[Hardware] Actual Amazon AWS-Solutions-Associate Practice Test - Quick Test Preparation Tip
95
Hardware Actual Amazon AWS-Solutions-Associate Practice Test - Quick Test Preparation Tip
Posted at 1/31/2026 10:31:07      View184 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon AWS-Solutions-Associate dumps are available on Google Drive shared by TestPassKing: https://drive.google.com/open?id=1UM9kcotZrP1tUlhObK-Ra9SI-m-LYTG9
Regular practice can give you the skills and confidence needed to perform well on your AWS-Solutions-Associate exam. By practicing your AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Associate) exam regularly, you can increase your chances of success and make sure that all of your hard work pays off when it comes time to take the test. We understand that every AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Associate) exam taker has different preferences. To make sure that our AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Associate) preparation material is accessible to everyone, we made it available in three different formats. You can choose the most suitable and convenient one for you.
To pass the exam, candidates must demonstrate their ability to design and deploy scalable, highly available, and fault-tolerant systems on the AWS platform. They must also demonstrate their understanding of AWS services such as Compute, Storage, Database, Networking, Security, and Analytics, and show proficiency in using various AWS services to build and deploy applications. Additionally, candidates must have a solid understanding of AWS best practices, including security, high availability, and cost optimization, to design and deploy applications on the AWS platform.
The AWS-Solutions-Associate Certification Exam is an excellent opportunity for IT professionals to demonstrate their expertise in designing and deploying scalable, highly available, and fault-tolerant systems on AWS. It is a valuable credential that can open up new career opportunities and help you stay competitive in the ever-evolving world of cloud computing.
AWS-Solutions-Associate Reliable Test Blueprint - New AWS-Solutions-Associate Test PapersIn modern society, everything is changing so fast with the development of technology. If you do no renew your knowledge and skills, you will be wiped out by others. Our AWS-Solutions-Associate guide materials also keep up with the society. After all, new technology has been applied in many fields. So accordingly our AWS-Solutions-Associate Exam Questions are also applied with the latest technologies to be up to date. You can free download the demos to check that how wonderful our AWS-Solutions-Associate learning praparation is!
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q36-Q41):NEW QUESTION # 36
An ecommerce application places orders in an Amazon Simple Queue Service (Amazon SQS) queue When a message is received, the Amazon EC2 worker instances process the request The EC2 instances are in an Auto Scaling group 236 How should the architecture be designed to scale the auto scaling group with the LEAST amount of operational overhead?
  • A. Use an Amazon CloudWatch alarm on the EC2 CPU to scale the Auto Scaling group up and down
  • B. Use an Amazon CloudWatch alarm based on the number of messages in the queue to scale the Auto Scaling group up or down
  • C. Use an Amazon CloudWatch alarm based on the CPU to scale the Auto Scaling group up or down
  • D. Use an Amazon EC2 Auto Scaling health check for messages processed on the EC2 instances to scale up or down.
NEW QUESTION # 37
What happens to the data on an instance if the instance reboots (intentionally or unintentionally)?
  • A. Data will be lost
  • B. Data may persist however cannot be sure
  • C. Data persists
NEW QUESTION # 38
When does the billing of an Amazon EC2 system begin?
  • A. It starts when your instance reaches 720 instance hours.
  • B. It starts when Amazon EC2 initiates the boot sequence of an AMI instance.
  • C. It starts as soon as you click the create instance option on the main EC2 console.
  • D. It starts when the Status column for your distribution changes from Creating to Deployed.
Billing commences when Amazon EC2 initiates the boot sequence of an AMI instance. Billing ends when the instance terminates, which could occur through a web services command, by running "shutdown -h", or through instance failure. When you stop an instance, Amazon shuts it down but doesnAE t charge hourly usage for a stopped instance, or data transfer fees, but charges for the storage for any Amazon EBS volumes.
Reference: http://aws.amazon.com/ec2/faqs/
NEW QUESTION # 39
A company has a two-tier application architecture that runs in public and private subnets Amazon EC2 instances running the web application are in the public subnet and a database runs on the private subnet The web application instances and the database are running in a single Availability Zone (AZ).
Which combination of steps should a solutions architect take to provide high availability for this architecture?
(Select TWO.)
  • A. Create an Amazon EC2 Auto Scaling group and Application Load Balancer spanning multiple AZs
  • B. Add the existing web application instances to an Auto Scaling group behind an Application Load Balancer
  • C. Create new public and private subnets in the same VPC each in a new AZ Migrate the database to an Amazon RDS multi-AZ deployment
  • D. Create new public and private subnets in the same AZ for high availability
  • E. Create new public and private subnets in a new AZ Create a database using Amazon EC2 in one AZ
NEW QUESTION # 40
A gaming company is moving its public scoreboard from a data center to the AWS Cloud. The company uses Amazon EC2 Windows Server instances behind an Application Load Balancer to host its dynamic application.
The company needs a highly available storage solution for the application. The application consists of static files and dynamic server-side code.
  • A. Which combination of steps should a solutions architect take to meet these requirements? (Select TWO.) ' Store the static files on Amazon S3. Use Amazon A. CloudFront to cache objects at the edge.
  • B. Store the server-side code on Amazon Elastic File System (Amazon EFS). Mount the EFS volume on each EC2 instance to share the files.
  • C. Store the server-side code on Amazon FSx for Windows File Server. Mount the FSx for Windows File Server volume on each EC2 instance to share the files.
  • D. Store the server-side code on a General Purpose SSD (gp2) Amazon Elastic Block Store (Amazon EBS) volume. Mount the EBS volume on each EC2 instance to share the files.
  • E. Store the static files on Amazon S3. Use Amazon ElastiCache to cache objects at the edge.
Answer: A,D
NEW QUESTION # 41
These experts are committed and work together and verify each AWS-Solutions-Associate exam question so that you can get the real, valid, and updated AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Associate) exam practice questions all the time. So you do not need to get worried, countless AWS-Solutions-Associate exam candidates have already passed their dream Amazon AWS-Solutions-Associate Certification Exam and they all got help from real, valid, and error-free AWS-Solutions-Associate exam practice questions. So you also need to think about your future and advance your career with the badge of AWS-Solutions-Associate certification exam.
AWS-Solutions-Associate Reliable Test Blueprint: https://www.testpassking.com/AWS-Solutions-Associate-exam-testking-pass.html
What's more, part of that TestPassKing AWS-Solutions-Associate dumps now are free: https://drive.google.com/open?id=1UM9kcotZrP1tUlhObK-Ra9SI-m-LYTG9
Posted at 2/1/2026 04:08:22        Only Author  2#
GoogleयProfessional-Data-Engineer|ȥȤ֤¤Υȥɤե`뤿ˡ`ǟoϤΥåץǩ`Ȥṩޤ Professional-Data-EngineerԇYȥȤϡUYNʌTҤˤäƤޤȤƤꡢdzˁޤ礯gäǤޤxkǤ뤵ޤޤʥЩ`ṩƤꡢProfessional-Data-EngineerԇYϤmʥЩ`ҊĤ뤳ȤǤޤΤᡢѧߤProfessional-Data-EngineerΆ}ȥȤäơ̕rgProfessional-Data-EngineerԇY˺ϸ񤹤ȱǤ
Posted at 2/23/2026 17:58:32        Only Author  3#
FlashArray-Implementation-SpecialistJԇYˤĤơʤϤɤä˼äƤΤǤdz˚ݤPure StorageJԇYһĤȤơԇYФǤԇYΜʂ褯Ǥ뤿ԇYο̽ƤȤˡʲοYϤҊĤΤϤؤyȤ狼ޤǤϡɤ餤Ǥ礦ɷǤ衣ShikenPASSϤʤߤ줷ơYνԤҪˤ뤿ˡһԇYFlashArray-Implementation-Specialist}ṩƤޤ
