New EAEP2201 Test Answers - EAEP2201 Test Discount
Posted at 1/31/2026 02:56:30
What's more, part of that VCEDumps EAEP2201 dumps now are free: https://drive.google.com/open?id=1VMT5rKwFM72zKnlKyUFsAc9omgvS726r
As long as you can practice EAEP2201 study guide regularly and persistently your goals of making progress and getting certificates smoothly will be realized just like a piece of cake. For our pass rate of our EAEP2201 Practice Engine which is high as 98% to 100% is tested and praised by our customers. You can trust in our quality of the EAEP2201 exam questions and you can try it by free downloading the demos.
Esri EAEP2201: Enterprise Administration Professional 2201 exam is designed to test a candidate's ability to manage ArcGIS Enterprise deployments. EAEP2201 Exam covers a wide range of topics related to installation, configuration, security, and performance tuning. It is intended for experienced GIS professionals who have a good understanding of ArcGIS Enterprise and IT concepts. Passing the exam is a significant achievement that can help professionals advance their careers and increase their earning potential.
Esri EAEP2201 Test Discount | EAEP2201 Answers FreeIf you are very busy, you can only take two or three hours a day to study our EAEP2201 study engine. Then I tell you this is enough! After ten days you can go to the exam. With such an efficient product, you really can't find the second one! In any case, many people have passed the exam after using EAEP2201 Training Materials. This is a fact that you must see. As long as you are still a sensible person, you will definitely choose EAEP2201 practice quiz. Don't hesitate! Time does not wait!
Esri Enterprise Administration Professional 2201 Sample Questions (Q21-Q26):NEW QUESTION # 21
An ArcGIS administrator executes a script to silently upgrade all components of ArcGIS Enterprise version
10.6.1 to version 10.9.1. The upgrade completes without logging any errors.
When the administrator logs in, the following message appears: "Members in your organization were assigned the Standard (Temporary) or Lite (Temporary) user types. No users can log in to the Portal." What is causing these issues?
- A. The organization has level 2 members and the new license file used for the upgrade now has more than one compatible user type.
- B. The portal has no internet access, and the Software Authorization Wizard could notconnect to Esri to validate the new license file.
- C. The Portal for ArcGIS upgrade process requires a restart of the Portal for ArcGIS service when adding additional user types.
During the upgrade from ArcGIS Enterprise 10.6.1 to 10.9.1, user type licensing is enforced. If the new license file includes more than one compatible user type (e.g., Creator and GIS Professional), existing members without a specified user type may be assigned temporary user types like "Standard (Temporary)" or
"Lite (Temporary)." These temporary assignments prevent users from logging in until valid user types are manually assigned.
This issue is not related to internet access (Option B) or the need to restart services (Option C).
Reference Source:ArcGIS Enterprise documentation on user type licensing during upgrades
NEW QUESTION # 22
A GIS administrator must share an imagery service with another ArcGIS Enterprise. The administrator sets up a distributed collaboration with the other ArcGIS Enterprise and shares the service as a reference. The users in the other organization keep being prompted for credentials.
Which action should the administrator perform?
- A. Save viewer credentials in the collaboration
- B. Configure the service with anonymous access
- C. Set the collaboration workspace to send and receive
- D. Share the image service as a copy
When sharing areferenced servicethrough adistributed collaboration, users accessing the service from the guest organization need valid credentialsunlesscredentials are stored with the item. To prevent repeated credential prompts, the administrator shouldsave credentials with the item when it is shared, particularly for read-only access like viewing imagery.
From the ArcGIS Enterprise documentation on collaborations:
"When sharing services as references across ArcGIS Enterprise organizations, credentials must be stored with the item to ensure seamless access unless the service is public."
* OptionA(sharing as a copy) is an alternative, but it'snot what was asked forand might not be ideal for large imagery.
* OptionC(workspace direction) affects sync behavior, not access control.
* OptionDwould only work if the service is made public, which often isn't acceptable for internal data.
Reference:ArcGIS Enterprise -Distributed Collaborations and Shared Credential Requirements
NEW QUESTION # 23
A GIS administrator is architecting a new ArcGIS Enterprise deployment. The organization has grown and evolved since the initial deployment. The organization is having difficulty meeting the existing Service Level Agreement.
Recently, the team rolled out a series of web tools that are used in various applications throughout the organization. In the existing deployment, users report poor performance when the web tools are used.
Which action should the GIS administrator perform?
- A. Configure additional ArcGIS Server machines within the existing ArcGIS Server site
- B. Install an additional ArcGIS Enterprise deployment for analysis workflows
- C. Dedicate an ArcGIS Server site for analysis to use workload separation
Workload separation is a best practice in ArcGIS Enterprise architecture. By dedicating a separate ArcGIS Server site for analysis tasks, such as geoprocessing services used in web tools, system resources can be managed more effectively, and performance can be improved. This configuration avoids overloading a single site and ensures that interactive web applications are not affected by resource-intensive analysis tools.
Adding more machines to the same site (Option A) does not isolate workloads and may still result in contention. Installing an entirely new ArcGIS Enterprise deployment (Option C) increases complexity and administration effort unnecessarily. The recommended solution is to implementa dedicated ArcGIS Server site for analysisas part of a federated multi-site deployment.
Reference Source:ArcGIS Enterprise System Design Strategies - Workload separation practices
NEW QUESTION # 24
An ArcGIS Pro user receives the following error when trying to publish to ArcGIS Enterprise:
"Unable to publish to ArcGIS Server, error 001369: failed to create service" The ArcGIS Server logs reveal:
* Failed to create service
* Internal server error
* Unable to instantiate class for XML schema type
* Invalid XML registry file
* 390 ArcSOC processes running
* Server uses only half of available RAM
- A. Scale up the ArcGIS Server machine resources
- B. Increase the non-interactive desktop heap size
- C. Use more dedicated instances instead of shared
This issue is consistent withdesktop heap exhaustion, especially when a high number ofArcSOC processes (e.g., 390)are running on Windows. Desktop heap is a limited memory resource used for GUI and system object management. When it runs out, services can fail to start and produce XML-related errors.
Increasing thenon-interactive desktop heap sizein the Windows registry resolves this.
From Esri documentation:
"If the Windows desktop heap size is too low, ArcGIS Server may be unable to create new processes (ArcSOC), causing service failures and related internal server errors."
* OptionBis a generic fix and won't address the specific heap exhaustion issue.
* OptionCdoesn't help if the root issue is OS-level heap size limits.
Reference:ArcGIS Enterprise -ArcSOC process limits and Windows desktop heap size
NEW QUESTION # 25
An organization experiences a temporary loss of service for its ArcGIS Enterprise deployment due to expired licenses.
What should the administrator have done to prevent this issue?
- A. Use the license file in read-only mode to extend the license
- B. Create a Python script to run an administrative report and schedule the script to run regularly
- C. Design an information banner to automatically display the license expiration date
- D. Configure the ArcGIS Enterprise portal to send an automated email when the portal license is expiring
ArcGIS Enterprise doesn't currently offerautomated license expiration email alerts. However, administrators can useadministrative scriptsto query license status andgenerate reports that can be automated using task schedulers (e.g., Windows Task Scheduler).
From Esri guidance:
"Administrators can monitor license status using the ArcGIS REST API or scripting tools. Automating these checks allows timely action before licenses expire."
* OptionAis not a native capability of the portal.
* OptionCis not tied to licensing and is only useful as a passive alert.
* OptionDis not a valid license management option.
Reference:ArcGIS Enterprise -Managing License Expiry and Automating Admin Reports
NEW QUESTION # 26
Many people prefer to buy our EAEP2201 valid study guide materials because they deeply believe that if only they buy them can definitely pass the EAEP2201 test. The reason why they like our EAEP2201 guide questions is that our study materials' quality is very high and the service is wonderful. For years we always devote ourselves to perfecting our EAEP2201 Study Materials and shaping our products into the model products which other companies strive hard to emulate. We boost the leading research team and the top-ranking sale service.
EAEP2201 Test Discount: https://www.vcedumps.com/EAEP2201-examcollection.html
- EAEP2201 New Test Materials 🏓 Frenquent EAEP2201 Update 🍎 EAEP2201 New Test Materials 🙄 Immediately open 「 [url]www.examcollectionpass.com 」 and search for ➠ EAEP2201 🠰 to obtain a free download 💬High EAEP2201 Passing Score[/url]
- Authoritative EAEP2201 - New Enterprise Administration Professional 2201 Test Answers 📡 Search for ➥ EAEP2201 🡄 and download it for free on { [url]www.pdfvce.com } website 🎿EAEP2201 Exam Certification[/url]
- Authoritative EAEP2201 - New Enterprise Administration Professional 2201 Test Answers 💜 Enter ⇛ [url]www.examdiscuss.com ⇚ and search for “ EAEP2201 ” to download for free 💟Latest EAEP2201 Test Materials[/url]
- New New EAEP2201 Test Answers 100% Pass | High-quality EAEP2201: Enterprise Administration Professional 2201 100% Pass 🩳 Search for ▛ EAEP2201 ▟ on ⇛ [url]www.pdfvce.com ⇚ immediately to obtain a free download 🕑Exam EAEP2201 Guide[/url]
- EAEP2201 Pass4sure Study Materials 🚆 EAEP2201 Latest Dump 🔸 EAEP2201 Pass4sure Study Materials 🐤 Search for 「 EAEP2201 」 and obtain a free download on ⮆ [url]www.verifieddumps.com ⮄ ⛺Examcollection EAEP2201 Free Dumps[/url]
- Examcollection EAEP2201 Free Dumps 🌳 EAEP2201 Pass4sure Study Materials 🤯 EAEP2201 Latest Dump 🏥 Copy URL ➡ [url]www.pdfvce.com ️⬅️ open and search for [ EAEP2201 ] to download for free 🦩Latest Test EAEP2201 Experience[/url]
- Top EAEP2201 Questions 🐱 Frenquent EAEP2201 Update 🚀 EAEP2201 Latest Dump 🔲 Search for ➡ EAEP2201 ️⬅️ and easily obtain a free download on [ [url]www.prepawaypdf.com ] 🛫EAEP2201 New Dumps Pdf[/url]
- EAEP2201 Exam Certification 🏕 EAEP2201 Pass4sure Study Materials 🔙 Exam EAEP2201 Guide 💹 Search on ▛ [url]www.pdfvce.com ▟ for ⇛ EAEP2201 ⇚ to obtain exam materials for free download 🔽Latest EAEP2201 Test Materials[/url]
- EAEP2201 Examcollection 🎂 Reliable Test EAEP2201 Test 🕺 EAEP2201 Pass Guarantee 🔶 Download { EAEP2201 } for free by simply entering ➽ [url]www.troytecdumps.com 🢪 website 💝Latest EAEP2201 Test Materials[/url]
- Get 1 year Free Updates with EAEP2201 Exam Questions 🐾 Go to website ( [url]www.pdfvce.com ) open and search for ☀ EAEP2201 ️☀️ to download for free 😰EAEP2201 Exam Simulator Online[/url]
- Reliable Test EAEP2201 Test 🏏 Examcollection EAEP2201 Free Dumps 🌷 EAEP2201 Examcollection 😫 ➽ [url]www.validtorrent.com 🢪 is best website to obtain ➥ EAEP2201 🡄 for free download 🗳New EAEP2201 Test Sample[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, estar.jp, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest VCEDumps EAEP2201 PDF Dumps and EAEP2201 Exam Engine Free Share: https://drive.google.com/open?id=1VMT5rKwFM72zKnlKyUFsAc9omgvS726r
