Best AZ-800 Study Material, New AZ-800 Test Preparation
98
Posted at 1/23/2026 11:57:03      View:159 | Replies:3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Itbraindumps AZ-800 dumps from Cloud Storage: https://drive.google.com/open?id=1iBKhukMc8oL5qptCYyhw5CCZP3ANh2cf
Our company has been engaged in compiling professional AZ-800 exam quiz in this field for more than ten years. Our large amount of investment for annual research and development fuels the invention of the latest AZ-800 study materials, solutions and new technologies so we can better serve our customers and enter new markets. We invent, engineer and deliver the best AZ-800 Guide questions that drive business value, create social value and improve the lives of our customers.
Exam OverviewExam AZ-800 implies that you are competent in using such technologies as cloud, on-premises, and hybrid to administer core Windows Server workloads. In addition, candidates are expected to be able to apply and operate on-premises and hybrid solutions and utilize such administrative technologies and tools as Azure Arc, PowerShell, Windows Admin, IaaS virtual machine administration. Your capacity to deal with Windows Server operating systems will also be checked.
New Microsoft AZ-800 Test Preparation | AZ-800 Valid Exam TopicsThe opportunity always belongs to a person who has the preparation. But, when opportunities arise, will you seize the opportunities successfully? At present, you are preparing for Microsoft AZ-800 test. Will you seize Itbraindumps to make you achievement? Itbraindumps Microsoft AZ-800 certification training materials will guarantee your success. With our exam preparation materials, you will save a lot of time and pass your exam effectively. If you choose Itbraindumps study guide, you will find the test questions and test answers are certainly different and high-quality, which is the royal road to success. And then, the dumps will help you prepare well enough for AZ-800 Exam.
Microsoft Administering Windows Server Hybrid Core Infrastructure Sample Questions (Q150-Q155):NEW QUESTION # 150
Your on-premises network contains an Active Directory Domain Services (AD DS) domain. The domain contains the servers shown in the following table.
The domain controllers do NOT have internet connectivity.
You plan to implement Azure AD Password Protection for the domain.
You need to deploy Azure AD Password Protection agents. The solution must meet the following requirements:
* All Azure AD Password Protection policies must be enforced.
* Agent updates must be applied automatically.
* Administrative effort must be minimized.
What should you do? To answer select the appropriate options in the answer area.
NEW QUESTION # 151
You are planning the deployment of DNS to a new network.
You have three internal DNS servers as shown in the following table.
The contoso.local zone contains zone delegations for east.contoso.local and west.contoso.local. All the DNS servers use root hints.
You need to ensure that all the DNS servers can resolve the names of all the internal namespaces and internet hosts.
Solution: You configure Server2 and Server3 to forward DNS requests to 10.0.1.10.
Does this meet the goal?
  • A. No
  • B. Yes
NEW QUESTION # 152
SIMULATION
Task 7
You need to collect the recommended Windows Performance Counters from SRV1 in a Log Analytics workspace.
The required tiles are stored in a shared folder named dcinstall.
See the solution of this Task below
To collect the recommended Windows Performance Counters from SRV1 in a Log Analytics workspace, you can follow these steps:
Step 1: Access the Log Analytics Workspace Log in to the Azure portal and navigate to your Log Analytics workspace.
Step 2: Configure Performance Counters In the Log Analytics workspace, select Advanced settings and then choose Data > Windows Performance Counters1. You can add the recommended performance counters by selecting the + button. If you're using legacy agent management, you can add counters from the Legacy agents management menu2.
Step 3: Add Performance Counters Select the counters you want to collect. You can add common counters quickly by checking the boxes next to them. For specific counters, enter the name of the counter in the format object(instance)counter. For example, to collect the Processor Time counter for all instances of the Processor object, specify Processor(_Total)% Processor Time.
Step 4: Set Sample Interval When adding a counter, you can set the sample interval, which is the frequency at which data is collected. The default is 10 seconds, but you can change this to a higher value if needed.
Step 5: Apply Configuration After adding the desired performance counters, select Apply at the top of the screen to save the configuration.
Step 6: Install and Configure the Agent Ensure that the Microsoft Monitoring Agent (MMA) is installed on SRV1. Configure the agent to report to your Log Analytics workspace by specifying the workspace ID and key during setup.
Step 7: Verify Data Collection After the agent is configured, it will start collecting the specified performance counters. You can verify the data collection in the Log Analytics workspace by running queries against the collected data.
Note: The legacy Log Analytics agent will be deprecated by August 2024. Migrate to the Azure Monitor agent before this date to continue ingesting data3.
By following these steps, you should be able to collect the recommended Windows Performance Counters from SRV1 in your Log Analytics workspace. Ensure that you have the necessary permissions and that SRV1 has network connectivity to Azure services.
NEW QUESTION # 153
You have an Azure subscription named sub1 and 500 on-premises virtual machines that run Windows Server.
You plan to onboard the on-premises virtual machines to Azure Arc by running the Azure Arc deployment script You need to create an identity that mil be used by the script to authenticate access to sub1. The solution must use the principle of least privilege.
How should you complete the command? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... d-service-principal
NEW QUESTION # 154
SIMULATION
You plan to create group managed service accounts (gMSAs).
You need to configure the domain to support the creation of gMSAs.
To complete this task, sign in the required computer or computers.
Getting Started with Group Managed Service Accounts
Preparing the domain
Perform these steps to prepare the domain:
Step 1: Run ADPrep /domainPrep
You will then see:
Note: Active Directory Domain Service requirements
The Active Directory schema in the gMSA domain's forest needs to be updated to Windows Server 2012 to create a gMSA.
*-> You can update the schema by installing a domain controller that runs Windows Server 2012 or by running the version of adprep.exe from a computer running Windows Server 2012 . The object-version attribute value for the object CN=Schema,CN=Configuration,DC=Contoso,DC=Com must be 52.
https://learn.microsoft.com/en-u ... up-managed-service- accounts/getting-started-with-group-managed-service-accounts
https://www.koolaid.info/dude-wheres-my-managed-service-accounts/
NEW QUESTION # 155
With our AZ-800 test prep, you don't have to worry about the complexity and tediousness of the operation. Our AZ-800 exam torrent is available in different versions. Whether you like to study on a computer or enjoy reading paper materials, our test prep can meet your needs. Our PDF version of the AZ-800 quiz guide is available for customers to print. You can print it out, so you can practice it repeatedly conveniently. And our AZ-800 Exam Torrent make it easy for you to take notes on it so that your free time can be well utilized and you can often consolidate your knowledge. Everything you do will help you successfully pass the exam and get the card.
New AZ-800 Test Preparation: https://www.itbraindumps.com/AZ-800_exam.html
BONUS!!! Download part of Itbraindumps AZ-800 dumps for free: https://drive.google.com/open?id=1iBKhukMc8oL5qptCYyhw5CCZP3ANh2cf
Posted at 1/24/2026 09:41:47        Only Author  2#
PRINCE2 PRINCE2-Agile-Foundation 시험탈락시RINCE2 PRINCE2-Agile-Foundation덤프비용전액을 환불해드릴만큼 저희 덤프자료에 자신이 있습니다. Fast2test에서는RINCE2 PRINCE2-Agile-Foundation덤프를 항상 최신버전이도록 보장해드리고 싶지만RINCE2 PRINCE2-Agile-Foundation시험문제변경시점을 예측할수 없어 시험에서 불합격받을수도 간혹 있습니다. 하지만 시험에서 떨어지면 덤프비용을 전액 환불해드려 고객님의 이익을 보장해드립니다.
Posted at 1/28/2026 04:06:53        Only Author  3#
I’m so thankful for your article, it’s definitely been eye-opening. Thanks to CLO-002 latest exam review, I secured a promotion and pay raise—today, I’m sharing it for free!
Posted at 5/16/2026 17:22:56        Only Author  4#
Das CompTIA PK0-005 Zertifikat kann nicht nur Ihre Fähigkeiten, sondern auch Ihre Fachkenntnisse und Erfahrungen beweisen. Der Boss hat Sie doch nicht umsonst eingestellt. Zur Zeit braucht IT-Branche eine zuverlässige Ressourcen zur CompTIA PK0-005 Zertifizierungsprüfung. ExamFragen ist eine gute Wahl. Sie können die CompTIA PK0-005 Prüfung in kurzer Zeit bestehen, ohne viel Zeit und Energie zu verwenden, und eine glänzende Zukunft haben.
