[General] CKA Test Questions, Dump CKA File
100
【General】 CKA Test Questions, Dump CKA File
Posted at 2/16/2026 08:51:00      View:114 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Prep4sureExam CKA PDF Dumps and CKA Exam Engine Free Share: https://drive.google.com/open?id=1txxRFnbVuNKJq2ZHm6LuzS8a4hY_52vN
The chance to examine the content of the CKA practice material before purchasing it will give you peace of mind. So, try a free demo to evaluate the authenticity of the Linux Foundation CKA Exam product. Prep4sureExam forewarns you that the topics of the Linux Foundation CKA test change from time to time.
The benefit of obtaining the CNCF CKA Certification Exam CertificationThe CNCF CKA Certification Exam is in demand in various countries. The demand for the CNCF Certified Kubernetes Administrator exam is high in many countries. Prospective clients will be able to find the benefits after obtaining the certification compared to other alternatives. The organizations preparing for the certification exam will be able to provide an employment opportunity for the certified engineering professionals. Component Providers will be able to find the benefits after obtaining the certification compared to other alternatives. Ingress and Rest components will be able to find the benefits after obtaining the certification compared with other alternatives. CNCF CKA exam dumps are the best option to pass the exam. The CNCF CKA certification exam will be beneficial for candidates with an interest in Kubernetes development. A variety of IT jobs will be available after obtaining the certification compared to other alternatives. Software developers, IT specialists, and software engineers will be able to find numerous positions after obtaining the verification. Configuring Kubernetes will prove to be of value for IT professionals who want to get into the IT industry.
A lot of software engineers are being employed by various organizations due to the demand for the CNCF Certified Kubernetes Administrator certification exam. Logging and Monitoring will be of value to IT professionals. IT professionals who want to work in the IT industry should take interest in getting the certification Exam. The job market will be an excellent place for software engineers and software developers after obtaining the certification. Scratch your name, handle, and email on the CNCF CKA Certification Exam website. Evaluation of the certification is done after acquiring the CNCF CKA Certification Exam. Marry: After obtaining the certification, you can get married. The salary of IT professionals who work in the IT industry is increasing. The certificate will be issued online after gaining the CNCF CKA Certification Exam.
Dump CKA File, CKA Free PracticeWhether you are at home or out of home, you can study our CKA test torrent. You don't have to worry about time since you have other things to do, because under the guidance of our CKA study tool, you only need about 20 to 30 hours to prepare for the exam. You can use our CKA exam materials to study independently. Then our system will give you an assessment based on your actions. You can understand your weaknesses and exercise key contents. You don't need to spend much time on it every day and will pass the exam and eventually get your certificate. CKA Certification can be an important tag for your job interview and you will have more competitiveness advantages than others.
Linux Foundation CKA (Certified Kubernetes Administrator) Program Exam is an industry-recognized certification program for IT professionals who want to demonstrate their skills in managing and deploying Kubernetes clusters. CKA exam is designed to test the skills and knowledge required to successfully deploy, manage, and troubleshoot Kubernetes clusters.
The Linux Foundation CKA exam is a performance-based exam that tests a candidate's ability to perform tasks commonly performed by Kubernetes administrators. CKA Exam consists of a set of tasks that must be completed within a set amount of time. Candidates are required to demonstrate their ability to perform tasks such as deploying applications, scaling clusters, and troubleshooting issues. CKA exam is designed to be challenging, but candidates who have experience with Kubernetes and have prepared adequately should be able to pass the exam.
Linux Foundation Certified Kubernetes Administrator (CKA) Program Exam Sample Questions (Q18-Q23):NEW QUESTION # 18
Score: 4%
Task
Schedule a pod as follows:
* Name: nginx-kusc00401
* Image: nginx
* Node selector: disk=ssd
Solution:
#yaml
apiVersion: v1
kind: Pod
metadata:
spec:
containers:
- name: nginx
image: nginx
imagePullPolicy: IfNotPresent
nodeSelector:
disk: spinning
kubectl create -f node-select.yaml
NEW QUESTION # 19
Score: 4%
Task
Set the node named ek8s-node-1 as unavailable and reschedule all the pods running on it.
SOLUTION:
[student@node-1] > ssh ek8s
kubectl cordon ek8s-node-1
kubectl drain ek8s-node-1 --delete-local-data --ignore-daemonsets --force
NEW QUESTION # 20
Given a partially-functioning Kubernetes cluster, identify symptoms of failure on the cluster.
Determine the node, the failing service, and take actions to bring up the failed service and restore the health of the cluster. Ensure that any changes are made permanently.
You can ssh to the relevant I nodes (bk8s-master-0 or bk8s-node-0) using:
[student@node-1] $ ssh <nodename>
You can assume elevated privileges on any node in the cluster with the following command:
[student@nodename] $ | sudo -i
NEW QUESTION # 21
You have a deployment named 'my-app' running a web application that uses an external database service. You need to configure a 'ClusterlP' service to route traffic to the external database service.
See the solution below with Step by Step Explanation.
Solution (Step by Step) :
1 . Create the ClusterlP service:
- Create a 'ClusterlP' service that points to the external database service using the 'externalName' field.
2. Apply the service: - Apply the YAML file using 'kubectl apply -f external-db-service.yamr 3. Verify the service: - Check the status of the service using 'kubectl get services external-db-service -n ' 4. Test the service: - From a pod in the same namespace as the service, try to connect to the external database service using the 'external-db-service' service name and port. Note: - Replace with the actual namespace. - Replace 'my-external-db.example.com' with the actual hostname of your external database service. - Ensure that your cluster has access to the external database service.
NEW QUESTION # 22
You have a deployment that runs multiple replicas of a web server application. You need to ensure that the Deployment always maintains at least 2 replicas available, even if one or more pods are deleted or become unavailable. How can you configure the Deployment to achieve this using the 'maxUnavailable' field in the 'strategy.rollingUpdate' section?
1. Define the Deployment with maxUnavailable': Define a Deployment YAML file with 'replicas: 3', indicating that you want three replicas of the web server application. Then, in the 'strategy.rollinglJpdate' section, set the 'maxUnavailable' field to '1'.
2. Apply the Deployment: Apply the YAML file to your cluster using 'kubectl apply -f my-web-server.yamr. The deployment will create three replicas of your web server application. 3. Test the 'maxUnavailable' Configuration: Delete or terminate one of the pods in the Deployment. The Deployment will automatically create a new pod to replace the deleted or unavailable one, ensuring that at least two replicas are always available. You can monitor the status of the deployment using 'kubectl get pods -l app=my-web-server'. You should see that two pods are consistently running, while the third is being replaced.
NEW QUESTION # 23
Dump CKA File: https://www.prep4sureexam.com/CKA-dumps-torrent.html
DOWNLOAD the newest Prep4sureExam CKA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1txxRFnbVuNKJq2ZHm6LuzS8a4hY_52vN
