[General] Test 1Z0-1042-25 Simulator Free, Reliable 1Z0-1042-25 Exam Vce
108
【General】 Test 1Z0-1042-25 Simulator Free, Reliable 1Z0-1042-25 Exam Vce
Posted at 2/1/2026 12:29:13      View:172 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 Latest Real4dumps 1Z0-1042-25 PDF Dumps and 1Z0-1042-25 Exam Engine Free Share: https://drive.google.com/open?id=1e2pH4bh0Yz7MZwIjvGdJTV4CEEnXBrZL
Of course, when we review a qualifying exam, we can't be closed-door. We should pay attention to the new policies and information related to the test 1Z0-1042-25 certification. For the convenience of the users, the 1Z0-1042-25 test materials will be updated on the homepage and timely update the information related to the qualification examination. Annual qualification examination, although content broadly may be the same, but as the policy of each year, the corresponding examination pattern grading standards and hot spots will be changed, the 1Z0-1042-25 Test Prep can help users to spend the least time to pass the exam.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
Topic 5
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Reliable 1Z0-1042-25 Exam Vce & 1Z0-1042-25 Free Pdf GuideThis format enables you to assess your 1Z0-1042-25 test preparation with a 1Z0-1042-25 practice exam. You can also customize your time and the kinds of questions of the Oracle 1Z0-1042-25 Practice Test. This Oracle Cloud Infrastructure 2025 Application Integration Professional 1Z0-1042-25 practice test imitates the Oracle 1Z0-1042-25 real exam pattern. Thus, it helps you kill Oracle Cloud Infrastructure 2025 Application Integration Professional exam anxiety.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q51-Q56):NEW QUESTION # 51
Which two statements are true regarding messaging adapters in Oracle Integration Cloud?
  • A. The Apache Kafka adapter can be configured to support Transactions in case of Producer.
  • B. The OCI Streaming Adapter does not support consuming messages from a specified consumer group.
  • C. Both the Apache Kafka and OCI Streaming adapter support XML, JSON, and Avro message formats.
  • D. It is not mandatory to install a Connectivity agent to use the OCI Streaming Adapter for inbound polling.
Both Apache Kafka and OCI Streaming adapters support various message formats like XML, JSON, and Avro. The Apache Kafka adapter also supports transactional messaging for producers.
NEW QUESTION # 52
In Oracle Integration Cloud (OIC), you are working on an integration that uses a REST trigger, which will require##(authentication). You need to ensure that only authorized clients can accessthe integration. Which configuration should you apply?
  • A. Configure the REST adapter with a Basic Authentication or OAuth 2.0 security policy and provide the required credentials.
  • B. Set up an IP whitelist in the OIC instance, allowing only specific IP addresses to access the integration.
  • C. Enable Cross-Origin Resource Sharing (CORS) and set an API key in the REST adapter configuration.
  • D. Encrypt the payload using a custom encryption algorithm and provide the decryption key to authorized clients.
Securing a REST trigger in OIC involves:
Option B:Configuring the REST adapter withBasic AuthenticationorOAuth 2.0ensures only authorized clients with valid credentials can invoke it- the standard approach.
Option A:CORS controls browser access, not authentication; API keys aren't natively supported here.
Option C:IP whitelisting is possible but less granular and not adapter-specific.
NEW QUESTION # 53
You need to create a scheduled orchestration integration that is based on an existing app-driven orchestration using the same display name. Which statement is valid for this use case?
  • A. You cannot create another integration that uses the same name.
  • B. You can clone the existing integration and specify it to use the scheduled orchestration pattern.
  • C. You can create the new integration as a different major version of the existing one.
  • D. You can create the new integration by using the same display name but with a different identifier.
OIC allows pattern changes:
B:True-cloning an app-driven integration and switching to scheduled pattern is supported, retaining the name.
A:False-versioning doesn't change the pattern.
C:False-same names are allowed with different identifiers.
NEW QUESTION # 54
You need to create an Oracle Integration (OIC) integration that processes many records individually that are contained within a single large file. You have been advised to use an implementation approach that uses the Download File operation of an FTP adapter in conjunction with the Stage File action Read File in Segments operation to mitigate issues with memory consumption. When using this approach, which is a valid consideration regarding the use of the Read File in Segments operation?
  • A. You need to explicitly configure a Scope action for this operation if you want to add additional actions during the processing of each segment.
  • B. You must provide the actual filename because file references cannot be processed by the Read File in Segments operation.
  • C. Segment sizes can be configured from 1-200 records.
  • D. The Read File in Segments operation allows you to process the segments sequentially or in parallel.
Segmented Processing:
A:True-Scope required for custom actions.
NEW QUESTION # 55
You receive a status code: 502 Proxy Error.
Which is a possible event cause for this error?
  • A. When the proxy setup is incorrect.
  • B. While the proxy server is not responding to the request.
  • C. While adding proxy for an enterprise application device.
  • D. While registering a large number of devices using the Batch Registration feature under the Devices menu.
A 502 Proxy Error can occur when the proxy server is overloaded or unresponsive due to a large number of concurrent requests, such as during the Batch Registration feature in the Oracle IoT Cloud. Incorrect proxy setup and server unresponsiveness can also cause the error.
NEW QUESTION # 56
We will provide high quality assurance of 1Z0-1042-25 exam questions for our customers with dedication to ensure that we can develop a friendly and sustainable relationship. First of all, we have security and safety guarantee, which mean that you cannot be afraid of virus intrusion and information leakage since we have data protection acts, even though you end up studying 1Z0-1042-25 test guide of our company, we will absolutely delete your personal information and never against ethic code to sell your message to the third parties. Secondly, our 1Z0-1042-25 Exam Questions will spare no effort to perfect after-sales services. Thirdly countless demonstration and customer feedback suggest that our Oracle Cloud Infrastructure 2025 Application Integration Professional study question can help them get the certification as soon as possible, thus becoming the elite, getting a promotion and a raise and so forth.
Reliable 1Z0-1042-25 Exam Vce: https://www.real4dumps.com/1Z0-1042-25_examcollection.html
Posted at 2/5/2026 18:22:53        Only Author  2#
ご客様は弊社のF5CAB4問題集を購入するかどうかと判断する前に、我が社は無料に提供するサンプルをダウンロードして試すことができます。それで、不必要な損失を避けできます。ご客様はF5CAB4問題集を購入してから、勉強中で何の質問があると、行き届いたサービスを得られています。ご客様はF5CAB4資格認証試験に失敗したら、弊社は全額返金できます。その他、F5CAB4問題集の更新版を無料に提供します。
Posted at 2/17/2026 18:58:02        Only Author  3#
Thank you for sharing such an inspiring piece of work! Get the Training PL-600 materials exam materials now—free and essential for your career and salary growth!
Posted at 3/10/2026 21:58:40        Only Author  4#
Thank you for sharing such an impressive article; it really made an impact. I’m sharing the AANP-FNP test discount voucher resources for free—good luck!
