[General] Quiz C-THR82-2505 - Valid SAP Certified Associate - SAP SuccessFactors Performan
103
【General】 Quiz C-THR82-2505 - Valid SAP Certified Associate - SAP SuccessFactors Performan
Posted at 2/8/2026 22:13:48      View:90 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Exam4Labs C-THR82-2505 dumps now are free: https://drive.google.com/open?id=1wT__RazcopBvRgM97vaKHWIQe2IYZziK
There are three different versions of our C-THR82-2505 exam questions to meet customers' needs you can choose the version that is suitable for you to study. If you buy our C-THR82-2505 test torrent, you will have the opportunity to make good use of your scattered time to learn. If you choose our C-THR82-2505 study torrent, you can make the most of your free time. So using our C-THR82-2505 Exam Prep will help customers make good use of their fragmentation time to study and improve their efficiency of learning. It will be easier for you to pass your C-THR82-2505 exam and get your certification in a short time.
SAP C-THR82-2505 Exam Syllabus Topics:
  • Configuration of Performance Management: This section of the exam measures skills of SAP Consultants in managing backend configuration for performance processes. It involves provisioning settings, XML modifications, and basic system integrations to ensure successful form deployment.
  • Job Architecture and Attributes: This section of the exam assess|es the knowledge of SAP Consultants in working with job structure elements. It includes configuration of job roles, families, and attributes that are essential for defining performance expectations and linking goals to job frameworks.
  • 360 Reviews: This section of the exam measures skills of Performance Management Specialists in configuring and deploying 360-degree feedback processes. It covers form templates, participant selection, and distribution workflows to gather comprehensive peer evaluations.
  • Form Templates: This section of the exam evaluates the abilities of Performance Management Specialists to create and customize performance review forms. It includes form sections, rating scales, and layout settings necessary for collecting structured employee evaluations.
Topic 5
  • AI Features: This section of the exam measures skills of SAP Consultants in applying AI-driven enhancements in performance management. It involves configuring features like intelligent suggestions and automated summaries to improve efficiency and personalization.
SAP C-THR82-2505 Dumps - Pass Exam And Build Successful CareerOur C-THR82-2505 exam braindumps are famous for its advantage of high efficiency and good quality which are carefully complied by the professionals. Our excellent professionals are furnishing exam candidates with highly effective C-THR82-2505 Study Materials, you can even get the desirable outcomes within one week. By concluding quintessential points into C-THR82-2505 actual exam, you can pass the exam with the least time while huge progress.
SAP Certified Associate - SAP SuccessFactors Performance and Goals Sample Questions (Q53-Q58):NEW QUESTION # 53
You are configuring hidden-threshold="2" for the Direct Report category.
What can happen when the subject of the form has only one direct report in the list of raters? Note: There are 2 correct answers to this question.
  • A. The hidden-threshold attribute can cause a message to be displayed that states the minimum is NOT met for the direct report category.
  • B. The hidden-threshold attribute can cause the direct report category to be dropped from the Detailed 360 Report.
  • C. The hidden-threshold attribute can cause the Direct Report category to roll up with another category in the Detailed 360 Report.
  • D. The hidden-threshold attribute can cause an error message to be displayed with the number of users in the direct report category.
NEW QUESTION # 54
You want to create a goal plan template. Which of the following methods are recommended?
  • A. Copy an existing goal plan XML, change the plan ID to a unique ID, and import it in Manage Templates.
  • B. Copy an existing goal plan XML, change the plan ID to a unique ID, and import it in Provisioning.
  • C. Download a template from the Software Download Center.
  • D. Copy an existing goal plan and save as a new version in Manage Templates.
  • E. Download a template from the SuccessStore.
Answer: B,D,E
Recommended methods for creating a goal plan template include:
* Downloading from SuccessStore: Provides pre-configured templates.
* Copying and modifying XML in Manage Templates: Allows customization of an existing template.
* Copying and saving as a new version in Manage Templates: Creates a new version of an existing plan.
Extract from SAP SuccessFactors Documentation:
* SAP SuccessFactors Goal Management Guide (Q3 2025):"To create a goal plan template, administrators can download a template from the SuccessStore, copy an existing goal plan XML and modify the plan ID for import in Manage Templates, or copy an existing goal plan and save it as a new version in Manage Templates." Explanation of Options:
* A. Correct: SuccessStore templates are recommended.
* B. Correct: Copying and importing in Manage Templates is supported.
* C. Incorrect: Provisioning is used for system-level configurations, not template imports.
* D. Correct: Saving as a new version in Manage Templates is valid.
* E. Incorrect: Software Download Center is not a source for goal plan templates.
SAP SuccessFactors Goal Management Guide, Section: "Creating Goal Plan Templates," Subsection:
"Recommended Methods" (Q3 2025).
NEW QUESTION # 55
Which actions can you enable and disable in Continuous Performance Management Configuration (CPM)? Note: There are 3 correct answers to this question.
  • A. Prevent feedback deletion by users
  • B. Support multiple roles
  • C. Use Al-assisted writing
  • D. Access the Delete Continuous Feedback page
  • E. Provide discussion topics
Answer: A,B,E
NEW QUESTION # 56
What can you do in Form Template Settings?
  • A. Upload an XML file in order to create a new template.
  • B. Download the latest XML file of a template.
  • C. Delete a template.
  • D. Upload an XML file in order to update an existing template.
NEW QUESTION # 57
If you are using distribution guidelines in calibration, where are they visible? Note: There are 3 correct answers to this question.
  • A. Dashboard view
  • B. List view
  • C. Executive review
  • D. Bin view
  • E. Matrix Grid view
Answer: A,C,D
NEW QUESTION # 58
Exam4Labs offers actual and updated C-THR82-2505 Dumps after seeing the students struggling to prepare quickly for the test. We have made this product after consulting with a lot of professionals so the students can be successful. Exam4Labs has hired a team of professionals who work on a daily basis without caring about themselves to update the SAP C-THR82-2505 practice material.
C-THR82-2505 Valid Exam Vce Free: https://www.exam4labs.com/C-THR82-2505-practice-torrent.html
2026 Latest Exam4Labs C-THR82-2505 PDF Dumps and C-THR82-2505 Exam Engine Free Share: https://drive.google.com/open?id=1wT__RazcopBvRgM97vaKHWIQe2IYZziK
