[Hardware] With Fortinet FCP_FGT_AD-7.6 Real Questions Nothing Can Stop You from Getting Su
91
【Hardware】 With Fortinet FCP_FGT_AD-7.6 Real Questions Nothing Can Stop You from Getting Su
Posted at 2/6/2026 14:48:51      View:143 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamBoosts FCP_FGT_AD-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=18S9FfuHmR3Dl0bF82yyyig0nmZIC2wMK
If you want to know the latest information for the exam timely, you can choose us, we can do that for you. We offer you free update for one year for FCP_FGT_AD-7.6 learning materials, so that you can obtain the latest information for the exam. Our system will send you the latest version automatically, and you just need to examine your email for the latest version. In addition, FCP_FGT_AD-7.6 Exam Materials are high-quality, and you can improve your efficiency by using them. We have online and offline service, and if you have any questions for FCP_FGT_AD-7.6 exam braindumps, you can contact us, and we will give you reply as quickly as we can.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Topic 5
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
Reliable FCP_FGT_AD-7.6 Dumps Questions, Valid FCP_FGT_AD-7.6 Exam ReviewOur company is no exception, and you can be assured to buy our FCP_FGT_AD-7.6 exam prep. Our company has been focusing on the protection of customer privacy all the time. We can make sure that we must protect the privacy of all customers who have bought our FCP_FGT_AD-7.6 test questions. If you decide to use our FCP_FGT_AD-7.6 test torrent, we are assured that we recognize the importance of protecting your privacy and safeguarding the confidentiality of the information you provide to us. We hope you will use our FCP_FGT_AD-7.6 Exam Prep with a happy mood, and you don’t need to worry about your information will be leaked out.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q111-Q116):NEW QUESTION # 111
Refer to the exhibits.
The exhibits show a diagram of a FortiGate device connected to the network, as well as the IP pool configuration and firewall policy objects.
The WAN (port2) interface has the IP address 100.65.0.101/24.
The LAN (port4) interface has the IP address 10.0.11.254/24.
Which IP address will be used to source NAT (SNAT) the traffic, if the user on HQ-PC-1 (10.0.11.50) pings the IP address of BR-FGT (100.65.1.111)
  • A. 100.65.0.101
  • B. 100.65.0.149
  • C. 100.65.0.99
  • D. 100.65.0.49
The ping traffic policy uses the IP pool named SNAT-Remote1, which has the external IP range 100.65.0.99. Therefore, traffic matching this policy (ping from HQ-PC-1 to BR1-FGT) will use 100.65.0.99 for source NAT.
NEW QUESTION # 112
The exhibits show a diagram of a FortiGate device connected to the network, as well as the firewall policy and IP pool configuration on the FortiGate device Two PCs PC1 and PC2, are connected behind FortiGate and can access the internet successfully However, when the administrator adds a third PC to the network (PC3), the PC cannot connect to the internet Based on the information shown in the exhibit, which two configuration options can the administrator use to fa the connectivity issue for PC3? (Choose two.)
  • A. In the system settings sot Multiple Interface Policies to enable
  • B. ln the IP pool configuration, set endip to 100.65.0.112.
  • C. In the IP pool configuration, set type to overload.
  • D. In the firewall policy, set match-vip to enable using CLI.
NEW QUESTION # 113
Refer to the exhibits. You have implemented the application sensor and the corresponding firewall policy as shown in the exhibits.
You cannot access any of the Google applications, but you are able to access www.fortinet.com.
What would you do to resolve this issue?
  • A. Change the Inspection mode to Proxy-based.
  • B. Add *Google*.com to the URL category in the security profile.
  • C. Move up Google in the Application and Filter Overrides section to set its priority to 1.
  • D. Set SSL inspection to deep-content-inspection.
In the Application and Filter Overrides, the Excessive-Bandwidth filter (set to Block) is priority 1, and Google (set to Monitor) is priority 2. Since overrides are evaluated by priority, Google traffic is being blocked by the higher-priority rule. Moving Google to the top (priority 1) ensures it is matched first, allowing access while still monitoring it.
NEW QUESTION # 114
Which three statements about SD-WAN performance SLAs are true? (Choose three.)
  • A. They rely on session loss and jitter.
  • B. They are applied in a SD-WAN rule lowest cost strategy.
  • C. They monitor the state of the FortiGate device.
  • D. All the SLAtargets can be configured.
  • E. They can be measured actively or passively.
Answer: A,D,E
SD-WAN SLAs monitor metrics like packet loss and jitter to evaluate link performance. SLA measurements can be performed using active probing or passive monitoring. Administrators can configure all SLA target parameters to define performance criteria.
NEW QUESTION # 115
Refer to the exhibit, which shows an SD-WAN zone configuration on the FortiGate GUI.
Based on the exhibit, which statement is true?
  • A. The virtual-wan-link zone contains no member.
  • B. The underlay zone contains port1 and port2.
  • C. The d-wan zone contains no member.
  • D. The d-wan zone cannot be deleted.
The "d-wan" zone in FortiGate SD-WAN configuration is the default SD-WAN zone created when SD- WAN is enabled. This zone contains all the interfaces assigned to SD-WAN and is essential for the functionality of the SD-WAN feature. The "d-wan" zone cannot be deleted because it is required for SD-WAN operations. Option A is incorrect because the underlay zone does not contain port1.
NEW QUESTION # 116
So many of our worthy customers have achieved success not only on the career but also on the life style due to the help of our FCP_FGT_AD-7.6 study guide. You can also join them and learn our FCP_FGT_AD-7.6 learning materials. You will gradually find your positive changes after a period of practices. Then you will finish all your tasks excellently. You will become the lucky guys if there has a chance. Our FCP_FGT_AD-7.6 Exam Braindumps are waiting for you to have a try.
Reliable FCP_FGT_AD-7.6 Dumps Questions: https://www.examboosts.com/Fortinet/FCP_FGT_AD-7.6-practice-exam-dumps.html
Posted at 3/5/2026 04:53:53        Only Author  2#
Such an enlightening read, I appreciate your sharing! With this Valid study guide C-TS462-2023 ebook, I earned my promotion and salary boost. It’s free for everyone now. Wishing you all success in your career advancement!
