[Hardware] FCP_FGT_AD-7.6 Test Practice & Free PDF Quiz Fortinet Realistic FCP - FortiG
101
【Hardware】 FCP_FGT_AD-7.6 Test Practice & Free PDF Quiz Fortinet Realistic FCP - FortiG
Posted at 2/15/2026 19:32:52      View:107 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PrepAwayETE FCP_FGT_AD-7.6 dumps from Cloud Storage: https://drive.google.com/open?id=1-wnsVqjEUEF6sGKBoHfgKCLSz3_dq4Dp
We provide you with our best Fortinet FCP_FGT_AD-7.6 exam study material, which builds your ability to get high-paying jobs. Fortinet FCP_FGT_AD-7.6 Exam Dumps includes Fortinet FCP_FGT_AD-7.6 Dumps PDF format, desktop FCP_FGT_AD-7.6 practice exam software, and web-based FCP_FGT_AD-7.6 practice test software.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Topic 5
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
Fortinet FCP_FGT_AD-7.6 Test Practice Exam Pass Once Try | FCP_FGT_AD-7.6 Simulations PdfDid you often feel helpless and confused during the preparation of the FCP_FGT_AD-7.6 exam? Do you want to find an expert to help but feel bad about the expensive tutoring costs? Don't worry. Our FCP_FGT_AD-7.6 exam questions can help you to solve all the problems. Our FCP_FGT_AD-7.6 Study Material always regards helping students to pass the exam as it is own mission. And we have successfully helped numerous of the candidates pass their exams.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q85-Q90):NEW QUESTION # 85
Refer to the exhibit. A network administrator is troubleshooting an IPsec tunnel between two FortiGate devices. The administrator has determined that phase 1 status is up, but phase 2 fails to come up.
Based on the phase 2 configuration shown in the exhibit, which two configuration changes will bring phase 2 up? (Choose two.)
  • A. On BR1-FGT, set Seconds to 43200.
  • B. On BR1-FGT, set Remote Address to 10.0.11.0/255.255.255.0.
  • C. On HQ-NGFW. set Encryption to AES256.
  • D. On HQ-NGFW, enable Diffie-Hellman Group 2.
The key lifetime (Seconds) must match on both sides; BR1-FGT is set to 14400, so setting it to
43200 matches HQ-NGFW.
The remote address on BR1-FGT should match the HQ-NGFW's local subnet (10.0.11.0/24), but it is currently set incorrectly as 172.20.1.0/24. Changing it to 10.0.11.0/255.255.255.0 will align the Phase 2 selectors.
NEW QUESTION # 86
Which method allows management access to the FortiGate CLI without network connectivity?
  • A. CLI console widget
  • B. Serial console
  • C. Telnet console
  • D. SSH console
The serial console provides direct physical access to the FortiGate CLI without requiring any network connectivity. It connects via the FortiGate's console port using a serial cable, allowing administrators to perform initial configuration, recovery, or troubleshooting even if the network interfaces are down or misconfigured.
NEW QUESTION # 87
Which two statements about the Security Fabric rating are true? (Choose two.)
  • A. The Security Posture category provides PCI compliance results.
  • B. The root FortiGate provides executive summaries of all the FortiGate devices in the Security Fabric.
  • C. Security Rating Insights are available only in the Security Rating page.
  • D. A license is required to obtain an executive summary in the Security Rating section.
NEW QUESTION # 88
An administrator configures FortiGuard servers as DNS servers on FortiGate using default settings.
What is true about the DNS connection to a FortiGuard server?
  • A. It uses DNS over TLS.
  • B. It uses DNS over HTTPS.
  • C. It uses UDP 53.
  • D. It uses UDP 8888.
When FortiGuard servers are configured as DNS servers on FortiGate with default settings, the DNS queries are sent using the standard DNS protocol over UDP port 53.
NEW QUESTION # 89
Refer to the exhibit showing a FortiGuard connection debug output.
Based on the output, which two facts does the administrator know about the FortiGuard connection? (Choose two.)
  • A. FortiGate is using default FortiGuard communication settings.
  • B. There is at least one server that lost packets consecutively.
  • C. One server was contacted to retrieve the contract information.
  • D. A local FortiManager is one of the servers FortiGate communicates with.
The output shows that one server was contacted to retrieve FortiGuard contract information, as indicated under "Service : Web-filter" with "License : Contract" and "Num. of servers : 1." The entry "Default servers : Included" confirms that FortiGate is using the default FortiGuard communication settings, meaning it communicates directly with Fortinet's public FortiGuard servers instead of a custom or local override.
NEW QUESTION # 90
The FCP - FortiGate 7.6 Administrator (FCP_FGT_AD-7.6) certification examination is an essential component of professional development, and passing this Fortinet FCP_FGT_AD-7.6 test can increase career options and a rise in salary. Nonetheless, getting ready for the Prepare for your FCP_FGT_AD-7.6 Exam may be difficult, and many working professionals have trouble locating the FCP_FGT_AD-7.6 practice questions they need to succeed in this endeavor.
FCP_FGT_AD-7.6 Simulations Pdf: https://www.prepawayete.com/Fortinet/FCP_FGT_AD-7.6-practice-exam-dumps.html
DOWNLOAD the newest PrepAwayETE FCP_FGT_AD-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-wnsVqjEUEF6sGKBoHfgKCLSz3_dq4Dp
Posted at 2/20/2026 17:53:27        Only Author  2#
I’ve got to like this—it’s that good. Free access to the C-ARCON-2508 latest exam preparation exam resources—your pathway to promotions and salary boosts!
