VCE NCA-6.10 Dumps & Exam NCA-6.10 Reviews
98
Posted at 1/24/2026 05:30:32      View145 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepPDF NCA-6.10 dumps for free: https://drive.google.com/open?id=1Weq31CP3sSNh83lh-3zmx1oOVnCyQZcc
People are very busy nowadays, so they want to make good use of their lunch time for preparing for their NCA-6.10 exam. If you choice our NCA-6.10 exam question as your study tool, you will not meet the problem. Because the app of our NCA-6.10 exam prep supports practice offline in anytime. If you buy our products, you can also continue your study when you are in an offline state. You will not be affected by the unable state of the whole network. You can choose to use our NCA-6.10 Exam Prep in anytime and anywhere
Getting the related NCA-6.10 certification in your field will be the most powerful way for you to show your professional knowledge and skills. However, it is not easy for the majority of candidates to prepare for the NCA-6.10 exam in order to pass it, if you are one of the candidates who are worrying about the exam now, congratulations, you can have our NCA-6.10 Study Tool. We can assure you that you can pass the exam as well as getting the related certification in a breeze with the guidance of our NCA-6.10 test torrent.
Exam NCA-6.10 Reviews, NCA-6.10 New Learning MaterialsWithout doubt, our NCA-6.10 practice dumps keep up with the latest information and contain the most valued key points that will show up in the real NCA-6.10 exam. Meanwhile, we can give you accurate and instant suggestion for our customer services know every detail of our NCA-6.10 Exam Questions. And they are pleased to give guide for 24 hours online. You can get assistant by them as long as you made your inquire.
Nutanix Certified Associate v6.10 Sample Questions (Q25-Q30):NEW QUESTION # 25
Shared storage for Windows Server Failover Clustering (WSFC) is a use case for which Nutanix Unified Storage solution?
  • A. Volumes
  • B. FT1
  • C. Files
  • D. RF2
NEW QUESTION # 26
Which Nutanix Disaster Recovery component or feature provides the best Recovery Time Objective (RTO)?
  • A. Async
  • B. Metro Availability
  • C. Availability Zone
  • D. NearSync
Nutanix Metro Availability provides the best Recovery Time Objective (RTO) because it enables synchronous replication between two sites. In the event of a failure at one site, VMs can be instantly restarted on the other site with minimal disruption. This setup ensures zero data loss and near-instantaneous recovery.
* A. Asyncrovides high RPO (Recovery Point Objective) but has a longer RTO compared to synchronous replication methods.
* B. Availability Zone:This term refers to a general site setup, not specific to recovery objectives.
* C. Metro Availability:Correct, as it uses synchronous replication for near-zero RTO.
* D. NearSyncrovides better RPO than Async but does not match the RTO of Metro Availability.
Nutanix Data Protection and Disaster Recovery Guide.
Nutanix University Certification Content.
NEW QUESTION # 27
What is the purpose of the Recycle Bin?
  • A. Centralizes the deleted data from the different VMs in the cluster.
  • B. Keeps deleted VMs for 24 hours for recovery.
  • C. Allows administrators to undo the last five actions.
  • D. Stores the OpLog's most recent deleted data in case of a CVM failure.
TheRecycle Binin Nutanix clusters temporarily stores deleted VMs for 24 hours, allowing administrators to recover them if needed. This feature helps protect against accidental deletions by providing a grace period for recovery before permanent deletion occurs.
* A. Stores the OpLog's most recent deleted data in case of a CVM failure:Incorrect, as the OpLog pertains to write operations, not VM deletion.
* B. Keeps deleted VMs for 24 hours for recovery:Correct, as the Recycle Bin's purpose is temporary VM recovery.
* C. Allows administrators to undo the last five actions:Incorrect, as there is no such feature for undoing multiple actions in Prism.
* D. Centralizes the deleted data from the different VMs in the cluster:Incorrect, as the Recycle Bin is specifically for deleted VMs, not generalized data centralization.
Nutanix Administration Guide: Recycle Bin Functionality.
Nutanix Support Knowledge Base Article on VM Recovery via Recycle Bin.
NEW QUESTION # 28
An administrator has been directed to ensure that all Prism Element and Prism Central clusters allow Nutanix Support to gather logs without needing engagement.
What should the administrator enable to meet this requirement?
  • A. NKP
  • B. Pulse
  • C. Proxy Server
  • D. Self-Service
NEW QUESTION # 29
What is the purpose of Life Cycle Management (LCM)?
  • A. To optimize server performance
  • B. To automate application deployment
  • C. To simplify software and firmware upgrades
  • D. To manage network configurations
Life Cycle Management (LCM) in Nutanix is a feature designed tosimplify software and firmware upgrades across the entire cluster. LCM automates and orchestrates upgrades for components like BIOS, hypervisors, firmware, and Nutanix software, ensuring that the cluster remains up-to-date with minimal manual intervention.
* A. To optimize server performance:Incorrect, as LCM focuses on updates, not performance optimization.
* B. To manage network configurations:Incorrect, as LCM is unrelated to network configuration management.
* C. To simplify software and firmware upgrades:Correct, as LCM is specifically designed for this purpose.
* D. To automate application deployment:Incorrect, as LCM does not handle application deployment.
Nutanix Life Cycle Manager Guide.
Nutanix Support KB on LCM Operations.
NEW QUESTION # 30
This is similar to the NCA-6.10 desktop format but this is browser-based. It requires an active internet connection to run and is compatible with all browsers such as Google Chrome, Mozilla Firefox, Opera, MS Edge, Safari, Internet Explorer, and others. The Nutanix NCA-6.10 Mock Exam helps you self-evaluate your Nutanix NCA-6.10 exam preparation and mistakes. This way you improve consistently and attempt the NCA-6.10 certification exam in an optimal way for excellent results in the exam.
Exam NCA-6.10 Reviews: https://www.preppdf.com/Nutanix/NCA-6.10-prepaway-exam-dumps.html
100% Authentic NCA-6.10 Exam PrepPDF, Nutanix VCE NCA-6.10 Dumps You spare time can be made good use, Nutanix VCE NCA-6.10 Dumps Correct questions and answers are of key importance to pass exam, Nutanix VCE NCA-6.10 Dumps So we develped trial versions for you, Four Steps to Prepare & Pass Exam NCA-6.10 Reviews Collaboration Exam, This kind of learning method is very convenient for the user, especially in the time of our fast pace to get NCA-6.10 certification.
Why is there a need to decentralize cloud computing services, NCA-6.10 He is currently an editor at Reuters, overseeing a team that reports on the stocks, bonds and foreign exchange markets.
100% Authentic NCA-6.10 Exam PrepPDF, You spare time can be made good use, Correct questions and answers are of key importance to pass exam, So we develped trial versions for you.
New VCE NCA-6.10 Dumps | High-quality Exam NCA-6.10 Reviews: Nutanix Certified Associate v6.10 100% PassFour Steps to Prepare & Pass Nutanix Certified Associate Collaboration Exam.
Posted at 2/8/2026 12:17:45        Only Author  2#
Im truly amazed by the depth of your article, thank you for sharing! I achieved career success with the Latest AANP-FNP mock exam, earning both a promotion and raise. Its free for everyone now. Best of luck!
