Actual Developing Solutions for Microsoft Azure Exam Questions are Easy to Under
Posted at 2/10/2026 07:22:21
P.S. Free 2026 Microsoft AZ-204 dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1FDoST0MaCVevWfjnk8lcAJvvX3rIeSrn
AZ-204 also offers free demos, allowing users to test the quality and suitability of the AZ-204 exam dumps before purchasing. The demo provides access to a limited portion of the material, providing users with a better understanding of the content. Additionally, AZ-204 provides three months of free updates to ensure that candidates have access to the latest questions.
Microsoft AZ-204 certification exam is an excellent way for developers to demonstrate their proficiency in building cloud-based solutions using Azure services. Developing Solutions for Microsoft Azure certification can help candidates advance their careers and open up new job opportunities in cloud computing. With the right preparation and study resources, candidates can Pass AZ-204 Exam and become certified Microsoft Azure developers.
Microsoft AZ-204 Exam Questions are Real and Recommended By ExpertsDo you want to pass the AZ-204 exam with 100% success guarantee? Our AZ-204 training quiz is your best choice. With the assistance of our study materials, you will advance quickly. Also, all AZ-204 guide materials are compiled and developed by our professional experts. So you can totally rely on our AZ-204 Exam simulating to aid you pass the exam. What is more, you will learn all knowledge systematically and logically, which can help you memorize better.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q383-Q388):NEW QUESTION # 383
You need to secure the Shipping Logic App.
What should you use?
- A. Azure AD B2B integration
- B. Azure App Service Environment (ASE)
- C. VNet service endpoint
- D. Integration Service Environment (ISE)
Scenario: The Shipping Logic App requires secure resources to the corporate VNet and use dedicated storage resources with a fixed costing model.
You can access to Azure Virtual Network resources from Azure Logic Apps by using integration service environments (ISEs).
Sometimes, your logic apps and integration accounts need access to secured resources, such as virtual machines (VMs) and other systems or services, that are inside an Azure virtual network. To set up this access, you can create an integration service environment (ISE) where you can run your logic apps and create your integration accounts.
https://docs.microsoft.com/en-us ... nvironment-overview Implement Azure security Question Set 3
NEW QUESTION # 384
You are developing an ASP.NET Core website that can be used to manage photographs which are stored in Azure Blob Storage containers.
Users of the website authenticate by using their Azure Active Directory (Azure AD) credentials.
You implement role-based access control (RBAC) role permission on the containers that store photographs.
You assign users to RBAC role.
You need to configure the website's Azure AD Application so that user's permissions can be used with the Azure Blob containers.
How should you configure the application? To answer, drag the appropriate setting to the correct location.
Each setting may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: user_impersonation
Box 2: delegated
Example:
1.Select the API permissions section
2.Click the Add a permission button and then:
Ensure that the My APIs tab is selected
3.In the list of APIs, select the API TodoListService-aspnetcore.
4.In the Delegated permissions section, ensure that the right permissions are checked: user_impersonation.
5.Select the Add permissions button.
Box 3: delegated
Example
2.Click the Add a permission button and then,
Ensure that the Microsoft APIs tab is selected
3.In the Commonly used Microsoft APIs section, click on Microsoft Graph
4.In the Delegated permissions section, ensure that the right permissions are checked: User.Read. Use the search box if necessary.
https://docs.microsoft.com/en-us ... bapi-openidconnect-
NEW QUESTION # 385
You are using Azure Front Door Service.
You are expecting inbound files to be compressed by using Brotli compression. You discover that inbound XML files are not compressed. The files are 9 megabytes (MB) in size.
You need to determine the root cause for the issue.
To answer, select the appropriate options in the answer area.
Box 1: No
Front Door can dynamically compress content on the edge, resulting in a smaller and faster response to your clients. All files are eligible for compression. However, a file must be of a MIME type that is eligible for compression list.
Box 2: No
Sometimes you may wish to purge cached content from all edge nodes and force them all to retrieve new updated assets. This might be due to updates to your web application, or to quickly update assets that contain incorrect information.
Box 3: Yes
These profiles support the following compression encodings: Gzip (GNU zip), Brotli Reference:
https://docs.microsoft.com/en-us ... /front-door-caching
NEW QUESTION # 386
A company backs up all manufacturing data to Azure Blob Storage. Admins move blobs from hot storage to archive tier storage every month.
You must automatically move blocks to Archive tier after they have not been accessed for 180 days. The path for any item that is not archived must be placed in an existing queue. This operation must be performed automatically once a month. You set the value of TierAgeInDays to 180.
How should you configure the Logic App? To answer, drag the appropriate triggers or action blocks to the correct trigger or action slots. Each trigger or action block may be used once, more than once, or not at all.
Box 1: Recurrence
Box 2: Insert Entity
Box 3 (if true): Tier Blob
Box 4: (if false):
Leave blank.
https://docs.microsoft.com/en-us ... orm-data-operations
NEW QUESTION # 387
You are preparing to deploy an application to an Azure Kubernetes Service (AKS) cluster.
The application must only be available from within the VNet that includes the cluster.
You need to deploy the application.
How should you complete the deployment YAML? To answer, drag the appropriate YAML segments to the correct locations. Each YAML segment may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
To create an internal load balancer, create a service manifest named internal-lb.yaml with the service type LoadBalancer and the azure-load-balancer-internal annotation as shown in the following example:
YAML:
apiVersion: v1
kind: Service
metadata:
annotations:
service.beta.kubernetes.io/azure-load-balancer-internal: "true"
spec:
type: LoadBalancer
ports:
- port: 80
selector:
app: internal-app
https://docs.microsoft.com/en-us/azure/aks/internal-lb
NEW QUESTION # 388
AZ-204 exam training allows you to pass exams in the shortest possible time. If you do not have enough time, our AZ-204 study material is really a good choice. In the process of your learning, our AZ-204 study materials can also improve your efficiency. If you don't have enough time to learn, AZ-204 Test Guide will make the best use of your spare time. The professional tailored by AZ-204 learning question must be very suitable for you. You will have a deeper understanding of the process. Efficient use of all the time, believe me, you will realize your dreams.
AZ-204 Exam Quiz: https://www.itcertmagic.com/Microsoft/real-AZ-204-exam-prep-dumps.html
- AZ-204 Exam Actual Questions 🚝 Answers AZ-204 Free 🌄 Updated AZ-204 Dumps 🥈 Download { AZ-204 } for free by simply entering 「 [url]www.examcollectionpass.com 」 website 📉AZ-204 Valid Test Guide[/url]
- Pass Guaranteed 2026 High Pass-Rate Microsoft AZ-204 Cert Exam 🆕 Easily obtain free download of ▷ AZ-204 ◁ by searching on 【 [url]www.pdfvce.com 】 🚦AZ-204 New Study Plan[/url]
- Pass Guaranteed 2026 High Pass-Rate Microsoft AZ-204 Cert Exam 🎅 Search for ⮆ AZ-204 ⮄ on ➠ [url]www.verifieddumps.com 🠰 immediately to obtain a free download 🕙AZ-204 Valid Braindumps Book[/url]
- AZ-204 Exam Actual Questions 🕐 AZ-204 Reliable Test Pdf 🍩 AZ-204 Reliable Test Pdf 🕕 Easily obtain ⇛ AZ-204 ⇚ for free download through ▶ [url]www.pdfvce.com ◀ 💁AZ-204 New Study Plan[/url]
- Pass-Sure AZ-204 Cert Exam offer you accurate Exam Quiz | Developing Solutions for Microsoft Azure 🥻 Immediately open ☀ [url]www.examcollectionpass.com ️☀️ and search for ➡ AZ-204 ️⬅️ to obtain a free download 🆕Customized AZ-204 Lab Simulation[/url]
- AZ-204 Valid Braindumps Book 🏮 AZ-204 Reliable Test Dumps ❔ New APP AZ-204 Simulations 🦸 Open ▷ [url]www.pdfvce.com ◁ enter ➡ AZ-204 ️⬅️ and obtain a free download 📌New APP AZ-204 Simulations[/url]
- Free PDF AZ-204 - Developing Solutions for Microsoft Azure Latest Cert Exam 🚉 Search on ➡ [url]www.examcollectionpass.com ️⬅️ for ⮆ AZ-204 ⮄ to obtain exam materials for free download 🤓AZ-204 New Study Plan[/url]
- Pass Guaranteed Marvelous Microsoft AZ-204 Cert Exam 🌖 Enter ▷ [url]www.pdfvce.com ◁ and search for ➡ AZ-204 ️⬅️ to download for free 📟AZ-204 Reliable Study Questions[/url]
- Pass-Sure AZ-204 Cert Exam offer you accurate Exam Quiz | Developing Solutions for Microsoft Azure 🧵 Enter ( [url]www.dumpsmaterials.com ) and search for ➥ AZ-204 🡄 to download for free 😍AZ-204 Reliable Study Questions[/url]
- Valid AZ-204 Cert Exam - Fantastic - 100% Pass-Rate AZ-204 Materials Free Download for Microsoft AZ-204 Exam 🧁 Search for ➡ AZ-204 ️⬅️ and download it for free on ☀ [url]www.pdfvce.com ️☀️ website 🍅Updated AZ-204 Dumps[/url]
- Test AZ-204 Centres 🧂 Updated AZ-204 Dumps 🛕 AZ-204 Valid Braindumps Book 🗳 Immediately open ⇛ [url]www.dumpsmaterials.com ⇚ and search for ➡ AZ-204 ️⬅️ to obtain a free download 🛶New APP AZ-204 Simulations[/url]
- www.stes.tyc.edu.tw, www.holmeslist.com.au, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest ITCertMagic AZ-204 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FDoST0MaCVevWfjnk8lcAJvvX3rIeSrn
