[Hardware] MikroTik - Accurate MTCNA - Test MikroTik Certified Network Associate Exam Tutor
107
【Hardware】 MikroTik - Accurate MTCNA - Test MikroTik Certified Network Associate Exam Tutor
Posted at 1/21/2026 07:58:19      View:154 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Pass4training MTCNA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1KqkSuR_--aC-H2KGa4Ehy9iivXar6Ms2
The simplified information contained in our MikroTik MTCNA training guide is easy to understand without any difficulties. And our MikroTik MTCNA practice materials enjoy a high reputation considered as the most topping practice materials in this career for the merit of high-effective. A great number of candidates have already been benefited from them.
MikroTik MTCNA certification exam is ideal for network administrators, technicians, and engineers who are looking to enhance their skills and knowledge in MikroTik RouterOS software. MTCNA exam is designed to provide a solid foundation in network administration, making it an excellent starting point for those who are new to the field. MikroTik Certified Network Associate Exam certification is also beneficial for professionals who are looking to expand their skillset and increase their marketability in the industry.
MikroTik’s MTCNA Certification program is recognized globally and is highly regarded in the networking industry. MikroTik Certified Network Associate Exam certification program is designed to ensure that network professionals who earn the certification have a comprehensive understanding of MikroTik devices and can manage and troubleshoot networks effectively. Employers worldwide recognize the value of the MTCNA certification and often seek certified professionals to manage their networks.
New MTCNA Exam Duration & MTCNA Learning MaterialsOur MTCNA study braindumps for the overwhelming majority of users provide a powerful platform for the users to share. Here, the all users of the MTCNA exam questions can through own ID number to log on to the platform and other users to share and exchange, each other to solve their difficulties in study or life. The MTCNA Prep Guide provides user with not only a learning environment, but also create a learning atmosphere like home. And our MTCNA exam questions will help you obtain the certification for sure.
MikroTik Certified Network Associate Exam Sample Questions (Q70-Q75):NEW QUESTION # 70
What does the firewall action "Redirect" do? Select all true statements.
  • A. Redirects a packet to a specified port on the router
  • B. Redirects a packet to a specified port on a host in the network
  • C. Redirects a packet to a specified IP
  • D. Redirects a packet to the router
NEW QUESTION # 71
What is necessary for PPPoE client configuration?
  • A. Static IP address on PPPoE client interface
  • B. Interface (on which PPPoE client is going to work)
  • C. ip firewall nat masquerade rule
To configure a PPPoE client on MikroTik, you need to:
* Set the client interface (usually ether1 or another WAN-facing port).
* Optionally add NAT masquerading to enable LAN users to reach the internet.
* IP address on the interface is assigned dynamically from the ISP after PPPoE negotiation, so a static IP is not required.
Option Analysis:
* A.#Required - You must select the interface that initiates the PPPoE connection.
* B.#Not Required - The IP is typically assigned by the PPPoE server (ISP).
* C.#Required - NAT masquerade is commonly used to allow internet access for private IP clients behind the router.
Extract from MTCNA Course Material - PPPoE Client Setup:
"The PPPoE client must have an interface specified. A NAT masquerade rule is recommended for internet access sharing." Extract from Rene Meneses MTCNA Study Guide - PPPoE:
"You do not need to assign a static IP to the PPPoE client interface. IP is received after successful login." Extract from MikroTik Wiki - PPPoE Client:
"After setting up the interface and credentials, PPPoE client negotiates and receives dynamic IP. Add NAT if routing LAN traffic."
NEW QUESTION # 72
The basic unit of a physical network (OSI Layer 1) is the:
  • A. Byte
  • B. Header
  • C. Bit
  • D. Frame
The OSI Layer 1, also known as the Physical Layer, is responsible for the transmission and reception of raw binary data over a physical medium. The most fundamental unit at this layer is the bit.
* Bit = Binary Digit (0 or 1)
* It is transmitted over physical media (cables, radio signals, etc.)
* Frames (A) exist at Layer 2 (Data Link Layer), not Layer 1.
* Bytes (C) are groups of 8 bits, but bits are still the smallest indivisible transmission unit.
* Headers (D) are metadata used at Layers 2-7; not relevant to Layer 1.
MTCNA Official Training Manual - OSI Model Chapter:
"Layer 1 transmits raw bits over a transmission medium. These bits form the foundation for higher-layer data structures." Rene Meneses MTCNA Guide - OSI Model Breakdown:
"hysical Layer (Layer 1) carries bits, not frames or bytes. It's concerned with voltages, cables, connectors, and signal encoding." Terry Combs Notes - OSI Layers:
"Layer 1 = Bits. Nothing more. Frames come into play in Layer 2."
answer: B
NEW QUESTION # 73
DHCP server is configured on a router's ether1 interface. IP address 192.168.0.100/24 is assigned to the interface. Possible IP pools, that can be used by this DHCP server, are:
  • A. 192.169.0.1-192.169.0.254
  • B. 192.168.0.1-192.168.0.14
  • C. 192.168.0.1-192.168.0.255
  • D. 192.168.0.1-192.168.0.99 , 192.168.0.101-192.168.0.254
NEW QUESTION # 74
Which of the following is NOT a valid MAC Address?
  • A. 13:16:86:53:89:43
  • B. EA:BA:AA:EE:FF:CB
  • C. 88:0C:00:99:5F:EF
  • D. 95:B5D:EE:78:8A
  • E. 80:GF:AA:67:13:5D
Answer: E
NEW QUESTION # 75
Dear, if you are preparing for the MTCNA exam test, you cannot miss Pass4training MTCNA dumps torrent. MTCNA pdf torrent is the best valid and reliable study material you are looking for. The content of MTCNA training vce are edited and compiled by the professional experts who have all been worked in the IT industry for decades. The authority and reliability are without any doubt. With the help of MikroTik MTCNA Free Download Pdf, you will get high scores in your actual test.
New MTCNA Exam Duration: https://www.pass4training.com/MTCNA-pass-exam-training.html
Posted at 2/24/2026 03:31:59        Only Author  2#
It was one of the most beneficial pieces I’ve read in a while. Wishing myself success in the upcoming Vce C-THR88-2505 exam exam!
