[Hardware] Exam Salesforce Plat-Con-201 Introduction - Valid Braindumps Plat-Con-201 Ppt
91
Hardware Exam Salesforce Plat-Con-201 Introduction - Valid Braindumps Plat-Con-201 Ppt
Posted at 2/6/2026 15:08:20      View205 | Replies1        Print      Only Author   [Copy Link] 1#
As long as you bought our Plat-Con-201 practice guide, then you will find that it cost little time and efforts to learn. You can have a quick revision of the Plat-Con-201 learning quiz in your spare time. Also, you can memorize the knowledge quickly. There almost have no troubles to your normal life. You can make use of your spare moment to study our Plat-Con-201 Preparation questions. The results will become better with your constant exercises. Please have a brave attempt.
It is quite clear that let the facts speak for themselves is more convincing than any word, therefore, we have prepared free demo in this website for our customers to have a taste of the Plat-Con-201 test torrent compiled by our company. You will understand the reason why we are so confident to say that the Plat-Con-201 Exam Torrent compiled by our company is the top-notch Plat-Con-201 exam torrent for you to prepare for the exam. You can choose to download our free demo at any time as you like, you are always welcome to have a try, and we trust that our Plat-Con-201 exam materials will never let you down.
Valid Braindumps Plat-Con-201 Ppt | Plat-Con-201 Valid VceIf you are looking for the latest updated questions and correct answers for Salesforce Plat-Con-201 exam, yes, you are in the right place. Our site is working on providing most helpful the real test questions answer in IT certification exams many years especially for Plat-Con-201. Good site provide 100% real test exam materials to help you clear exam surely. If you find some mistakes in other sites, you will know how the important the site have certain power. Choosing good Plat-Con-201 exam materials, we will be your only option.
Salesforce Certified Omnistudio Consultant Sample Questions (Q17-Q22):NEW QUESTION # 17
An insurance agency wants to enable its call center agents to be more efficient when handling customer inquiries. After analyzing patterns in the call logs, the agency discovers that one of the top customer requests is to find out total insurance premiums paid as well as the difference year over year. Agents need to relay this information to the customer and then send them a summary report by email. The agency decides to implement this process using OmniScript.
What three OmniScrlpts elements should be used to meet the requirements?
Choose 3 answers
  • A. DataRaptor Extract Action
  • B. Calculation Action
  • C. DataRaptor Post Action
  • D. Messaging Element
  • E. Email Action
Answer: A,B,E
The three OmniScript elements that should be used to meet the requirements are: DataRaptor Extract Action, Email Action, and Calculation Action. A DataRaptor Extract Action can retrieve data from a Salesforce object, such as total insurance premiums paid and the difference year over year, and store it in an Interface object or a JSON object. An Email Action can send an email to the customer with a summary report attached, using data from an Interface object or a JSON object. A Calculation Action can perform mathematical operations on data from an Interface object or a JSON object, such as calculating the difference year over year
NEW QUESTION # 18
A company needs an OmniScript to allow customers to order products and services from their website. After the order is submitted, the customer should be able to download a PDF summary of the order.
What type of DataRaptor should the consultant recommend to meet this requirement?
  • A. DataRaptor Load
  • B. DataRaptor Transform
  • C. DataRaptor Extract
  • D. DataRator Turbo Extract
The type of DataRaptor that should be recommended to meet this requirement is DataRaptor Transform.
DataRaptor Transform allows the designer to transform data from one format to another using templates. In this case, a PDF template can be used to generate a PDF summary of the order. DataRaptor Load is used to write data to Salesforce or an external system. DataRaptor Extract is used to retrieve data from Salesforce or an external system. DataRator Turbo Extract is used to retrieve data from Salesforce in batch mode.
NEW QUESTION # 19
Agents for an insurance company need to know the current and past weather conditions when creating claims for customers. The consultant implements a FlexCard for weather conditions in the console to ensure the agents have access to the information. The FlexCard needs to provide fields extracted from a weather API and an account field from Salesforce.
According to best practice, what data source should be used?
  • A. REST
  • B. DataRaptor Extract
  • C. Streaming API
  • D. Integration Procedure
An Integration Procedure is the best data source to use for a FlexCard that needs to provide fields from both an external API and a Salesforce object. An Integration Procedure can combine multiple DataRaptor actions, such as Extract, Transform, and Load, and also invoke REST or SOAP services. This way, the FlexCard can display data from different sources in one place
NEW QUESTION # 20
A company has a process that requires minimum age to purchase. Potential customers must fill in an application form. Rather than have someone fill in the entire form and be denied at the end, 2 consultant recommends using an Omniscript that will ask users to input their birthdate. If the user is younger than than
18 years, then the Omniscript needs to display a message stating "You must be 18 years or older to purchase" and also prevent users from continuing. If the user is 18 or older, then the Omniscript should allow them to proceed without any message.
Which two Omniscript components should the using to meet this validation requirement?
Choose 2 answers
  • A. Alert
  • B. Formula
  • C. Calculation
  • D. Messaging
* Formula (C) - The Formula element calculates whether the user is 18 years or older based on the birthdate they input.
* It performs a real-time calculation using the current date minus the birthdate to determine the age.
* Alert (A) - The Alert element is used to display an error message when the user does not meet the age requirement.
* It prevents the user from proceeding until the condition (age >= 18) is met.
* B. Calculation - Calculation is used for business logic and rules processing, but a Formula element is more suitable for real-time validation within an OmniScript.
* D. Messaging - The Messaging element displays information but does not prevent further progress, while an Alert stops the user from continuing.
Comprehensive and Detailed In-Depth Explanation:Why not the other options?? Salesforce OmniStudio Reference:
* OmniScript Formula Element
* OmniScript Alert Element
NEW QUESTION # 21
A consultant is designing a Flexcard for a client. The client wants the Flexcard to launch a child card with additional information and actions related to the parent card when the agent clicks on a button.
How should the consultant design the Flexcard to meet the client's requirements?
  • A. Design the parent card to launch a child card through a Flyout Action.
  • B. Design the parent card to launch a new Data Mapper when the specific action is taken.
  • C. Design the parent card to launch a child card when the specific action is taken.
  • D. Design the parent card to launch a new Omniscript when the specific action is taken,
The requirement is for a FlexCard (parent card) to launch a child card with additional information and actions when an agent clicks a button. In Salesforce OmniStudio, the Flyout Action is the specific mechanism designed within FlexCards to achieve this, making B the most precise and correct answer.
Here's why B. Design the parent card to launch a child card through a Flyout Action is the correct answer:
* Flyout Action Overview: A Flyout Action in FlexCards is an interactive feature that displays a pop-up panel (flyout) when triggered, typically by a button or link. This flyout can contain a child FlexCard, OmniScript, or custom content, showing additional details or enabling actions related to the parent card' s data.
* Meeting the Requirement:
* Child Card Launch: The Flyout Action can embed a child FlexCard, which displays supplemental information (e.g., related records or details) and includes actions (e.g., buttons to update data).
* Button Trigger: In the FlexCard Designer, the consultant can add a Button element to the parent card, configure its action type as "Flyout," and link it to a child FlexCard. When the agent clicks the button, the flyout appears with the child card.
* Contextual Data: The parent card's data (e.g., a record ID) can be passed to the child card via the Flyout Action's context parameters, ensuring the child card shows relevant information.
* Example: If the parent card displays a customer's summary (name, account number), clicking the button could launch a child card in a flyout showing order history and a button to initiate a return, all tied to the parent card's account ID.
Now, let's examine why the other options are incorrect or less optimal:
* A. Design the parent card to launch a child card when the specific action is taken: While this is conceptually correct, it's vague and lacks specificity. "Launch a child card" isn't a defined OmniStudio action-Flyout Action is the actual mechanism to achieve this. Thus, B is the more precise answer, as it names the tool explicitly supported by FlexCards.
* C. Design the parent card to launch a new DataRaptor when the specific action is taken: A DataRaptor (e.g., DataRaptor Extract) retrieves or manipulates data, not displays a UI like a child card. While a DataRaptor might fetch data for the child card, it doesn't "launch" anything visible to the agent, making this option irrelevant to the UI requirement.
* D. Design the parent card to launch a new OmniScript when the specific action is taken: An OmniScript could be launched via a FlexCard action (e.g., an "OmniScript" action type), but it's a guided process, not a "child card." The requirement specifies a child card (implying another FlexCard), not a multi-step script, so a Flyout Action with a child FlexCard is more appropriate than an OmniScript.
* Salesforce OmniStudio Documentation: FlexCard Actions - Details the Flyout Action for launching child cards or content.
* Salesforce OmniStudio Developer Guide: Flyouts in FlexCards - Explains configuring flyouts with child FlexCards.
NEW QUESTION # 22
Our Salesforce Exam Questions greatly help Salesforce Certified Omnistudio Consultant (Plat-Con-201) exam candidates in their preparation. Our Salesforce Certified Omnistudio Consultant (Plat-Con-201) practice questions are designed and verified by prominent and qualified Salesforce Certified Omnistudio Consultant (Plat-Con-201) exam dumps preparation experts. The qualified Salesforce Certified Omnistudio Consultant (Plat-Con-201) exam questions preparation experts strive hard and put all their expertise to ensure the top standard and relevancy of Plat-Con-201 exam dumps topics.
Valid Braindumps Plat-Con-201 Ppt: https://www.actual4dump.com/Salesforce/Plat-Con-201-actualtests-dumps.html
Salesforce Exam Plat-Con-201 Introduction When we need to use the knowledge we must learn again, We are sure, all the aspiring potential professionals are intended to attempt Plat-Con-201 exam dumps to update their credentials, Salesforce Exam Plat-Con-201 Introduction Just visit us for further details, Salesforce Valid Braindumps Plat-Con-201 Ppt Valid Braindumps Plat-Con-201 Ppt is the industry leader in information technology, and getting certified by them is a guaranteed way to succeed with IT careers, And a lot of our worthy customers praised our accuracy for that sometimes they couldn't find the Plat-Con-201 exam braindumps on the other websites or they couldn't find the updated questions and answers.
To understand why the joint filter produced a slightly lower return, understand Plat-Con-201 that the joint filter switched risk off" for some borderline volatile months, In some cases, this question is very easy to answer.
Salesforce Exam Plat-Con-201 Introduction: Salesforce Certified Omnistudio Consultant - Actual4dump Help you PassWhen we need to use the knowledge we must learn again, We are sure, all the aspiring potential professionals are intended to attempt Plat-Con-201 Exam Dumps to update their credentials.
Just visit us for further details, Salesforce Salesforce Consultant is the Exam Plat-Con-201 Introduction industry leader in information technology, and getting certified by them is a guaranteed way to succeed with IT careers.
Posted at 4/20/2026 08:54:11        Only Author  2#
Im in total awe of your article, thank you for letting us read it! Wishing you success! Here are the free study materials for ServSafe-Manager resources for you!
