[Hardware] UiPath-ADPv1 VCE Torrent & UiPath-ADPv1 Exam Dumps & UiPath-ADPv1 Study
138
【Hardware】 UiPath-ADPv1 VCE Torrent & UiPath-ADPv1 Exam Dumps & UiPath-ADPv1 Study
Posted at 2/16/2026 17:40:36      View:106 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New UiPath-ADPv1 dumps are available on Google Drive shared by DumpsTests: https://drive.google.com/open?id=1uCx0U1OAGyk72PHZEKg-Ecmlmlu00SCA
Our UiPath experts also guarantee that anyone who studies well enough from the prep material will pass the UiPath Exams on the first try. We have kept the price of our UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) exam prep material very reasonable compared to other platforms so as not to stretch your tight budget further. And we also offer up to 1 year of free updates. A demo version of the preparation material is available on the website so that you can verify the validity of the product before obtaining them.
DumpsTests provides with actual UiPath UiPath-ADPv1 exam dumps in PDF format. You can easily download and use UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) PDF dumps on laptops, tablets, and smartphones. Our real UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) dumps PDF is useful for applicants who don't have enough time to prepare for the examination. If you are a busy individual, you can use UiPath UiPath-ADPv1 PDF dumps on the go and save time.
Latest UiPath UiPath-ADPv1 Questions – Key To Success In First TryWith pass rate reaching 98%, our UiPath-ADPv1 learning materials have gained popularity among candidates, and they think highly of the exam dumps. In addition, UiPath-ADPv1 exam braindumps are edited by professional experts, and they have rich experiences in compiling the UiPath-ADPv1 exam dumps. Therefore, you can use them at ease. We offer you free update for one year for UiPath-ADPv1 Training Materials, and the update version will be sent to your email automatically. If you have any questions after purchasing UiPath-ADPv1 exam dumps, you can contact us by email, we will give you reply as quickly as possible.
UiPath (ADPv1) Automation Developer Professional Sample Questions (Q183-Q188):NEW QUESTION # 183
In which of the following places can you access a recording of a failed queue transaction in UiPath Orchestrator?
  • A. In the queue transaction list view, by hovering over the transaction status.
  • B. In the Logs page of the queue transaction.
  • C. In the job details window of the process that contains the failed transaction.
  • D. In the contextual menu of the failed transaction, by clicking Open recording.
In UiPath Orchestrator, when a queue item fails and a recording is available (if enabled and the job was executed with recording turned on), you can access the recording directly from thecontextual menu of the failed transaction. This is done by selecting"Open recording", which provides insight into what occurred during the automation at runtime. This feature is valuable for debugging and exception analysis.
Reference:UiPath Orchestrator Guide > Monitoring > Queue Transactions > Recordings
NEW QUESTION # 184
Suppose you have the following workflow that verifies if the text value of an element is equal to "Work Items":
The configuration for the Verify Control Attribute and Get Text activities is shown below:
The element and its selector are highlighted in the image below:
Taking into consideration that the page shown above will be present on screen at execution time, what will be the result of the Verify Control Attribute activity?
  • A. Verification will be passed.
  • B. Verification will be failed because the actual value is different than expected value.
  • C. Verification will not be executed.
  • D. An exception will be thrown because there is no variable set in the Save to property of the Get text activity.
The workflow in question uses a 'Verify Control Attribute' activity to check if the text value of a UI element is equal to "Work Items". The Get Text activity is used to retrieve the text from the specified UI element, and the result of this activity is compared against the expected value "Work Items".
From the provided information, the 'Verify Control Attribute' activity has been set up with the Expression
"Work Items" and the Operator set to Equality. The 'Get Text' activity is configured to extract the text from the UI element with the visible text "Work Items", as indicated by the selector shown in the image.
Since the actual value of the UI element's text is "Work Items" (which matches the expected value in the
'Verify Control Attribute' activity), and provided that the 'Get Text' activity successfully retrieves this value, the verification will pass. The configuration indicates that the activity should take a screenshot only if the verification fails (TakeScreenshotIfFailed is set to True), which will not be the case here.
Therefore, assuming that there are no other issues such as incorrect selectors or unexpected changes to the UI element at execution time, the result of the 'Verify Control Attribute' activity will be a pass.
UiPath Documentation: Verify Control Attribute Activity
NEW QUESTION # 185
A project built using REFramework pulls phone numbers from a database of employees and creates queue items for each one. Following processing, these elements must be added to a financing application. The queue item holding a phone number becomes invalid if a digit is accidentally left out because of a human mistake. As a requirement, queue items that contain partial numbers should not be accepted.
What type of error should be thrown according to best practices?
  • A. Fatal Exception
  • B. Application Exception
  • C. Business Exception
  • D. System Exception
NEW QUESTION # 186
Considering that the attached table is stored in a variable called "dt":
Which LINQ query can be used to return the maximum total Quantity?
  • A. dt.AsEnumerable. Max(Function(x) Convert.ToInt32(x("Quantity").ToString))("Item")
  • B. dt.AsEnumerable. GroupBy(Function(x) x("Item").ToString). Max(Function(x) x.Sum(Function(y) Convert.ToInt32(y("Quantity").ToString)))
  • C. dt.AsEnumerable. Max(Function(x) Convert.ToInt32(x("Quantity").ToString))
  • D. dt.AsEnumerable. OrderByDescending(Function(x) Convert.ToInt32(x("Quantity").ToString)).First.Item("Quantity")
The LINQ query that can be used to return the maximum total Quantity from the attached table is dt.AsEnumerable. GroupBy(Function(x) x("Item").ToString). Max(Function(x) x.Sum(Function(y) Convert.ToInt32(y("Quantity").ToString))). This query uses the LINQ methods AsEnumerable, GroupBy, Max, and Sum to manipulate the data in the dt variable. The dt variable is a DataTable that contains the following data:
No.
Item
Quantity
1
apple
10
2
orange
20
3
mango
50
4
kiwi
80
5
pear
1
6
apple
5
7
mango
15
The AsEnumerable method converts the DataTable into an Enumerable collection of DataRow objects. The GroupBy method groups the elements of the collection by the value of the Item column, creating a collection of groups. Each group has a key, which is the Item name, and a list of elements, which are the DataRows that have the same Item value. The Max method returns the maximum value of the collection, based on a selector function. The selector function is a lambda expression that calculates the sum of the Quantity column for each group. The Sum method returns the sum of the elements in a collection, based on a selector function. The selector function is a lambda expression that converts the value of the Quantity column into an integer.
Therefore, the query will group the DataRows by the Item name, calculate the total Quantity for each group, and return the maximum total Quantity among the groups. The maximum total Quantity is 80, which corresponds to the group with the key "kiwi". References: [DataTable.AsEnumerable Method],
[Enumerable.GroupBy Method], [Enumerable.Max Method], [Enumerable.Sum Method]
NEW QUESTION # 187
Consider testing a workflow that computes the sum of two numbers having the data driven test data from the Excel file below:
Expanding the functionality of the workflow to compute the sum of three numbers, the data needs to be updated as well to accommodate the new scenario:
What are steps to do that?
  • A. Click Right on the Test Case and select Add Test Data.
  • B. Click Right on the Test Case and select Refresh Test Data
  • C. Click Right on the Test Case and select Update Test Data
  • D. Click Right on the Test Case and select Remove Test Data.
When expanding the functionality of a workflow to compute the sum of three numbers instead of two, and having to update the test data in an Excel file accordingly, you would generally need to:
Open the Excel file that contains the test data.
Add a new column for the third number (e.g., Number3).
Fill in the data for the new column with the appropriate values for the test cases.
Save the Excel file with the updated data.
Refresh or update the data source in the test case to reflect these changes.
This is because "Refresh Test Data" suggests that the test case will re-import or re-read the test data from its source, which in this case is the updated Excel file with the additional Number3 column. "Update Test Data" might also seem appropriate, but it typically refers to a scenario where you need to update the test case's reference to the data, not the structure of the data itself. "Add Test Data" and "Remove Test Data" are not appropriate as they imply adding a new data set or removing an existing one, rather than refreshing or updating the existing data set with the new column.
NEW QUESTION # 188
DumpsTests presents you with their effective UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) exam dumps as we know that the registration fee is very high (from $100-$1000). DumpsTests product covers all the topics with a complete collection of actual UiPath-ADPv1 exam questions. We also offer free demos and up to 1 year of free UiPath Dumps updates. So, our UiPath UiPath-ADPv1 prep material is the best to enhance knowledge which is helpful to pass UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) on the first attempt.
Valid Test UiPath-ADPv1 Testking: https://www.dumpstests.com/UiPath-ADPv1-latest-test-dumps.html
The UiPath UiPath-ADPv1 PDF questions file is very installed on any device and operating system, UiPath Valid Test UiPath-ADPv1 Testking eBook is wide so I focused only on what I was not confident in, Our website provides the most up to date and accurate UiPath Valid Test UiPath-ADPv1 Testking Valid Test UiPath-ADPv1 Testking - UiPath (ADPv1) Automation Developer Professional free download training materials which are the best for clearing Valid Test UiPath-ADPv1 Testking - UiPath (ADPv1) Automation Developer Professional pass guaranteed exam and to get certified by UiPath Valid Test UiPath-ADPv1 Testking certified associate, When you want to perfect your skill, choosing to pass UiPath-ADPv1 exam sounds nice.
Such relationships include whether you have physically met UiPath-ADPv1 that person, if that person is a friend or colleague, even if that person is a family member or significant other.
Maximise security capabilities in existing investments, The UiPath UiPath-ADPv1 PDF Questions file is very installed on any device and operating system, UiPath eBook is wide so I focused only on what I was not confident in.
Is It Important To Get UiPath UiPath-ADPv1 Exam Material For The Exam?Our website provides the most up to date and accurate UiPath UiPath (ADPv1) Automation Developer Professional free Real UiPath-ADPv1 Exams download training materials which are the best for clearing UiPath (ADPv1) Automation Developer Professional pass guaranteed exam and to get certified by UiPath certified associate.
When you want to perfect your skill, choosing to pass UiPath-ADPv1 exam sounds nice, There is no doubt that you can get a great grade.
What's more, part of that DumpsTests UiPath-ADPv1 dumps now are free: https://drive.google.com/open?id=1uCx0U1OAGyk72PHZEKg-Ecmlmlu00SCA
Posted at 2/24/2026 14:23:43        Only Author  2#
I really appreciate your article, it has been an eye-opening experience. Thanks to the C-S4CCO-2506 Examcollection questions answers exam, I reached a new level in my career. Now I’m sharing it for free with all of you!
