[General] 2026 Salesforce Newest MCE-Dev-201 Latest Test Fee
98
【General】 2026 Salesforce Newest MCE-Dev-201 Latest Test Fee
Posted at 2/12/2026 15:05:07      View:124 | Replies:0        Print      Only Author   [Copy Link] 1#
Three versions are available for MCE-Dev-201 study materials, and you can choose the most suitable one according to your own needs. MCE-Dev-201 PDF version is printable, and you can print them and take some notes on them if you want. MCE-Dev-201 Soft test engine can be used in more than 200 personal computers, and they support MS operating system. MCE-Dev-201 Online Test engine is convenient and easy to learn, and it supports all web browsers. You can have a general review of what you have learned. Just have a try, and there is always a version for you.
Salesforce MCE-Dev-201 Exam Syllabus Topics:
  • Data Modeling: This domain covers structuring contact and subscriber data in Marketing Cloud including configuring the contact model understanding data extension types and uses managing contact records across channels and the contact deletion process.
  • Programmatic Languages: This domain focuses on coding with AMPscript and Server-Side JavaScript including language syntax functions processing methods development best practices and programmatic subscriber exclusion during sends.
  • Security: This domain addresses data protection in Marketing Cloud including available security options and best practices for maintaining secure platform configurations.
  • API: This domain addresses interacting with Marketing Cloud through SOAP and REST APIs including API objects methods routes OAuth authentication flows with access tokens and handling API responses.
Topic 5
  • Data Management: This domain covers importing data with various file formats writing SQL queries for data manipulation extracting data from Marketing Cloud applying SQL best practices managing send logs and understanding data impacts from contact deletion.
100% Pass 2026 MCE-Dev-201: Efficient Salesforce Certified Marketing Cloud Engagement Developer Latest Test FeeWe promise you will pass the MCE-Dev-201 exam and obtain the MCE-Dev-201 certificate successfully with our help of MCE-Dev-201 exam questions. According to recent survey of our previous customers, 99% of them can achieve their goals, so believe that we can be the helping hand to help you achieve your ultimate goal. Bedsides we have high-quality MCE-Dev-201 Test Guide for managing the development of new knowledge, thus ensuring you will grasp every study points in a well-rounded way.
Salesforce Certified Marketing Cloud Engagement Developer Sample Questions (Q30-Q35):NEW QUESTION # 30
A developer wants to configure an automation to import files placed on the SFTP shared by a customer's data vendor. The automation will start when a file matching a specific namingpattern is encountered in the Import folder. The first step of the automation is a File Import Activity referencing a substion string for the matching file. Which substituon string represents the name of the file?
  • A. %%FILENAME%%
  • B. %%TRIGGER_FILENAME%%
  • C. %%FILENAME_FROM_IMPORT%%
  • D. %%FILENAME_FROM_TRIGGER%%
When configuring an automation to import files placed on the SFTP, and starting the automation based on a file matching a specific naming pattern, the substitution string that represents the name of the file is %% TRIGGER_FILENAME%%. This substitution string is used to reference the filename of the triggering file in the File Import Activity.
Salesforce Marketing Cloud Documentation on Automation Studio
NEW QUESTION # 31
When appending data to links via Web Analytics Connector, which parameter should be used to track subscriber behavior?
  • A. Email Address
  • B. Contact Key
  • C. Subscriber Key
  • D. Subscriber ID
The SubscriberKey is the appropriate parameter to use when appending data to links via the Web Analytics Connector. This parameter uniquely identifies subscribers across all sends and ensures accurate tracking of subscriber behavior.
* Subscriber Key: A unique identifier for a subscriber that remains consistent across all data extensions and sends.
Salesforce Web Analytics Connector
NEW QUESTION # 32
A developer needs to process a payload from an external system in a CloudPage.
What Marketing Cloud Server-Side JavaScript Platform function should be used for converting a string payload in JSON format to a JavaScript object?
  • A. ParseJSON
  • B. Stringify
  • C. Base64Decode
  • D. CreateObject
To convert a string payload in JSON format to a JavaScript object on a CloudPage, the developer should use the ParseJSON (B) function in Marketing Cloud Server-Side JavaScript (SSJS). This function parses a JSON string and returns a corresponding JavaScript object.
Example:
var jsonString = '{"key1":"value1", "key2":"value2"}'; var jsonObject = Platform.Function.ParseJSON (jsonString); References:
Salesforce Marketing Cloud SSJS Guide
SSJS Platform.Function.ParseJSON
NEW QUESTION # 33
Northern Trail Outfitters has created subscriber attributes including AGE underProfile Manager within their Enterprise 2.0 account.
How would a developer retrieve subscribers over 30 years of age?
  • A. Create a filtered Group of subscribers with AGE more than 30
  • B. Create a query that references the _EnterpriseAttribute data view
  • C. The data cannot be retrieved with a query
  • D. Create a query thatreferences the _Subscribers data view
Profile attributes like AGE in Profile Manager are not directly accessible via the _Subscribers data view or
_EnterpriseAttribute data view. To retrieve subscribers over 30 years of age, creating a filtered Group based on the AGE attribute is the most effective method.
Salesforce Subscriber Filters and Groups
NEW QUESTION # 34
Certification Aid uses Marketing Cloud Connect and wants to create a lead capture form on a landing page.
When a customer submits the form, a Lead record should be created in Salesforce. Which scripting language can be used for this? Choose 2.
  • A. AMPscript to create Salesforce record, SSJS for form handling.
  • B. SSJS for whole functionality.
  • C. AMPscript for whole functionality.
  • D. SSJS to create Salesforce record, AMPscript for form handling.
To create a lead capture form on a landing page and create a Lead record in Salesforce, you can use either AMPscript or SSJS. AMPscript can be used for interacting with Salesforce, and SSJS can handle form processing. Alternatively, SSJS can handle the entire process, including creating the Salesforce record.
* AMPscript and SSJS Combination: You can use AMPscript to interact with Salesforce APIs to create records and SSJS for form handling.
* SSJS for Full Functionality: SSJS can handle both the form submission and the interaction with Salesforce to create Lead records.
Salesforce AMPscript and SSJS Integration
NEW QUESTION # 35
If you are prepared to take the MCE-Dev-201 exam with the help of excellent MCE-Dev-201 learning materials on our website, the choice is made brilliant. Our MCE-Dev-201 training materials are your excellent choices, especially helpful for those who want to pass the MCE-Dev-201 Exam without bountiful time and eager to get through it successfully. Besides that, our MCE-Dev-201 study questions have three versions: PDF version, Soft version and APP version, which can be interestinng and helpful for you to choose.
Test MCE-Dev-201 Questions Vce: https://www.verifieddumps.com/MCE-Dev-201-valid-exam-braindumps.html
