¡¾General¡¿
2026 DP-300¨C100% Free Reliable Study Plan | Pass-Sure DP-300 Cert Exam
Posted at 1/29/2026 23:20:10
View£º155
Replies£º0
BONUS!!! Download part of TestPassed DP-300 dumps for free: https://drive.google.com/open?id=17RFO-9xXTM_oIx7gSjh_qllmdzrIDIWD
We believe that the greatest value of DP-300 training guide lies in whether it can help candidates pass the examination, other problems are secondary. And at this point, our DP-300 study materials do very well. We can proudly tell you that the passing rate of our DP-300 Exam Questions is close to 100 %. That is to say, almost all the students who choose our products can finally pass the exam. What are you waiting for? Just rush to buy our DP-300 learning braindumps!
Microsoft DP-300 exam is a part of the Azure certification path, which includes other certification exams such as AZ-900 (Azure Fundamentals), AZ-104 (Microsoft Azure Administrator), and AZ-204 (Developing Solutions for Microsoft Azure). Earning the DP-300 Certification demonstrates that the candidate has the necessary skills to administer and manage relational databases on Microsoft Azure, making them a valuable asset to any organization that uses cloud-based database solutions.
Reliable DP-300 Reliable Study Plan Provide Prefect Assistance in DP-300 PreparationNo doubt the Microsoft DP-300 certification exam is one of the most difficult TestPassed certification exams in the modern TestPassed world. This DP-300 exam always gives a tough time to their candidates. The TestPassed understands this challenge and offers real, valid, and top-notch Microsoft DP-300 Exam Dumps in three different formats. All these three DP-300 exam questions formats are easy to use and compatible with all devices, operating systems, and web browsers.
Passing the DP-300 exam requires a deep understanding of Azure SQL databases and the ability to perform various administrative tasks. The Microsoft Certified: Azure Database Administrator Associate certification is highly valued in the industry and can help professionals advance their careers in database administration. Overall, the DP-300 Exam is an excellent opportunity for professionals to validate their skills and knowledge in administering relational databases on Microsoft Azure.
Microsoft Administering Relational Databases on Microsoft Azure Sample Questions (Q288-Q293):NEW QUESTION # 288
You need to configure user authentication for the SERVER1 databases. The solution must meet the security and compliance requirements.
1 - Create an Azure AD administrator for the logical server
2 - Create contained database users
3 - Connect to the database by using an Azure AD account
https://docs.microsoft.com/en-us ... cation-aad-overview
Topic 1, Litware
Existing Environment
Network Environment
The manufacturing and research datacenters connect to the primary datacenter by using a VPN.
The primary datacenter has an ExpressRoute connection that uses both Microsoft peering and private peering. The private peering connects to an Azure virtual network named HubVNet.
Identity Environment
Litware has a hybrid Azure Active Directory (Azure AD) deployment that uses a domain named litwareinc.com. All Azure subscriptions are associated to the litwareinc.com Azure AD tenant.
Database Environment
The sales department has the following database workload:
An on-premises named SERVER1 hosts an instance of Microsoft SQL Server 2012 and two 1-TB databases.
A logical server named SalesSrv01A contains a geo-replicated Azure SQL database named SalesSQLDb1. SalesSQLDb1 is in an elastic pool named SalesSQLDb1Pool. SalesSQLDb1 uses database firewall rules and contained database users.
An application named SalesSQLDb1App1 uses SalesSQLDb1.
The manufacturing office contains two on-premises SQL Server 2016 servers named SERVER2 and SERVER3. The servers are nodes in the same Always On availability group. The availability group contains a database named ManufacturingSQLDb1 Database administrators have two Azure virtual machines in HubVnet named VM1 and VM2 that run Windows Server 2019 and are used to manage all the Azure databases.
Licensing Agreement
Litware is a Microsoft Volume Licensing customer that has License Mobility through Software Assurance.
Current Problems
SalesSQLDb1 experiences performance issues that are likely due to out-of-date statistics and frequent blocking queries.
Requirements
Planned Changes
Litware plans to implement the following changes:
Implement 30 new databases in Azure, which will be used by time-sensitive manufacturing apps that have varying usage patterns. Each database will be approximately 20 GB.
Create a new Azure SQL database named ResearchDB1 on a logical server named ResearchSrv01. ResearchDB1 will contain Personally Identifiable Information (PII) data.
Develop an app named ResearchApp1 that will be used by the research department to populate and access ResearchDB1.
Migrate ManufacturingSQLDb1 to the Azure virtual machine platform.
Migrate the SERVER1 databases to the Azure SQL Database platform.
Technical Requirements
Litware identifies the following technical requirements:
Maintenance tasks must be automated.
The 30 new databases must scale automatically.
The use of an on-premises infrastructure must be minimized.
Azure Hybrid Use Benefits must be leveraged for Azure SQL Database deployments.
All SQL Server and Azure SQL Database metrics related to CPU and storage usage and limits must be analyzed by using Azure built-in functionality.
Security and Compliance Requirements
Litware identifies the following security and compliance requirements:
Store encryption keys in Azure Key Vault.
Retain backups of the PII data for two months.
Encrypt the PII data at rest, in transit, and in use.
Use the principle of least privilege whenever possible.
Authenticate database users by using Active Directory credentials.
Protect Azure SQL Database instances by using database-level firewall rules.
Ensure that all databases hosted in Azure are accessible from VM1 and VM2 without relying on public endpoints.
Business Requirements
Litware identifies the following business requirements:
Meet an SLA of 99.99% availability for all Azure deployments.
Minimize downtime during the migration of the SERVER1 databases.
Use the Azure Hybrid Use Benefits when migrating workloads to Azure.
Once all requirements are met, minimize costs whenever possible.
NEW QUESTION # 289
You have a SQL Server on Azure Virtual Machines instance that hosts a 10-TB SQL database named DB1.
You need to identify and repair any physical or logical corruption in DB1. The solution must meet the following requirements:
* Minimize how long it takes to complete the procedure.
* Minimize data loss.
How should you complete the command? To answer, select the appropriate options in the answer area NOTE:
Each correct selection is worth one point.
NEW QUESTION # 290
You plan to migrate on-premises Microsoft SQL Server databases to Azure.
You need to identify which deployment and resiliency options meet the following requirements:
* Support user-initiated backups.
* Support multiple automatically replicated instances across Azure regions.
* Minimize administrative effort to implement and maintain business continuity.
What should you identify? To answer, select the appropriate options in the answer area.
Box 1: SQL Server on Azure VMs
SQL Server on Azure Virtual Machines can take advantage of Automated Backup, which regularly creates backups of your database to blob storage. You can also manually use this technique.
Box 2: Active geo-replication
Geo-replication for services such as Azure SQL Database and Cosmos DB will create secondary replicas of your data across multiple regions. While both services will automatically replicate data within the same region, geo-replication protects you against a regional outage by enabling you to fail over to a secondary region.
https://docs.microsoft.com/en-us ... r-on-azure-vm-iaas- what-is-overview
https://docs.microsoft.com/en-us ... re-resiliency-azure
NEW QUESTION # 291
You have an Azure Data Lake Storage Gen2 container.
Data is ingested into the container, and then transformed by a data integration application. The data is NOT modified after that. Users can read files in the container but cannot modify the files.
You need to design a data archiving solution that meets the following requirements:
New data is accessed frequently and must be available as quickly as possible.
Data that is older than five years is accessed infrequently but must be available within one second when requested.
Data that us older than seven years is NOT accessed. After seven years, the data must be persisted at the lowest cost possible.
Costs must be minimized while maintaining the required availability.
How should you manage the data? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... -blob-storage-tiers
NEW QUESTION # 292
You have an Azure subscription.
You need to deploy a logical SQL server by using an Azure Resource Manager (ARM) template. The solution must ensure that the server will allow inbound connectivity from any Azure resource.
How should you complete the template? To answer, select the appropriate options in the answer area NOTE: Each correct selection is worth one point.
NEW QUESTION # 293
DP-300 Cert Exam: https://www.testpassed.com/DP-300-still-valid-exam.html
- Microsoft DP-300 Desktop-Based Practice Program 🎬 Go to website ▷ [url]www.validtorrent.com ◁ open and search for ➥ DP-300 🡄 to download for free 📏DP-300 Exam Cram Questions[/url]
- DP-300 Exam Book 💜 DP-300 Exam Cram Questions 🚋 Certification DP-300 Book Torrent 😹 Search for ▛ DP-300 ▟ and obtain a free download on ➥ [url]www.pdfvce.com 🡄 ⛄DP-300 Latest Dumps Ppt[/url]
- DP-300 Practical Information 🐭 Certification DP-300 Book Torrent 👖 DP-300 New Exam Camp ✒ Go to website ➠ [url]www.pass4test.com 🠰 open and search for ✔ DP-300 ️✔️ to download for free 🧤DP-300 Accurate Study Material[/url]
- DP-300 Reliable Test Blueprint 🍟 Test DP-300 Objectives Pdf 👆 VCE DP-300 Exam Simulator 👮 Search for ⏩ DP-300 ⏪ and download it for free on ⇛ [url]www.pdfvce.com ⇚ website 💦Latest DP-300 Exam Camp[/url]
- Certification DP-300 Book Torrent 🐕 Formal DP-300 Test 🏉 DP-300 Exam Cram Questions 🆒 Search for ¡° DP-300 ¡± and download it for free immediately on { [url]www.troytecdumps.com } 🥮DP-300 New Exam Camp[/url]
- Certification DP-300 Book Torrent 💞 Certification DP-300 Book Torrent 🤐 DP-300 Reliable Braindumps ⛽ Open ☀ [url]www.pdfvce.com ️☀️ enter ¡° DP-300 ¡± and obtain a free download 🕞Authorized DP-300 Exam Dumps[/url]
- Reliable DP-300 Study Plan 😒 DP-300 Latest Exam Notes 🦙 DP-300 Exam Cram Questions 🎶 Go to website ➥ [url]www.validtorrent.com 🡄 open and search for ¡° DP-300 ¡± to download for free 📔Reliable DP-300 Study Plan[/url]
- DP-300 Accurate Study Material 🚏 DP-300 Reliable Braindumps 🏴 DP-300 Exam Cram Questions 🧯 Go to website ✔ [url]www.pdfvce.com ️✔️ open and search for { DP-300 } to download for free 🛀Certification DP-300 Book Torrent[/url]
- Pass Guaranteed 2026 DP-300: Pass-Sure Administering Relational Databases on Microsoft Azure Reliable Study Plan 🥗 Immediately open [ [url]www.torrentvce.com ] and search for ☀ DP-300 ️☀️ to obtain a free download 🆓DP-300 New Exam Camp[/url]
- DP-300 New Exam Camp 🐉 Formal DP-300 Test 🤤 DP-300 Latest Exam Notes ⛺ Enter ▷ [url]www.pdfvce.com ◁ and search for ☀ DP-300 ️☀️ to download for free 🛳DP-300 Exam Cram Questions[/url]
- DP-300 New Exam Camp ⚠ DP-300 Exam Learning 🤏 DP-300 Practical Information 👉 Simply search for ➥ DP-300 🡄 for free download on ➽ [url]www.dumpsquestion.com 🢪 🚼Test DP-300 Objectives Pdf[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, kaeuchi.jp, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of TestPassed DP-300 dumps from Cloud Storage: https://drive.google.com/open?id=17RFO-9xXTM_oIx7gSjh_qllmdzrIDIWD
