[General] Operations-Management最新考古題,Operations-Management最新考證
92
【General】 Operations-Management最新考古題,Operations-Management最新考證
Posted at 2/8/2026 12:53:57      View:115 | Replies:0        Print      Only Author   [Copy Link] 1#
雖然大多數人會覺得通過WGU Operations-Management認證考試很難。但是如果你選擇了我們的NewDumps,你會覺得拿到WGU Operations-Management認證考試的證書不是那麼難了。NewDumps的訓練工具很全面,包含線上服務和售後服務。我們的線上服務是研究資料,它包含類比訓練題,和WGU Operations-Management認證考試相關的考試練習題和答案。售後服務是NewDumps不僅能提供最新的WGU Operations-Management認證考試練習題和答案以及動態消息,還不斷的更新考試練習題和答案和裝訂。
為什麼我們領先於行業上的其他網站? 因為我們提供的資料覆蓋面更廣,品質更高,準確性也更高。所以NewDumps是你參加WGU Operations-Management 認證考試的最好的選擇,也是你成功的最好的保障。
Operations-Management PDF考古題雖然有其他的線上WGU的Operations-Management考試培訓資源在市場上,但我們NewDumps WGU的Operations-Management考試培訓資料是最好的。因為我們會定期更新,始終提供準確的WGU的Operations-Management考試認證資料,我們NewDumps WGU的Operations-Management考試培訓資料提供一年的免費更新,你會得到最新的更新了的NewDumps WGU的Operations-Management考試培訓資料。
最新的 Courses and Certificates Operations-Management 免費考試真題 (Q69-Q74):問題 #69
Why is capacity requirements planning (CRP) important?
  • A. It coordinates availability of materials for production processes.
  • B. It creates a transparent view of lead time and overtime usage in work centers.
  • C. It provides the ability to compare available production capabilities to the planned workload.
  • D. It enables an assessment of employee production efficiency.
答案:C
解題說明:
Capacity Requirements Planning (CRP) is important because itcompares available production capacity to planned workloads, ensuring feasibility.
Once demand has been translated into production and material plans, CRP validates whether:
* Machines are available
* Labor hours are sufficient
* Work centers are not overloaded
Without CRP, organizations risk releasing production plans that cannot be executed, resulting in:
* Bottlenecks
* Overtime
* Missed delivery dates
* Poor resource utilization
The incorrect options describe other functions:
* Employee efficiency is evaluated through performance metrics
* Lead time transparency is a scheduling outcome, not CRP's core purpose
* Material coordination is handled by MRP
CRP ensures alignment betweenwhat is plannedandwhat is possible, making it a critical link between planning and execution in Operations Management.
問題 #70
Which definition used for quality evaluates how well a product performs its intended function?
  • A. Value for price paid
  • B. Fitness for use
  • C. Psychological criteria
  • D. Support services
答案:B
解題說明:
The concept ofquality as "fitness for use"evaluates how well a product or service performs itsintended function from the customer's perspective. This definition was strongly emphasized by quality pioneer Joseph Juranand is widely adopted in Operations Management and Total Quality Management (TQM) frameworks.
Fitness for use means that a product must not only meet technical specifications but must alsoperform reliably, safely, and effectively in real customer usage conditions. For example, a shoe that looks attractive but causes discomfort or wears out quickly is not "fit for use," even if it meets internal manufacturing standards.
This definition contrasts with other quality perspectives:
* Support servicesfocus on after-sales service, not the product's core function.
* Value for price paidevaluates perceived value, which includes cost considerations.
* Psychological criteriarelate to image, aesthetics, or brand perception.
Operations Management emphasizes fitness for use because it directly linksdesign, production, and customer satisfaction. Products designed without considering how customers actually use them often lead to defects, complaints, and warranty costs-even if internal quality standards are met.
Fitness for use also reinforcescross-functional coordination, especially between marketing (understanding customer needs), design (translating needs into specifications), and operations (producing consistently). This definition supports continuous improvement by encouraging organizations to reduce variability, improve reliability, and focus on customer-defined quality rather than internally defined metrics alone.
問題 #71
Which two capacity measurement concepts should a firm consider when conducting a location analysis?
Choose 2 answers
  • A. Site considerations
  • B. Building employee relations
  • C. Proximity to sources of supply
  • D. Throughput time
答案:A,C
解題說明:
When conducting a location analysis, firms must considerproximity to sources of supplyandsite considerationsas key capacity-related factors.
Proximity to sources of supplyaffects:
* Transportation cost and reliability
* Lead times
* Inventory requirements
* Production continuity
Reliable supply access directly influences effective capacity by reducing disruptions and variability.
Site considerationsinclude:
* Land availability and cost
* Infrastructure and utilities
* Expansion potential
* Zoning and regulatory constraints
These factors determine how much capacity can be installed, expanded, and operated efficiently over time.
The other options are less relevant:
* Throughput time is a process performance metric
* Employee relations are important but not capacity measurement concepts Operations Management emphasizes that capacity decisions are long-term and capital-intensive. Poor location choices constrain future capacity, flexibility, and growth.
問題 #72
Why is kanban significant to the "pull" system?
  • A. It is a process that is only for support or maintenance.
  • B. It is a process that highlights the highest-performing organization.
  • C. It requires that all work items are sized the same.
  • D. It specifies the exact quantity of a product that needs to be produced.
答案:D
解題說明:
Kanbanis significant to the pull system because itspecifies the exact quantity of a product that needs to be produced.
In a pull system, production is triggered byactual demand, not forecasts. Kanban cards or signals authorize the movement or production of a specific quantity only when downstream processes require it.
Kanban supports:
* Inventory reduction
* Flow synchronization
* Waste elimination
* Visual control
Each kanban represents permission to produce or move a defined quantity, preventing overproduction-one of the most costly forms of waste.
* Work items do not need to be identical
* Kanban applies to core production, not just support
* It does not rank organizations
Kanban is a cornerstone of JIT and lean systems because it operationalizes the pull principle in a simple, visual, and disciplined way.
問題 #73
Which work system acknowledges the benefits of employee proficiency?
  • A. Enhanced employee relations
  • B. Employee longevity
  • C. Lower operating cost
  • D. Labor specialization
答案:D
解題說明:
Comprehensive and Detailed Explanation (#250 words):
Labor specializationacknowledges the benefits of employee proficiency by allowing workers to focus on specific tasks, increasing skill, speed, and consistency.
In Operations Management, labor specialization:
* Reduces learning time
* Increases productivity
* Improves quality consistency
* Lowers unit costs
Employees become highly proficient through repetition and experience. This principle underpins early scientific management and remains relevant in many high-volume environments.
The other options are outcomes or enablers, not work systems:
* Employee longevity is a result, not a system
* Enhanced relations support performance but do not define task design
* Lower operating cost is a consequence of specialization
While specialization can create efficiency, it must be balanced with job design strategies (e.g., enrichment or rotation) to avoid fatigue and disengagement.
問題 #74
通過WGU Operations-Management 認證考試的方法有很多種,花大量時間和精力來復習WGU Operations-Management 認證考試相關的專業知識是一種方法,通過少量時間和金錢選擇使用NewDumps的針對性訓練和練習題也是一種方法。
Operations-Management最新考證: https://www.newdumpspdf.com/Operations-Management-exam-new-dumps.html
所有購買 NewDumps Operations-Management最新考證 WGU Operations-Management最新考證認證題庫學習資料的客戶都將得到半年的免費升級服務,確保您的題庫學習資料始終保持最新狀態,我們NewDumps WGU的Operations-Management考試學習指南可以成為你職業生涯中的燈塔,因為它包含了一切需要通過的Operations-Management考試,選擇我們NewDumps,可以幫助你通過考試,這是個絕對明智的決定,因為它可以讓你從那些可怕的研究中走出來,NewDumps就是你的幫手,你可以得到雙倍的結果,只需要付出一半的努力,如果您購買我們的 Operations-Management 題庫,首次考試沒有通過,憑借您的 WGU Operations Management (C215, VDC2) 考試成績單,我們將退還您購買考題的全部費用,絕對保證您的利益不受到任何的損失,NewDumps Operations-Management最新考證致力於為客戶提供WGU Operations-Management最新考證認證的題庫學習資料,幫助客戶通過WGU Operations-Management最新考證認證考試。
小男孩蒙著眼睛走路,在他身上絲毫看不到那種失明人的消沈與低迷,在接下來的幾周中,Operations-Management我們將詳細討論該報告,所有購買 NewDumps WGU認證題庫學習資料的客戶都將得到半年的免費升級服務,確保您的題庫學習資料始終保持最新狀態。
Pass-Sure Operations-Management最新考古題和資格考試中的領先供應商和奇妙的WGU WGU Operations Management (C215, VDC2)我們NewDumps WGU的Operations-Management考試學習指南可以成為你職業生涯中的燈塔,因為它包含了一切需要通過的Operations-Management考試,選擇我們NewDumps,可以幫助你通過考試,這是個絕對明智的決定,因為它可以讓你從那些可怕的研究中走出來,NewDumps就是你的幫手,你可以得到雙倍的結果,只需要付出一半的努力。
如果您購買我們的 Operations-Management 題庫,首次考試沒有通過,憑借您的 WGU Operations Management (C215, VDC2) 考試成績單,我們將退還您購買考題的全部費用,絕對保證您的利益不受到任何的損失,NewDumps致力於為客戶提供WGU認證的題庫學習資料,幫助客戶通過WGU認證考試。
那麼,如何才能保證我們都能高效的使用它?
