[Hardware] Testking 2V0-15.25 Learning Materials - 2V0-15.25 Vce Test Simulator
98
Hardware Testking 2V0-15.25 Learning Materials - 2V0-15.25 Vce Test Simulator
Posted at 1/28/2026 14:02:56      View186 | Replies0        Print      Only Author   [Copy Link] 1#
As the old saying goes people change with the times. People must constantly update their stocks of knowledge and improve their practical ability. Passing the test 2V0-15.25 certification can help you achieve that and buying our 2V0-15.25 study materials can help you pass the test smoothly. Our 2V0-15.25 Study Materials are superior to other same kinds of study materials in many aspects. Our products test bank covers the entire syllabus of the test and all the possible questions which may appear in the test. Each question and answer has been verified by the industry experts.
VMware 2V0-15.25 Exam Syllabus Topics:
  • VMware by Broadcom Solution: This section focuses on understanding VMware by Broadcom's virtualization and cloud infrastructure platform for managing modern enterprise workloads.
  • Plan and Design the VMware by Broadcom Solution: This domain addresses architectural planning and design principles for creating scalable, secure virtual environments aligned with business requirements.
  • Troubleshoot and Optimize the VMware by Broadcom Solution: This domain focuses on troubleshooting VCF deployment, upgrades, conversions, workload domains, fleet operations (certificates, passwords, identity), licensing, compute resources, storage (vSAN, supplemental storage), networking (VDS, NSX), VCF Operations tools, Identity Broker automation, and HCX workload migrations.
  • Install, Configure, Administrate the VMware by Broadcom Solution: This area covers installing, configuring, and managing VMware solutions including VCF Fleet deployment, expansion, and reduction operations.
Topic 5
  • IT Architectures, Technologies, Standards: This domain covers fundamental frameworks, tools, and best practices for building scalable, secure, and interoperable enterprise IT systems.
2V0-15.25 Vce Test Simulator | Exam 2V0-15.25 SuccessWhile all of us enjoy the great convenience offered by 2V0-15.25 information and cyber networks, we also found ourselves more vulnerable in terms of security because of the inter-connected nature of information and cyber networks and multiple sources of potential risks and threats existing in 2V0-15.25 information and cyber space. Taking this into consideration, our company can provide the best electronic 2V0-15.25 Exam Torrent for you in this website. I strongly believe that under the guidance of our 2V0-15.25 test torrent, you will be able to keep out of troubles way and take everything in your stride.
VMware Cloud Foundation 9.0 Support Sample Questions (Q43-Q48):NEW QUESTION # 43
An administrator logs into the VMware NSX Manager UI and discovers a time sync issue that has been reported in the VMWare Cloud Foundation (VCF) installer.
The administrator performs the following steps:
1. Validates that the NTP server IP addresses are present in the NTP configuration on the VCF Installer.
2. Validates that the DNS records are correctly set for the FQDN and IP address of the two NTP servers.
3. Validates that the NTP servers can be pinged by name and IP address from the VCF Installer.
4. Validates that the time between the NTP servers and the VCF Installer is synchronized successfully.
What additional step should the administrator perform to help identify the cause of the error?
  • A. Confirm that the ESX hosts have been configured to use host time synchronization.
  • B. Confirm that the NTP server details have been specified in the deployment parameter workbook using the required FQDN format.
  • C. Confirm that the time on the ESX hosts allocated for the management domain is synchronized with the same NTP servers as the VCF Installer.
  • D. Confirm that the NTP service has an allowed rule in the iptables on the VCF Installer.
During VMware Cloud Foundation bring-up,time synchronization across all management components is mandatory. The VCF Installer, ESXi hosts, NSX Manager nodes, and vCenter must all sync tothe same NTP servers. If even one host or component has a time skew exceeding VMware's allowed limits, VCF will report time sync errors during bring-up or post-deployment.
The administrator validated NTP configuration, DNS resolution, ping connectivity, and time synconly on the VCF Installer appliance, butdid not verify the ESXi hosts' time synchronization. NSX Manager obtains its time reference from the underlying ESXi host during deployment, so if the ESXi hosts are not synchronized with the same NTP sources, NSX Manager will drift, triggering the exact error described.
Option B (iptables) does not apply-the VCF Installer does not block outbound NTP by default.
Option C refers to workbook formatting, which would fail earlier in deployment-not after NSX Manager is running.
Option A is incorrect because ESXi should never use "host time sync"; NTP must be used.
NEW QUESTION # 44
An administrator is automating the deployment of a new VMware Cloud Foundation (VCF) fleet using VCF Installer. The VCF fleet must include VCF Automation being deployed in a simple deployment model.
The administrator creates a JSON file, but during the installation attempt the VCF Installer returns an error indicating that the JSON validation has failed.
What is the cause of the errors?
  • A. Second IP address for VCF Automation is not specified.
  • B. A separate distributed switch was defined for vSAN traffic.
  • C. NSX Manager size was defined as large.
  • D. VCF components binaries are not downloaded.
In VCF 9.0, when deployingVCF Automationusing the VCF Installer in aSimple Deployment Model, the appliance requirestwo IP addresses:
* Primary IP- Management interface
* Secondary IP- Required for service separation and internal routing for Automation services VMware's JSON schema for VCF Installer enforces this requirement. If the second IP is missing, incorrectly formatted, or placed under the wrong JSON section, the installer validation will fail immediately with a JSON schema error before deployment begins.
This is one of themost common causesof validation failure for VCF Automation deployment.
Option A (component binaries missing) produces abundle downloaderror, not JSON schema failure.
Option C (NSX Manager size = large) is allowed and does not break JSON validation.
Option D (separate vDS for vSAN) is allowed if defined correctly and also does not cause JSON schema failure.
NEW QUESTION # 45
An administrator has a vSphere 8.0 update 3 environment with the following configuration:
* A 3-node vSAN cluster
* A vSphere Standard Switch (VSS)
* Several standalone ESX hosts in the vCenter inventory
They want to convert this vSphere environment into a new VMware Cloud Foundation (VCF) 9.0 management domain.
Identify two changes they will need to make before converting this vSphere environment into a VMWare Cloud Foundation (VCF) Management domain? (Choose two.)
  • A. Upgrade vSphere 8.0 Update 3 to vSphere 9.0.
  • B. Remove the vSphere Standard Switch from the vCenter Inventory.
  • C. Remove the standalone hosts from the vCenter inventory.
  • D. Configure a vSphere Distributed Switch.
Answer: A,D
To convert an existing vSphere environment into aVMware Cloud Foundation (VCF) 9.0 Management Domain, several prerequisites must be met as defined in the VCF 9.x documentation.
First,VCF 9.0 requires vSphere 9.0as part of its Bill of Materials (BOM). The uploaded VCF 9.0 documentation confirms that VCF 9.0 is built onvSphere 9.0, vCenter 9.0, and NSX versions that align with the 9.x stack. A vSphere 8.0 Update 3 environment isnot supportedas a foundation for a VCF 9.0 management domain; therefore, the administrator mustupgrade the entire vSphere platform to vSphere 9.0 before VCF deployment.
(Reference: VCF 9.0 BOM - vSphere 9.0 is mandatory.)
Second, VCF management domain creation strictly requiresvSphere Distributed Switches (vDS). VCF does notsupportvSphere Standard Switches (VSS)for any management domain hosts. The VCF 9.0 design and deployment guides state that all ESXi hosts intended for a management domain must use vDS for management, vSAN, and vMotion networking. Therefore, the existence of a VSS must be corrected by deploying and configuring avSphere Distributed Switchand migrating host networking accordingly before Cloud Builder deployment.
Removing standalone hosts or removing a VSS from inventory isnot required. Only the hosts selected for the management domain need to be prepared.
Thus, the required changes are:
#B. Upgrade vSphere 8.0 Update 3 to vSphere 9.0
#C. Configure a vSphere Distributed Switch
These are the only changes explicitly required by VCF 9.0 documentation.
NEW QUESTION # 46
An administrator has received reports of high CPU ready times on several Virtual Machines (VMs) running within a VMware Cloud Foundation (VCF) with error" F.iain and has been tasked with collecting detailed metrics for all running Virtual Machines from each ESX host. com.vmware.esx.setungs_aaemon.sonware.
scan_spec.".
What is the cause of this error?
  • A. A vendor add-on was not provided in the image.
  • B. A device driver Is incompatible with the included firmware.
  • C. A component was removed from the image.
  • D. The cluster was not assigned a default image.
The error message com.vmware.esx.settings.daemon.software.scan_spec (reconstructed from the typo setungs_aaemon.sonware.scan_spec) is a specific failure generated by thevSphere Lifecycle Manager (vLCM)compliance engine on the ESXi host.
* Cause - Removed Component:This error is a documented known issue in vSphere 8.x/VCF 5.x+, specifically occurring when an administrator hasremoved a componentfrom the Cluster Image that the system validates as "required" or "structural" for the host's hardware configuration (common with hosts using DPUs or specific OEM add-ons).
* The Scenario:The mention of "High CPU ready times" likely implies the administrator attempted to streamline the host image byremovinga perceived "bloatware" component (like a vendor monitoring agent or unused driver) to improve performance.
* The Result:When vLCM attempts to build the "Scan Specification" (scan_spec) to validate the host against this modified image, the internal struct validation fails because the removed component creates an invalid dependency state, throwing the Invalid field software_spec... or scan_spec exception.
NEW QUESTION # 47
An administrator is tasked with replacing a VMware vCenter certificate in VMware Cloud Foundation (VCF) Operations with an external CA-signed certificate. The certificate import completes successfully but when running the certificate replacement task, it fails with the following error: Certificate replacement has failed...
The Certificate Chain validation failed due to 'Signature does not match' What is the possible cause of this issue?
  • A. The Certificate Signing Request (CSR) included the IP address of the vCenter.
  • B. The server certificate was copied to the wrong field.
  • C. The external CA is not trusted by VCF Operations.
  • D. The external CA is not accessible to VCF Operations.
When replacing certificates in VMware Cloud Foundation (VCF) Operations, the system performs strict certificate chain validation. The error shown:
"Certificate chain validation failed due to 'Signature does not match'" indicates that VCF Operations attempted to validate the presented certificate chain but detected that the server certificate did not correctly match the signing CA certificate. This occursmost commonly when the administrator pastes the server certificate and CA root/intermediate certificates into the wrong fields during import.
VCF requires the certificate bundle to be uploaded in the correct format:
* Server certificate# Server Certificate field
* Intermediate certificates# Intermediate Chain field
* Root certificate# Root CA field
If the chain order is wrong or the server certificate is mistakenly placed in an intermediate or root CA field, the cryptographic signature validation fails. This exact failure mode is documented in VMware certificate replacement workflows.
Option A is incorrect because including an IP address in a CSR does not invalidate chain signatures.
Option B is incorrect because an untrusted CA produces atrustfailure, not asignature mismatch.
Option C is unrelated: accessibility is not required for certificate validation.
NEW QUESTION # 48
There is an irreplaceable trend that an increasingly amount of clients are picking up 2V0-15.25 practice materials from tremendous practice materials in the market. There are unconquerable obstacles ahead of us if you get help from our 2V0-15.25 practice materials. So many exam candidates feel privileged to have our 2V0-15.25 practice materials. Your aspiring wishes such as promotion chance, or higher salaries or acceptance from classmates or managers and so on. And if you want to get all benefits like that, our 2V0-15.25 practice materials are your rudimentary steps to begin.
2V0-15.25 Vce Test Simulator: https://www.prep4pass.com/2V0-15.25_exam-braindumps.html
