[General] Salesforce Analytics-Con-301 Certification Test Questions & Analytics-Con-30
98
General Salesforce Analytics-Con-301 Certification Test Questions & Analytics-Con-30
Posted at 1/30/2026 01:23:36      View150 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Analytics-Con-301 dumps are available on Google Drive shared by PassCollection: https://drive.google.com/open?id=1HgUtcraz3rNCCXR5RiTX1_PeOzobL7Lo
Salesforce Analytics-Con-301 actual test questions have effective high-quality content and cover many the real test questions. Salesforce Analytics-Con-301 study guide is the best product to help you achieve your goal. If you pass exam and obtain a certification with our Salesforce Analytics-Con-301 Study Materials, you can apply for satisfied jobs in the large enterprise and run for senior positions with high salary and high benefits.
Salesforce Analytics-Con-301 Exam Syllabus Topics:
  • Business Analysis: This section of the exam measures skills of Tableau Consultants focusing on evaluating the current state of analytics within an organization. It covers mapping business needs to Tableau capabilities, translating analytical requirements to best practices in Tableau, and recommending appropriate deployment options like Tableau Server or Tableau Cloud. It also includes evaluating existing data structures for supporting business needs and identifying performance risks and opportunities.
  • IT Management: This domain measures skills related to managing Tableau environments. It includes planning server upgrades, recommending deployment solutions (on-premise or cloud), and ensuring alignment between technical and business requirements for analytics infrastructure. It also involves troubleshooting and optimizing system performance relevant to Tableau Server and Cloud deployments.
  • Data Management: This part focuses on establishing governance and support for published content. Tableau Consultants are expected to manage data security, publish and maintain data sources and workbooks, and oversee content access. It includes applying governance best practices, using metadata APIs, and supporting administration functions to maintain data integrity and accessibility.
  • Business Consulting: For Tableau Consultants, this section involves designing and troubleshooting calculations and workbooks to meet advanced analytical use cases. It covers selecting appropriate chart types, applying Tableaus order of operations in calculations, building interactivity into dashboards, and optimizing workbook performance by resolving resource-intensive queries and other design-related issues.
100% Pass Quiz Salesforce - Analytics-Con-301 - Valid Salesforce Certified Tableau Consultant Certification Test QuestionsYou still can pass the exam with our help. The key point is that you are serious on our Salesforce Analytics-Con-301 exam questions and not just kidding. Our Analytics-Con-301 practice engine can offer you the most professional guidance, which is helpful for your gaining the certificate. And our Salesforce Certified Tableau Consultant Analytics-Con-301 learning guide contains the most useful content and keypoints which will come up in the real exam.
Salesforce Certified Tableau Consultant Sample Questions (Q34-Q39):NEW QUESTION # 34
A client is using Tableau to visualize data by leveraging security token-based credentials. Suddenly, sales representatives in the field are reporting that they cannot access the necessary workbooks. The client cannot recreate the error from their offices, but they have seen screenshots from the field agents. The client wants to restore functionality for the field agents with minimal disruption.
Which step should the consultant recommend to accomplish the client's goal?
  • A. Renew the security token via the Data Connection on Tableau Server.
  • B. Ask the workbook owners to republish the workbooks to refresh the security token.
  • C. Ensure that "Allow Refresh Access" was checked when the data source was published.
  • D. Change the data source permissions for the connection to "Prompt User."
When field agents are unable to access workbooks due to issues with security token-based credentials, the most immediate and least disruptive solution is to renew the security token. This can be done through the Data Connection settings on Tableau Server. Renewing the token will restore access for the field agents without requiring them to take any action or affecting other users.
References: The use of personal access tokens (PATs) in Tableau and the procedure for renewing them are documented in Tableau's official resources. It is noted that PATs are long-lived authentication tokens that can be revoked and renewed to manage access securely1. Additionally, there have been discussions in the Tableau Community regarding issues with concurrent PAT access, which further supports the need to manage tokens effectively2.
NEW QUESTION # 35
A client currently has a workbook with the table shown below.
Which method will produce the output for the Total Sales Value field for all the categories shown in the table?
  • A. MAX() Function
  • B. A Window Function
  • C. Level of Detail (LOD) Calculation
  • D. Quick Table Calculation
To calculate the Total Sales Value for all categories as displayed in the table, an LOD expression is ideal. An LOD calculation in Tableau allows you to compute values at the data level that is different from the view level. In this case, since the Total Sales Value appears consistent across different sub-categories within each category, an LOD expression can be used to fix the Total Sales Value irrespective of the sub-category detail. Here's how to set it up:
Go to the Calculations area by right-clicking in the data pane and selecting "Create Calculated Field".
Enter a name for the calculation, such as "Total Sales Value".
Enter the LOD expression: { FIXED [Category] : SUM([Sales]) }. This calculation fixes the total sales to the category level, effectively summing sales for all sub-categories within each category, irrespective of how the data is broken down in the view.
Drag this new calculated field into your visualization alongside the existing measures.
This method ensures that the Total Sales Value reflects the total for each category across all its sub-categories, matching the uniform values shown across different rows for each category in your table.
References
The explanation utilizes the concept of Level of Detail calculations in Tableau, which allows for advanced aggregations independent of the view level details. This concept is covered extensively in Tableau's official documentation and relevant training materials such as Tableau's online help resources.
NEW QUESTION # 36
A company has a data source for sales transactions. The data source has the following characteristics:
. Millions of transactions occur weekly.
. The transactions are added nightly.
. Incorrect transactions are revised every week on Saturday.
* The end users need to see up-to-date data daily.
A consultant needs to publish a data source in Tableau Server to ensure that all the transactions in the data source are available.
What should the consultant do to create and publish the data?
  • A. Publish an incremental extract refresh every day and perform a full extract refresh every Saturday.
  • B. Publish a live connection to Tableau Server.
  • C. Publish an incremental extract refresh every day and publish a secondary data set containing data revisions.
  • D. Publish an incremental refresh every Saturday.
Given the need for up-to-date data on a daily basis and weekly revisions, the best approach is to use an incremental extract refresh daily to update the data source with new transactions. On Saturdays, when incorrect transactions are revised, a full extract refresh should be performed to incorporate all revisions and ensure the data's accuracy. This strategy allows end users to have access to the most current data throughout the week while also accounting for any necessary corrections12.
References: The solution is based on best practices for managing data sources in Tableau Server, which recommend using incremental refreshes for frequent updates and full refreshes when significant changes or corrections are made to the data12.
NEW QUESTION # 37
A customer wants to leverage generative AI capabilities. The customer is currently on Tableau Server 2023.1.
How is the customer able to leverage generative AI in Tableau?
  • A. Perform API calls from Tableau Server to sandboxed extensions hosted by Tableau.
  • B. Upgrade Tableau Server from 2023.1 to the latest version.
  • C. Migrate Tableau Server to Tableau Cloud.
  • D. Use a dashboard accelerator from Tableau Exchange.
Tableau's official generative AI capability-Tableau Pulse and Einstein-powered Tableau AI features- are available only on Tableau Cloud, not Tableau Server.
Key Tableau facts:
* Tableau Server (any version, including new ones) does not provide generative AI capabilities.
* Tableau Cloud includes AI features such as:
* Tableau Pulse
* Einstein Copilot
* Natural language questions
* Automated insights
* Upgrading Tableau Server does not provide generative AI.
* Extensions and accelerators do not enable AI functionality.
Therefore, the customer must migrate from Tableau Server to Tableau Cloud to leverage generative AI.
* Tableau AI/Pulse documentation stating availability only in Tableau Cloud.
* Feature comparison charts showing generative AI unavailable on Tableau Server.
NEW QUESTION # 38
A client has a Tableau Cloud deployment. Currently, dashboards are available only to internal users.
The client needs to embed interactive Tableau visualizations on their public website.
Data is < 5,000 rows, updated infrequently via manual refresh.
Cost is a priority.
Which product should the client use?
  • A. Tableau Cloud licensed per user
  • B. Tableau Embedded Analytics
  • C. Tableau Public
  • D. Tableau Server licensed per core
Tableau documentation explains:
Tableau Public
* Free platform.
* Allows public sharing and embedding of fully interactive dashboards.
* Ideal for small datasets and infrequent updates.
* Does not require user-based licensing.
* Embedding is unrestricted because all content is publicly visible.
This perfectly matches the scenario:
# Public-facing website
# Low cost priority
# Small dataset
# Manual, infrequent updates
A). Tableau Cloud (per user)
* Requires paid licenses.
* Does not allow unrestricted public embedding without expensive add-ons.
* Designed for secure internal use, not public web-wide embedding.
C). Tableau Embedded Analytics
* A paid embedding solution requiring proper licensing.
* Designed for large-scale, secure, programmatic embedding - too costly for this use case.
D). Tableau Server (per core)
* Requires server infrastructure & licensing.
* Far more expensive than Tableau Public.
Thus, Tableau Public is the correct, cost-effective solution.
* Tableau Public documentation describing free embedding for public websites.
* Comparison guides showing Tableau Cloud/Server require licensing for embedding.
* Public vs. Enterprise Tableau deployment best practices.
NEW QUESTION # 39
Our Analytics-Con-301 practice braindumps have striking achievements up to now with passing rate up to 98-100 percent. Because we clearly understand your exam hinge on the quality of our Analytics-Con-301 exam prep. So we understand your worries. Some immoral companies may cash in on you at this moment by making use of your worries. On the contrary, we admire your willpower and willing to offer the most sincere help. To have our Analytics-Con-301 study engjne, this decision of you may bring stinking achievements in the future.
Analytics-Con-301 Valid Dumps Files: https://www.passcollection.com/Analytics-Con-301_real-exams.html
What's more, part of that PassCollection Analytics-Con-301 dumps now are free: https://drive.google.com/open?id=1HgUtcraz3rNCCXR5RiTX1_PeOzobL7Lo
