[General] Best way to practice test for Microsoft AI-102?
91
【General】 Best way to practice test for Microsoft AI-102?
Posted at 2/6/2026 14:23:51      View:125 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassTorrent AI-102 dumps from Cloud Storage: https://drive.google.com/open?id=1rsKRwGHgqeqooN7u5ObDns3d_ZL8Msku
The AI-102 certification verifies that you are a skilled professional. PassTorrent product is designed by keeping all the rules and regulations in focus that Microsoft publishes. Our main goal is that you can memorize the actual Microsoft AI-102 exam question to complete the Designing and Implementing a Microsoft Azure AI Solution (AI-102) test in time with extraordinary grades. Microsoft AI-102 Exam Dumps includes Microsoft AI-102 dumps PDF format, desktop AI-102 practice exam software, and web-based AI-102 practice test software.
Our desktop software also tracks your progress, and identifies your strengths and weaknesses, to ensure you're getting the best possible experience for the AI-102 Exam. All features of the web-based version are available in the desktop software. But the desktop software works offline and only on Windows computers.
Don't Waste Time Preparing for Microsoft AI-102 Exam. Crack it Instantly with This Proven MethodThey work together and put all their expertise, knowledge, and experience and make sure the top standard of PassTorrent AI-102 exam questions all the time. So we can say that the PassTorrent AI-102 exam practice test questions are the ideal study material for quick Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam preparation. The PassTorrent AI-102 exam questions are real, valid, and updated as per the latest Microsoft AI-102 exam syllabus and you can trust it and start Microsoft AI-102 exam preparation right now.
The Designing and Implementing a Microsoft Azure AI Solution certification exam covers various topics related to designing and implementing AI solutions using Azure services, including natural language processing, computer vision, speech recognition, and machine learning. AI-102 Exam also covers topics related to data preparation, data wrangling, and data analysis, which are essential skills for designing and implementing AI solutions. Candidates are expected to have a good understanding of Azure services, including Azure Cognitive Services, Azure Machine Learning, and Azure Databricks.
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q364-Q369):NEW QUESTION # 364
You are developing a streaming Speech to Text solution that will use the Speech SDK and MP3 encoding.
You need to develop a method to convert speech to text for streaming MP3 data.
How should you complete the code? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... compressed-audio-in
NEW QUESTION # 365
You have a mobile app that manages printed forms.
You need the app to send images of the forms directly to Forms Recognizer to extract relevant information.
For compliance reasons, the image files must not be stored in the cloud.
In which format should you send the images to the Form Recognizer API endpoint?
  • A. form URL encoded
  • B. JSON
  • C. raw image binary
The requirement is to process images of forms with Azure Form Recognizer (now part of Azure AI Document Intelligence) while ensuring that the image files are not stored in the cloud.
When sending images directly to the Form Recognizer REST API endpoint, you have two options:
* Send the file as binary data in the request body (for local file upload).
* Send a URL reference (if the file is stored in Azure Blob Storage or another public location).
Since the requirement explicitly states that the image files must not be stored in the cloud, you cannot send a URL. Instead, you must send the raw binary content of the file directly in the request body.
* Option A - raw image binary
* Correct. This allows you to directly send the local image file to the API without uploading/storing it in the cloud.
* Option B - form URL encoded
* Incorrect. Form Recognizer does not accept URL-encoded form data.
* Option C - JSON
* Incorrect. JSON is only used when providing the API with the URL of a cloud-stored document, not when sending the actual file.
The  answer: A. raw image binary
* Form Recognizer REST API - Analyze a document
* Quickstart: Extract layout and text - Document Intelligence"If your document is available locally, pass the file as binary data in the request body."
NEW QUESTION # 366
You are building a chatbot by using the Microsoft Bot Framework Composer.
You have the dialog design shown in the following exhibit.
Dialog RecapThe Bot Framework Composer dialog shown:
* Bot asks: "What is your name?"
* User input stored in user.name.
* Property is user.name with a value expression: =coalesce(@user.Name, @personName)
* Bot asks: "Hello ${user.name}, how old are you?"
* User input stored in user.age.
* user.name is an entity.
* No.
* user.name here is not an entity. It is a property in the bot's memory (user state).
* Entities come from LUIS/CLU recognition, while this is a variable property.
* The dialog asks for a user name and a user age and assigns appropriate values to the user.name and user.
age properties.
* Yes.
* The dialog explicitly prompts for a text input (name) and a number input (age) and assigns them to user.name and user.age.
* The chatbot attempts to take the first non-null entity value for userName or personName and assigns the value to user.name.
* Yes.
* The expression =coalesce(@user.Name, @personName) ensures that if @user.Name exists, it's used; otherwise, it tries @personName. This is exactly first-non-null entity resolution.
Statement Analysis
* user.name is an entity. # No
age properties. # Yes
* The chatbot attempts to take the first non-null entity value for userName or personName and assigns the value to user.name. # Yes Final Answer
* Bot Framework Composer - Memory and Properties
* Expressions and coalesce function
https://docs.microsoft.com/en-us ... language-generation
NEW QUESTION # 367
You are developing a webpage that will use the Video Indexer service to display videos of internal company meetings.
You embed the Player widget and the Cognitive Insights widget into the page.
You need to configure the widgets to meet the following requirements:
Ensure that users can search for keywords.
Display the names and faces of people in the video.
Show captions in the video in English (United States).
How should you complete the URL for each widget? To answer, drag the appropriate values to the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 368
You develop an application that uses the Face API.
You need to add multiple images to a person group.
Box 1: Stream
The File.OpenRead(String) method opens an existing file for reading.
Example: Open the stream and read it back.
using (FileStream fs = File.OpenRead(path))
Box 2: CreateAsync
Create the persons for the PersonGroup. Persons are created concurrently.
Example:
await faceClient.PersonGroupPerson.CreateAsync(personGroupId, personName); Reference:
https://docs.microsoft.com/en-us ... cs/how-to-add-faces
NEW QUESTION # 369
The most distinguished feature of PassTorrent's study guides is that they provide you the most workable solution to grasp the core information of the certification syllabus in an easy to learn set of AI-102 study questions. Far more superior in quality than any online courses free, the questions and answers contain information drawn from the best available sources. They are relevant to the AI-102 Exam standards and are made on the format of the actual AI-102 exam.
Latest AI-102 Exam Forum: https://www.passtorrent.com/AI-102-latest-torrent.html
BONUS!!! Download part of PassTorrent AI-102 dumps for free: https://drive.google.com/open?id=1rsKRwGHgqeqooN7u5ObDns3d_ZL8Msku
