[General] Practice FCP_FAZ_AD-7.4 Exam Fee - Exam FCP_FAZ_AD-7.4 Questions Fee
96
【General】 Practice FCP_FAZ_AD-7.4 Exam Fee - Exam FCP_FAZ_AD-7.4 Questions Fee
Posted at 1/23/2026 23:34:28      View:152 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Prep4cram FCP_FAZ_AD-7.4 PDF Dumps and FCP_FAZ_AD-7.4 Exam Engine Free Share: https://drive.google.com/open?id=14Jt13WODxsd7Ei-Nl8AmONegA8tE8qHy
Prep4cram Fortinet Certification Exam comes in three different formats so that the users can choose their desired design and prepare Fortinet FCP_FAZ_AD-7.4 exam according to their needs. The first we will discuss here is the PDF file of real Fortinet FCP_FAZ_AD-7.4 Exam Questions. It can be taken to any place via laptops, tablets, and smartphones.
Fortinet FCP_FAZ_AD-7.4 Exam Syllabus Topics:
  • Logs and Reports Management: This part of the exam measures the candidate's ability to handle log data and generate reports using FortiAnalyzer.  Network and security analysts must show proficiency in managing, analyzing, and reviewing logs to ensure effective system monitoring and auditing processes are in place.
  • Device Management: Here, Fortinet network and security analysts are evaluated on their ability to handle devices linked to FortiAnalyzer. This includes adding new devices, managing them efficiently, and troubleshooting communication issues.
  • Administration: This section evaluates the ability of network and security analysts to configure administrative access and manage Administrative Domains (ADOMs). It covers tasks such as setting user permissions, managing backups, and disk quotas, and ensuring secure and efficient management of administrative privileges within FortiAnalyzer systems.
  • System Configuration: This section assesses the capabilities of network and security analysts in managing FortiAnalyzer systems. It includes tasks like performing initial configurations, setting up high-availability systems, and configuring RAID for storage.
Free PDF 2026 Fortinet High-quality Practice FCP_FAZ_AD-7.4 Exam FeeThese Fortinet FCP_FAZ_AD-7.4 dumps are real, updated, and error-free. It provides you with the essential Fortinet FCP_FAZ_AD-7.4 exam knowledge that you need to prepare and pass the Fortinet FCP_FAZ_AD-7.4 certification test with high scores. You can easily use all these three Fortinet FCP_FAZ_AD-7.4 Exam Questions format. These formats are compatible with all devices, operating systems, and the latest browsers.
Fortinet FCP - FortiAnalyzer 7.4 Administrator Sample Questions (Q79-Q84):NEW QUESTION # 79
Based on the partial outputs displayed, which devices can be members of a FortiAnalyzer Fabric?
  • A. All devices listed can be members.
  • B. FortiAnalyzer1 and FortiAnalyzer3
  • C. FortiAnalyzer1 and FortiAnalyzer2
  • D. FortiAnalyzer2 and FortiAnalyzer3
Based on the partial configuration output, the primary factor for determining which devices can be members of a FortiAnalyzer Fabric is the log-mode setting. Devices with the same log mode can be part of the same FortiAnalyzer Fabric.
FortiAnalyzer1: Log mode is set to collector.
FortiAnalyzer2: Log mode is set to collector.
FortiAnalyzer3: Log mode is set to analyzer.
Devices with the same log mode can be part of the same fabric. Since FortiAnalyzer1 and FortiAnalyzer2 both have their log modes set to collector, they can be members of a FortiAnalyzer Fabric.
Therefore, the correct answer is FortiAnalyzer1 and FortiAnalyzer2.
NEW QUESTION # 80
On the RAID management page, the disk status is listed as Initializing.
What does the status Initializing indicate about what the FortiAnalyzer is currently doing?
  • A. FortiAnalyzer is functioning normally
  • B. FortiAnalyzer is writing data to a newly added hard drive to restore it to an optimal state
  • C. FortiAnalyzer is writing to all of its hard drives to make the array fault tolerant
  • D. FortiAnalyzer is ensuring that the parity data of a redundant drive is valid
8977-00505692583a/FortiAnalyzer-5.6.10-Administration-Guide.pdf (40)
NEW QUESTION # 81
What does the data point at 12:20 indicate?
  • A. The log insert lag time is increasing.
  • B. The performance of FortiAnalyzer is below the baseline.
  • C. The sqlplugind service is caught up with new logs.
  • D. FortiAnalyzer is using its cache to avoid dropping logs.
NEW QUESTION # 82
Which two statements are true regarding log fetching on FortiAnalyzer? (Choose two.)
  • A. Log fetching allows the administrator to run queries and reports against historical data by retrieving archived logs from one FortiAnalyzer device and sending them to another FortiAnalyzer device.
  • B. Log fetching allows the administrator to fetch analytics logs from another FortiAnalyzer for redundancy.
  • C. A FortiAnalyzer device can perform either the fetch server or client role, and it can perform two roles at the same time with the same FortiAnalyzer devices at the other end.
  • D. Log fetching can be done only on two FortiAnalyzer devices that are running the same firmware version.
Answer: A,D
Using FortiAnalyzer, you can enable log fetching. This allows FortiAnalyzer to fetch the archived logs of specified devices from another FortiAnalyzer, which you can then run queries or reports on for forensic analysis.
The FortiAnalyzer device that fetches logs operates as the fetch client, and the other FortiAnalyzer device that sends logs operates as the fetch server. Log fetching can happen only between two FortiAnalyzer devices, and both of them must be running the same firmware version. A FortiAnalyzer device can perform either the fetch server or client role, and it can perform two roles at the same time with different FortiAnalyzer devices at the other end.
FortiAnalyzer_7.0_Study_Guide-Online pag. 168
NEW QUESTION # 83
An administrator has moved FortiGate A from the root ADOM to ADOM1.
Which two statements are true regarding logs? (Choose two.)
  • A. Analytics logs will be moved to ADOM1 from the root ADOM automatically.
  • B. Logs will be presented in both ADOMs immediately after the move.
  • C. Archived logs will be moved to ADOM1 from the root ADOM automatically.
  • D. Analytics logs will be moved to ADOM1 from the root ADOM after you rebuild the ADOM1 SQL database.
NEW QUESTION # 84
We are famous for our company made these FCP_FAZ_AD-7.4 exam questions with accountability. We understand you can have more chances getting higher salary or acceptance instead of preparing for the FCP_FAZ_AD-7.4 exam. Our FCP_FAZ_AD-7.4 practice materials are made by our responsible company which means you can gain many other benefits as well. We offer free demos of our FCP_FAZ_AD-7.4 learning guide for your reference, and send you the new updates if our experts make them freely.
Exam FCP_FAZ_AD-7.4 Questions Fee: https://www.prep4cram.com/FCP_FAZ_AD-7.4_exam-questions.html
P.S. Free & New FCP_FAZ_AD-7.4 dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=14Jt13WODxsd7Ei-Nl8AmONegA8tE8qHy
Posted at 2/1/2026 10:11:03        Only Author  2#
Thank you for the article, it really broadened my outlook. Wish me luck as I’m getting ready to take the Cost-effective AP-205 certification exam!
