[General] NCP-US-6.5 New Braindumps Files, Valid NCP-US-6.5 Exam Guide
【General】 NCP-US-6.5 New Braindumps Files, Valid NCP-US-6.5 Exam Guide
Posted at 2/13/2026 14:52:16      View:120 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Real4test NCP-US-6.5 PDF Dumps and NCP-US-6.5 Exam Engine Free Share: https://drive.google.com/open?id=1ZlrrbYH8dQQi8qZpRGwhHTu3K3aZcIGY
Our NCP-US-6.5 exam materials are famous among candidates. Once they need to prepare an exam, our NCP-US-6.5 study materials are their first choice. As you know, it is troublesome to get the NCP-US-6.5certificate. Now, you are fortunate enough to come across our NCP-US-6.5 Exam Guide. We have free demos on the website for our customers to download if you still doubt our products, and you can check whether it is the right one for you before purchase as well.
Nutanix NCP-US-6.5 Exam Syllabus Topics:
  • Troubleshoot issues related to Nutanix Objects
  • Troubleshoot issues related to Nutanix Volumes
  • Deploy and Upgrade Nutanix Unified Storage
  • Perform upgrades
  • maintenance for Files
  • Objects implementations
  • Given a scenario, configure shares, buckets, and
  • or Volume Groups
  • Troubleshoot a failed upgrade for Files
  • Objects
  • Identify the steps to deploy Nutanix Files
  • Given a scenario, determine product and sizing parameters
Topic 5
  • Troubleshoot issues related to Nutanix Files
  • Explain Data Management processes for Files and Objects
Topic 6
  • Analyze and Monitor Nutanix Unified Storage
  • Describe the use of Data Lens for data security
Valid NCP-US-6.5 Exam Guide, NCP-US-6.5 Test Dumps FreeOwning Real4test is to have a key to pass NCP-US-6.5 exam certification. Real4test's NCP-US-6.5 exam certification training materials is the achievement that our IT elite team take advantage of their own knowledge and experience, and grope for rapid development and achievements of the IT industry. Its authority is undeniable. Before purchase Real4test's NCP-US-6.5 Braindumps, you can download NCP-US-6.5 free demo and answers on probation on Real4test.COM.
Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Sample Questions (Q83-Q88):NEW QUESTION # 83
An administrator is tasked with creating an Objects store with the following settings:
* Medium Performance (around 10,000 requests per second)
* 10 TiB capacity
* Versioning disabled
* Hosted on an AHV cluster
immediately after creation, the administrator is asked to change the name of Objects store Who will the administrator achieve this request?
  • A. Delete and recreate a new Objects store with the updated name
  • B. Enable versioning and then rename the Object store, disable versioning
  • C. The Objects store can only be renamed if hosted on ESXI.
The administrator can achieve this request by deleting and recreating a new Objects store with the updated name. Objects is a feature that allows users to create and manage object storage clusters on a Nutanix cluster. Objects clusters can provide S3-compatible access to buckets and objects for various applications and users. Objects clusters can be created and configured in Prism Central. However, once an Objects cluster is created, its name cannot be changed or edited. Therefore, the only way to change the name of an Objects cluster is to delete the existing cluster and create a new cluster with the updated name. Reference: Nutanix Objects User Guide, page 9; Nutanix Objects Solution Guide, page 8
NEW QUESTION # 84
A company's Marketing department requires the ability to recover files hosted in a Files share. They also require the ability to restore files within a timeframe of 14 days. Which two configurations are required to meet these requirements? (Choose two.)
  • A. Enable Self-Service Restore at the share level.
  • B. Change default settings in the Protection Configuration window.
  • C. Install Nutanix Guest Tools on clients who need to perform Self-Service Restore.
  • D. Change the Protection Domain settings to keep at least 14 days of snapshots.
Answer: A,D
The Marketing department needs to recover files in a Nutanix Files share with a recovery window of 14 days.
Nutanix Files, part of Nutanix Unified Storage (NUS), supports file recovery through Self-Service Restore (SSR) for SMB shares, which relies on snapshots to provide previous versions of files.
Analysis of Options:
* Option A (Change default settings in the Protection Configuration window): Incorrect. The
"Protection Configuration window" is not a specific feature in Nutanix Files. This may be a vague reference to snapshot policies, but the correct terminology is Protection Domain or snapshot schedules, as in option B.
* Option B (Change the Protection Domain settings to keep at least 14 days of snapshots): Correct.
Nutanix Files uses snapshots to enable file recovery via SSR. These snapshots are managed through Protection Domains (or snapshot schedules in newer terminology) in Prism Element or Prism Central.
To ensure files can be restored within a 14-day timeframe, the snapshot retention policy must be configured to retain snapshots for at least 14 days.
* Option C (Install Nutanix Guest Tools on clients who need to perform Self-Service Restore):
Incorrect. Nutanix Guest Tools (NGT) is used for VM management features (e.g., VSS snapshots for backups, VM mobility), but it is not required for Self-Service Restore in Nutanix Files. SSR is a client- side feature for SMB shares that works natively with Windows clients (via the Previous Versions tab) and does not require NGT.
* Option D (Enable Self-Service Restore at the share level): Correct. Self-Service Restore (SSR) must be enabled at the share level in Nutanix Files to allow users to recover files without administrator intervention. This feature enables the Marketing department to restore files directly from their Windows clients using the Previous Versions feature, provided snapshots are available (as configured in option B).
Selected Configurations:
* B: Configuring the snapshot retention to at least 14 days ensures that previous versions of files are available for recovery within the required timeframe.
* D: Enabling SSR at the share level allows the Marketing department to perform the recovery themselves, meeting the requirement for user-driven file recovery.
Exact Extract from Nutanix Documentation:
From the Nutanix Files Administration Guide (available on the Nutanix Portal):
"Self-Service Restore (SSR) allows users to recover previous versions of files in SMB shares. To enable SSR, it must be activated at the share level in the Files Console. SSR relies on snapshots to provide previous versions; ensure that snapshot schedules (via Protection Domains or snapshot policies) are configured to retain snapshots for the desired recovery period, such as 14 days."
Nutanix Files Administration Guide, Version 4.0, Section: "Configuring Self-Service Restore and Snapshots" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix Files Recovery Features".
NEW QUESTION # 85
Before upgrading Files or creating a file server, which component must first be upgraded to a compatible version?
  • A. Prism Central
  • B. FSM
  • C. FSVM
  • D. File Analytics
The component that must first be upgraded to a compatible version before upgrading Files or creating a file server is Prism Central. Prism Central is a web-based user interface that allows administrators to manage multiple Nutanix clusters and services, including Files. Prism Central must be upgraded to a compatible version with Files before upgrading an existing file server or creating a new file server. Otherwise, the upgrade or creation process may fail or cause unexpected errors. Reference: Nutanix Files Administration Guide, page 21; Nutanix Files Upgrade Guide
NEW QUESTION # 86
What does the ''X'' represent on the icon?
  • A. Tiered File
  • B. Distributed shared file
  • C. Corrupt ISO
  • D. Share Disconnected File
The "X" on the icon represents a distributed shared file, which is a file that belongs to a distributed share or export. A distributed share or export is a type of SMB share or NFS export that distributes the hosting of top- level directories across multiple FSVMs. The "X" indicates that the file is not hosted by the current FSVM, but by another FSVM in the cluster. The "X" also helps to identify which files are eligible for migration when using the Nutanix Files Migration Tool. References: Nutanix Files Administration Guide, page 34; Nutanix Files Migration Tool User Guide, page 10
NEW QUESTION # 87
An administrator needs to generate a File Analytics report which lists the top owners with space consumed.
Which two formats are available to the administrator for this task? (Choose two.)
  • A. JSON
  • B. CSV
  • C. XML
  • D. PDF
Nutanix File Analytics, part of Nutanix Unified Storage (NUS), provides reporting capabilities for monitoring file server activity, including space usage by owners. The administrator wants to generate a report listing the top owners by space consumed, which is a standard report in File Analytics. The available export formats for such reports determine how the data can be shared or analyzed.
* Option A (XML): Incorrect. File Analytics does not support exporting reports in XML format. While XML is a common data format, Nutanix File Analytics focuses on more user-friendly formats like PDF and CSV for report exports.
* Option B (PDF): Correct. File Analytics allows reports, such as the top owners by space consumed, to be exported in PDF format. This format is useful for creating a formatted, printable report that can be shared with stakeholders or archived for documentation purposes.
* Option C (CSV): Correct. File Analytics also supports exporting reports in CSV (Comma-Separated Values) format. This format is ideal for further analysis, as the data can be imported into tools like Excel or other data processing software to manipulate the list of top owners and their space consumption.
* Option D (JSON): Incorrect. JSON is a data format often used for APIs or data interchange, but File Analytics does not support exporting reports in JSON format. The focus is on PDF for presentation and CSV for data analysis.
Selected Formats:
* B: PDF format provides a formatted report suitable for sharing or printing.
* C: CSV format allows for data export and further analysis in external tools.
From the Nutanix File Analytics Administration Guide (available on the Nutanix Portal):
"File Analytics reports, such as top owners by space consumed, can be exported in PDF format for presentation or CSV format for further analysis. These formats allow administrators to share reports with stakeholders or import the data into other tools for additional processing."
Nutanix File Analytics Administration Guide, Version 4.0, Section: "Generating and Exporting Reports" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix File Analytics Reporting".
NEW QUESTION # 88
You can also become part of this skilled and qualified community. To do this just enroll in the Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Exam and start preparation with real and valid NCP-US-6.5 practice test questions right now. The Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 practice test questions are checked and verified by experienced and qualified NCP-US-6.5 Exam trainers. So you can trust Real4test Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 practice test questions and start preparation with confidence.
Valid NCP-US-6.5 Exam Guide: https://www.real4test.com/NCP-US-6.5_real-exam.html
P.S. Free & New NCP-US-6.5 dumps are available on Google Drive shared by Real4test: https://drive.google.com/open?id=1ZlrrbYH8dQQi8qZpRGwhHTu3K3aZcIGY
Posted at 2/15/2026 10:13:59        Only Author  2#
Wir bemühen uns nun darum, den Kandidaten rechtzeitigen und effizieten Service zu bieten, um Ihre wertvolle Zeit zu ersparen. Fast2test bietet Ihnen zahlreiche Lerntipps, Fragen und Antworten zur ServiceNow CAD Zertifizierungsprüfung. Einige Websites bieten Ihnen auch Lernmaterialien zur CAD Zertifizierungsprüfung, die von guter Qualität ist und mit dem Zeit Schritt halten. Aber Fast2test ist die einzige Website, die beste Schulungsunterlagen zur CAD Zertifizierungsprüfung bietet. Mit Hilfe der Lernmaterialien und der Anleitung von Fast2test können Sie die ServiceNow CAD Zertifizierungsprüfung einmalig bestehen.
