[General] SAP C-ACDET-2506 Online Exam & Valid C-ACDET-2506 Test Guide
104
General SAP C-ACDET-2506 Online Exam & Valid C-ACDET-2506 Test Guide
Posted at 1/21/2026 03:08:48      View192 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest It-Tests C-ACDET-2506 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=15CC_x3Sw1REeAnclMqtLwWf-X79z--91
In order to reflect our sincerity on consumers and the trust of more consumers, we provide a 100% pass rate guarantee for all customers who have purchased C-ACDET-2506 study quiz. If you fail to pass the exam after you purchased C-ACDET-2506 preparation questions, you only need to provide your transcript to us, and then you can receive a full refund. Or we can free exchange two other exam materials for you if you have other exams to attend at the same time. So just buy our C-ACDET-2506 Exam Questions!
SAP C-ACDET-2506 Exam Syllabus Topics:
  • Field Configuration: This domain evaluates the knowledge of an SAP Deployment Specialist and focuses on customizing and configuring business fields in the SAP system according to client-specific needs. This includes adjusting system settings for master data, transaction data, and other essential field-level controls to support business processes effectively. The section tests the candidates ability to use configuration tools, apply SAP standard templates, and ensure that the field configurations align with the desired operational workflows of the business. It also touches upon validation, testing, and documenting the configuration changes made during the implementation.
  • Project Overview, Roles and Responsibilities: This section of the exam measures the skills of an SAP Cloud Consultant and covers the fundamental understanding of SAP Activate methodology within the context of a cloud implementation project. Candidates are expected to be familiar with the project lifecycle, including phases such as Prepare, Explore, Realize, Deploy, and Run. This part also focuses on identifying key roles and responsibilities within a cloud project team, ensuring clarity in collaboration between consultants, clients, and SAP. It checks whether the consultant understands governance, stakeholder management, and the high-level structure of cloud deployment using SAP best practices.
  • Deploy and Migration: This part of the exam assesses the expertise of an SAP Deployment Specialist and focuses on the final deployment of the configured solution and the data migration process. Candidates should demonstrate a solid grasp of how to move configurations from a testing environment into production while minimizing disruption. It also includes knowledge of tools and strategies used for data extraction.
C-ACDET-2506 Online Exam - Realistic SAP SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Online Exam 100% PassWe are impassioned, thoughtful team. So our C-ACDET-2506 exam torrents will never put you under great stress but solve your problems with efficiency. Otherwise if you fail to pass the exam unfortunately with our C-ACDET-2506 test braindumps, we will return your money fully or switch other versions for you. So by using our C-ACDET-2506 exam torrents made by excellent experts, the learning process can be speeded up to one week. They have taken the different situation of customers into consideration and designed practical C-ACDET-2506 Test Braindumps for helping customers save time. As elites in this area they are far more proficient than normal practice materials editors, you can trust them totally.
SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Sample Questions (Q54-Q59):NEW QUESTION # 54
Which scenarios are applicable when moving templates from the test site to the production site by Intelligent Configuration Manager (ICM)? (Select 2 correct answers)
  • A. Draft templates on the source site are skipped.
  • B. New templates that successfully migrated to the production site are in Draft state.
  • C. Batch imports are available for templates when migrating configuration bundles.
  • D. Published templates with flex master data references in the test site are migrated to the production site during the first migration attempt.
ICM only migratespublished templates; draft templates are skipped (A). When templates are imported into production, they arrive indraft stateby default to allow review and publishing before use (C). Batch imports for templates (B) are not supported; migration is typically handled per template. Flex master data references require manual migration steps and are not migrated automatically during the initial template transfer (D).
NEW QUESTION # 55
When preparing to load legacy contracts during a Bluefield deployment in SAP Ariba Contracts, which of the following actions are required to ensure a successful migration?
  • A. Skip the legacy contract upload step if the Production site already contains migrated Flex Master Data Templates.
  • B. Create a new customized contract upload process specifically for Bluefield deployments to accommodate differences in site structure.
  • C. Manually enter legacy contract data into SAP Ariba Contracts using the application's UI instead of using import tools.
  • D. Use the exact same process and tools as used in the Greenfield migration scenario to upload legacy contracts.
In Bluefield deployments,the legacy contract migration process is the same as in Greenfield deployments.
The standard approach uses SAP Ariba's import tools to upload contract data in bulk; no special new processes are needed. Manual entry via UI is inefficient and error-prone. Also, existing Flex Master Data Templates do not negate the need to migrate legacy contract data.
Following the established Greenfield procedures ensures data consistency and alignment with configured templates and workflows in the target environment. This includes exporting contract data from legacy systems, validating, transforming as needed, and importing through the Production UI under contract management.
This standardization simplifies migrations across different deployment scenarios.
NEW QUESTION # 56
A Migration is performed for a Greenfield deployment to production, and the status of the Template configuration type indicates that it Failed. What actions do you take to make the failed template(s) available in production?
  • A. The template must always be rebuilt in production
  • B. Request SAP intervention
  • C. Import the template in production
  • D. Import the missing data in production and then import the template in production
NEW QUESTION # 57
What system is provided by SAP Free of charge and provides an outline of how to deploy SAP Ariba solutions with a task list and project management format?
  • A. SAP Cloud Project Studio
  • B. SAP for Me
  • C. SAP Cloud Application Lifecycle Management
  • D. SAP Ariba Enablement Worrkbook
NEW QUESTION # 58
During a Bluefield migration, you discover missing flex master data templates.
What do you do?
  • A. Use reporting workaround
  • B. Rebuild them manually in production
  • C. Ignore them
  • D. Defer to post-go-live
NEW QUESTION # 59
To increase your chances of passing SAPs certification, we offer multiple formats for braindumps for all C-ACDET-2506 exam at It-Tests. However, since not all takers have the same learning styles, we devise a customizable module to suite your needs. More importantly, our commitment to help you become C-ACDET-2506 Certified does not stop in buying our products. We offer customer support services that offer help whenever youll be need one.
Valid C-ACDET-2506 Test Guide: https://www.it-tests.com/C-ACDET-2506.html
P.S. Free & New C-ACDET-2506 dumps are available on Google Drive shared by It-Tests: https://drive.google.com/open?id=15CC_x3Sw1REeAnclMqtLwWf-X79z--91
Posted at 1/28/2026 07:26:24        Only Author  2#
Your article took my breath away, thank you for sharing! Free Mock FCSS_SASE_AD-25 exam exam materialsgood luck to everyone!
