[General] NSE5_FNC_AD_7.6 Download Demo & Exam NSE5_FNC_AD_7.6 Syllabus
104
General NSE5_FNC_AD_7.6 Download Demo & Exam NSE5_FNC_AD_7.6 Syllabus
Posted at 2/9/2026 02:53:24      View121 | Replies1        Print      Only Author   [Copy Link] 1#
Are you still satisfied with your present job? Do you still have the ability to deal with your job well? Do you think whether you have the competitive advantage when you are compared with people working in the same field? If your answer is noyou are a right place now. Because our NSE5_FNC_AD_7.6 Exam Torrent will be your good partner and you will have the chance to change your work which you are not satisfied with, and can enhance your ability by our NSE5_FNC_AD_7.6 guide questions, you will pass the exam and achieve your target.
Laptops, smartphones, and tablets are appropriate devices to access PDF Questions for FreeDumps. Therefore, you can open this PDF file and go through real Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) exam questions from any comfort zone. This version of actual NSE5_FNC_AD_7.6 exam dumps is portable, latest, and regularly upgrades this document according to tweaks in sections of the actual NSE5_FNC_AD_7.6 Exam Questions. The Desktop and web-based practice software is available to attempt Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) practice exam of FreeDumps for self-assessment.
Fortinet NSE5_FNC_AD_7.6 Pass-Sure Download DemoWith the rapid development of the economy, the demands of society on us are getting higher and higher. If you can have NSE5_FNC_AD_7.6 certification, then you will be more competitive in society. Our study materials will help you get the according certification you want to have. Believe me, after using our study materials, you will improve your work efficiency. You will get more opportunities than others, and your dreams may really come true in the near future. NSE5_FNC_AD_7.6 Test Guide will make you more prominent in the labor market than others, and more opportunities will take the initiative to find you.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:
  • Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
  • Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
  • Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
  • Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q20-Q25):NEW QUESTION # 20
An administrator wants to build device profiling rules based on network traffic, but the network session view is not populated with any records.
Which two settings can be enabled to gather network session information? (Choose two.)
  • A. Netflow setting on the FortiNAC-F interfaces
  • B. Layer 3 polling on the infrastructure devices
  • C. Firewall session polling on modeled FortiGate devices
  • D. Network traffic polling on any modeled infrastructure device
In FortiNAC-F, the Network Sessions view provides a real-time and historical log of traffic flows, including source/destination IP addresses, ports, and protocols. This data is essential for building Device Profiling Rules that rely on "Traffic Patterns" or "Network Footprints" to identify devices (e.g., an IP camera communicating with its specific NVR). If the network session view is empty, the system is not receiving the necessary flow or session data from the network infrastructure.
According to the FortiNAC-F Administration Guide, there are two primary methods to populate this view:
NetFlow/sFlow/IPFIX (C): FortiNAC-F can act as a flow collector. By enabling NetFlow settings on the FortiNAC-F service interface (port2/eth1) and configuring your switches or routers to export flow data to the FortiNAC IP, the system can parse these packets and record sessions.
Firewall Session Polling (B): For environments with FortiGate firewalls, FortiNAC-F can proactively poll the FortiGate via the REST API to retrieve its current session table. This is particularly useful as it provides session visibility without requiring the overhead of configuring NetFlow on every access layer switch.
Settings like Layer 3 Polling (D) only provide ARP table mappings (IP to MAC correlation) and do not provide the detailed flow information required for the session view.
"The Network Sessions view displays information regarding active and inactive network traffic sessions... To populate this view, FortiNAC must receive data through one of the following methods: * NetFlow/sFlow Support: Configure network devices to send flow data to the FortiNAC service interface. * Firewall Session Polling: Enable session polling on modeled FortiGate devices to retrieve session information via API. These records are then used by the Device Profiler to match rules based on traffic patterns." - FortiNAC-F Administration Guide: Network Sessions and Flow Data Collection.
NEW QUESTION # 21
While discovering network infrastructure devices, a switch appears in the inventory topology with a question mark (?) on the icon. What would cause this?
  • A. The wrong SNMP community string was entered during discovery.
  • B. SNMP is not enabled on the switch.
  • C. A read-only SNMP community siring was used.
  • D. The SNMP ObjectlD is not recognized by FortiNAC-F.
In FortiNAC-F, the Inventory topology uses specific icons to represent the status and model of discovered network infrastructure. When a switch or other network device is discovered via SNMP, FortiNAC-F retrieves its System ObjectID (sysObjectID) to identify the specific make and model. This OID is then compared against the internal database of supported device mappings.
A question mark (?) icon appearing on a discovered switch indicates that while the discovery process successfully communicated with the device (meaning SNMP credentials were correct), the SNMP ObjectID is not recognized or mapped in the current version of FortiNAC-F. This essentially means the device is "unsupported" by the current software out-of-the-box. Because the OID is unknown, FortiNAC-F does not know which CLI or SNMP command set to use for critical functions like L2 polling (host visibility) or VLAN switching (enforcement). To resolve this, an administrator can manually "Set Device Mapping" to a similar existing model or a "Generic SNMP Device" if only basic L3 visibility is required.
"Discovered devices displaying a '?' icon indicate the currently running version does not have a mapping for that device's System OID (device is not supported). Device mappings are used to manage the device by performing functions such as L2/L3 Polling, Reading, and Switching VLANs." - Fortinet Technical Tip: Options for devices unable to be modeled in Inventory.
NEW QUESTION # 22
An administrator wants to create a conference manager administrator account but would like to limit the number of conference accounts that can be generated to 30.
Which statement about conference accounts is true?
  • A. Conference account limits are defined in the conference guest and contractor template.
  • B. The conference account limit is defined in the onboarding conference portal.
  • C. In FortiNAC-F, conference accounts can be limited by multiples of 25, so the conference administrator could create 50 accounts.
  • D. The administrator can set a maximum of 30 conference accounts in the administrative profile for the conference manager.
In FortiNAC-F, the Conference Manager is a specialized administrative role designed for delegated administration, often used by receptionists or event organizers to create temporary guest accounts. To maintain security and prevent the over-provisioning of credentials, FortiNAC-F allows for granular restrictions on these accounts.
According to the FortiNAC-F Administration Guide regarding Administrative Profiles, when an administrator creates a profile for a Conference Manager, they can define specific "Account Limits." Under the profile settings (located in System > Settings > Admin Profiles), there is a field specifically for "Max Accounts." By entering "30" into this field, the administrator ensures that any user assigned to this profile cannot exceed 30 active conference accounts at any given time.
This setting is distinct from the Portal configuration or the Guest templates. While templates define the type of account (e.g., duration and access level), the Administrative Profile defines the capabilities and limitations of the person creating those accounts. This ensures that even if a guest template allows for unlimited registrations, the specific administrator is physically restricted by the system from generating more than the allotted 30.
"Administrative Profiles define what an administrator can see and do within the system. For delegated administration roles like the Conference Manager, the 'Max Accounts' field in the Administrative Profile is used to specify the maximum number of accounts the user is permitted to create. Once this limit is reached, the user will be unable to generate additional accounts until existing ones expire or are deleted." - FortiNAC-F Administration Guide: Administrative Profiles and Delegated Administration.
NEW QUESTION # 23
A network administrator is troubleshooting a network access issue for a specific host. The administrator suspects the host is being assigned a different network access policy than expected.
Where would the administrator look to identify which network access policy, if any, is being applied to a particular host?
  • A. The Connections view
  • B. The Port Properties view of the hosts port
  • C. The Policy Details view for the host
  • D. The Policy Logs view
When troubleshooting network access in FortiNAC-F, it is often necessary to verify exactly why a host has been granted a specific level of access. Since FortiNAC-F evaluates policies from the top down and assigns access based on the first match, an administrator needs a clear way to see the results of this evaluation for a specific live endpoint.
The Policy Details (C) view is the designated tool for this purpose. By navigating to the Hosts > Hosts (or Adapter View) in the Administration UI, an administrator can search for the specific MAC address or IP of the host in question. Right-clicking on the host record reveals a context menu from which Policy Details can be selected. This view provides a real-time "look" into the policy engine's decision for that specific host, showing the Network Access Policy that was matched, the User/Host Profile that triggered the match, and the resulting Network Access Configuration (VLAN/ACL) currently applied.
While Policy Logs (A) provide a historical record of all policy transitions across the system, they are often too high-volume to efficiently find a single host's current state. The Connections view (B) shows the physical port and basic status but lacks the granular policy logic breakdown. The Port Properties (D) view shows the configuration of the switch interface itself, which is only one component of the final access determination.
"To identify which policy is currently applied to a specific endpoint, use the Policy Details view. Navigate to Hosts > Hosts, select the host, right-click and choose Policy Details. This window displays the specific Network Access Policy, User/Host Profile, and Network Access Configuration currently in effect for that host record." - FortiNAC-F Administration Guide: Policy Details and Troubleshooting.
NEW QUESTION # 24
An administrator wants FortiNAC-F to return a group of user-defined RADIUS attributes in RADIUS responses.
Which condition must be true to achieve this?
  • A. The device models in the inventory view must be configured for proxy-based authentication.
  • B. The requesting device must support RFC 5176.
  • C. RADIUS accounting must be enabled on the FortiNAC-F RADIUS server configuration.
  • D. Inbound RADIUS requests must contain the Calling-Station-ID attribute.
In FortiNAC-F, the RADIUS Attribute Groups feature allows administrators to return customized RADIUS attributes (such as specific VLAN IDs, filter IDs, or vendor-specific attributes) in an Access-Accept packet sent back to a network device. This is particularly useful for supporting "Generic RADIUS" devices that are not natively supported but can be managed using standard AVPairs.
According to the FortiNAC-F Generic RADIUS Wired Cookbook and the RADIUS Attribute Groups section of the Administration Guide, there is one critical prerequisite for this feature to function: the inbound RADIUS request must contain the Calling-Station-ID attribute. The Calling-Station-ID typically contains the MAC address of the connecting endpoint. Because FortiNAC-F is a host-centric system, it uses the MAC address as the unique identifier to look up the host record, evaluate the associated Network Access Policy, and determine which Logical Network (and thus which Attribute Group) should be applied. If the incoming request lacks this attribute, FortiNAC-F cannot reliably identify the host and, as a safety mechanism, will not include any user-defined RADIUS attributes in the response. This ensures that unauthorized or unidentifiable devices do not receive privileged access through misapplied attributes.
"Configure a set of attributes that must be included in the RADIUS Access-Accept packet returned by FortiNAC... Requirement: Inbound RADIUS request must contain Calling-Station-Id. Otherwise, FortiNAC will not include the RADIUS attributes. This attribute is used to identify the host and its current state within the FortiNAC database." - FortiNAC-F 7.6.0 Generic RADIUS Wired Cookbook: Configure RADIUS Attribute Groups.
NEW QUESTION # 25
As a reliable product website, we have the responsibility to protect our customers' personal information leakage and your payment security. So you can be rest assured the purchase of our NSE5_FNC_AD_7.6 exam software. Besides, we have the largest IT exam repository, if you are interested in NSE5_FNC_AD_7.6 Exam or any other exam dumps, you can search on our FreeDumps or chat with our online support any time you are convenient. Wish you success in NSE5_FNC_AD_7.6 exam.
Exam NSE5_FNC_AD_7.6 Syllabus: https://www.freedumps.top/NSE5_FNC_AD_7.6-real-exam.html
Posted at 3/6/2026 18:19:22        Only Author  2#
IT인증시험은 국제적으로 인정받는 자격증을 취득하는 과정이라 난이도가 아주 높습니다. Guidewire인증 ClaimCenter-Business-Analysts시험은 IT인증자격증을 취득하는 시험과목입니다.어떻게 하면 난이도가 높아 도전할 자신이 없는 자격증을 한방에 취득할수 있을가요? 그 답은Itcertkr에서 찾을볼수 있습니다. Itcertkr에서는 모든 IT인증시험에 대비한 고품질 시험공부가이드를 제공해드립니다. Itcertkr에서 연구제작한 Guidewire인증 ClaimCenter-Business-Analysts덤프로Guidewire인증 ClaimCenter-Business-Analysts시험을 준비해보세요. 시험패스가 한결 편해집니다.
