[Hardware] Hottest AZ-700 Certification & Reliable AZ-700 Exam Prep
103
【Hardware】 Hottest AZ-700 Certification & Reliable AZ-700 Exam Prep
Posted at 1/28/2026 09:03:28      View:154 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ValidVCE AZ-700 dumps for free: https://drive.google.com/open?id=1cPVQYjSwBdc08J02n5-Fga8mYGFZ1C9B
The society has an abundance of capable people and there is a keen competition. Don't you feel a lot of pressure? No matter how high your qualifications, it does not mean your strength forever. Qualifications is just a stepping stone, and strength is the cornerstone which can secure your status. Microsoft AZ-700 certification exam is a popular IT certification, and many people want to have it. With it you can secure your career. ValidVCE's Microsoft AZ-700 Exam Training materials is a good training tool. It can help you pass the exam successfully. With this certification, you will get international recognition and acceptance. Then you no longer need to worry about being fired by your boss.
The AZ-700 exam is ideal for network architects, network administrators, systems engineers, and other IT professionals who want to enhance their skills in Azure networking solutions. AZ-700 exam covers a wide range of topics related to Azure networking, such as designing and implementing Azure virtual networks, Azure load balancers, Azure VPN gateways, Azure Application Gateway, and Azure Traffic Manager. AZ-700 exam also evaluates the candidate's knowledge of Azure DNS, Azure ExpressRoute, Azure Firewall, and Azure Network Watcher.
Microsoft AZ-700 certification exam is a professional-level certification exam for those who seek to design and implement networking solutions using Microsoft Azure. Designing and Implementing Microsoft Azure Networking Solutions certification is an excellent way to demonstrate your expertise in Azure networking and enhance your career prospects. To prepare for the exam, candidates can take advantage of a variety of study resources, including online courses, practice tests, and study guides. By passing AZ-700 Exam, you can demonstrate your ability to design and implement networking solutions that meet the requirements of modern businesses.
Reliable Microsoft AZ-700 Exam Prep - Practice AZ-700 Exam FeeYou can find that there are three versions of the AZ-700 training questions: the PDF, Software and APP online. As youIf you have more time at home, you can use the Software version of AZ-700 exam materials. If you are a person who likes to take notes, you can choose the PDF version. You can print out the PDF version of AZ-700 Practice Engine, carry it with you and read it at any time. If you are used to reading on a mobile phone, you can use our APP version.
Microsoft Designing and Implementing Microsoft Azure Networking Solutions Sample Questions (Q80-Q85):NEW QUESTION # 80
You have an Azure subscription that contains a virtual network named VNet1. VNet1 has a subnet mask of/24.
You plan to implement an Azure application gateway that will have the following configurations:
- Public endpoints: 1
- Private endpoints: 1
- Minimum instances: 1
- Maximum instances: 10
You need to configure the address space for the subnet of the application gateway. The solution must minimize the number of IP addresses allocated to the application gateway subnet.
What is the minimum number of assignable IP addresses required?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
  • E. 4
Application Gateway uses one private IP address per instance, plus another private IP address if a private frontend IP is configured.
https://learn.microsoft.com/en-u ... astructure#size-of- the-subnet
NEW QUESTION # 81
You have an Azure application gateway that has Azure Web Application Firewall (WAF) enabled.
You configure the application gateway to direct traffic to the URL of the application gateway.
You attempt to access the URL and receive an HTTP 403 error. You view the diagnostics log and discover the following error.
You need to ensure that the URL is accessible through the application gateway.
Solution: You disable the WAF rule that has a ruleld of 920300.
Does this meet the goal?
  • A. No
  • B. Yes
NEW QUESTION # 82
You have an Azure subscription. The subscription contains multiple Azure SQL Database resources and a virtual network named VNet1 that has five subnets. All the subnets are associated with a network security group (NSG) named NSG1. NSG1 blocks all outbound traffic, unless specifically allowed by a rule.
Each subnet contains 50 virtual machines. Multiple virtual machines host instances of SQL Server on Virtual Machines and will be configured to replicate with the Azure SQL Database resources.
You need to configure a new outbound rule in NSG1 to allow the SQL Server on Virtual Machines instances to connect to the Azure SQL Database resources. The solution must meet the following requirements:
* Minimize modifications to NSG1 when additional instances of SQL Server on Virtual Machines are deployed.
* Ensure that only SQL Server on Virtual Machines instances can connect to the Azure SQL Database resources.
How should you configure each setting for the new outbound rule? To answer, select the appropriate options in the answer area.
NEW QUESTION # 83
You have an Azure subscription that contains the route tables and routes shown in the following table.
The subscription contains the subnets shown in the following table.
The subscription contains the virtual machines shown in the following table.
There is a Site-to-Site VPN connection to each local network gateway.
For each of the following statements, select Yes of the statement is true. Otherwise, select No.
https://docs.microsoft.com/en-us ... tworks-udr-overview
NEW QUESTION # 84
You have an internal Basic Azure Load Balancer named LB1 That has two frontend IP addresses. The backend pool of LB1 contains two Azure virtual machines named VM1 and VM2.
You need to configure the rules on LB1 as shown in the following table.
What should you do for each rule?
  • A. Disable Floating IP.
  • B. Set Session persistence to Disabled
  • C. Set Session persistence to Enabled.
  • D. Enable Floating IP.
NEW QUESTION # 85
The Designing and Implementing Microsoft Azure Networking Solutions (AZ-700) practice exam software in desktop and web-based versions has a lot of premium features. One of which is the customization of Designing and Implementing Microsoft Azure Networking Solutions (AZ-700) practice exams. The AZ-700 Practice Tests are specially made for the customers so that they can practice unlimited times and improve day by day and pass Microsoft AZ-700 certification exam with good grades.
Reliable AZ-700 Exam Prep: https://www.validvce.com/AZ-700-exam-collection.html
Posted at 2/12/2026 08:06:33        Only Author  2#
Thank you for your powerful article, it left a lasting impression. The ADM-201 latest exam tutorial exam questions are free—essential for career advancement and salary increase!
Posted at 2/16/2026 19:46:39        Only Author  3#
The article was truly eye-opening. Comm-Dev-101 latest exam syllabus provides free, abundant content, designed to help you succeed.
