2V0-16.25 Exam Cram Review, 2V0-16.25 Training Solutions
101
Posted at 1/29/2026 22:03:37      View119 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New 2V0-16.25 dumps are available on Google Drive shared by ITExamDownload: https://drive.google.com/open?id=1sHmev5cSYvJG7lmdsXCywYWeItVYAzRt
We think of providing the best services as our obligation. So we have patient colleagues offering help 24/7 and solve your problems about 2V0-16.25 practice materials all the way. We have considerate services as long as you need us. Besides, to fail while trying hard is no dishonor. If you fail the exam with our 2V0-16.25 Study Guide unfortunately, we will switch other versions or give your full money back assuming that you fail this time, and prove it with failure document. Do not underestimate your ability, we will be your strongest backup while you are trying with our 2V0-16.25 actual tests.
At present, our 2V0-16.25 study guide gains popularity in the market. The quality of our training material is excellent. After all, we have undergone about ten years development. Never has our 2V0-16.25 practice test let customers down. Although we also face many challenges and troubles, our company get over them successfully. If you are determined to learn some useful skills, our 2V0-16.25 practice material will be your good assistant. Then you will seize the good chance rather than others. Time and tide wait for no man. You cannot depend on others to change your destiny.
Valid free 2V0-16.25 exam dumps collection - VMware 2V0-16.25 exam testsIf you want to be a leader in some industry, you have to continuously expand your knowledge resource. Our ITExamDownload always updates the exam dumps and the content of our exam software in order to ensure the 2V0-16.25 exam software that you have are the latest and comprehensive version. No matter which process you are preparing for 2V0-16.25 Exam, our exam software will be your best helper. As the collection and analysis of our 2V0-16.25 exam materials are finished by our experienced and capable IT elite.
VMware vSphere Foundation 9.0 Administrator Sample Questions (Q53-Q58):NEW QUESTION # 53
An administrator is tasked with enabling a Supervisor in a VMware vSphere Foundation (VVF) environment using vSphere networking and the Foundation Load Balancer. The vSAN-backed cluster has been configured with a vSphere Distributed Switch.
Which two actions must the administrator perform when enabling a Supervisor using vSphere networking?
(Choose two.)
  • A. Provide a static IP address range for the Supervisor control plane VMs.
  • B. Enable the VM Service before deploying the Supervisor.
  • C. Select a vSphere namespace template to define initial namespace limits.
  • D. Assign a vSphere Distributed Switch and a corresponding port group.
  • E. Configure a Tier-0 Gateway with BGP or static routing.
Answer: A,D
When enabling aSupervisor Cluster in vSphere with Tanzuusing vSphere networking and the Foundation Load Balancer:
* You must provide astatic IP rangefor the Supervisor control plane VMs so they can be deployed with dedicated addresses. (B)
* You must assign avSphere Distributed Switch (VDS)with an appropriateport groupfor Supervisor networking. (E) Other options:
* A. Namespace template# Optional after Supervisor is enabled, not required at setup.
* C. Tier-0 Gateway# Applies to NSX networking, not vSphere networking.
* D. VM Service# Enabled after Supervisor, not a prerequisite.
VMware vSphere 9.0 -Enable a Supervisor Cluster with vSphere Networking VMware Docs: Supervisor Setup Networking Requirements
NEW QUESTION # 54
An administrator is tasked with creating dashboards to track system performance metrics for both the IT department and executive leadership. The requirements for this task are:
* The IT team needs detailed, technical metrics across all of the infrastructure components in the environment.
* The executives need high-level summaries that highlight Key Performance Indicators (KPIs) across the environment in a single dashboard.
* The executives need to access the dashboard via a shared URL.
* The dashboards must be capable of being shared, and always display the latest data collected when the link is used.
What two steps should the administrator perform to meet these requirements? (Choose two.)
  • A. Create a Custom dashboard in VCF Operations for Logs to display the Key Performance Indicators.
  • B. Use Out-of-the-Box dashboards in VCF Automation to highlight Key Performance Indicators.
  • C. Use Out-of-the-Box dashboards in VCF Operations to display detailed technical metrics.
  • D. Create a Custom dashboard in VCF Operations to highlight Key Performance Indicators.
To satisfy both IT and executive requirements:
* IT team# Needsdetailed technical metrics, which are available throughOut-of-the-Box dashboards in VCF Operations. (A)
* Executives# Need acustom KPI-focused dashboard, with summaries and high-level visibility. This can be shared via aURL linkthat always shows the latest data. (B) Why others are incorrect:
* C. Custom dashboard in VCF Operations for Logs# Logs are not KPI-focused performance metrics.
* D. Out-of-the-Box dashboards in VCF Automation# VCF Automation is not designed for KPI reporting.
VMware Cloud Foundation 9.0.2 -Dashboards and KPI Tracking
VMware Docs: [Custom and Out-of-the-Box Dashboards in vRealize Operations]
NEW QUESTION # 55
An administrator needs to ensure that only specific users can manage the virtual machines (VM) in a specific VMware vCenter folder.
Which three steps are required to accomplish this? (Choose three.)
  • A. Assign the new role to the appropriate users/groups.
  • B. Create a datastore cluster.
  • C. Apply the role to the specific vCenter folder.
  • D. Create a new role in vCenter with VM management permissions.
  • E. Add the identity source to vCenter.
Answer: A,C,D
To ensure that only specific users can manage VMs in a specific VMware vCenter folder, the following three steps are required:
* Create a new role in vCenter with VM management permissions(Answer B):You must define a custom role tailored to managing VMs, which includes permissions such as powering on/off VMs, editing VM settings, and accessing consoles. This role must include the appropriate privileges under the
"Virtual machine" category in vCenter permissions.
* Apply the role to the specific vCenter folder(Answer C):The custom role needs to be applied directly to the target vCenter folder. This enables scope-based access control, where permissions are applied only to VMs within that folder.
* Assign the new role to the appropriate users/groups(Answer A):After creating the role and applying it to the folder, the role must be associated with the correct users or groups. This step uses the vCenter Server's identity source integration to assign roles.
* D. Add the identity source to vCenter:This is a prerequisite step for any role assignment but is not directly required in this specific scenario if the identity source is already configured.
* E. Create a datastore cluster:This is unrelated to managing VM access. Datastore clusters pertain to storage management and are not involved in user permissions or role assignments.
VMware vSphere 9.0 Documentation # Role-based Access Control
VMware Docs: vSphere Permissions and User Management
VMware vSphere 9.0 PDF, section on vCenter Server Permissions Management.
NEW QUESTION # 56
What is the purpose of a port group on a Distributed Switch?
  • A. To define a logical grouping of virtual ports for network traffic segmentation.
  • B. To allocate CPU and memory resources to virtual machines.
  • C. To enable vSAN connectivity.
  • D. To manage storage I/O performance.
Aport groupon avSphere Distributed Switch (VDS)provides:
* Logical grouping of virtual ports.
* Definesnetwork policiessuch as VLAN IDs, traffic shaping, security policies, and teaming.
* Used for segmenting traffic types (vMotion, vSAN, management, VM traffic).
Other options:
* A. Enable vSAN connectivity# Achieved by assigning vSAN traffic to a port group, but not the main definition.
* B. Allocate CPU/memory resources# Done via resource pools, not port groups.
* D. Manage storage I/O performance# Done with Storage I/O Control, not port groups.
VMware vSphere 9.0 -vSphere Networking Basics
VMware Docs: Port Groups on Distributed Switch
NEW QUESTION # 57
An administrator is tasked with deploying a VMware Cloud Foundation (VCF) Operations for Logs appliance into vSphere Foundation.
After downloading the .ova, which component does the administrator use to deploy the file?
  • A. VCF Operations
  • B. VCF Automation
  • C. vSphere Client
  • D. VCF Fleet Management
To deploy theVCF Operations for Logs OVA appliance:
* ThevSphere Clientis used to deploy.ovaand.ovftemplates directly into a vCenter environment.
* After deployment, the appliance can be configured and integrated with VCF.
Other options:
* A. VCF Fleet Management# Used for multi-instance management, not OVA deployment.
* C. VCF Automation# Provides automation workflows, not appliance deployment.
* D. VCF Operations# Monitoring and analytics platform, not used for OVA installs.
VMware Cloud Foundation 9.0 -Deploying VCF Operations for Logs Appliance VMware Docs: Deploy OVF/OVA Templates Using vSphere Client
NEW QUESTION # 58
If you are ready for the exam for a long time, but lack of a set of suitable 2V0-16.25 learning materials, I will tell you that you are so lucky to enter this page. We are such 2V0-16.25 exam questions that you can use our products to prepare the exam and obtain your dreamed 2V0-16.25 certificates. We all know that if you desire a better job post, you have to be equipped with appropriate professional quality and an attitude of keeping forging ahead. Our 2V0-16.25 exam questions will be your best ally to get what you wanted.
2V0-16.25 Training Solutions: https://www.itexamdownload.com/2V0-16.25-valid-questions.html
In a word, the three different versions of our 2V0-16.25 test torrent will help you pass the 2V0-16.25 exam, VMware 2V0-16.25 Exam Cram Review For instance, you can closely concentrate your mind and learn more effectively, We provide authentic braindumps for 2V0-16.25 certification exam, The moment you make a purchase for our VMware 2V0-16.25 exam prep, our staff will send our 2V0-16.25 exam torrent: VMware vSphere Foundation 9.0 Administrator to your mail boxes so as to help you get early preparation for your exams, One year free update: You will enjoy one year update freely without any extra charge after you buy our 2V0-16.25 exam dumps.
Configuration Summary for Mandrake, To progress, you've got to 2V0-16.25 be able to understand the business problem, the industry implications and have somewhat of an eye to the future, Thorne said.
2V0-16.25 dumps torrent & 2V0-16.25 exam VCE & 2V0-16.25 VCE PDFIn a word, the three different versions of our 2V0-16.25 Test Torrent will help you pass the 2V0-16.25 exam, For instance, you can closely concentrate your mind and learn more effectively.
We provide authentic braindumps for 2V0-16.25 certification exam, The moment you make a purchase for our VMware 2V0-16.25 exam prep, our staff will send our 2V0-16.25 exam torrent: VMware vSphere Foundation 9.0 Administrator to your mail boxes so as to help you get early preparation for your exams.
2026 Latest ITExamDownload 2V0-16.25 PDF Dumps and 2V0-16.25 Exam Engine Free Share: https://drive.google.com/open?id=1sHmev5cSYvJG7lmdsXCywYWeItVYAzRt
Posted at 2/4/2026 01:58:33        Only Author  2#
Your article was such a breath of fresh air, thank you! Frequent ASVAB Updates offers high-quality materials without any charge.
