[General] AZ-104 Valid Braindumps - AZ-104 Valid Dumps Ppt
114
【General】 AZ-104 Valid Braindumps - AZ-104 Valid Dumps Ppt
Posted at 2/12/2026 06:42:04      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sures AZ-104 PDF Dumps and AZ-104 Exam Engine Free Share: https://drive.google.com/open?id=1G4mD4hs_A-iaNqUf6xlvAzGrRfZc56ex
Perhaps now you are one of the candidates of the Microsoft AZ-104 exam, perhaps now you are worried about not passing the exam smoothly. Now we have good news for you: our AZ-104 study materials will solve all your worries and help you successfully pass it. With the high pass rate as 98% to 100%, you will find that we have the best Microsoft Azure Administrator AZ-104 learning braindumps which contain the most accurate real exam questions.
Microsoft AZ-104 frequently changes the content of the Microsoft Azure Administrator (AZ-104) exam. Therefore, to save your valuable time and money, we keep a close eye on the latest updates. Furthermore, Pass4sures also offers free updates of AZ-104 exam questions for up to 365 days after buying Microsoft Azure Administrator (AZ-104) dumps. We guarantee that nothing will stop you from earning the esteemed Microsoft Certification Exam on your first attempt if you diligently prepare with our Microsoft in AZ-104 real exam questions.
AZ-104 Valid Dumps Ppt, AZ-104 Examcollection Questions AnswersThe Microsoft AZ-104 certification is important for those who desire to advance their careers in the tech industry. They are also aware that receiving this certificate requires passing the Microsoft AZ-104 exam. Due to poor study material choices, many of these test takers are still unable to receive the Microsoft AZ-104 credential.
Microsoft Azure Administrator Sample Questions (Q23-Q28):NEW QUESTION # 23
You have an Azure virtual machine named VM1 that connects to a virtual network named VNet1. VM1 has the following configurations:
Subnet: 10.0.0.0/24
Availability set: AVSet
Network security group (NSG): None
Private IP address: 10.0.0.4 (dynamic)
Public IP address: 40.90.219.6 (dynamic)
You deploy a standard, Internet-facing load balancer named slb1.
You need to configure slb1 to allow connectivity to VM1.
Which changes should you apply to VM1 as you configure slb1? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... ndard-public-portal
https://docs.microsoft.com/en-us ... d-balancer-overview
NEW QUESTION # 24
You need to configure Azure Backup to back up the file shares and virtual machines.
What is the minimum number of Recovery Services vaults and backup policies you should create? To answer, select the appropriate options in the answer area.
https://learn.microsoft.com/en-u ... ?tabs=backup-center
https://learn.microsoft.com/en-u ... rom-azure-vm-settin
NEW QUESTION # 25
An IT administrator has a setup a Web app in Azure called pass4test-app. Currently the Application is part of a Free App service plan.
The Web app just stops after 60 minutes of usage every day. You need to ensure that the application can run continuously every day.
You propose to add a web job so that the app could run on a continuous basis.
Would this solution resolve the issue?
  • A. False
  • B. True
No, because even if you have a web job, you can still can only consume 60 minutes of CPU time per day.
https://azure.microsoft.com/en-u ... /app-service/plans/
NEW QUESTION # 26
Case Study 2 - Contoso, Ltd
Overview
Contoso, Ltd. is a manufacturing company that has offices worldwide. Contoso works with partner organizations to bring products to market.
Contoso products are manufactured by using blueprint files that the company authors and maintains.
Existing Environment
Currently, Contoso uses multiple types of servers for business operations, including the following:
- File servers
- Domain controllers
- Microsoft SQL Server servers
Your network contains an Active Directory forest named contoso.com. All servers and client computers are joined to Active Directory.
You have a public-facing application named App1. App1 is comprised of the following three tiers:
- A SQL database
- A web front end
- A processing middle tier
Each tier is comprised of five virtual machines. Users access the web front end by using HTTPS only.
Requirements
Planned Changes
Contoso plans to implement the following changes to the infrastructure:
- Move all the tiers of App1 to Azure.
- Move the existing product blueprint files to Azure Blob storage.
- Create a hybrid directory to support an upcoming Microsoft Office 365 migration project.
Technical Requirements
Contoso must meet the following technical requirements:
- Move all the virtual machines for App1 to Azure.
- Minimize the number of open ports between the App1 tiers.
- Ensure that all the virtual machines for App1 are protected by
backups.
- Copy the blueprint files to Azure over the Internet.
- Ensure that the blueprint files are stored in the archive storage
tier.
- Ensure that partner access to the blueprint files is secured and
temporary.
- Prevent user passwords or hashes of passwords from being stored in
Azure.
- Use unmanaged standard storage for the hard disks of the
virtualmachines.
- Ensure that when users join devices to Azure Active Directory (Azure
AD), the users use a mobile phone to verify their identity.
- Minimize administrative effort whenever possible.
User Requirements
Contoso identifies the following requirements for users:
- Ensure that only users who are part of a group named Pilot can join
devices to Azure AD.
- Designate a new user named Admin1 as the service administrator of the Azure subscription.
- Ensure that a new user named User3 can create network objects for the Azure subscription.
Hotspot Question
You need to recommend a solution for App1. The solution must meet the technical requirements.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
Box 1: 1
1 VNET and then follow the N-tier application architecture.
Box 2: 3
3 Subnets (1 Subnet for each tier of the App1). The tiers can communicate each other, because they are inside the same VNET. Of course you would need additional NSGs to restrict traffic.
https://docs.microsoft.com/en-us ... r/n-tier-sql-server
NEW QUESTION # 27
You have Azure subscription that includes following Azure file shares:
You have the following on-premises servers:
You create a Storage Sync Service named Sync1 and an Azure File Sync group named Group1. Group1 uses share1 as a cloud endpoint.
You register Server1 and Server2 in Sync1. You add D:Folder1 on Server1 as a server endpoint of Group1.
https://docs.microsoft.com/en-us ... e?tabs=azure-portal
NEW QUESTION # 28
To some extent, to pass the AZ-104 exam means that you can get a good job. The AZ-104 exam materials you master will be applied to your job. The possibility to enter in big and famous companies is also raised because they need outstanding talents to serve for them. Our AZ-104 Test Prep is compiled elaborately and will help the client get the AZ-104 certification. To get a better and full understanding of our AZ-104 quiz torrent, you can just free download the demo of our AZ-104 exam questions.
AZ-104 Valid Dumps Ppt: https://www.pass4sures.top/Microsoft-Azure-Administrator-Associate/AZ-104-testking-braindumps.html
If you buy the AZ-104 learning dumps from our company, we can promise that you will get the professional training to help you pass your exam easily, Microsoft AZ-104 Valid Braindumps And if you didn’t receive it, you can notify us through live chat or email, we will settle it for you, Just have a try on our free demo of AZ-104 exam questions, The passing rate of our AZ-104 exam materials are very high and about 99% and so usually the client will pass the AZ-104 exam successfully.
You can invoke security measures that ensure that users know Real AZ-104 Exam Answers that the behavior is unacceptable, Security best practices to secure a workstation: Implementation of best practices.
If you buy the AZ-104 learning dumps from our company, we can promise that you will get the professional training to help you pass your exam easily, And if you didn’t Real AZ-104 Exam Answers receive it, you can notify us through live chat or email, we will settle it for you.
Free PDF Microsoft AZ-104 - Microsoft Azure Administrator Perfect Valid BraindumpsJust have a try on our free demo of AZ-104 exam questions, The passing rate of our AZ-104 exam materials are very high and about 99% and so usually the client will pass the AZ-104 exam successfully.
Our experts have collected all AZ-104 such study questions and have added them in our dumps.
BONUS!!! Download part of Pass4sures AZ-104 dumps for free: https://drive.google.com/open?id=1G4mD4hs_A-iaNqUf6xlvAzGrRfZc56ex
