONTOSO
User1 and EASTUser2.
You need to ensure that the users can perform the following tasks:
* User1 must deploy an additional domain controller to eastcontoso.com.
* User2 must deploy a new domain controller that will host a domain named west.contoso.com.
The solution must follow the principle of least privilege.
To which group should you add each user? To answer, select the appropriate options in the answer area.
NEW QUESTION # 234
You have servers that run Windows Server 2022 as shown in the following table.
Server2 contains a .NET app named App1.
You need to establish a WebSocket connection from App1 to the SQL Server instance on Server!. The solution must meet the following requirements:
* Minimize the number of network ports that must be open on the on-premises network firewall.
* Minimize administrative effort.
What should you create first?
  • A. an Azure VPN gateway
  • B. a hybrid connection
  • C. a WFC relay connection
  • D. an Azure Relay namespace
NEW QUESTION # 235
After purchasing the AZ-800 exam dumps from Lead1Pass, you will have access to three formats designed by Lead1Pass for the preparation of the Microsoft AZ-800 exam. These Administering Windows Server Hybrid Core Infrastructure exam dumps formats will provide actual Microsoft AZ-800 PDF Questions to help you prepare for the Microsoft AZ-800 exam.
AZ-800 Test Answers: https://www.lead1pass.com/Microsoft/AZ-800-practice-exam-dumps.html
BONUS!!! Download part of Lead1Pass AZ-800 dumps for free: https://drive.google.com/open?id=1EjGbLVL6mas-OwLnAGDRuEfR5EUH43RB
Posted at 1/23/2026 11:20:44        Only Author  2#
This article has helped me answer many questions, and it's really great. Free Download PDD pdf exam papers available. Best of luck to everyone!
