[General] Oracle 1Z0-1042-25 Valid Test Syllabus & 1Z0-1042-25 Test Papers
94
【General】 Oracle 1Z0-1042-25 Valid Test Syllabus & 1Z0-1042-25 Test Papers
Posted at 2/9/2026 06:37:07      View:129 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassExamDumps 1Z0-1042-25 dumps from Cloud Storage: https://drive.google.com/open?id=1jWPyBH3gXAoUD8vMscLDuO5s2aTVXILW
Our 1Z0-1042-25 prep torrent boosts the highest standards of technical accuracy and only use certificated subject matter and experts. We provide the latest and accurate Oracle Cloud Infrastructure 2025 Application Integration Professional exam torrent to the client and the questions and the answers we provide are based on the real exam. But you buy our 1Z0-1042-25 prep torrent you can mainly spend your time energy and time on your job, the learning or family lives and spare little time every day to learn our Oracle Cloud Infrastructure 2025 Application Integration Professional exam torrent. Our answers and questions are compiled elaborately and easy to be mastered. Because our 1Z0-1042-25 Test Braindumps are highly efficient and the passing rate is very high you can pass the exam fluently and easily with little time and energy needed.
PassExamDumps provides an opportunity for fulfilling your career goals and significantly ease your way to become 1Z0-1042-25 Certified professional. While you are going attend your 1Z0-1042-25 exam, in advance knowledge assessment skips your worries regarding actual exam format. Groom up your technical skills with PassExamDumps practice test training that has no substitute at all. Get the best possible training through PassExamDumps; our practice tests particularly focus the key contents of 1Z0-1042-25 Certification exams. PassExamDumps leads the 1Z0-1042-25 exam candidates towards perfection while enabling them to earn the 1Z0-1042-25 credentials at the very first attempt. The way our products induce practical learning approach, there is no close alternative.
Oracle 1Z0-1042-25 Test Papers - 1Z0-1042-25 Valid Test ExperienceThe customers can prepare from the actual 1Z0-1042-25 and can clear Oracle Cloud Infrastructure 2025 Application Integration Professional exam with ease and if they failed to do it despite all of their efforts they can get a full refund of their money according to terms and conditions. The 1Z0-1042-25 exam solutions is packed with a lot of premium features and it is getting updated on the daily basis according to the syllabus. Oracle 1Z0-1042-25 updates real questions so the students can easily prepare for it and clear Oracle 1Z0-1042-25 exam.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
Topic 5
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q69-Q74):NEW QUESTION # 69
You need to create an Oracle Integration (OIC) integration that processes many records individually that are contained within a single large file. You have been advised to use an implementation approach that uses the Download File operation of an FTP adapter in conjunction with the Stage File action Read File in Segments operation to mitigate issues with memory consumption. When using this approach, which is a valid consideration regarding the use of the Read File in Segments operation?
  • A. The Read File in Segments operation allows you to process the segments sequentially or in parallel.
  • B. You need to explicitly configure a Scope action for this operation if you want to add additional actions during the processing of each segment.
  • C. Segment sizes can be configured from 1-200 records.
  • D. You must provide the actual filename because file references cannot be processed by the Read File in Segments operation.
Segmented Processing:
A:True-Scope required for custom actions.
NEW QUESTION # 70
Which are types of certificates in Oracle Integration Cloud (OIC) that can be imported from the Certificates page under settings? Select THREE.
  • A. Identity certificates
  • B. Message protection certificates
  • C. Unified Communications Certificate
  • D. Trust Certificate
  • E. Multi Domain SSL Certificate
Answer: A,B,D
OIC supports certificate management:
Identity certificates (A):Used for client authentication (e.g., two-way SSL).
Message protection certificates (B):Encrypt/sign messages for security.
Trust Certificate (E):Validates trusted external services.
Multi Domain SSL Certificate (C):Not a distinct OIC category; handled as identity or trust.
Unified Communications Certificate (D):Specific to communication platforms, not OIC-supported.
A, B, E are standard OIC certificate types.
NEW QUESTION # 71
When creating integrations in Oracle Integration Cloud (OIC), a visual mapper enables you to map element nodes between applications by dragging source element nodes onto target element nodes. Which statement is NOT true about the OIC Data Mapper functionality?
  • A. All transformation mappings use eXtensible Stylesheet Language (XSL).
  • B. The data structure for the target service is always displayed on the right side in the designer view.
  • C. When you navigate to the mapper and select a target element, Expression Builder launches in auser- friendly mode by default.
  • D. All source and target data objects are represented internally as JSON structures.
  • E. In the designer view, the Sources section contains data structure of all available data objects, which includes integration metadata, tracking variables, global variables, and integration property values.
OIC Mapper:
D:False-data is XML-based internally, not JSON.
NEW QUESTION # 72
In an Oracle Integration (OIC) project, you are asked to leverage a custom JavaScript library function to be used within an Application pattern integration flow. Which set of steps should you follow to handle this requirement?
  • A. Import the JavaScript library file to the project, then use the JavaScript action within the integration flow to reference the library function.
  • B. Use the Function Call action within the integration flow to reference the external URL that is hosting the JavaScript library function.
  • C. Import the JavaScript library file into your OIC instance's database schema, then use a Local Invoke action to call the function.
  • D. Copy and paste the JavaScript function code into a new JavaScript stage within the integration flow, then map the inbound and outbound data elements in the corresponding Map action.
JS Library:
B:True-import and reference is standard.
NEW QUESTION # 73
There are use cases in which you need to perform an advanced XSLT task that you cannot performin the Oracle Integration Cloud (OIC) data mapper. To perform the advanced mapping tasks, you decide to use an external XSLT mapper and then import the .xsl file back to your integration. What is NOT a valid consideration when handling this use case?
  • A. You must export the entire integration that contains one or more .xsl files.
  • B. Once the advanced mapping is complete, you must import the entire integration that contains the updated .xsl files.
  • C. The exported archive file can include a map file that is largely complete in content or a map file that is empty of content.
  • D. The exported archive must be imported into an Oracle Service Bus project in JDeveloper.
Advanced XSLT in OIC requires external tools. Let's analyze:
A:True-exported maps can be complete or empty templates.
B:False-not required; XSLT can be edited in any editor and reimported directly.
C:True-entire integration must be reimported with updated XSLT.
NEW QUESTION # 74
PassExamDumps offers highly designed Oracle 1Z0-1042-25 exam questions and online 1Z0-1042-25 practice test engine to help you successfully clear the Oracle exam. Their study materials cover all the basic to advanced required 1Z0-1042-25 Exam Questions material that you need to know to pass the 1Z0-1042-25 Exam. These two simple, easy, and accessible learning formats will boost your confidence.
1Z0-1042-25 Test Papers: https://www.passexamdumps.com/1Z0-1042-25-valid-exam-dumps.html
DOWNLOAD the newest PassExamDumps 1Z0-1042-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1jWPyBH3gXAoUD8vMscLDuO5s2aTVXILW
Posted at 2/16/2026 17:12:03        Only Author  2#
Your article is fantastic, I really appreciate you sharing it! Boost your IT knowledge with free Reliable OGEA-103 braindumps questions. Best of luck to everyone!
