AD0-E117 Reliable Exam Answers | Test AD0-E117 Engine
Posted at 1/30/2026 19:04:07
BTW, DOWNLOAD part of Pass4Test AD0-E117 dumps from Cloud Storage: https://drive.google.com/open?id=11Z9RNSRt_m3Bzx3gj_t5fJv-brpeok3G
Do you want to spend the least time to pass your exam? If you do, then we will be your bets choice. AD0-E117 training materials are compiled by experienced experts who are quite familiar with the exam center, so the quality can be guaranteed. In addition, AD0-E117 exam materials contain most of the knowledge points for the exam, and you can have a good command of these knowledge points through practicing. In order to strengthen your confidence for the AD0-E117 Exam Braindumps, we are pass guarantee and money back guarantee if you fail to pass the exam. The money will be returned to your payment account.
Adobe AD0-E117 exam is designed to test the skills and knowledge of professionals who want to become Adobe Experience Manager (AEM) Architect Masters. AEM is a leading digital experience platform that helps organizations to create and manage digital content across multiple channels. AD0-E117 exam is intended for experienced AEM professionals who want to demonstrate their mastery of the platform's architecture and design principles.
Adobe AD0-E117 certification exam is designed for those who have a strong understanding of Adobe Experience Manager (AEM) and are looking to enhance their skills in architecture and design. AD0-E117 Exam evaluates the candidates' knowledge in designing and architecting AEM solutions that meet the business requirements. Adobe Experience Manager Architect Master certification exam equips the candidates with the necessary skills and knowledge to design, implement, and optimize AEM solutions.
Test AD0-E117 Engine & Valid AD0-E117 Exam SimsYou have to upgrade your skills and knowledge then you will be in a position to compete in the modern world. The Adobe AD0-E117 certification offers a great way to learn new in-demand skills and upgrade your knowledge level. To do this you just need to enroll in the AD0-E117 Exam and put in your efforts to pass this career booster AD0-E117 certification exam.
Adobe Experience Manager Architect Master Sample Questions (Q71-Q76):NEW QUESTION # 71
A client is using AEM and wants to make sure they are managing their configurations correctly. Refer to the following requirements:
The client has multiple brands that they will be hosting on a single AEM implementation The client wants to reuse as much between brands as possible Each brand needs to be able to override the default values for items like contact us information The client plans to support multiple languages in multiple regions for each brand Each brand/language/region combination will have its own set of content approvers used as part of a custom workflow Which approach should an Architect recommend to manage the client's configurations for AEM?
- A. Use OSGi Configuration to handle configuration overrides by brand. Create a new workflow for each brand/language/region combination for content approval.
- B. Use Context-aware configurations to manage configuration overrides and approval group by brand/language/region combination.
- C. Use OSGi to manage approval group and provide default contact us information by runmode.
- D. Use the OOTB Configuration Browser to set configuration defaults and approval group by brand/language/region combination.
NEW QUESTION # 72
A customer is migrating from their On-Premises AEM 6.4 instances to AEM as a Cloud Service. Next to the required code refactoring, a content migration of approximately 100,000 pages needs to be performed. The customer wants the content freeze period to be limited so that editors can continue to do content actions as long as possible.
Which two recommendations should the Architect make for the migration of the content pages? (Choose two.)
- A. Ensure sufficient storage space on the On-Premise AEM instance
- B. Migrate the content using the Content Transfer Tool
- C. Upscale the memory of the On-Premise AEM instance
- D. Migrate the content using Lazy Content Migration approach
- E. Migrate content deltas using a query-based packaging tool
NEW QUESTION # 73
A customer is about to go live with a new website on AEM on prem. The DNS (www.domam.com) already points to the load balancer of the AEM environment and final sanity checks are being performed. The website was tested in lower environments without SSL On production, the website is served over https. During sanity testing, all requests result in a 404.
While investigating this issue, an Architect determines the following:
* The requests land on port 443 on the load balancer where SSL is terminated and an HTTP header X-Forwarded-Proto is set
* The website Sling Mapping is created beneath /etc/map/http/www.domain.com.80
* The URLs on the website are externalized with http in the absolute links Which two actions should the Architect take to resolve this problem? (Choose two.)
- A. Ensure the Sling Mapping exist at /etc/map/httpj)mwp<.domain.com.443Configure the Adobe Granite SSL Connector Factory with the correct SSL port
- B. Configure Apache Felix Http Service SSL Filter to use the correct SSL forward header
- C. Ensure the Sling Mapping exist at /etc/map/https/www.domain.com.80
- D. Ensure the Sling Mapping exist at /etc/map/https/www.domain.com.443
"the Sling Mapping should match the protocol and port of the incoming request, which in this case is https and 443. The Apache Felix Http Service SSL Filter should be configured to use the X-Forwarded-Proto header to detect if the request is secure or not".
NEW QUESTION # 74
A customer has a requirement to allow authors to access AEM with single sign-on. To achieve this an Architect needs to integrate AEM with the customer's identity management system.
Which two actions could an Architect take to meet this requirement? (Choose two.)
- A. Configure the Sling Authentication Requirements for the OSGi HTTP Service
- B. Configure the generic SSO Authentication Handler
- C. Implement a custom JAAS Login Module
- D. Configure the SAML Authentication Handler
- E. Implement the generic SSO Authentication Handler interface
Answer: B,E
NEW QUESTION # 75
A fashion retail company is planning to enhance the online shopping experience by integrating Adobe Experience Manager (AEM) with a third-party commerce platform using the Commerce Integration Framework (CIF). What are the purpose and benefits of using CIF in this integration?
- A. CIF provides a set of pre-built UI components for AEM that can be easily embedded into the third-party commerce platform, ensuring consistent branding.
- B. CIF allows for direct data synchronization between AEM and the third-party commerce platform, eliminating the need for APIs and simplifying integration.
- C. CIF facilitates the exchange of commerce data, such as products, prices, and inventory, between AEM and the third-party commerce platform, enabling a unified shopping experience.
- D. CIF enables AEM to host the entire checkout process, reducing the dependency on the third-party commerce platform and improving security.
NEW QUESTION # 76
Generally speaking, Adobe certification has become one of the most authoritative voices speaking to us today. Let us make our life easier by learning to choose the proper AD0-E117 test answers, pass the AD0-E117 exam, obtain the certification, and be the master of your own life, not its salve. Our AD0-E117 Exam Questions are exactly what you are looking for. With three different versions of AD0-E117 exam study materials are shown on our website, so you will be glad to know you have so many different ways to study.
Test AD0-E117 Engine: https://www.pass4test.com/AD0-E117.html
- Adobe AD0-E117 Exam Questions Come With Free 12 Months Updates 🦂 Open { [url]www.testkingpass.com } enter “ AD0-E117 ” and obtain a free download 🦆Exam AD0-E117 Cram[/url]
- New AD0-E117 Reliable Exam Answers Free PDF | Pass-Sure Test AD0-E117 Engine: Adobe Experience Manager Architect Master 💖 Easily obtain [ AD0-E117 ] for free download through [ [url]www.pdfvce.com ] 🏐AD0-E117 Practice Engine[/url]
- AD0-E117 Passed ❗ Exam AD0-E117 Collection Pdf ⏭ AD0-E117 Exam Questions Pdf 💺 Copy URL [ [url]www.prep4away.com ] open and search for 《 AD0-E117 》 to download for free 🔗Reliable AD0-E117 Test Tips[/url]
- AD0-E117 Pdf Pass Leader ☸ AD0-E117 Practice Engine 🆗 Exam AD0-E117 Learning 🟤 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for ✔ AD0-E117 ️✔️ to obtain a free download 🛑AD0-E117 Practice Engine[/url]
- Adobe AD0-E117 PDF Dumps - Study Whenever You Want 🥙 The page for free download of “ AD0-E117 ” on “ [url]www.examcollectionpass.com ” will open immediately 🧛Certification AD0-E117 Test Answers[/url]
- Adobe AD0-E117 PDF Dumps - Study Whenever You Want ⏫ Easily obtain ➡ AD0-E117 ️⬅️ for free download through ▛ [url]www.pdfvce.com ▟ 🙈AD0-E117 Download[/url]
- New AD0-E117 Reliable Exam Answers 100% Pass | High-quality Test AD0-E117 Engine: Adobe Experience Manager Architect Master 🏆 Download { AD0-E117 } for free by simply entering ✔ [url]www.examcollectionpass.com ️✔️ website 🌇AD0-E117 Latest Learning Material[/url]
- Adobe AD0-E117 Exam | AD0-E117 Reliable Exam Answers - Money Back Guaranteed of Test AD0-E117 Engine 🐉 Search for ☀ AD0-E117 ️☀️ and download exam materials for free through ☀ [url]www.pdfvce.com ️☀️ 📪AD0-E117 Exam Questions Pdf[/url]
- New AD0-E117 Reliable Exam Answers 100% Pass | High-quality Test AD0-E117 Engine: Adobe Experience Manager Architect Master 🤳 Download ⇛ AD0-E117 ⇚ for free by simply entering 《 [url]www.testkingpass.com 》 website ⬅️AD0-E117 Latest Learning Material[/url]
- AD0-E117 Exam Questions Pdf 🛶 AD0-E117 Latest Learning Material 💘 AD0-E117 Exam Sample Online 👎 Go to website ⇛ [url]www.pdfvce.com ⇚ open and search for ➡ AD0-E117 ️⬅️ to download for free 😿Valid Exam AD0-E117 Registration[/url]
- AD0-E117 Dumps Free Download 🌛 Exam AD0-E117 Learning ☃ Formal AD0-E117 Test 🕡 Search for ➠ AD0-E117 🠰 and easily obtain a free download on ▛ [url]www.testkingpass.com ▟ ⏪Exam AD0-E117 Learning[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest Pass4Test AD0-E117 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=11Z9RNSRt_m3Bzx3gj_t5fJv-brpeok3G
