[General] 2026 High-quality CPQ-301–100% Free Guide Torrent | Valid CPQ-301 Practice Mater
97
【General】 2026 High-quality CPQ-301–100% Free Guide Torrent | Valid CPQ-301 Practice Mater
Posted at 1/25/2026 23:37:48      View:105 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of NewPassLeader CPQ-301 dumps for free: https://drive.google.com/open?id=1EwwwNkzZWdd3fBfI4zwS0EhgajxROkjJ
Our society needs to various comprehensive talents, rather than a man only know the book knowledge but not understand the applied to real bookworm, therefore, we need to get the CPQ-301 certification, obtain the corresponding certifications. What a wonderful news it is for everyone who wants to pass the certification exams. There is a fabulous product to prompt the efficiency--the CPQ-301 Exam Prep, as far as concerned, it can bring you high quality learning platform to pass the variety of exams.
On successful completion of the Salesforce CPQ-301 exam, candidates are awarded the Salesforce Certified CPQ Specialist certification, which validates their skills and expertise in administering and customizing Salesforce CPQ. Configure and Administer a Salesforce CPQ Solution certification enhances the candidate's credibility and increases their employability in the Salesforce ecosystem, giving them a competitive edge in the market.
By obtaining the Salesforce CPQ-301 Certification, you will be able to demonstrate your expertise in Salesforce CPQ solutions. Configure and Administer a Salesforce CPQ Solution certification will set you apart from other professionals in the industry and increase your job opportunities. You will also gain access to the Salesforce Certified Professional community and be able to attend exclusive events and training sessions.
Valid CPQ-301 Practice Materials & CPQ-301 Reliable Test PrepOur veteran professional generalize the most important points of questions easily tested in the CPQ-301 practice exam into our practice questions. Their professional work-skill paid off after our CPQ-301 training materials being acceptable by tens of thousands of exam candidates among the market. They have delicate perception of the CPQ-301 study quiz over ten years. So they are dependable. You will have a big future as long as you choose us!
Salesforce Configure and Administer a Salesforce CPQ Solution Sample Questions (Q152-Q157):NEW QUESTION # 152
The Universal Containers sales operations team wants to ensure that without reopening the Quote Line Editor, quotes have current information prior to submitting them for approval.
Which two actions could the admin take to meet the business requirement?
Choose 2 answers
  • A. Add the Calculate button to the quote layout.
  • B. Create a Flow to trigger recalculation upon record save.
  • C. Change the value of a field in the Calculating Fields Field Set.
  • D. Q Create a new Lightning button to trigger recalculation.
NEW QUESTION # 153
The Universal Containers Admin is creating a custom formula field, Approval Score, on the Quote Line object to calculate approval score. This field will calculate the average approval score for the Quote to determine how many levels of approval the record should go through when submitted.
The Admin planned to use a roll-up summary field on the Quote object to average the Quote Line Approval Score field. The Admin received an error when attempting to create the field. The Quote object has too many roll-up summary fields.
In addition to creating a custom number field on the Quote object to capture the average Approval Score, which action Should the Admin take to resolve the issue?
  • A. Create a Summary Variable and Price Rule to populate the number field with the average Approval Score.
  • B. Create a Workflow Rule with a Field Update to populate the average Approval Score.
  • C. Create a trigger to populate the average Approval Score.
  • D. Create a Summary Variable and Product Rule to populate the number field with the average Approval Score.
NEW QUESTION # 154
An admin is setting up multiple Option Constraints. When configuration the bundle. a user should be unable to select Product B unless the user has also selected Product A.
What are two steps the Admin must take to set up the Option Constraint?
Choose 2 answers
  • A. Check Prior purchases should be set to False.
  • B. The Active checkbox should be set to True.
  • C. type should be dependency.
  • D. Option Constrain Group should be populated.
NEW QUESTION # 155
Suppose you have several Product Rules with conditions that evaluate a Configuration Attribute. You want the rules to fire immediately when the user changes the value of the Configuration Attribute. How do you accomplish this?
  • A. Check the Apply Immediately checkbox on the Configuration Attribute record
  • B. Add the Product Rules to the related list on the Configuration Attribute record
  • C. Check the Run Immediately checkbox on the Product Rule records
  • D. Set the Evaluation Order of the Product Rules to be later than the Evaluation Order of the Configuration Attributes
NEW QUESTION # 156
When selecting Product Option A inside a bundle, Universal Containers has a requirement that Product Option B's Quantity should be updated in real time. Apply Immediately has been set on Product Option A.
Which settings should be used on the Price Rule to meet these requirements?
  • A. Evaluation Scope = Configurator
    Configurator Evaluation Event = Edit
  • B. Evaluation Scope = Calculator
    Calculator Evaluation Event = Edit
  • C. Evaluation Scope = Configurator
    Configurator Evaluation Event = Save
  • D. Evaluation Scope = Calculator
    Calculator Evaluation Event = Save
NEW QUESTION # 157
NewPassLeader is an excellent platform where you get relevant, credible, and unique Salesforce CPQ-301 exam dumps designed according to the specified pattern, material, and format as suggested by the Salesforce CPQ-301 exam. To make the Salesforce CPQ-301 Exam Questions content up-to-date for free of cost up to 1 year after buying them, our certified trainers work strenuously to formulate the exam questions in compliance with the Configure and Administer a Salesforce CPQ Solution (CPQ-301) dumps.
Valid CPQ-301 Practice Materials: https://www.newpassleader.com/Salesforce/CPQ-301-exam-preparation-materials.html
What's more, part of that NewPassLeader CPQ-301 dumps now are free: https://drive.google.com/open?id=1EwwwNkzZWdd3fBfI4zwS0EhgajxROkjJ
Posted at 2/11/2026 10:08:35        Only Author  2#
It opened my mind in ways I didn’t expect. With the New C_S4CPB_2508 braindumps sheet, I secured my promotion and salary increase. It’s now free for all. Best of luck with your own promotions!
