[General] 100% Pass Data-Engineer-Associate - Trustable AWS Certified Data Engineer - Asso
70
General 100% Pass Data-Engineer-Associate - Trustable AWS Certified Data Engineer - Asso
Posted at 2/6/2026 12:04:38      View116 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest SureTorrent Data-Engineer-Associate PDF Dumps and Data-Engineer-Associate Exam Engine Free Share: https://drive.google.com/open?id=1VhAOOYdq46p9-5LL5ejwkOAZrZe5aL7b
If you are still a student, you must have learned from the schoolmaster how difficult it is to go out to work now. If you have already taken part in the work, you must have felt deeply the pressure of competition in society. Data-Engineer-Associate exam materials can help you stand out in the fierce competition. After using our Data-Engineer-Associate Study Materials, you have a greater chance of passing the Data-Engineer-Associatecertification, which will greatly increase your soft power and better show your strength.
Our Data-Engineer-Associate study dumps are suitable for you whichever level you are in right now. Whether you are in entry-level position or experienced exam candidates who have tried the exam before, this is the perfect chance to give a shot. High quality and high accuracy Data-Engineer-Associate real materials like ours can give you confidence and reliable backup to get the certificate smoothly because our experts have extracted the most frequent-tested points for your reference, because they are proficient in this exam who are dedicated in this area over ten years. If you make up your mind of our Data-Engineer-Associate Exam Questions after browsing the free demos, we will staunchly support your review and give you a comfortable and efficient purchase experience this time.
Data-Engineer-Associate Certification Cost - New Data-Engineer-Associate Exam Pass4sureThe Data-Engineer-Associate quiz torrent we provide is compiled by experts with profound experiences according to the latest development in the theory and the practice so they are of great value. Please firstly try out our product before you decide to buy our product. It is worthy for you to buy our Data-Engineer-Associate Exam Preparation not only because it can help you pass the Data-Engineer-Associate exam successfully but also because it saves your time and energy. Your satisfactions are our aim of the service and please take it easy to buy our Data-Engineer-Associate quiz torrent.
Amazon AWS Certified Data Engineer - Associate (DEA-C01) Sample Questions (Q155-Q160):NEW QUESTION # 155
A manufacturing company collects sensor data from its factory floor to monitor and enhance operational efficiency. The company uses Amazon Kinesis Data Streams to publish the data that the sensors collect to a data stream. Then Amazon Kinesis Data Firehose writes the data to an Amazon S3 bucket.
The company needs to display a real-time view of operational efficiency on a large screen in the manufacturing facility.
Which solution will meet these requirements with the LOWEST latency?
  • A. Use Amazon Managed Service for Apache Flink (previously known as Amazon Kinesis Data Analytics) to process the sensor data. Create a new Data Firehose delivery stream to publish data directly to an Amazon Timestream database. Use the Timestream database as a source to create an Amazon QuickSight dashboard.
  • B. Configure the S3 bucket to send a notification to an AWS Lambda function when any new object is created. Use the Lambda function to publish the data to Amazon Aurora. Use Aurora as a source to create an Amazon QuickSight dashboard.
  • C. Use Amazon Managed Service for Apache Flink (previously known as Amazon Kinesis Data Analytics) to process the sensor data. Use a connector for Apache Flink to write data to an Amazon Timestream database. Use the Timestream database as a source to create a Grafana dashboard.
  • D. Use AWS Glue bookmarks to read sensor data from the S3 bucket in real time. Publish the data to an Amazon Timestream database. Use the Timestream database as a source to create a Grafana dashboard.
This solution will meet the requirements with the lowest latency because it uses Amazon Managed Service for Apache Flink to process the sensor data in real time and write it to Amazon Timestream, a fast, scalable, and serverless time series database. Amazon Timestream is optimized for storing and analyzing time series data, such as sensor data, and can handle trillions of events per day with millisecond latency. By using Amazon Timestream as a source, you can create an Amazon QuickSight dashboard that displays a real-time view of operational efficiency on a large screen in the manufacturing facility. Amazon QuickSight is a fully managed business intelligence service that can connect to various data sources, including Amazon Timestream, and provide interactive visualizations and insights123.
The other options are not optimal for the following reasons:
A . Use Amazon Managed Service for Apache Flink (previously known as Amazon Kinesis Data Analytics) to process the sensor data. Use a connector for Apache Flink to write data to an Amazon Timestream database. Use the Timestream database as a source to create a Grafana dashboard. This option is similar to option C, but it uses Grafana instead of Amazon QuickSight to create the dashboard. Grafana is an open source visualization tool that can also connect to Amazon Timestream, but it requires additional steps to set up and configure, such as deploying a Grafana server on Amazon EC2, installing the Amazon Timestream plugin, and creating an IAM role for Grafana to access Timestream. These steps can increase the latency and complexity of the solution.
B . Configure the S3 bucket to send a notification to an AWS Lambda function when any new object is created. Use the Lambda function to publish the data to Amazon Aurora. Use Aurora as a source to create an Amazon QuickSight dashboard. This option is not suitable for displaying a real-time view of operational efficiency, as it introduces unnecessary delays and costs in the data pipeline. First, the sensor data is written to an S3 bucket by Amazon Kinesis Data Firehose, which can have a buffering interval of up to 900 seconds. Then, the S3 bucket sends a notification to a Lambda function, which can incur additional invocation and execution time. Finally, the Lambda function publishes the data to Amazon Aurora, a relational database that is not optimized for time series data and can have higher storage and performance costs than Amazon Timestream .
D . Use AWS Glue bookmarks to read sensor data from the S3 bucket in real time. Publish the data to an Amazon Timestream database. Use the Timestream database as a source to create a Grafana dashboard. This option is also not suitable for displaying a real-time view of operational efficiency, as it uses AWS Glue bookmarks to read sensor data from the S3 bucket. AWS Glue bookmarks are a feature that helps AWS Glue jobs and crawlers keep track of the data that has already been processed, so that they can resume from where they left off. However, AWS Glue jobs and crawlers are not designed for real-time data processing, as they can have a minimum frequency of 5 minutes and a variable start-up time. Moreover, this option also uses Grafana instead of Amazon QuickSight to create the dashboard, which can increase the latency and complexity of the solution .
1: Amazon Managed Streaming for Apache Flink
2: Amazon Timestream
3: Amazon QuickSight
: Analyze data in Amazon Timestream using Grafana
: Amazon Kinesis Data Firehose
: Amazon Aurora
: AWS Glue Bookmarks
: AWS Glue Job and Crawler Scheduling
NEW QUESTION # 156
A company uses an Amazon Redshift cluster that runs on RA3 nodes. The company wants to scale read and write capacity to meet demand. A data engineer needs to identify a solution that will turn on concurrency scaling.
Which solution will meet this requirement?
  • A. Turn on concurrency scaling for the daily usage quota for the Redshift cluster.
  • B. Turn on concurrency scaling in the settings during the creation of and new Redshift cluster.
  • C. Turn on concurrency scaling at the workload management (WLM) queue level in the Redshift cluster.
  • D. Turn on concurrency scaling in workload management (WLM) for Redshift Serverless workgroups.
Concurrency scaling is a feature that allows you to support thousands of concurrent users and queries, with consistently fast query performance. When you turn on concurrency scaling, Amazon Redshift automatically adds query processing power in seconds to process queries without any delays. You can manage which queries are sent to the concurrency-scaling cluster by configuring WLM queues. To turn on concurrency scaling for a queue, set the Concurrency Scaling mode value to auto. The other options are either incorrect or irrelevant, as they do not enable concurrency scaling for the existing Redshift cluster on RA3 nodes.
* Working with concurrency scaling - Amazon Redshift
* Amazon Redshift Concurrency Scaling - Amazon Web Services
* Configuring concurrency scaling queues - Amazon Redshift
* AWS Certified Data Engineer - Associate DEA-C01 Complete Study Guide (Chapter 6, page 163)
NEW QUESTION # 157
A data engineer needs to create a new empty table in Amazon Athena that has the same schema as an existing table named old-table.
Which SQL statement should the data engineer use to meet this requirement?
  • A.
  • B.
  • C.
  • D.
* Problem Analysis:
* The goal is to create a new empty table in Athena with the same schema as an existing table (old_table).
* The solution must avoid copying any data.
* Key Considerations:
* CREATE TABLE AS (CTAS) is commonly used in Athena for creating new tables based on an existing table.
* Adding the WITH NO DATA clause ensures only the schema is copied, without transferring any data.
* Solution Analysis:
* Option A: Copies both schema and data. Does not meet the requirement for an empty table.
* Option B: Inserts data into an existing table, which does not create a new table.
* Option C: Creates an empty table but does not copy the schema.
* Option D: Creates a new table with the same schema and ensures it is empty by using WITH NO DATA.
* Final Recommendation:
* Use D. CREATE TABLE new_table AS (SELECT * FROM old_table) WITH NO DATA to create an empty table with the same schema.
Athena CTAS Queries
CREATE TABLE Statement in Athena
NEW QUESTION # 158
A company uses an Amazon QuickSight dashboard to monitor usage of one of the company's applications.
The company uses AWS Glue jobs to process data for the dashboard. The company stores the data in a single Amazon S3 bucket. The company adds new data every day.
A data engineer discovers that dashboard queries are becoming slower over time. The data engineer determines that the root cause of the slowing queries is long-running AWS Glue jobs.
Which actions should the data engineer take to improve the performance of the AWS Glue jobs? (Choose two.)
  • A. Modify the 1AM role that grants access to AWS glue to grant access to all S3 features.
  • B. Partition the data that is in the S3 bucket. Organize the data by year, month, and day.
  • C. Adjust AWS Glue job scheduling frequency so the jobs run half as many times each day.
  • D. Increase the AWS Glue instance size by scaling up the worker type.
  • E. Convert the AWS Glue schema to the DynamicFrame schema class.
Partitioning the data in the S3 bucket can improve the performance of AWS Glue jobs by reducing the amount of data that needs to be scanned and processed. By organizing the data by year, month, and day, the AWS Glue job can use partition pruning to filter out irrelevant data and only read the data that matches the query criteria. This can speed up the data processing and reduce the cost of running the AWS Glue job.
Increasing the AWS Glue instance size by scaling up the worker type can also improve the performance of AWS Glue jobs by providing more memory and CPU resources for the Spark execution engine. This can help the AWS Glue job handle larger data sets and complex transformations more efficiently. The other options are either incorrect or irrelevant, as they do not affect the performance of the AWS Glue jobs. Converting the AWS Glue schema to the DynamicFrame schema class does not improve the performance, but rather provides additional functionality and flexibility for data manipulation. Adjusting the AWS Glue job scheduling frequency does not improve the performance, but rather reduces the frequency of data updates. Modifying the IAM role that grants access to AWS Glue does not improve the performance, but rather affects the security and permissions of the AWS Glue service. References:
* Optimising Glue Scripts for Efficient Data Processing: Part 1 (Section: Partitioning Data in S3)
* Best practices to optimize cost and performance for AWS Glue streaming ETL jobs (Section:
Development tools)
* Monitoring with AWS Glue job run insights (Section: Requirements)
* AWS Certified Data Engineer - Associate DEA-C01 Complete Study Guide (Chapter 5, page 133)
NEW QUESTION # 159
A company receives call logs as Amazon S3 objects that contain sensitive customer information. The company must protect the S3 objects by using encryption. The company must also use encryption keys that only specific employees can access.
Which solution will meet these requirements with the LEAST effort?
  • A. Use an AWS CloudHSM cluster to store the encryption keys. Configure the process that writes to Amazon S3 to make calls to CloudHSM to encrypt and decrypt the objects. Deploy an IAM policy that restricts access to the CloudHSM cluster.
  • B. Use server-side encryption with Amazon S3 managed keys (SSE-S3) to encrypt the objects that contain customer information. Configure an IAM policy that restricts access to the Amazon S3 managed keys that encrypt the objects.
  • C. Use server-side encryption with customer-provided keys (SSE-C) to encrypt the objects that contain customer information. Restrict access to the keys that encrypt the objects.
  • D. Use server-side encryption with AWS KMS keys (SSE-KMS) to encrypt the objects that contain customer information. Configure an IAM policy that restricts access to the KMS keys that encrypt the objects.
Option C is the best solution to meet the requirements with the least effort because server-side encryption with AWS KMS keys (SSE-KMS) is a feature that allows you to encrypt data at rest in Amazon S3 using keys managed by AWS Key Management Service (AWS KMS). AWS KMS is a fully managed service that enables you to create and manage encryption keys for your AWS services and applications. AWS KMS also allows you to define granular access policies for your keys, such as who can use them to encrypt and decrypt data, and under what conditions. By using SSE-KMS, you can protect your S3 objects by using encryption keys that only specific employees can access, without having to manage the encryption and decryption process yourself.
Option A is not a good solution because it involves using AWS CloudHSM, which is a service that provides hardware security modules (HSMs) in the AWS Cloud. AWS CloudHSM allows you to generate and use your own encryption keys on dedicated hardware that is compliant with various standards and regulations.
However, AWS CloudHSM is not a fully managed service and requires more effort to set up and maintain than AWS KMS. Moreover, AWS CloudHSM does not integrate with Amazon S3, so you have to configure the process that writes to S3 to make calls to CloudHSM to encrypt and decrypt the objects, which adds complexity and latency to the data protection process.
Option B is not a good solution because it involves using server-side encryption with customer-provided keys (SSE-C), which is a feature that allows you to encrypt data at rest in Amazon S3 using keys that you provide and manage yourself. SSE-C requires you to send your encryption key along with each request to upload or retrieve an object. However, SSE-C does not provide any mechanism to restrict access to the keys that encrypt the objects, so you have to implement your own key management and access control system, which adds more effort and risk to the data protection process.
Option D is not a good solution because it involves using server-side encryption with Amazon S3 managed keys (SSE-S3), which is a feature that allows you to encrypt data at rest in Amazon S3 using keys that are managed by Amazon S3. SSE-S3 automatically encrypts and decrypts your objects as they are uploaded and downloaded from S3. However, SSE-S3 does not allow you to control who can access the encryption keys or under what conditions. SSE-S3 uses a single encryption key for each S3 bucket, which is shared by all users who have access to the bucket. This means that you cannot restrict access to the keys that encrypt the objects by specific employees, which does not meet the requirements.
* Protecting Data Using Server-Side Encryption with AWS KMS-Managed Encryption Keys (SSE- KMS) - Amazon Simple Storage Service
* What is AWS Key Management Service? - AWS Key Management Service
* What is AWS CloudHSM? - AWS CloudHSM
* Protecting Data Using Server-Side Encryption with Customer-Provided Encryption Keys (SSE-C) - Amazon Simple Storage Service
* Protecting Data Using Server-Side Encryption with Amazon S3-Managed Encryption Keys (SSE-S3) - Amazon Simple Storage Service
NEW QUESTION # 160
The web-based Amazon Data-Engineer-Associate practice exam does not require special plugins and creates a Data-Engineer-Associate testing atmosphere that removes candidates exam anxiety. "SureTorrent" web-based AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) practice test tracks your progress and helps you overcome mistakes. Our Amazon Data-Engineer-Associate practice exam software displays results at the end of each attempt.
Data-Engineer-Associate Certification Cost: https://www.suretorrent.com/Data-Engineer-Associate-exam-guide-torrent.html
Amazon Data-Engineer-Associate Test Sample Online It will be easy for you to find your prepared learning material, We also offer up to 365 days of free updates so you can prepare as per the AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) latest exam content, The Amazon Data-Engineer-Associate exam questions were developed by SureTorrent in three formats, Amazon Data-Engineer-Associate Test Sample Online PDF Version cannot be purchased separately.
Doing mode" has a massive benefit, You cannot create Recovery Plans Data-Engineer-Associate without first creating Protection Groups, as their name implies the point to the datastores that you have configured for replication.
2026 Amazon Fantastic Data-Engineer-Associate Test Sample OnlineIt will be easy for you to find your prepared learning material, We also offer up to 365 days of free updates so you can prepare as per the AWS Certified Data Engineer - Associate (DEA-C01) (Data-Engineer-Associate) latest exam content.
The Amazon Data-Engineer-Associate exam questions were developed by SureTorrent in three formats, PDF Version cannot be purchased separately, Although the passing rate of our Data-Engineer-Associate study materials is close to 100 %, if you are still worried, we can give you another guarantee: if you don't pass the exam, you can get a full refund.
BONUS!!! Download part of SureTorrent Data-Engineer-Associate dumps for free: https://drive.google.com/open?id=1VhAOOYdq46p9-5LL5ejwkOAZrZe5aL7b
