[General] C_THR86_2505 Free Brain Dumps - C_THR86_2505 New Guide Files
109
【General】 C_THR86_2505 Free Brain Dumps - C_THR86_2505 New Guide Files
Posted at 2/16/2026 13:56:27      View:76 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 SAP C_THR86_2505 dumps are available on Google Drive shared by RealVCE: https://drive.google.com/open?id=16nFGTOSsMvnFamt9aZgfcuC5HtegMeNy
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation (C_THR86_2505) certification exams are a great way to analyze and evaluate the skills of a candidate effectively. Big companies are always on the lookout for capable candidates. You need to pass the SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation (C_THR86_2505) certification exam to become a certified professional. This task is considerably tough for unprepared candidates however with the right C_THR86_2505 prep material there remains no chance of failure.
SAP C_THR86_2505 Exam Syllabus Topics:
  • Permissions:This section of the exam measures the knowledge of Compensation Analysts in managing role-based permissions for compensation planners and administrators. It includes securing access to forms, fields, and processes.
  • Compensation Plan Guidelines: This section of the exam measures skills of Compensation Analysts and covers the configuration of compensation plan guidelines, including eligibility and budgeting parameters that guide manager decisions during compensation cycles.
  • Reports and Workflows: This section of the exam evaluates the proficiency of SAP Consultants in setting up reports and approval workflows. It covers route maps, executive reviews, and standard reporting capabilities.
  • Managing Employee Specific Data:This section of the exam assesses the skills of SAP Consultants in handling employee-specific data used in compensation planning. It includes importing and mapping fields like pay, performance, and custom metrics.
Topic 5
  • Compensation Statements: This section of the exam assesses the ability of SAP Consultants to configure and generate employee-facing compensation statements. It includes statement templates, design options, and output settings to ensure clear communication of compensation results.
Topic 6
  • Set Up Import Tables:This section of the exam assesses the ability of Compensation Analysts to configure and import required compensation-related tables. It includes loading lookup tables and data required for business rules and logic.
SAP C_THR86_2505 Free Brain Dumps Exam Instant Download | Updated C_THR86_2505: SAP Certified Associate - Implementation Consultant - SAP SuccessFactors CompensationOur SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation study questions have a high quality, that mainly reflected in the passing rate. More than 99% students who use our C_THR86_2505 exam material passed the exam and successfully obtained the relating certificate. This undoubtedly means that if you purchased C_THR86_2505 exam guide and followed the information we provided you, you will have a 99% chance of successfully passing the exam. With C_THR86_2505 Exam Guide, there will not be a situation like other students that you need to re-purchase guidance materials once the syllabus has changed. C_THR86_2505 exam material not only helps you to save a lot of money, but also let you know the new exam trends earlier than others.
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation Sample Questions (Q24-Q29):NEW QUESTION # 24
For which customer requirement do you need to develop a custom statement?
  • A. Field visibility is conditional on amount
  • B. Different statements per employee group
  • C. Pie graph showing compensation element distribution
  • D. Mix of data from compensation variable pay
SAP SuccessFactors Compensation statements do not support advanced graphical elements like pie charts directly within standard statements.
* Creating Custom Statements for Graphs
* Option B: A custom statement would be required to include advanced elements such as pie graphs, as standard statement templates do not natively support graphical components.
* Why Other Options Are Incorrect
* Option A (mix of data from compensation and variable pay), Option C (different statements per employee group), and Option D (conditional field visibility based on amount) are all possible with standard statement configurations.
* Reference Documentation
* SAP SuccessFactors Compensation Guide on Custom Statement Development and Standard vs. Custom Statement Capabilities.
NEW QUESTION # 25
You configure the following salary rule in the compensation plan template:
How does the system behave?
  • A. A pop-up message asks the planner if the exceeded amount should be assigned to Lump Sum.
    *The planner CANNOT save the merit increase by selecting Cancel in the pop-up message.
  • B. A pop-up message asks the planner if the exceeded amount should be assigned to Lump Sum.
    *The planner can save the merit recommendation by selecting Cancel in the pop-up message.
  • C. The rule alerts the planner that the range penetration threshold has been exceeded the merit field text turns red.
    *The planner can save the merit recommendation.
  • D. The rule prevents the planner from saving the merit increase.
    *The planner must go back change their merit recommendation.
NEW QUESTION # 26
What action is required to enable Employee Central integration for a template?
  • A. Enable field-based permissions.
  • B. Reload guidelines.
  • C. Provide an effective date
  • D. Update pay guide format.
In SAP SuccessFactors Compensation, enabling integration with Employee Central requires specifying an effective date. This date is essential because Employee Central (EC) integration pulls data that is time- dependent, such as employee job information, pay components, and other relevant details.
* Providing an Effective Date for Integration
* Effective Date: Setting an effective date in the compensation template is necessary to synchronize data accurately from Employee Central. The system uses this date to retrieve the correct employee data as of that specific point in time.
* Option A (field-based permissions) relates to access control but is not specifically required for enabling EC integration.
* Option B (reload guidelines) is used when updating or reloading guideline data but does not affect EC integration.
* Option C (update pay guide format) is unrelated to Employee Central integration.
* SAP SuccessFactors Compensation Guide on Employee Central Integration Setup and Effective Date Configuration.
NEW QUESTION # 27
A customer is using the following number format: ###0 Mode: Round down Multiple: 100. How will a value of 9575.50 be displayed?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
In SAP SuccessFactors Compensation, when using a number format that specifies rounding down and rounding to the nearest multiple of 100, calculations are done as follows:
* Understanding the Format Settings
* Mode: Round Down: This setting rounds the value down to the nearest specified multiple.
* Multiple: 100: Specifies that rounding should occur to the nearest 100.
* Calculation for 9575.50
* Given the number 9575.50, rounding down to the nearest multiple of 100 results in 9500, as rounding down means moving to the lower nearest 100.
* Option B (9570) would not be correct as it does not round to the nearest 100.
* Options C (9000) and D (9600) do not accurately reflect the rounding down requirement with a multiple of 100.
* SAP SuccessFactors Compensation Guide on Number Formatting and Rounding Options.
NEW QUESTION # 28
You have configured a worksheet for a client that uses the following formula in a custom column of type Money: (curSalary lookup("budget_table",customCountry,1))/100.
The lookup table "budget_table" is configured with one input one output. There are three rows in the table:
*         USA = 5
*         GBR = 3
*         *=2
When the worksheet loads, the column displays correctly, but when a merit value is changed, it switches to N/A for the employee. What could be done to fix this behavior?
  • A. Change the column to be of the Amount type.
  • B. Surround the lookup function with the toNumber function.
  • C. Remove the extra parentheses.
  • D. Surround the curSalary with the toString function.
NEW QUESTION # 29
To clear the SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation C_THR86_2505 exam questions in one go and not waste your time and money, follow these tips and see the result yourself. And when you know that you are ready with all the SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Compensation C_THR86_2505 Preparation, just relax, breathe and chill out. You have put your best efforts to mark your success and you shall get the best outcome out of it.
C_THR86_2505 New Guide Files: https://www.realvce.com/C_THR86_2505_free-dumps.html
2026 Latest RealVCE C_THR86_2505 PDF Dumps and C_THR86_2505 Exam Engine Free Share: https://drive.google.com/open?id=16nFGTOSsMvnFamt9aZgfcuC5HtegMeNy
