[Hardware] Marvelous Latest 1Z0-083 Test Simulator - Win Your Oracle Certificate with Top S
109
【Hardware】 Marvelous Latest 1Z0-083 Test Simulator - Win Your Oracle Certificate with Top S
Posted at 1/23/2026 08:35:51      View:160 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest PDFVCE 1Z0-083 PDF Dumps and 1Z0-083 Exam Engine Free Share: https://drive.google.com/open?id=1WTFvxK5r81ITSQo_HGY_gZcCY1X5MeBS
The only goal of all experts and professors in our company is to design the best and suitable 1Z0-083 study materials for all people. According to the different demands of many customers, they have designed the three different versions of the 1Z0-083 certification study guide materials for all customers: PDF, Soft and APP versions. They sincerely hope that all people who use 1Z0-083 Exam Questions from our company can pass the 1Z0-083 exam and get the related certification successfully. And our pass rate for 1Z0-083 exam questions is high as more than 98%.
Oracle 1Z1-083 exam is an advanced-level certification designed for professionals who want to enhance their skills in Oracle database administration. Candidates who Pass 1Z0-083 Exam are recognized as experts in managing, controlling, and maintaining databases. Oracle Database Administration II certification is the second level of Oracle's database administration curriculum, and it builds on the knowledge and skills acquired in the first level.
Oracle 1Z0-083 certification exam is an excellent opportunity for database administrators and other IT professionals to validate their skills and knowledge in advanced database administration concepts. Oracle Database Administration II certification can help professionals advance their careers and increase their earning potential. To prepare for the exam, candidates should have a good understanding of Oracle database administration concepts and should consider taking training courses and using study materials.
1Z0-083 Exam Score & Pass 1Z0-083 GuideWhen it comes to negotiating your salary with reputed tech firms, you could feel entirely helpless if you're a fresh graduate or don't have enough experience. You will have no trouble landing a well-paid job in a reputed company if you have Oracle 1Z0-083 Certification on your resume. Success in the test is also a stepping stone to climbing the career ladder. If you are determined enough, you can get top positions in your firm with the Oracle 1Z0-083 certification.
Oracle Database Administration II Sample Questions (Q15-Q20):NEW QUESTION # 15
Which two are true about RMAN duplexed backup sets? (Choose two.)
  • A. A duplexed backup set always uses twice as many SBT channels as a non-duplexed backup set for the same number of files.
  • B. A non-duplexed backup set written to disk can be duplexed to tape by backing up the backup set that is already on disk.
  • C. A non-duplexed backup set written to disk can be duplexed to disk by backing up the backup set that is already on disk.
  • D. A duplexed backup set uses the same number of SBT channels as a non-duplexed backup set for the same number of files.
  • E. A non-duplexed backup set written to SBT can be duplexed to tape by backing up the backup set that is already on tape.
  • F. A non-duplexed backup set written to SBT can be duplexed to disk by backing up the backup set that is already on tape.
NEW QUESTION # 16
A database is configured in archivelog mode.
A full RMAN backup exists but no control file backup to trace has been taken.
A media failure has occurred.
In which two scenarios is incomplete recovery required?
  • A. after losing all members of the current online redo log group
  • B. after losing a sysaux tablespace data file
  • C. after losing an undo tablespace that is in use
  • D. after losing all copies of the control file
  • E. after losing all members of an inactive online redo log group
NEW QUESTION # 17
Choose the best answer. Examine this configuration:
1. CDB1 is a container database.
2. There are several pluggable databases (PDBs) in CDB1.
5. Each PDB has several tables with referential integrity constraints.
6. FLASHBACK DATABASE is ON.
7. UNDO RETENTION GUARANTEE is enabled.
Multiple undesired multitable changes were made in all the PDBs.
Which method can be used to undo the changes using a single command?
  • A. restore and recover database
  • B. flashback table and transaction
  • C. flashback database
  • D. flashback table
  • E. flashback transaction
NEW QUESTION # 18
Which two are true about diagnosing Oracle Database failure situations using Data Recovery Advisor? (Choose two.)
  • A. Data Recovery Advisor can proactively check for failures.
  • B. Using the Data Recovery Advisor LIST FAILURE command always requires that the database for which failures are to be listed is in MOUNT state.
  • C. The Data Recovery Advisor CHANGE FAILURE command can be used only to change failure priorities.
  • D. Data Recovery Advisor can be used if a database is closed.
  • E. A failure can be closed only when it has been repaired.
Answer: A,D
A is NOT correct - DB can be even NOT MOUNTED.
B is NOT correct - you can close it whenever you want, eventually new check will find the failure again.
C has to be CORRECT despite it is not fully clear, anyway Recovery Advisor can be used when database is even NOT mounted, hence it is CLOSED while instance is STARTED.
D is NOT correct because of ONLY word. Change Failure can CLOSE or CHANGE PRIORITY.
E is CORRECT - Data Recovery Advisor can potentially detect, analyze, and repair data failures BEFORE a database process discovers the corruption and signals an error. Early warnings help limit damage caused by corruption.
The health assessment is known as a data integrity check and can be invoked reactively or PROACTIVELY.
NEW QUESTION # 19
Which three are true about actions that can or cannot be performed by users with the SYSBACKUP privilege? (Choose three.)
  • A. They can view data from any user-defined tables.
  • B. They can view data from any data dictionary view or dynamic performance view.
  • C. They can drop any tablespace.
  • D. They can create any table.
  • E. They cannot drop tablespaces.
  • F. They cannot create restore points.
Answer: B,C,D
https://docs.oracle.com/en/datab ... ring-privilege-and- role-authorization.html#GUID-BF12E37F-4606-42BB-B8B6-4CDC5A870EE7
NEW QUESTION # 20
Using our reliable exam product can prove a helping hand for you to become Oracle 1Z0-083 certified. Do not waste any more time because this 1Z0-083 exam dumps can be a turning point in your exam preparation journey. Remember that you cannot afford to suffer from 1Z0-083 Exam failure because the registration fee of the test is high and you will not want to spend this massive amount for the second attempt.
1Z0-083 Exam Score: https://www.pdfvce.com/Oracle/1Z0-083-exam-pdf-dumps.html
P.S. Free & New 1Z0-083 dumps are available on Google Drive shared by PDFVCE: https://drive.google.com/open?id=1WTFvxK5r81ITSQo_HGY_gZcCY1X5MeBS
Posted at 1/26/2026 04:16:16        Only Author  2#
Fast2test에는 베터랑의전문가들로 이루어진 연구팀이 잇습니다, 그들은 it지식과 풍부한 경험으로 여러 가지 여러분이Oracle인증1z1-809-KR시험을 패스할 수 있을 자료 등을 만들었습니다, Fast2test 에서는 일년무료 업뎃을 제공하며, Fast2test 의 덤프들은 모두 높은 정확도를 자랑합니다. Fast2test 선택함으로 여러분이Oracle인증1z1-809-KR시험에 대한 부담은 사라질 것입니다.
Posted at 2/15/2026 08:05:14        Only Author  3#
This article really resonated with me, thank you for sharing! Improve your IT skills with free Reliable Arch-303 exam simulator. Best wishes for your exams!
