[General] Valid JN0-351 Exam Pattern | JN0-351 Reliable Test Topics
99
【General】 Valid JN0-351 Exam Pattern | JN0-351 Reliable Test Topics
Posted at 2/7/2026 03:03:29      View:135 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ITExamDownload JN0-351 dumps for free: https://drive.google.com/open?id=1klBsrbN1-whvfe06HUztjD0Flkd9QOJi
Do you feel Juniper JN0-351 exam preparation is tough? ITExamDownload desktop and web-based online Juniper JN0-351 practice test software will give you a clear idea about the final JN0-351 Test Pattern. Practicing with the Juniper JN0-351 practice test, you can evaluate your Juniper JN0-351 exam preparation.
Juniper JN0-351 Exam Syllabus Topics:
  • OSPF: The concepts and operational details of OSPF are explored, providing tools for routing efficiency. Configuration and troubleshooting mastery ensure readiness for both the exam and complex enterprise environments.
  • Protocol Independent Routing: An essential domain for understanding routing components outside protocol dependencies, this topic enhances expertise in configuring, monitoring, and troubleshooting critical elements.
  • BGP: This topic focuses on the operational and conceptual elements of BGP, a cornerstone in enterprise networks.
  • Spanning Tree: Networking professionals explore the principles and advantages of the Spanning Tree Protocol (STP) to ensure loop-free topologies in Layer 2 networks.
Topic 5
  • Tunnels: The fundamentals of IP tunneling are emphasized, highlighting their requirements and functionalities. Mastery in configuring, monitoring, and troubleshooting tunnels equips professionals to meet the demands of the JN0-351 Exam.
Topic 6
  • IS-IS: Aspiring Juniper networking professionals enhance their understanding of IS-IS routing protocols. This topic equips candidates with the knowledge to configure and monitor IS-IS systems, addressing specific exam challenges and practical applications.
JN0-351 Reliable Test Topics | Testking JN0-351 Exam QuestionsOur users are all over the world and they have completed their exams through the help of our JN0-351 study guide. As you can see the feedbacks from our loyal customers, all of them are grateful to our JN0-351 exam braindumps and become succussful people with the JN0-351 Certification. And what are you waiting for? Just selecting our JN0-351 learning materials, the next one to get an international certificate is you!
Juniper Enterprise Routing and Switching, Specialist (JNCIS-ENT) Sample Questions (Q111-Q116):NEW QUESTION # 111
You are a network operator who wants to add a second ISP connection and remove the default route to the existing ISP You decide to deploy the BGP protocol in the network.
What two statements are correct in this scenario? (Choose two.)
  • A. IBGP peers advertise routes received from IBGP peers to other IBGP peers.
  • B. IBGP peers advertise routes received from EBGP peers to other IBGP peers.
  • C. IBGP updates the next-hop attribute to ensure reachability within an AS.
  • D. EBGP peers advertise routes received from IBGP peers to other EBGP peers.
A is correct because IBGP updates the next-hop attribute to ensure reachability within an AS. This is because the next-hop attribute is the IP address of the router that advertises the route to a BGP peer. If the next-hop attribute is not changed by IBGP, it would be the IP address of an external router, which may not be reachable by all routers within the AS. Therefore, IBGP updates the next-hop attribute to the IP address of the router that received the route from an EBGP peer1.
B is correct because IBGP peers advertise routes received from EBGP peers to other IBGP peers. This is because BGP follows the rule of advertising only the best route to a destination, and EBGP routes have a higher preference than IBGP routes. Therefore, IBGP peers advertise routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers1.
NEW QUESTION # 112
Referring to the exhibit, which router will become the OSPF BDR if all routers are powered on at the same time?
  • A. R3
  • B. R2
  • C. R1
  • D. R4
Priority set to 0 will never become DR or BDR so R1 is excluded.
Higher priority is better in OSPF so R2 is lowest than both R3 and R4.
R3 and R4 has the same priority so RID will decide.
R4 has the highest RID so it will become DR and R3 will then become BDR.
NEW QUESTION # 113
Referring to the exhibit, which two statements are correct? (Choose two.)
  • A. The ge-0/0/10 interface will not participate in the RSTP topology.
  • B. The ge-0/0/13 interface will be selected as the forwarding interface.
  • C. This device must be selected as the root bridge.
  • D. The ge-0/0/10 interface will be part of the RSTP topology but will block incoming BPDUs.
NEW QUESTION # 114
Which two statements are true about the default VLAN on Juniper switches? (Choose two.)
  • A. The default VLAN ID can be changed.
  • B. The default VLAN ID is not visible.
  • C. The default VLAN ID is not assigned to any interface.
  • D. The default VLAN is set to a VLAN ID of 1 by default
Answer: A,D
On Juniper switches, the default VLAN is set to a VLAN ID of 1 by default. This means that all interfaces on the switch are members of VLAN until they are specifically assigned to another VLAN. Therefore, option A is correct.
The default VLAN ID can be changed. This allows network administrators to configure the switch to use a different VLAN as the default, if necessary. Therefore, option D is correct.
NEW QUESTION # 115
You are an operator for a network running 1S-IS. Two routers are failing to form an adjacency. What are two reasons for this problem? (Choose two.)
  • A. There are mismatched router IDs on the L2 routers.
  • B. There is no configured ISO address on any IS-IS interface.
  • C. There is a mismatched area ID between the L2 routers.
  • D. The family iso configuration is missing from the adjacency interface.
The two reasons for the failure to form an adjacency in a network running IS-IS could be:
B: There is no configured ISO address on any IS-IS interface. IS-IS requires each router interface to have an ISO address configured. Without this address, the routers cannot form an adjacency1.
D: The family iso configuration is missing from the adjacency interface. The 'family iso' configuration is essential for IS-IS to function correctly. If this configuration is missing from the adjacency interface, it could prevent the formation of an adjacency1.
These explanations are based on the Enterprise Routing and Switching Specialist (JNCIS-ENT) documents and learning resources available at Juniper Networks23.
NEW QUESTION # 116
Long time learning might makes your attention wondering but our effective JN0-351 study materials help you learn more in limited time with concentrated mind. Just visualize the feeling of achieving success by using our JN0-351 exam guide,so you can easily understand the importance of choosing a high quality and accuracy JN0-351 training engine. You will have handsome salary get higher chance of winning and separate the average from a long distance and so on.
JN0-351 Reliable Test Topics: https://www.itexamdownload.com/JN0-351-valid-questions.html
BTW, DOWNLOAD part of ITExamDownload JN0-351 dumps from Cloud Storage: https://drive.google.com/open?id=1klBsrbN1-whvfe06HUztjD0Flkd9QOJi
Posted at 2/7/2026 14:18:44        Only Author  2#
Xhs1991は多くの認証業界の評判を持っています。それは我々はCiscoの300-540問題集や300-540スタディガイドや300-540問題と解答がたくさんありますから。現在のサイトで最もプロなITテストベンダーとして我々は完璧なアフターサービスを提供します。全てのお客様に追跡サービスを差し上げますから、あなたが買ったあとの一年間で、弊社は全てのお客様に問題集のアップグレードを無料に提供します。その間で認定テストセンターのCiscoの300-540試験問題は修正とか表示されたら、無料にお客様に保護して差し上げます。Ciscoの300-540試験問題集はXhs1991のIT領域の専門家が心を込めて研究したものですから、Xhs1991のCiscoの300-540試験資料を手に入れると、あなたが美しい明日を迎えることと信じています。
Posted at 2/10/2026 07:07:33        Only Author  3#
どのようにITIL ITIL-4-Transition-JPN試験に準備すると悩んでいますか。我々社のITIL-4-Transition-JPN問題集を参考した後、ほっとしました。弊社のITIL-4-Transition-JPNソフト版問題集はかねてより多くのIT事業をしている人々は順調にITIL ITIL-4-Transition-JPN資格認定を取得させます。試験にパースする原因は我々問題集の全面的で最新版です。
