[Hardware] Microsoft SC-200 Exam Study Guide | New SC-200 Exam Pattern
111
【Hardware】 Microsoft SC-200 Exam Study Guide | New SC-200 Exam Pattern
Posted at 1/24/2026 11:19:45      View:198 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New SC-200 dumps are available on Google Drive shared by BraindumpsPrep: https://drive.google.com/open?id=1rgQCWtnqnYudwFpGD9f0ceRvTGYqtKft
May be you still strange to our SC-200 dumps pdf, you can download the free demo of the dump torrent before you buy. If you have any questions to our Microsoft exam questions torrent, please feel free to contact us and we will give our support immediately. You will be allowed to updating SC-200 Learning Materials one-year once you bought pdf dumps from our website.
Get ready for the Microsoft SC-200 ExamMicrosoft Security Operations Analyst Certification is a professional-level certification that has been designed to recognize individuals with the knowledge and skills necessary to protect enterprise networks from any online threats. While taking the Microsoft SC-200 test, the candidate will be required to have a good understanding of various security threats, malware, and hacker attacks. They will also have to have a deep understanding of different types of firewalls and IDS/IPS systems, as well as how they work together. Candidates should also be aware of network infrastructure devices, such as routers, proxies, and servers involved in implementing an effective security strategy. Another important area that the candidate must cover is risk management techniques used by the enterprise department to identify potential risks and vulnerabilities. The candidate must also know how to effectively monitor internal and external networks for any signs of intrusions or other Cyber crime. The Microsoft SC-200 exam dumps have been designed to provide you with all the knowledge required to pass the Microsoft SC-200 Certification Exam.
The Microsoft SC-200 exam requires you to have expert knowledge on Windows Server Update Services (WSUS), Group Policy, and Active Directory. Candidates must also possess expert knowledge on System Center Configuration Manager (SCCM) 2007 R2 and Windows Intune.
Microsoft SC-200 (Microsoft Security Operations Analyst) Exam is a certification exam that tests the skills and knowledge needed to identify, investigate, and respond to security incidents in a Microsoft environment. SC-200 exam is intended for security professionals who have experience in security operations and are looking to validate their skills with a recognized certification. SC-200 exam covers various topics related to security operations, including threat detection, incident response, cloud security, and compliance.
New Microsoft SC-200 Exam Pattern - Valid Dumps SC-200 SheetMany candidates worry that after a long-time review of SC-200, they may still fail the exam due to inadaptation of the test model. So our BraindumpsPrep will provide a exam simulation for you to experience the real exam model before real exam. SC-200 exam simulation software is full of questions, which will improve your ability to face the exam after you exercise them. Besides, the detailed answers analysis provided by our professionals will make you be more confidence to Pass SC-200 Exam.
Microsoft Security Operations Analyst Sample Questions (Q352-Q357):NEW QUESTION # 352
You have a Microsoft subscription that has Microsoft Defender for Cloud enabled You configure the Azure logic apps shown in the following table.
You need to configure an automatic action that will run if a Suspicious process executed alert is triggered. The solution must minimize administrative effort.
1 - Configure the Trigger automated response settings.
2 - Filter by alert title.
3 - Select Take action.
NEW QUESTION # 353
Your company uses Azure Sentinel.
A new security analyst reports that she cannot assign and dismiss incidents in Azure Sentinel. You need to resolve the issue for the analyst. The solution must use the principle of least privilege. Which role should you assign to the analyst?
  • A. Azure Sentinel Responder
  • B. Azure Sentinel Reader
  • C. Logic App Contributor
  • D. Azure Sentinel Contributor
NEW QUESTION # 354
You need to create the analytics rule to meet the Azure Sentinel requirements.
What should you do? To answer, select the appropriate options in the answer area.
According to Microsoft Security Operations (SecOps) and Azure Sentinel documentation, when you need to create an analytics rule that executes a custom KQL query and automatically initiates a playbook, the correct configuration is to create a Scheduled rule and ensure the playbook includes a trigger.
Here's why:
* A Scheduled analytics rule in Microsoft Sentinel (Microsoft Defender XDR portal) is designed for running custom KQL queries at defined intervals (for example, every hour or every few minutes) to detect specific patterns of suspicious activity. When the rule's conditions are met, Sentinel generates alerts that can automatically trigger a playbook for response and automation.
* A playbook in Sentinel is an Azure Logic App that automates responses to incidents or alerts. To connect a playbook to an analytics rule, it must include a trigger-specifically, the "Microsoft Sentinel Alert" or "Incident trigger." This allows the rule to start the playbook automatically when the defined condition is met.
* Fusion rules are built-in and use Microsoft's machine learning to correlate signals automatically; they can't be used for custom queries.
* Microsoft incident creation rules are also built-in and handle alert-to-incident grouping logic, not custom query execution.
* A service principal would be needed for permissions (e.g., admin1 configuring playbooks), but not inside the playbook itself.
* Diagnostics settings apply to log collection and retention, not rule automation.
Therefore, based on Microsoft Sentinel best practices and documentation:
# Create the rule of type: Scheduled
# Configure the playbook to include: A trigger
NEW QUESTION # 355
You need to implement the scheduled rule for incident generation based on rulequery1.
What should you configure first?
  • A. alert details
  • B. custom details
  • C. entity mapping
  • D. event grouping
Topic 4, Mix Questions
Mix Questions
SC-200 Mix Questions IN THIS CASE STUDY
Fabrikam. Inc. is a financial services company.
The company has branch offices in New York. London, and Singapore. Fabrikam has remote users located across the globe. The remote users access company resources, including cloud resources, by using a VPN connection to a branch office.
The network contains an Active Directory Domain Services (AD DS) forest named fabrikam.com that syncs with an Azure AD tenant named fabrikam.com. To sync the forest, Fabrikam uses Azure AD Connect with pass-through authentication enabled and password hash synchronization disabled.
The fabrikam.com forest contains two global groups named Group1 and Group2.
All the users at Fabrikam are assigned a Microsoft 365 E5 license and an Azure Active Directory Premium Plan 2 license. Fabrikam implements Microsoft Defender for Identity and Microsoft Defender for Cloud Apps and enables log collectors.
Fabrikam has an Azure subscription that contains the resources shown in the following table.
Fabrikam has an Amazon Web Services (AWS) account named Account1. Account1 contains 100 Amazon Elastic Compute Cloud (EC2) instances that run a custom Windows Server 2022. The image includes Microsoft SQL Server 2019 and does NOT have any agents installed.
When the users use the VPN connections. Microsoft 365 Defender raises a high volume of impossible travel alerts that are false positives. Defender for Identity raises a high volume of Suspected DCSync attack alerts that are false positives.
Fabrikam plans to implement the following services:
* Microsoft Defender for Cloud
* Microsoft Sentinel
Fabrikam identifies the following business requirements:
* Use the principle of least privilege, whenever possible.
♦ Minimize administrative effort.
Fabrikam identifies the following Microsoft Defender for Cloud Apps requirements:
* Ensure that impossible travel alert policies are based on the previous activities of each user.
* Reduce the amount of impossible travel alerts that are false positives.
Minimize the administrative effort required to investigate the false positive alerts.
Fabrikam identifies the following Microsoft Defender for Cloud requirements:
* Ensure that the members of Group2 can modify security policies.
* Ensure that the members of Group1 can assign regulatory compliance policy initiatives at the Azure subscription level.
* Automate the deployment of the Azure Connected Machine agent for Azure Arc-enabled servers to the existing and future resources of Account1.
* Minimize the administrative effort required to investigate the false positive alerts.
Fabrikam identifies the following Microsoft Sentinel requirements:
* Query for NXDOMAIN DNS requests from the last seven days by using built-in Advanced Security Information Model (ASIM) unifying parsers.
* From AWS EC2 instances, collect Windows Security event log entries that include local group membership changes.
* Identify anomalous activities of Azure AD users by using User and Entity Behavior Analytics (UEBA).
* Evaluate the potential impact of compromised Azure AD user credentials by using UEBA.
* Ensure that App1 is available for use in Microsoft Sentinel automation rules.
* Identify the mean time to triage for incidents generated during the last 30 days.
* Identify the mean time to close incidents generated during the last 30 days.
* Ensure that the members of Group1 can create and run playbooks.
* Ensure that the members of Group1 can manage analytics rules.
* Run hunting queries on Pool! by using Jupyter notebooks.
* Ensure that the members of Group2 can manage incidents.
* Maximize the performance of data queries.
* Minimize the amount of collected data.
NEW QUESTION # 356
You need to create the test rule to meet the Azure Sentinel requirements.
What should you do when you create the rule?
  • A. From Set rule logic, turn off suppression.
  • B. From Set rule logic, map the entities.
  • C. From Analytics rule details, configure the severity.
  • D. From Analytics rule details, configure the tactics.
Section: [none]
Explanation/Reference:
https://docs.microsoft.com/en-us ... tect-threats-custom
NEW QUESTION # 357
New developments in the tech sector always bring new job opportunities. These new jobs have to be filled with the SC-200 certification holders. So to fill the space, you need to pass the SC-200 Exam. Earning the SC-200 certification helps you clear the obstacles you face while working in the Microsoft field.
New SC-200 Exam Pattern: https://www.briandumpsprep.com/SC-200-prep-exam-braindumps.html
P.S. Free 2026 Microsoft SC-200 dumps are available on Google Drive shared by BraindumpsPrep: https://drive.google.com/open?id=1rgQCWtnqnYudwFpGD9f0ceRvTGYqtKft
Posted at 1/27/2026 05:26:49        Only Author  2#
This article has really touched me, thank you for sharing! Free NCP-DB-6.10 practice exam online test materials—the essential resource for your promotion and salary increase!
Posted at 3/6/2026 21:56:16        Only Author  3#
This article is amazing, thank you for sharing it with us! Free access to C_P2WWM_2023 test experience materials for all—good luck!
