[Hardware] 最新的NCM-MCI-6.10認證考試的參考資料
98
【Hardware】 最新的NCM-MCI-6.10認證考試的參考資料
Posted at 1/24/2026 21:31:52      View:268 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 VCESoft最新的NCM-MCI-6.10 PDF版考試題庫和NCM-MCI-6.10考試問題和答案免費分享:https://drive.google.com/open?id=14u49ghdn3HGX963IVL-O0QaNgy7ioxEQ
要想一次性通過Nutanix NCM-MCI-6.10 認證考試您必須得有一個好的準備和一個完整的知識結構。VCESoft為你提供的資源正好可以完全滿足你的需求。
最新NCM-MCI-6.10題庫的PDF版是廣大考生必選對象-是通過 NCM-MCI-6.10 考試的保障我們VCESoft網站是在盡最大的努力為廣大考生提供最好最便捷的服務。速度和高效率當然不可避免,在當今的社會裏,高效率走到哪里都是熱議的話題,所以我們網站為廣大考生設計了一個高效率的培訓資料,可以讓考生迅速領悟,從而考試取得優異的成績。VCESoft Nutanix的NCM-MCI-6.10考試培訓資料可以幫助考生節省大量的時間和精力,考生也可以用多餘的時間和盡力來賺去更多的金錢。
最新的 Master Level NCM-MCI-6.10 免費考試真題 (Q12-Q17):問題 #12
Task 8
An administrator has environment that will soon be upgraded to 6.5. In the meantime, they need to implement log and apply a security policy named Staging_Production, such that not VM in the Staging Environment can communicate with any VM in the production Environment, Configure the environment to satisfy this requirement.
Note: All other configurations not indicated must be left at their default values.
答案:
解題說明:
See the Explanation for step by step solution.
To configure the environment to satisfy the requirement of implementing a security policy named Staging_Production, such that no VM in the Staging Environment can communicate with any VM in the production Environment, you need to do the following steps:
Log in to Prism Central and go to Network > Security Policies > Create Security Policy. Enter Staging_Production as the name of the security policy and select Cluster A as the cluster.
In the Scope section, select VMs as the entity type and add the VMs that belong to the Staging Environment and the Production Environment as the entities. You can use tags or categories to filter the VMs based on their environment.
In the Rules section, create a new rule with the following settings:
Direction: Bidirectional
Protocol: Any
Source: Staging Environment
Destination: Production Environment
Action: Deny
Save the security policy and apply it to the cluster.
This will create a security policy that will block any traffic between the VMs in the Staging Environment and the VMs in the Production Environment. You can verify that the security policy is working by trying to ping or access any VM in the Production Environment from any VM in the Staging Environment, or vice versa.
You should not be able to do so.
問題 #13
Task 16
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
* VM specifications:
* vCPUs: 2
* Memory: BGb
* Disk Size: 50Gb
* Cluster: Cluster A
* Network: default- net
The API call is falling, indicating an issue with the payload:
The body is saved in Desktop/ Files/API_Create_VM,text
Correct any issues in the text file that would prevent from creating the VM. Also ensure the VM will be created as speeded and make sure it is saved for re-use using that filename.
Deploy the vm through the API
Note: Do not power on the VM.
答案:
解題說明:
https://portal.nutanix.com/page/ ... =kA00e000000LLEzCAO
https://jsonformatter.curiousconcept.com/#
acli net.list (uuid network defult_net)
ncli cluster info (uuid cluster)
Put Call: https://Prism Central IP address : 9440/api/nutanix/v3vms
Edit these lines to fix the API call, do not add new lines or copy lines.
You can test using the Prism Element API explorer or PostMan
Body:
"spec": {
"name": "Test_Deploy",
"resources": {
"power_state":"OFF",
"num_vcpus_per_socket": ,
"num_sockets": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type":"DISK"
"device_type":"CDROM"
"nic_list":[
"nic_type": "NORMAL_NIC",
"is_connected": true,
"ip_endpoint_list": [
"ip_type": "DHCP"
"subnet_reference": {
"kind": "subnet",
"name": "default_net",
"uuid": "00000000-0000-0000-0000-000000000000"
"cluster_reference": {
"kind": "cluster",
"name": "NTNXDemo",
"api_version": "3.1.0",
"metadata": {
"kind": "vm"
https://www.nutanix.dev/2019/08/ ... t-api-post-request/ Reference
問題 #14
Task 1
An administrator needs to configure storage for a Citrix-based Virtual Desktop infrastructure.
Two VDI pools will be created
Non-persistent pool names MCS_Pool for tasks users using MCS Microsoft Windows 10 virtual Delivery Agents (VDAs) Persistent pool named Persist_Pool with full-clone Microsoft Windows 10 VDAs for power users
20 GiB capacity must be guaranteed at the storage container level for all power user VDAs The power user container should not be able to use more than 100 GiB Storage capacity should be optimized for each desktop pool.
Configure the storage to meet these requirements. Any new object created should include the name of the pool (s) (MCS and/or Persist) that will use the object.
Do not include the pool name if the object will not be used by that pool.
Any additional licenses required by the solution will be added later.
答案:
解題說明:
To configure the storage for the Citrix-based VDI, you can follow these steps:
Log in to Prism Central using the credentials provided.
Go to Storage > Storage Pools and click on Create Storage Pool.
Enter a name for the new storage pool, such as VDI_Storage_Pool, and select the disks to include in the pool.
You can choose any combination of SSDs and HDDs, but for optimal performance, you may prefer to use more SSDs than HDDs.
Click Save to create the storage pool.
Go to Storage > Containers and click on Create Container.
Enter a name for the new container for the non-persistent pool, such as MCS_Pool_Container, and select the storage pool that you just created, VDI_Storage_Pool, as the source.
Under Advanced Settings, enable Deduplication and Compression to reduce the storage footprint of the non- persistent desktops. You can also enable Erasure Coding if you have enough nodes in your cluster and want to save more space. These settings will help you optimize the storage capacity for the non-persistent pool.
Click Save to create the container.
Go to Storage > Containers and click on Create Container again.
Enter a name for the new container for the persistent pool, such as Persist_Pool_Container, and select the same storage pool, VDI_Storage_Pool, as the source.
Under Advanced Settings, enable Capacity Reservation and enter 20 GiB as the reserved capacity. This will guarantee that 20 GiB of space is always available for the persistent desktops. You can also enter 100 GiB as the advertised capacity to limit the maximum space that this container can use. These settings will help you control the storage allocation for the persistent pool.
Go to Storage > Datastores and click on Create Datastore.
Enter a name for the new datastore for the non-persistent pool, such as MCS_Pool_Datastore, and select NFS as the datastore type. Select the container that you just created, MCS_Pool_Container, as the source.
Click Save to create the datastore.
Go to Storage > Datastores and click on Create Datastore again.
Enter a name for the new datastore for the persistent pool, such as Persist_Pool_Datastore, and select NFS as the datastore type. Select the container that you just created, Persist_Pool_Container, as the source.
The datastores will be automatically mounted on all nodes in the cluster. You can verify this by going to Storage > Datastores and clicking on each datastore. You should see all nodes listed under Hosts.
You can now use Citrix Studio to create your VDI pools using MCS or full clones on these datastores. For more information on how to use Citrix Studio with Nutanix Acropolis, see Citrix Virtual Apps and Desktops on Nutanix or Nutanix virtualization environments.
https://portal.nutanix.com/page/ ... x-Virtual-Apps-and- Desktops:bp-nutanix-storage-configuration.html
問題 #15
The DB team is requesting an SQL database instance and has requested it be configured for best performance.
This VM has been migrated from a 3 tier solution into Nutanix.
The database VM hosts 4 databases, each set to a 20 GB limit. Logs are expected to not grow beyond 20 GB and should be limited to within 25% to avoid runaway processes. Do not configure more storage than is needed.
The VM that has been migrated is identified as sql3532. Once the VM has been properly reconfigured, the DBA team will reconfigure the OS and database.
The VM should be configured as per KB-3532.
While this VM is being tested, make sure it is the first VM to power up in the event the node it is on goes down.
To maximize performance, ensure as much of the VM as possible will be kept on SSD drives.
Note: The VM does not need to be powered on. The VM should remain on the default container and should not be configured with a volume group. No network is required at this time.
答案:
解題說明:
See the Explanation below for detailed answer.
Here is the step-by-step solution to reconfigure the sql3532 virtual machine.
This task is performed from the Prism Element interface for the cluster the VM is on (e.g., Cluster 1).
1. Locate and Update the VM
* From the Prism Element main dashboard, navigate to the VM view.
* Find the VM named sql3532 in the VM table.
* Select the checkbox next to sql3532 and click the Update button.
2. Configure HA Priority and Flash Mode
In the "Update VM" dialog, configure the HA and SSD performance settings:
* HA Priority:
* Find the VM High Availability section.
* Select the High Priority radio button. This ensures it is one of the first VMs to power on during an HA event.
* Flash Mode (SSD Performance):
* Scroll down to the Flash Mode section.
* Check the box to Enable Flash Mode. This pins the VM's vDisks to the SSD tier, satisfying the requirement to keep as much of the VM as possible on SSDs, especially since it's on the default (hybrid) container.
3. Reconfigure Disks (per KB-3532)
While still in the "Update VM" dialog, scroll to the Disks section to add the new data and log disks. The key to "best performance" (KB-3532) is to place Data and Logs on separate vSCSI controllers.
* (The VM already has an OS disk, which we will assume is on scsi.0.)
* Add Data Disk:
* Click the + Add New Disk button.
* Storage Container: default (as required).
* Size: 80 GB (for the 4 x 20 GB databases).
* Bus Type: SCSI.
* Device Index: 1. (This creates a new vSCSI controller, scsi.1, for the data disk).
* Click Add.
* Add Log Disk:
* Size: 20 GB.
* Bus Type: SCSI.
* Device Index: 2. (This creates a third vSCSI controller, scsi.2, for the log disk).
* Click Add.
4. Save Configuration
* After adding the disks and setting HA/Flash Mode, click the main Save button at the bottom of the
"Update VM" dialog.
The VM is now configured with high availability, its storage is pinned to SSD, and its disk layout follows performance best practices by separating the OS, Data, and Log I/O paths onto three different controllers.
問題 #16
Your security team is working on automation to manage Security Policies.
They have exported some of the existing rules to the file "Security Policy.txt" located on the desktop. This file needs to be modified for the test environment.
* All rules except the quarantine rule should be logged.
* Only the Quarantine rule should be enforced, the other rules will only be logged.
* The quarantine rule should affect the SecOps environment.
* The SMB rule should only affect VMs with the "smbhost" and "smbclient" tags.
* The "DN test" policy should allow ipv6 and should not restrict any protocols between the included tiers.
There are three rules in the file, do not delete, add or copy lines. Only replace xxxx with the correct value as appropriate. It is possible that not all "xxxxx" will be replaced.
Save the file with the same name.
Possible values to replace the "xxxxx":
8080
ALL
APPLY
false
MONITOR
Non-Prod
SecOps
smbhost
smbclient
TCP
True
答案:
解題說明:
Here is the step-by-step solution to modify the security policy file as required.
Navigate to the desktop and open the file Security Policy.txt (which corresponds to the provided Security Policy.bak content) using a text editor like Notepad.
Modify the file content by replacing the xxxxx and xxxx placeholders according to the security requirements.
Modifications by Rule
Here are the specific changes to make within the file:
1. Quarantine Rule
Requirement 1 (No Logging): The quarantine rule should not be logged.
Change "is_policy_hitlog_enabled": "xxxxx" to "is_policy_hitlog_enabled": "false" Requirement 2 (Enforce): This rule must be enforced.
Change "action": "xxxxx" (under quarantine_rule) to "action": "APPLY"
Requirement 3 (Environment): The rule must affect the "SecOps" environment.
Change "Environment": ["xxxxx"] to "Environment": ["SecOps"]
2. SMB-block Rule
Requirement 1 (Logging): This rule must be logged.
Change "is_policy_hitlog_enabled": "xxxxx" to "is_policy_hitlog_enabled": "True" Requirement 2 (Monitor): This rule must not be enforced, only logged.
Change "action": "xxxxx" (under isolation_rule) to "action": "MONITOR"
Requirement 4 (Tags): The rule must affect the "smbhost" and "smbclient" tags.
Change "SMBv1": ["xxxxx"] to "SMBv1": ["smbhost"]
Change "SMRv1": ["xxxxx"] to "SMRv1": ["smbclient"]
3. DN test (dn-policy1) Rule
Change "action": "xxxx" (under app_rule) to "action": "MONITOR"
Requirement 5 (Allow IPv6): This policy must allow IPv6 traffic.
Change "allow_ipv6_traffic": "xxxx" to "allow_ipv6_traffic": "True"
Final Step
After making all the replacements, Save the file, overwriting the original Security Policy.txt on the desktop.
Example of completed rules (replace xxxxx accordingly):
Rule Name: Quarantine Rule
Logged: false
Action: APPLY
Environment: SecOps
Protocols: TCP
Ports: 8080
Rule Name: SMB Rule
Logged: True
Action: MONITOR
Tags: smbhost, smbclient
Protocols: TCP
Ports: 8080
Rule Name: DN Test Policy
Logged: True
Action: MONITOR
Environment: Non-Prod
Protocols: ALL
Ports: 8080
問題 #17
看著這麼多種IT認證考試和這麼多考試資料,你是否感到頭疼了呢?到底要怎麼辦才好呢?要選擇哪種考試哪種資料呢?如果你不知道應該怎麼選擇,那麼我來替你選擇吧。你可以選擇參加最近很有人氣的Nutanix的NCM-MCI-6.10認證考試。得到這個考試的認證資格,你可以得到很大的好處。另外,為了更有效率地準備考試,你可以選擇VCESoft的NCM-MCI-6.10考古題。這是你輕鬆通過考試的最好的方法。
NCM-MCI-6.10證照: https://www.vcesoft.com/NCM-MCI-6.10-pdf.html
在練習NCM-MCI-6.10問題集階段盡量拓展自己的思維;如果思路不正確,要找到原因:是因為自己對相關知識點理解的不夠透徹,還是因為自己沒有讀懂題意就急忙答題,導致解題的切入點就沒有找對,繼而解題思路出現偏差,Nutanix的NCM-MCI-6.10題庫由世界各地的資深IT工程師組成的專業團隊制作完成,包含最新的考試試題,并附有全部正確的答案,幫助考生通過他們認為很難的NCM-MCI-6.10考試,如果你還在惡補你的專業知識為考試做準備,那麼你就選錯了方式方法,這樣不僅費時費力,而且很有可能失敗,不過補救還來得及,趕緊去購買VCESoft Nutanix的NCM-MCI-6.10考試培訓資料,有了它,你將得到不一樣的人生,記住,命運是掌握在自己手中的,VCESoft NCM-MCI-6.10證照為你提供了不同版本的資料以方便你的使用。
而對方也不在意楊光這三具屍身是從哪兒掏出來的,高明英的聲音壹NCM-MCI-6.10下子消失了,就像是壹只被掐住脖子的鴨子壹般,過了好壹會兒,方才吶吶的道,他,他不是三天之前才閉的關嗎,在練習NCM-MCI-6.10問題集階段盡量拓展自己的思維;如果思路不正確,要找到原因:NCM-MCI-6.10考試資訊是因為自己對相關知識點理解的不夠透徹,還是因為自己沒有讀懂題意就急忙答題,導致解題的切入點就沒有找對,繼而解題思路出現偏差。
新版的NCM-MCI-6.10題庫上線 - 下載NCM-MCI-6.10題庫 & 通過NCM-MCI-6.10認證考試Nutanix的NCM-MCI-6.10題庫由世界各地的資深IT工程師組成的專業團隊制作完成,包含最新的考試試題,并附有全部正確的答案,幫助考生通過他們認為很難的NCM-MCI-6.10考試,如果你還在惡補你的專業知識為考試做準備,那麼你就選錯了方式方法,這樣不僅費時費力,而且很有可能失敗,不過補救還來得及,趕緊去購買VCESoft Nutanix的NCM-MCI-6.10考試培訓資料,有了它,你將得到不一樣的人生,記住,命運是掌握在自己手中的。
VCESoft為你提供了不同版本的資料以方便你的使用,以我們VCESoft在IT行業中的高信譽度可以給你提供100%的保障,為了讓你更安心的選擇購買我們,你可以先嘗試在網上下載我們提供的關於Nutanix NCM-MCI-6.10認證考試的部分考題及答案。
P.S. VCESoft在Google Drive上分享了免費的、最新的NCM-MCI-6.10考試題庫:https://drive.google.com/open?id=14u49ghdn3HGX963IVL-O0QaNgy7ioxEQ
Posted at 1/28/2026 12:46:09        Only Author  2#
Thank you for your article; it truly shocked me! Wish me all the best for the Reliable dumps for C-THR87-2505 exam coming up!
