Hardware
New NCM-MCI-6.10 Exam Test | Test NCM-MCI-6.10 Simulator Fee
Posted at 1/29/2026 15:41:51
View168
Replies2
By using our NCM-MCI-6.10 exam braindumps, it will be your habitual act to learn something with efficiency. With the cumulative effort over the past years, our NCM-MCI-6.10 study guide has made great progress with passing rate up to 98 to 100 percent among the market. A lot of professional experts concentrate to making our NCM-MCI-6.10 Preparation materials by compiling the content so they have gained reputation in the market for their proficiency and dedication.
We have installed the most advanced operation system in our company which can assure you the fastest delivery speed, to be specific, you can get immediately our NCM-MCI-6.10 training materials only within five to ten minutes after purchase after payment. As soon as you pressed the payment button on our NCM-MCI-6.10 Exam Questions, you can study right away if you choose to buy the NCM-MCI-6.10 exam practice from us. We aim to leave no misgivings to our customers so that they are able to devote themselves fully to their studies on NCM-MCI-6.10 guide materials and they will find no distraction from us.
Test NCM-MCI-6.10 Simulator Fee | NCM-MCI-6.10 Accurate AnswersOnce you decide to pass the NCM-MCI-6.10 exam and get the certification, you may encounter many handicaps that you don't know how to deal with, so, you may think that it is difficult to pass the NCM-MCI-6.10 exam and get the certification. In order to help you solve these problem and help you pass the exam easy, we complied such a NCM-MCI-6.10 Exam Torrent. We can promise that you will have no regret buying our NCM-MCI-6.10 exam dumps. Our NCM-MCI-6.10 exam questions have a high pass rate as 99% to 100%, you will pass with it for sure.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q15-Q20):NEW QUESTION # 15
Task 16
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
* VM specifications:
* vCPUs: 2
* Memory: BGb
* Disk Size: 50Gb
* Cluster: Cluster A
* Network: default- net
The API call is falling, indicating an issue with the payload:
The body is saved in Desktop/ Files/API_Create_VM,text
Correct any issues in the text file that would prevent from creating the VM. Also ensure the VM will be created as speeded and make sure it is saved for re-use using that filename.
Deploy the vm through the API
Note: Do not power on the VM.
See the Explanation for step by step solution.
https://portal.nutanix.com/page/ ... =kA00e000000LLEzCAO
https://jsonformatter.curiousconcept.com/#
acli net.list (uuid network defult_net)
ncli cluster info (uuid cluster)
Put Call: https://Prism Central IP address : 9440/api/nutanix/v3vms
Edit these lines to fix the API call, do not add new lines or copy lines.
You can test using the Prism Element API explorer or PostMan
Body:
"spec": {
"name": "Test_Deploy",
"resources": {
"power_state":"OFF",
"num_vcpus_per_socket": ,
"num_sockets": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type":"DISK"
"device_type":"CDROM"
"nic_list":[
"nic_type": "NORMAL_NIC",
"is_connected": true,
"ip_endpoint_list": [
"ip_type": "DHCP"
"subnet_reference": {
"kind": "subnet",
"name": "default_net",
"uuid": "00000000-0000-0000-0000-000000000000"
"cluster_reference": {
"kind": "cluster",
"name": "NTNXDemo",
"api_version": "3.1.0",
"metadata": {
"kind": "vm"
https://www.nutanix.dev/2019/08/ ... t-api-post-request/ Reference
NEW QUESTION # 16
The security team has provided some new security requirements for cluster level security on Cluster 2.
Security requirements:
* Update the password for the root user on the Cluster 2 node to match the admin user password.
Note: The 192.168.x.x network is not available. To access a node use the host IP (172.30.0.x) from the CVM.
* Output the cluster-wide configuration of the SCMA policy to desktopoutput.txt before changes are made.
* Enable the Advanced Intrusion Detection Environment (AIDE) to run on a weekly basis for the hypervisor and cvms for Cluster 2.
* Enable high-strength password policies for the hypervisor and cluster.
* Ensure CVMs require SSH keys for login instead of passwords. (SSH keys are located in the desktopFilesSSH folder.) Ensure the cluster meets these requirements. Do not reboot any cluster components.
Note: Please ensure you are modifying the correct components.
See the Explanation below for detailed answer.
Here is the step-by-step solution to apply the security requirements to Cluster 2.
1. Access Cluster 2 Prism Element
First, we must access the Prism Element (PE) interface for Cluster 2, as most security settings are cluster- specific.
* From the Prism Central dashboard, navigate to Hardware > Clusters.
* Find Cluster 2 in the list and click its name. This will open the Prism Element login page for that specific cluster in a new tab.
* Log in to Cluster 2's Prism Element using the admin credentials.
2. Requirement: Update Node Root Password
This task syncs the root password for all AHV hypervisor nodes with the cluster's admin user password.
* In the Cluster 2 PE interface, click the gear icon (Settings) in the top right corner.
* Select Cluster Lockdown from the left-hand menu.
* Click the Set Root Password on All Hosts button.
* A dialog box will appear. Enter the current admin password (the one you just used to log in) into both the New Password and Confirm New Password fields.
* Click Save. This will propagate the admin password to the root user on all nodes in Cluster 2.
3. Requirement: Add CVM SSH Key
This task adds the security team's public key to the admin user, which is required before we can disable password-based login.
* On the desktop, navigate to the Files > SSH folder.
* Open the id_rsa.pub file (or equivalent public key file) with Notepad.
* Copy the entire string of text (e.g., ssh-rsa AAAA...).
* In the Cluster 2 PE interface, go to Settings (gear icon) > User Management.
* Select the admin user and click Modify User.
* Paste the copied public key into the Public Keys text box.
* Click Save.
4. Requirement: Apply SCMA Policies (All other requirements)
The remaining requirements are all applied via the command line on a CVM using Nutanix's Security Configuration Management Automation (SCMA).
* Access the CVM:
* Find a CVM IP for Cluster 2 by going to Hardware > CVMs in the PE interface.
* Open an SSH client (like PuTTY) and connect to that CVM's IP address.
* Log in with the username admin and the corresponding password.
* Output Current Policy (Req 2):
* Before making changes, run the following command to see the current policy:
ncli scma status
* Copy the entire output from your SSH terminal.
* Open Notepad on the desktop, paste the copied text, and Save the file to the desktop as output.
txt.
* Apply New Policies (Req 3, 4, 5):
* Run the following commands one by one. The cluster will apply them immediately without a reboot.
* Enable AIDE (Req 3):
ncli scma update aide-status=enabled aide-schedule=weekly
* Enable High-Strength Passwords (Req 4):
ncli scma update password-policy=high
* Require SSH Keys for CVMs (Req 5):
ncli scma update ssh-login=keys-only
Verification
You can verify all changes by running the status command again. The output should now reflect the new, hardened security posture.
ncli scma status
* AIDE Status: should show Enabled
* AIDE Schedule: should show Weekly
* Password Policy: should show High
* SSH Login: should show keys-only
NEW QUESTION # 17
Task 9
The application team has requested several mission-critical VMs to be configured for disaster recovery. The remote site (when added) will not be managed by Prism Central. As such, this solution should be built using the Web Console.
Disaster Recovery requirements per VM:
Mkt01
RPO: 2 hours
Retention: 5 snapshots
Fin01
RPO: 15 minutes
Retention: 7 days
Dev01
RPO: 1 day
Retention: 2 snapshots
Configure a DR solution that meets the stated requirements.
Any objects created in this item must start with the name of the VM being protected.
Note: the remote site will be added later
To configure a DR solution that meets the stated requirements, you can follow these steps:
Log in to the Web Console of the source cluster where the VMs are running.
Click on Protection Domains on the left menu and click on Create Protection Domain.
Enter a name for the protection domain, such as PD_Mkt01, and a description if required. Click Next.
Select Mkt01 from the list of VMs and click Next.
Select Schedule Based from the drop-down menu and enter 2 hours as the interval. Click Next.
Select Remote Site from the drop-down menu and choose the remote site where you want to replicate the VM.
Click Next.
Enter 5 as the number of snapshots to retain on both local and remote sites. Click Next.
Review the protection domain details and click Finish.
Repeat the same steps for Fin01 and Dev01, using PD_Fin01 and PD_Dev01 as the protection domain names, and adjusting the interval and retention values according to the requirements.
NEW QUESTION # 18
Task 12
The application team is reporting performance degradation for a business-critical application that runs processes all day on Saturdays.
The team is requesting monitoring or processor, memory and storage utilization for the three VMs that make up the database cluster for the application: ORA01, ORA02 and ORA03.
The report should contain tables for the following:
At the cluster level, only for the current cluster:
The maximum percentage of CPU used
At the VM level, including any future VM with the prefix ORA:
The maximum time taken to process I/O Read requests
The Maximum percentage of time a VM waits to use physical CPU, out of the local CPU time allotted to the VM.
The report should run on Sundays at 12:00 AM for the previous 24 hours. The report should be emailed to appdev@cyberdyne.net when competed.
Create a report named Weekends that meets these requirements
Note: You must name the report Weekends to receive any credit. Any other objects needed can be named as you see fit. SMTP is not configured.
To create a report named Weekends that meets the requirements, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Report.
Enter Weekends as the report name and a description if required. Click Next.
Under the Custom Views section, select Data Table. Click Next.
Under the Entity Type option, select Cluster. Click Next.
Under the Custom Columns option, add the following variable: CPU Usage (%). Click Next.
Under the Aggregation option for CPU Usage (%), select Max. Click Next.
Under the Filter option, select Current Cluster from the drop-down menu. Click Next.
Click on Add to add this custom view to your report. Click Next.
Under the Custom Views section, select Data Table again. Click Next.
Under the Entity Type option, select VM. Click Next.
Under the Custom Columns option, add the following variables: Name, I/O Read Latency (ms), VM Ready Time (%). Click Next.
Under the Aggregation option for I/O Read Latency (ms) and VM Ready Time (%), select Max. Click Next.
Under the Filter option, enter ORA* in the Name field. This will include any future VM with the prefix ORA.
Click Next.
Under the Report Settings option, select Weekly from the Schedule drop-down menu and choose Sunday as the day of week. Enter 12:00 AM as the time of day. Enter appdev@cyberdyne.net as the Email Recipient.
Select CSV as the Report Output Format. Click Next.
Review the report details and click Finish.
NEW QUESTION # 19
An administrator wants to increase the performance of their Database virtual machine.
Database_VM has a database that is spread across three vDisks in the volume group Database_VM. The volume group is directly attached to the virtual machine. Previous performance analysis has indicated all storage requests are going to the same node. While this test environment has 1 node, the production environment has 3 nodes.
Configure the Volume Group Database_VM so that it's optimized for the user's VM and the production environment. The virtual machine has been powered off and moved to this test cluster for the maintenance work.
Here is the step-by-step solution to configure the Volume Group for optimized performance in the production environment.
This task is performed in Prism Central.
* From the main dashboard, navigate to Compute & Storage > Volume Groups.
* Find the Volume Group named Database_VM in the list.
* Select the checkbox next to Database_VM.
* Click the Actions dropdown menu and select Update.
* In the "Update Volume Group" dialog, scroll to the bottom of the "Basic Configuration" section.
* Find the checkbox labeled Enable Client Side Load Balancing and check it.
Note: This setting allows the iSCSI initiator within the guest VM to connect to all CVMs in the cluster, distributing the storage load from the three vDisks across all three nodes in the production environment instead of focusing all I/O on just one.
Click Save.
NEW QUESTION # 20
You will need to pass the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) exam to achieve the Nutanix NCM-MCI-6.10 certification. Due to extremely high competition, passing the Nutanix NCM-MCI-6.10 exam is not easy; however, possible. You can use DumpsKing products to pass the NCM-MCI-6.10 Exam on the first attempt. The Nutanix practice exam gives you confidence and helps you understand the criteria of the testing authority and pass the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) (NCM-MCI-6.10) exam on the first attempt.
Test NCM-MCI-6.10 Simulator Fee: https://www.dumpsking.com/NCM-MCI-6.10-testking-dumps.html
And you can feel the features of each version from the free demos of NCM-MCI-6.10 exam torrent, Now, there is good news for the IT workers who are preparing for the NCM-MCI-6.10 test, In addition, you will instantly download the new NCM-MCI-6.10 pdf study material after you complete the payment, Users using our NCM-MCI-6.10 study materials must be the first group of people who come into contact with new resources, In this way, you will be confident on the day of the NCM-MCI-6.10 Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) exam and solve all the Nutanix NCM-MCI-6.10 exam questions.
Many of those settings relate directly to functionality discussed in other chapters, The Wily Hacker, And you can feel the features of each version from the free demos of NCM-MCI-6.10 Exam Torrent.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) latest study dumps & NCM-MCI-6.10 simulated test torrentNow, there is good news for the IT workers who are preparing for the NCM-MCI-6.10 test, In addition, you will instantly download the new NCM-MCI-6.10 pdf study material after you complete the payment.
- Pass Guaranteed Quiz 2026 Accurate Nutanix New NCM-MCI-6.10 Exam Test 💅 Download NCM-MCI-6.10 for free by simply entering ➽ [url]www.pdfdumps.com 🢪 website 🥛Exam NCM-MCI-6.10 Dump[/url]
- Nutanix NCM-MCI-6.10 PDF Questions - Pass Your Exam With Ease 🪑 Easily obtain free download of ✔ NCM-MCI-6.10 ️✔️ by searching on { [url]www.pdfvce.com } 🤑NCM-MCI-6.10 Latest Study Questions[/url]
- NCM-MCI-6.10 Reliable Test Preparation 📂 New NCM-MCI-6.10 Real Exam 🧖 Latest NCM-MCI-6.10 Exam Notes 🌙 Simply search for NCM-MCI-6.10 for free download on ▛ [url]www.prepawayexam.com ▟ 🎣NCM-MCI-6.10 Pdf Pass Leader[/url]
- New Exam NCM-MCI-6.10 Braindumps 📂 New NCM-MCI-6.10 Real Exam 🎅 Exam NCM-MCI-6.10 Exercise 🗻 Search for NCM-MCI-6.10 and download exam materials for free through ➡ [url]www.pdfvce.com ️⬅️ 🏘NCM-MCI-6.10 Test Dates[/url]
- NCM-MCI-6.10 Pdf Pass Leader 🍧 Exam NCM-MCI-6.10 Labs 📥 NCM-MCI-6.10 Pdf Pass Leader 🤨 Easily obtain NCM-MCI-6.10 for free download through [ [url]www.pass4test.com ] 🦄NCM-MCI-6.10 Key Concepts[/url]
- Valid Nutanix New NCM-MCI-6.10 Exam Test Are Leading Materials - Free Download Test NCM-MCI-6.10 Simulator Fee 📥 Search for ☀ NCM-MCI-6.10 ️☀️ and obtain a free download on ⇛ [url]www.pdfvce.com ⇚ 🧑Latest NCM-MCI-6.10 Exam Notes[/url]
- 100% Pass NCM-MCI-6.10 - Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) CValid New Exam Test 📅 Enter ▷ [url]www.examcollectionpass.com ◁ and search for ▷ NCM-MCI-6.10 ◁ to download for free 👄Sample NCM-MCI-6.10 Questions Pdf[/url]
- [url=https://www.miasmat.no/?s=Demo%20NCM-MCI-6.10%20Test%20%f0%9f%98%89%20NCM-MCI-6.10%20Reliable%20Test%20Preparation%20%f0%9f%94%ba%20NCM-MCI-6.10%20Key%20Concepts%20%f0%9f%a7%82%20Easily%20obtain%20free%20download%20of%20%e3%80%8a%20NCM-MCI-6.10%20%e3%80%8b%20by%20searching%20on%20[%20www.pdfvce.com%20]%20%f0%9f%95%a4Sample%20NCM-MCI-6.10%20Questions%20Pdf]Demo NCM-MCI-6.10 Test 😉 NCM-MCI-6.10 Reliable Test Preparation 🔺 NCM-MCI-6.10 Key Concepts 🧂 Easily obtain free download of NCM-MCI-6.10 by searching on [ www.pdfvce.com ] 🕤Sample NCM-MCI-6.10 Questions Pdf[/url]
- NCM-MCI-6.10 Pdf Pass Leader ✉ NCM-MCI-6.10 Pdf Pass Leader 😊 Trusted NCM-MCI-6.10 Exam Resource 🧨 Search for NCM-MCI-6.10 and download it for free immediately on ➥ [url]www.exam4labs.com 🡄 🏄Exam NCM-MCI-6.10 Dump[/url]
- Latest NCM-MCI-6.10 Exam Notes 🦙 Exam NCM-MCI-6.10 Dump 😥 Trusted NCM-MCI-6.10 Exam Resource 🥩 Download ⮆ NCM-MCI-6.10 ⮄ for free by simply searching on [url]www.pdfvce.com 🤒NCM-MCI-6.10 Reliable Test Preparation[/url]
- New NCM-MCI-6.10 Exam Test - Realistic 2026 Nutanix Test Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Simulator Fee 🤬 Enter [url]www.examcollectionpass.com and search for ▶ NCM-MCI-6.10 ◀ to download for free 🔨NCM-MCI-6.10 Reliable Test Preparation[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, justpaste.me, kemono.im, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, writeablog.net, www.stes.tyc.edu.tw, Disposable vapes
