[General] UiPath-ADPv1認證指南 - UiPath-ADPv1認證考試
98
【General】 UiPath-ADPv1認證指南 - UiPath-ADPv1認證考試
Posted at 1/28/2026 04:28:50      View:155 | Replies:3        Print      Only Author   [Copy Link] 1#
順便提一下,可以從雲存儲中下載VCESoft UiPath-ADPv1考試題庫的完整版:https://drive.google.com/open?id=1KtM3RO8nt8T7HIdE643_aktgxh50DrGx
在UiPath的UiPath-ADPv1考試題庫頁面中,我們擁有所有最新的考古題,由VCESoft資深認證講師和經驗豐富的技術專家精心編輯而來,完整覆蓋最新試題。UiPath的UiPath-ADPv1考古題包含了PDF電子檔和軟件版,還有在線測試引擎,全新收錄了UiPath-ADPv1認證考試所有試題,并根據真實的考題變化而不斷變化,適合全球考生通用。我們保證UiPath-ADPv1考古題的品質,百分之百通過考試,對于購買我們網站UiPath-ADPv1題庫的客戶,還可以享受一年更新服務。
UiPath UiPath-ADPv1 考試大綱:
主題簡介
主題 1
  • UiPath Studio Fundamentals: In this section, the focus is given to the understanding of Robotic Process Automation (RPA) concepts; it covers UiPath Studio and its components, Working with the UiPath user interface, project creation, management, and version control.
主題 2
  • Debugging and Testing: This section is about utilizing logging and debugging tools and adopting unit testing and test automation strategies.
主題 3
  • UiPath Activities: In this section, the discussion is related to various UiPath activities for UI interaction, data manipulation, control flow, and more.
主題 4
  • Design and Development: This section covers designing workflows using sequences, flowcharts, and state machines, building reusable components with libraries, exception handling and debugging techniques, etc.
閱讀UiPath-ADPv1認證指南意味著你已經通過UiPath (ADPv1) Automation Developer Professional的一半當前 UiPath 作爲企業資訊解決方案的重要性及緊要性與日俱增,相關的工作機會將會越來越多,對技術能力的要求也越來越被企業作爲面試的一個標準,所以不管在哪個行業,UiPath 工作者都必須不斷自我學習、接受訓練課程或是參加各式的專業認證來充實自己,使自己在工作上可以更加得心應手。而通過了UiPath UiPath-ADPv1 認證考試,證明你的IT專業知識很強,有很強的能力,可以勝任一份很好的工作。
最新的 UiPath Certified Professional - Developer Track UiPath-ADPv1 免費考試真題 (Q203-Q208):問題 #203
A developer designed a project in the REFramework. The "Config.xlsx" has me following Setting entry:
Assuming the default REFramework configuration, how can the developer reference the Setting in the Config variable to obtain the Setting value as a String from the dictionary?
  • A. Config ("ProcessABCOueue")ToString
  • B. Config ("ProcessABCQueue"."OrchestratorQueueName").ToString
  • C. Config ("OrchestratorOueueName ).ToString
  • D. Config ("OrchestratorOueueName"." Process ABCQueue" )ToString
答案:C
問題 #204
What advantages do pre-built connectors in UiPath Integration Service offer?
  • A. Providing a fully customizable catalog of connectors for developing proprietary applications.
  • B. Reducing the need for Ul and API automation, allowing developers to work exclusively with connectors.
  • C. Replacing all types of authorization and authentication protocols with a single, standardized method.
  • D. Simplified integration with popular applications, faster deployment, and integration across all UiPath Platform product solutions.
答案:D
解題說明:
UiPath Integration Service is the component of the UiPath Platform that makes the automation of third-party applications much easier by standardizing authorization and authentication, helping you manage API connections and also allowing faster integration into SaaS platforms1. By using pre-built connectors, the development of automation projects in UiPath Studio is more simple and more consistent, regardless of the third-party applications you are automating1. Some of the advantages of pre-built connectors are:
They enable automation with an out-of-the-box library of connectors for popular applications such as Salesforce, Slack, Microsoft Office 365, SAP, ServiceNow, and Google G Suite23.
They help setting up and managing connections easily with standardized authentication methods such as OAuth 2.0, Basic, API Key, and Custom1.
They enable kicking off automations with server-side triggers or events, such as receiving an email, creating a record, or updating a field1.
They provide curated activities and events (with additional data filters) for ease of use in UiPath Studio1.
They simplify automation design by providing a uniform experience across all Studio designers1.
They integrate across all UiPath Platform product solutions, such as UiPath Orchestrator, UiPath Assistant, UiPath Action Center, and UiPath Apps3.
Introducing UiPath Integration Service | UiPath
Integration Service - Introduction - UiPath Documentation Portal
Integration Service - Connectors - UiPath Documentation Portal
New UiPath Integration Service | UiPath
問題 #205
The following table is stored in a variable called "dt".
Which query can be used to extract the table column names and store them in a list?
  • A. dt.AsEnumerable.Select(function(x) x.ColumnName).ToList()
  • B. dt.Columns.Select(function(x) x.ColumnName).ToList()
  • C. dt.Columns.Cast(Of Datacolumn).Select(function(col) col).ToList()
  • D. dt.Columns.Cast(Of Datacolumn).Select(function(x) x.ColumnName).ToList()
答案:D
解題說明:
The DataTable object in UiPath is a representation of a table with rows and columns that can store data of various types. It has a Columns property that returns a collection of DataColumn objects that describe the schema of the table1. To extract the column names from a DataTable and store them in a list, you can use the following query:
dt.Columns.Cast(Of Datacolumn).Select(function(x) x.ColumnName).ToList() This query does the following:
* It casts the Columns collection to a generic IEnumerable(Of DataColumn) using the Cast(Of T) extension method2. This is necessary because the Columns collection is a non-generic IEnumerable that cannot be used with LINQ methods directly3.
* It selects the ColumnName property of each DataColumn object using the Select extension method and a lambda expression4. The ColumnName property returns the name of the column as a string5.
* It converts the resulting IEnumerable(Of String) to a List(Of String) using the ToList extension method6.
* Option B does not cast the Columns collection to a generic IEnumerable(Of DataColumn), which will cause a runtime error.
* Option C uses the AsEnumerable extension method, which returns a collection of DataRow objects, not DataColumn objects7. Therefore, the ColumnName property will not be available.
* Option D selects the whole DataColumn object instead of its ColumnName property, which will result in a list of DataColumn objects, not strings.
DataTable Class (System.Data) | Microsoft Docs
Enumerable.Cast(Of TResult) Method (System.Linq) | Microsoft Docs
DataColumnCollection Class (System.Data) | Microsoft Docs
Enumerable.Select(Of TSource, TResult) Method (System.Linq) | Microsoft Docs DataColumn.ColumnName Property (System.Data) | Microsoft Docs Enumerable.ToList(Of TSource) Method (System.Linq) | Microsoft Docs DataTableExtensions.AsEnumerable Method (System.Data) | Microsoft Docs
問題 #206
A developer configured the properties for a Click activity as shown below:
What happens if the activity cannot find its target at runtime?
  • A. An exception is thrown after 10 seconds.
  • B. An exception is thrown after 10 milliseconds.
  • C. The next activity is executed after 10 seconds.
  • D. The next activity is executed after 10 milliseconds.
答案:A
問題 #207
A user is working on their computer while an automation is running in PiP mode. What can the user do while the process runs?
  • A. Open a second PiP window to run a different automation.
  • B. Access files and modify documents without interrupting the automation.
  • C. Directly interact with the automation running in PiP mode.
  • D. Suspend the PiP session and resume it later without affecting the automation.
答案:B
解題說明:
Picture-in-Picture (PiP)mode allows the automation to run in anisolated desktop session, enabling theuser to continue working in their main desktop session. While the PiP session runs the automation, the user can access files and modify documentsin their own sessionwithout interference, making it ideal for attended automations.
Reference:UiPath Studio Guide > Picture in Picture > Overview
問題 #208
大多數人在選擇UiPath的UiPath-ADPv1的考試,由於它的普及,你完全可以使用VCESoft UiPath的UiPath-ADPv1考試的試題及答案來檢驗,可以通過考試,還會給你帶來極大的方便和舒適,這個被實踐檢驗過無數次的網站在互聯網上提供了考試題及答案,眾所周知,我們VCESoft是提供 UiPath的UiPath-ADPv1考試試題及答案的專業網站。
UiPath-ADPv1認證考試: https://www.vcesoft.com/UiPath-ADPv1-pdf.html
此外,這些VCESoft UiPath-ADPv1考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1KtM3RO8nt8T7HIdE643_aktgxh50DrGx
Posted at 2/3/2026 03:48:40        Only Author  2#
I was deeply moved by the article. I was promoted and received a raise with the help of the N10-009 visual cert exam. Now it’s available for free to all. Best wishes for your promotions!
Posted at 2/5/2026 19:03:37        Only Author  3#
The content is on point, so I’m liking it. Here’s the H31-311_V2.5 latest vce exam simulator test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
Posted at 2/14/2026 06:03:13        Only Author  4#
I’m truly amazed by the depth of your article, thank you for sharing! Improve your IT skills and grab the free New CSSBB exam duration. Best of luck with everything!
