[General] TDA-C01 Test Dates - Exam TDA-C01 Learning
107
General TDA-C01 Test Dates - Exam TDA-C01 Learning
Posted at 2/5/2026 22:06:27      View107 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Free4Torrent TDA-C01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1jztfN2WunzwWxnu1asAauX036wYF0IaB
Free4Torrent understands the importance of your satisfaction with their TDA-C01 Exams Certification. To guarantee your confidence in their product, they offer a free demo of the Tableau TDA-C01 exam questions in PDF format. This enables you to assess the quality of the TDA-C01 Practice Exam preparation before committing to purchasing the full package of Tableau TDA-C01 test questions.
Tableau TDA-C01 is a certification exam designed for individuals who want to enhance their skills and knowledge in data analytics. Tableau Certified Data Analyst certification is ideal for data analysts who want to validate their Tableau skills and knowledge. Passing TDA-C01 Exam demonstrates an individual's ability to use Tableau to connect to various data sources, perform data analysis, create and share visualizations, and design dashboards.
100% Pass Quiz Tableau - Pass-Sure TDA-C01 Test DatesEach format specializes in a specific study style and offers unique benefits, each of which is crucial to good Tableau Certified Data Analyst (TDA-C01) exam preparation. The specs of each Tableau TDA-C01 Exam Questions format are listed below, you may select any of them as per your requirements.
Tableau Certified Data Analyst Sample Questions (Q163-Q168):NEW QUESTION # 163
You have a data source that contains the following columns.
You want to filter regions based on the highest sales. Users must be able to specify the number of regions shown.
Which three actions should you perform in order? (Place the three correct options in order. Use the arrows to move Options to Answer Area.
Use Answer Area arrows to re-order the options.)
To filter regions based on the highest sales and allow users to specify the number of regions shown, you should perform these actions in order:
Answer area:
Create an integer data type parameter named Param1.
Drag Region to the Filters shelf.
Configure a Top filter by field. Use Param1 and filter by the sum of Sales.
To create a dynamic filter that lets users choose the number of regions to display, you need to use a parameter and a top filter. A parameter is a user-defined variable that can be used in calculations, filters, and reference lines. A top filter is a type of filter that shows only the top or bottom N values based on a specified field or expression.
In this question, you want to filter regions based on the highest sales. You also want users to be able to specify the number of regions shown. To achieve this, you need to follow these steps:
First, you need to create an integer data type parameter named Param1. This parameter will allow users to enter a number that will determine how many regions to show. You can create a parameter by right-clicking on the Data pane and selecting Create Parameter. Then, you need to specify the name, data type, current value, and allowable values for the parameter. In this case, you can choose Integer as the data type, 10 as the current value, and All as the allowable values. You also need to show the parameter control by right-clicking on the parameter and selecting Show Parameter Control. This will display a slider or a text box where users can enter or adjust the parameter value.
Next, you need to drag Region to the Filters shelf. This will open the Filter dialog box, where you can choose how to filter the Region field. You can filter by general, wildcard, condition, or top. In this case, you want to filter by top, so you need to select the Top tab.
Finally, you need to configure a top filter by field. Use Param1 and filter by the sum of Sales. This will filter the Region field by showing only the top N regions based on the sum of Sales, where N is the value of the parameter Param1. You can configure a top filter by field by selecting By field in the Top tab, then choosing the parameter Param1 from the drop-down list, and selecting the aggregation function Sum and the field Sales from the other drop-down lists. This will create a filter expression that looks like this: Top Param1 by SUM(Sales).
By following these steps, you will create a filter that shows only the regions with the highest sales, and allows users to change the number of regions shown by adjusting the parameter value.
Tableau Certified Data Analyst Exam Prep Guide, page 10, section "Filtering Data" Tableau Help: Parameters Tableau Help: Top Filters
NEW QUESTION # 164
You have the following chart that shows profits and discounts over time.
You need to combine the lines to appear as shown in the following chart.
What should you do?
  • A. Set Discount to Dual Axis
  • B. Convert Discount to Discrete
  • C. Drag Discount to Color on the Marks card
  • D. Drag Discount to the Columns shelf
To combine the lines to appear as shown in the second chart, you should set Discount to Dual Axis. Dual Axis is a feature that allows you to show two measures on two separate axes on one chart. You can create a dual axis by right-clicking on a measure on any shelf and selecting Dual Axis from the menu. This will create two axes on one chart and synchronize their scales.
In this case, you want to show Profit and Discount on two separate axes on one chart. You can right-click on Discount on any shelf and select Dual Axis from the menu. This will create a dual axis chart that shows Profit and Discount as two lines with different colors.
The other options are not correct for this scenario. Dragging Discount to Color on the Marks card will change the color of Profit based on Discount, but it will not show two lines. Converting Discount to Discrete will change Discount from a green pill to a blue pill, but it will not affect how it appears on the chart. Dragging Discount to Columns shelf will create two separate charts for Profit and Discount, but it will not combine them. References: https://help.tableau.com/current ... ultiplemeasures.htm https://help.
tableau.com/current/pro/desktop/en-us/multiplemeasures_dualaxes.htm
NEW QUESTION # 165
You have the following dashboard that contains two sheets.
You want to minimize the whitespace between the sheets.
What should you configure?
  • A. The size
  • B. The background
  • C. The padding
  • D. The position
  • E. The border
To minimize the whitespace between the sheets, you should configure the padding of the sheets and the dashboard. Padding is the amount of space between the edge of a sheet or dashboard and its content. You can adjust the padding by using the Layout tab in the Format pane. You can reduce the padding for each sheet by selecting the sheet and changing the values for the inner and outer padding. You can also reduce the padding for the dashboard by selecting the dashboard and changing the values for the outer padding. Reducing the padding will make the sheets and the dashboard more compact and eliminate unnecessary whitespace. Reference:
Format Dashboards - Tableau
Tableau Certified Data Analyst Study Guide
NEW QUESTION # 166
Open the link to Book1 found on the desktop. Open the Movie Durations worksheet.
Replace the existing data source with the Netflix_2019 data source.
  • A. check the steps below in explanation
To replace the existing data source with the Netflix_2019 data source, you need to do the following steps:
Open the link to Book1 found on the desktop. This will open the Tableau workbook that contains the Movie Durations worksheet.
Click on the Movie Durations tab at the bottom of the workbook to open the worksheet. You will see a bar chart that shows the number of movies by duration for the existing data source.
Go to the Data Source tab at the bottom of the workbook to see the data source page. You will see a table that shows the fields and values from the existing data source.
Click on the drop-down arrow next to the data source name at the top of the page and select Replace Data Source from the menu. This will open a dialog box that allows you to replace your data source with another one.
Select Netflix_2019 from the list of available data sources and click OK. This will replace your existing data source with the Netflix_2019 data source and update your worksheet accordingly. You may need to fix any broken fields or calculations that result from the replacement.
NEW QUESTION # 167
You have the following two tables.
Table A is the primary table.
Which type of join is established when a blend is created by using the join key of Category?
  • A. Outer join
  • B. Left join
  • C. Right join
  • D. Inner join
NEW QUESTION # 168
The Tableau Certified Data Analyst prep torrent that we provide is compiled elaborately and highly efficient. You only need 20-30 hours to practice our TDA-C01 exam torrent and then you can attend the exam. For most of our customers, who are busy with their jobs or other things. But if they use our TDA-C01 test prep, they won't need so much time to prepare the exam and master exam content in a short time. What they need to do is just to spare 1-2 hours to learn and practice every day and then pass the exam with TDA-C01 Test Prep easily. It costs them little time and energy to pass the exam.
Exam TDA-C01 Learning: https://www.free4torrent.com/TDA-C01-braindumps-torrent.html
BONUS!!! Download part of Free4Torrent TDA-C01 dumps for free: https://drive.google.com/open?id=1jztfN2WunzwWxnu1asAauX036wYF0IaB
