[Hardware] Analytics-Con-201 Exam Consultant | Exam Analytics-Con-201 Exercise
62
Hardware Analytics-Con-201 Exam Consultant | Exam Analytics-Con-201 Exercise
Posted at 2/7/2026 02:53:30      View111 | Replies0        Print      Only Author   [Copy Link] 1#
If you do not have access to internet most of the time, if you need to go somewhere is in an offline state, but you want to learn for your Analytics-Con-201 exam. Don not worry, our products will help you solve your problem. We deeply believe that our latest Analytics-Con-201 exam torrent will be very useful for you to strength your ability, pass your exam and get your certification. Our study materials with high quality and high pass rate in order to help you get out of your harassment. So, act now! Use our Analytics-Con-201 Quiz prep.
Salesforce Certified CRM Analytics and Einstein Discovery Consultant (Analytics-Con-201) questions is a comprehensive solution for Analytics-Con-201 exam preparation, offering a wide range of features designed to help you succeed. The Salesforce exam is an essential milestone to achieve the Analytics-Con-201 Certification. With Analytics-Con-201 exam dumps, you'll have access to Salesforce Analytics-Con-201 actual questions that are enough to crack the Analytics-Con-201 exam in a short time.
Quiz 2026 Analytics-Con-201: Updated Salesforce Certified CRM Analytics and Einstein Discovery Consultant Exam ConsultantIn order to let you have a deep understanding of our Analytics-Con-201 learning guide, our company designed the trial version for our customers. We will provide you with the trial version of our Analytics-Con-201 study materials before you buy our products. If you want to know our Analytics-Con-201 Training Materials, you can download the trial version from the web page of our company. It is easy and fast to download the free trial version of our Analytics-Con-201 exam braindumps.
Salesforce Certified CRM Analytics and Einstein Discovery Consultant Sample Questions (Q87-Q92):NEW QUESTION # 87
A system administrator at Cloud Kicks creates a joined report to showcase the new business deals closing in the current quarter, which was well received by the business stakeholders. A manager wants to visualize this report on CRM Analytics.
The CRM Analytics consultant determines the report can be trended on CRM Analytics, but it's not working as expected.
What is causing the issue?
  • A. Trending dashboards cannot be created from joined reports.
  • B. The Analytics Integration user did not have permission to view the report on Salesforce.
  • C. The Salesforce report was filtered on quarterly data which meant it did not have enough data to trend on CRM Analytics.
NEW QUESTION # 88
Several users are complaining they are unable to see a specific dashboard on a Salesforce Lightning page anymore. The CRM Analytics consultant logs in as one of the users and sees an error page once the dashboard is opened.
How should the consultant solve this issue?
  • A. Check the Analytics Studio app to see if user's access has been removed.
  • B. Open the Lightning page, remove the dashboard component, reinsert it, and save the page.
  • C. Clone the dashboard and replace the existing one on the Lightning page with the new one
NEW QUESTION # 89
CRM Analytics users at Cloud Kicks are granted access to an app with specific dashboards. When trying to download a specific widget, they are unable to do so.
  • A. The users have access to the dashboard but not the dataset.
  • B. The dashboard has been created for internal use and the users have a view only license.
  • C. The permission set for the users Is missing the download data permission.
As in the previous question, the issue is related to permissions. Users can be granted access to dashboards and apps, but if their permission set does not explicitly allow the "Download Data" action, they will not be able to download the widget data. This is a common issue encountered when users have restricted permissions, especially in environments where security and data access are tightly controlled.
NEW QUESTION # 90
Universal Containers' CRM Analytics team is building a dashboard with two widgets.
1. List widget associated to the query "Type_2" and grouped by the dimension "Type" (multi-selection)
2. Donut chart widget associated to the query "Step_pie_3" and grouped by the dimension "Type" The team wants to use bindings/interactions so any selection in the List widget will filter the Donut chart. The queries use different datasets, and users should be able to choose more than one Type (multi-selection).
What is the right syntax for the binding/interaction?
  • A.
  • B.
  • C.
For the given requirement where a selection in a list widget needs to filter data displayed on a donut chart, and considering the list allows for multi-selection of the 'Type', the correct binding/interaction would be to use a syntax that captures the multi-select aspect and passes it appropriately. The right syntax, as indicated in Option A, looks like this:
"{{column(Type_2.selection, ["Type"]).asObject()}}"
This syntax ensures:
* Multi-selection: The column() function in combination with .asObject() ensures that multiple selected values from the 'Type_2' query can be passed as an object, which the donut chart can utilize to filter its content.
* Correct Data Type Handling: By using .asObject(), the binding ensures the data passed between widgets maintains the correct structure expected by the CRM Analytics dashboard, thereby ensuring accurate filtering.
NEW QUESTION # 91
Which capability can a consultant use if "Deploy without connecting to a Salesforce Object" is selected while deploying the model?
  • A. Einstein Predictions Component score
  • B. Predict Function in Salesforce flows
  • C. No-Code Writeback to SFDC objects
When deploying a model with the option "Deploy without connecting to a Salesforce Object", the suitable capabilities include:
* Use of Predict Function in Salesforce Flows: This capability allows the deployed model to be used within Salesforce Flow as a predictive tool, enabling automation flows to include predictions without directly writing back to Salesforce objects.
* Flexibility in Application: This method provides flexibility in how predictions are utilized across various Salesforce processes and workflows, without the need for direct data manipulation within Salesforce objects.
* Enhanced Workflow Integration: By integrating predictive insights directly into flows, organizations can automate decision-making processes, enhance user interactions, and streamline operations based on predictive outcomes.
This setup aligns with Salesforce's best practices for leveraging CRM Analytics to enhance operational efficiency and decision accuracy across different business functions.
NEW QUESTION # 92
With our Analytics-Con-201 practice test software, you can simply assess yourself by going through the Analytics-Con-201 practice tests. We highly recommend going through the Analytics-Con-201 answers multiple times so you can assess your preparation for the Salesforce Certified CRM Analytics and Einstein Discovery Consultant. Make sure that you are preparing yourself for the Analytics-Con-201 test with our practice test software as it will help you get a clear idea of the real Analytics-Con-201 exam scenario. By passing the exams multiple times on practice test software, you will be able to pass the real Analytics-Con-201 test in the first attempt.
Exam Analytics-Con-201 Exercise: https://www.testkingit.com/Salesforce/latest-Analytics-Con-201-exam-dumps.html
As we know the official departments do not provide Analytics-Con-201 actual lab questions: Salesforce Certified CRM Analytics and Einstein Discovery Consultant, they hope learners can read the teaching books seriously, Analytics-Con-201 study guide materials of us are compiled by experienced experts, and they are familiar with the exam center, therefore the quality can be guaranteed, Salesforce Analytics-Con-201 Exam Consultant Dear customers, welcome to get to know about our products.
As a side effect, the descriptor table becomes part Analytics-Con-201 of the segment and can be accessed by all code that has sufficient access rights, Working with Sites, As we know the official departments do not provide Analytics-Con-201 actual lab questions: Salesforce Certified CRM Analytics and Einstein Discovery Consultant, they hope learners can read the teaching books seriously.
Hot Analytics-Con-201 Exam Consultant Pass Certify | Pass-Sure Exam Analytics-Con-201 Exercise: Salesforce Certified CRM Analytics and Einstein Discovery ConsultantAnalytics-Con-201 study guide materials of us are compiled by experienced experts, and they are familiar with the exam center, therefore the quality can be guaranteed, Dear customers, welcome to get to know about our products.
You will be surprised by the high-effective of our Analytics-Con-201 study guide, Our products' test bank covers the entire syllabus of the test and all the possible questions which may appear in the test.
