[General] Oracle 1z0-1104-25 Prüfungs & 1z0-1104-25 Vorbereitung
89
【General】 Oracle 1z0-1104-25 Prüfungs & 1z0-1104-25 Vorbereitung
Posted at 1/21/2026 06:04:40      View:149 | Replies:2        Print      Only Author   [Copy Link] 1#
Laden Sie die neuesten ExamFragen 1z0-1104-25 PDF-Versionen von Prüfungsfragen kostenlos von Google Drive herunter: https://drive.google.com/open?id=1Ls4U2xEuejcxGDiAGaHSZeG36q75EweA
Die Oracle 1z0-1104-25 Zertifizierungsprüfung ist der erste Schritt zum Berufserfolg fur IT-Fachleute. Durch die Oracle 1z0-1104-25 Zertifizierungsprüfung haben Sie schon den ersten Fuß auf die Spitze Ihrer Karriere gesetzt. ExamFragen wird Ihnen helfen, die Oracle 1z0-1104-25 Zertifizierungsprüfung zu bestehen.
Oracle 1z0-1104-25 Prüfungsplan:
ThemaEinzelheiten
Thema 1
  • OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
Thema 2
  • Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
Thema 3
  • Implementing Identity and Access Management (IAM): This section of the exam measures skills of OCI Administrators and focuses on identity and access controls. It covers IAM domains, users, groups, and compartments, as well as the use of IAM policies to manage access to resources. Candidates are also tested on configuring dynamic groups, network sources, and tag-based access control, along with managing MFA, sign-on policies, and activity monitoring.
1z0-1104-25 Vorbereitung - 1z0-1104-25 AusbildungsressourcenWir bemühen uns nun darum, den Kandidaten rechtzeitigen und effizieten Service zu bieten, um Ihre wertvolle Zeit zu ersparen. ExamFragen bietet Ihnen zahlreiche Lerntipps, Fragen und Antworten zur Oracle 1z0-1104-25 Zertifizierungsprüfung. Einige Websites bieten Ihnen auch Lernmaterialien zur 1z0-1104-25 Zertifizierungsprüfung, die von guter Qualität ist und mit dem Zeit Schritt halten. Aber ExamFragen ist die einzige Website, die beste Schulungsunterlagen zur 1z0-1104-25 Zertifizierungsprüfung bietet. Mit Hilfe der Lernmaterialien und der Anleitung von ExamFragen können Sie die Oracle 1z0-1104-25 Zertifizierungsprüfung einmalig bestehen.
Oracle Cloud Infrastructure 2025 Security Professional 1z0-1104-25 Prüfungsfragen mit Lösungen (Q36-Q41):36. Frage
You have created a compartment TEST in your subscribed tenancy. Then, you created two groups, test1 and test2, and want the users in these groups to be able to manage all the resources in the TEST compartment.
Which policy would you use to achieve this?
  • A. Allow any-user to manage all resources in compartment test where request.group='test*'
  • B. Allow group/test*/to manage all resources in compartment test.
  • C. Allow any-user to manage all resources in compartment test where any {request.groups.test1, test2}
  • D. Allow group test1, test2 to manage all resources in compartment test.
37. Frage
Which are the essential components to create a rule for the Oracle Cloud Infrastructure (OCI) Events Service?
  • A. Rule Conditions and Management Agent Cloud Service
  • B. Rule Conditions and Actions
  • C. Install Key and Service Connector
  • D. Install Key and Actions
38. Frage
Challenge 2 -Task 1
In deploying a new application, a cloud customer needs to reflect different security postures. If a security zone is enabled with the Maximum Security Zone recipe, the customer will be unable to create or update a resource in the security zone if the action violates the attached Maximum Security Zone policy.
As an application requirement, the customer requires a compute instance in the public subnet. You therefore, need to configure Custom Security Zones that allow the creation of compute instances in the public subnet.
Review the architecture diagram, which outlines the resoures you'll need to address the requirement:
Preconfigured
To complete this requirement, you are provided with the following:
Access to an OCI tenancy, an assigned compartment, and OCI credentials
Required IAM policies
Task3: Create and configure a Virtual Cloud Network and Private Subnet
Createand configure virtual cloud Network (VCN) named IAD SP-PBT-VCN-01, with an internet Gateway and configure appropriate route rules to allow external connectivity.
Enter the OCID of the created VCN in the text box below.
Antwort:
Begründung:
See the solution below in Explanation.
To create and configure a Virtual Cloud Network (VCN) named IAD-SP-PBT-VCN-01 with an Internet Gateway and appropriate route rules for external connectivity, follow these steps based on the Oracle Cloud Infrastructure (OCI) Networking documentation.
Step-by-Step Solution for Task 3: Create and Configure a VCN and Private Subnet
* Log in to the OCI Console:
* Use your OCI credentials to log in to the OCI Console (https://console.us-ashburn-1.oraclecloud.
com).
* Ensure you have access to the assigned compartment.
* Navigate to Virtual Cloud Networks:
* From the OCI Console, click the navigation menu (hamburger icon) on the top left.
* UnderNetworking, selectVirtual Cloud Networks.
* Create a New VCN:
* ClickStart VCN Wizardand selectCreate VCN with Internet Connectivity.
* VCN Name:Enter IAD-SP-PBT-VCN-01.
* Compartment:Select the assigned compartment.
* VCN CIDR Block:Enter 10.0.0.0/16 (matches the diagram's VCN CIDR).
* Public Subnet CIDR Block:Enter 10.0.10.0/24 (matches the diagram's public subnet).
* Accept the default settingsfor the public subnet and Internet Gateway creation.
* ClickCreateto provision the VCN, Internet Gateway, and public subnet.
* Verify the Internet Gateway:
* After creation, go to the VCN details page for IAD-SP-PBT-VCN-01.
* UnderResources, selectInternet Gateways.
* Ensure the Internet Gateway is attached and enabled.
* Configure Route Rules:
* In the VCN details page, underResources, selectRoute Tables.
* Select the default route table associated with the public subnet (10.0.10.0/24).
* ClickAdd Route Rules.
* Target Type:SelectInternet Gateway.
* Destination CIDR Block:Enter 0.0.0.0/0.
* Target Internet Gateway:Select the Internet Gateway created with the VCN.
* ClickAdd Route Ruleto save.
* Update Security List (if needed):
* UnderResources, selectSecurity Lists.
* Edit the default security list for the public subnet.
* Add an ingress rule:
* Source CIDR:0.0.0.0/0
* IP Protocol:TCP
* Source Port Range:All
* Destination Port Range:22 (for SSH) or as required by your application.
* Add an egress rule:
* Destination CIDR:0.0.0.0/0
* IP Protocol:All
* Save the changes.
* Note the VCN OCID:
* Return to the VCN details page for IAD-SP-PBT-VCN-01.
* Copy theOCIDdisplayed (e.g., ocid1.vcn.oc1..<unique_string>).
OCID of the Created VCN
* Enter the OCID of the created VCN (IAD-SP-PBT-VCN-01) into the text box. The exact OCID will be available after Step 3 (e.g., ocid1.vcn.oc1..<unique_string>).
39. Frage
A company has implemented OCI IAM policies with multiple levels of compartments. A policy attached to a parent compartment grants "manage virtual-network-family" permissions. A policy attached to a child compartment grants "use virtual-network-family" permissions.
According to OCI IAM policy inheritance, how does the OCI IAM policy engine resolve the permissions for a user attempting to perform an operation that requires 'manage' permissions in the child compartment?
  • A. The policy in the parent compartment takes precedence, and the user is granted "manage" permissions.
  • B. The operation is denied due to conflicting policies.
  • C. The policy in the child compartment takes precedence, and the user is granted "use" permissions only.
40. Frage
Based on the provided diagram, you have a group of critical compute instances in a private subnet that require vulnerability using the Oracle Cloud Infrastructure(OCI) Vulnerability Scanning Service (VSS).
"What additional configuration is required to enable VSS to scan instances in the private subnet
  • A. No additional configuration is needed. VSS can access private instances by default.
  • B. Configure a service gateway in the VCN and a route rule to direct traffic for the VSS service through the gateway.
  • C. Use an OCI Bastion session to establish connectivity and forward scan results from the private instances."
  • D. VSS cannot scan private instances. You need to move them to a public subnet for vulnerability scanning.
41. Frage
Haben Sie die Prüfungssoftware für IT-Zertifizierung von unserer ExamFragen probiert? Wenn ja, werden Sie natürlich unsere Oracle 1z0-1104-25 benutzen, ohne zu zaudern. Wenn nein, dann werden Sie durch diese Erfahrung ExamFragen in der Zukunft als Ihre erste Wahl. Die Oracle 1z0-1104-25 Prüfungssoftware, die wir bieten, wird von unseren IT-Profis durch langjährige Analyse der Inhalt der Oracle 1z0-1104-25 entwickelt. Es gibt insgesamt drei Versionen dieser Software für Sie auszuwählen.
1z0-1104-25 Vorbereitung: https://www.examfragen.de/1z0-1104-25-pruefung-fragen.html
BONUS!!! Laden Sie die vollständige Version der ExamFragen 1z0-1104-25 Prüfungsfragen kostenlos herunter: https://drive.google.com/open?id=1Ls4U2xEuejcxGDiAGaHSZeG36q75EweA
Posted at 1/24/2026 15:57:51        Only Author  2#
I’m so grateful for your article, it truly brightened my day. Ready to crush the New DS0-001 test notes exam! Hope it goes great!
Posted at 1/26/2026 18:54:13        Only Author  3#
This article is absolutely excellent, I’m grateful for your share. Thanks to the NetSec-Analyst valid test tips, I received a promotion and salary increase. It’s free now for everyone. Wishing you all success in your careers!
