[General] Latest ATLASSIAN ACP-120 Practice Materials, Reliable ACP-120 Exam Preparation
98
General Latest ATLASSIAN ACP-120 Practice Materials, Reliable ACP-120 Exam Preparation
Posted at 2/16/2026 23:44:26      View143 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Actual4Cert ACP-120 dumps for free: https://drive.google.com/open?id=1_W-5_FXlY_ikjEWZmQ3o0ddGgyahLLVk
It is universally acknowledged that the pass rate is the most persuasive evidence to prove how useful and effective a kind of ACP-120 practice test is. In terms of our ACP-120 training materials, the pass rate is one of the aspects that we take so much pride in because according to the statistics from the feedbacks of all of our customers, under the guidance of our ACP-120 Preparation materials, the pass rate among our customers has reached as high as 98% to 100%, which marks the highest pass rate in the field. So just feel rest assured to buy our ACP-120 study guide!
ATLASSIAN ACP-120 (Jira Cloud Administrator) Certification Exam is an industry-standard certification designed for professionals who have experience in administering Jira Cloud instances. Jira Cloud Administrator certification exam is intended to validate the skills and knowledge of an individual in setting up and managing Jira Cloud projects, workflows, and schemes.
Reliable ACP-120 Exam Preparation | ACP-120 Relevant QuestionsHowever, you should keep in mind to pass the Jira Cloud Administrator (ACP-120) certification exam is not an easy task. It is a challenging job. If you want to pass the ACP-120 exam then you have to put in some extra effort, time, and investment then you will be confident to pass the Jira Cloud Administrator (ACP-120) exam. With the complete and comprehensive Jira Cloud Administrator (ACP-120) exam dumps preparation you can pass the Jira Cloud Administrator (ACP-120) exam with good scores. The Actual4Cert ACP-120 Questions can be helpful in this regard. You must try this.
ATLASSIAN Jira Cloud Administrator Sample Questions (Q16-Q21):NEW QUESTION # 16
Users have been adding sensitive information into the Description field of issues in a particular project. You must secure the project by any means necessary so that only members of the Managers group can view the contents of the Description field.
Which approach will definitively satisfy this requirement? (Choose one)
  • A. Hide the description field in the field configuration
  • B. Remove everyone from the browse projects permission
  • C. Remove the description field from the screen used by the view operation
  • D. Remove everyone except the managers group from every project role
  • E. Remove everyone except the managers group from every project permission
NEW QUESTION # 17
You are using a bulk move operation to migrate issues in a company-managed project from one issue type to another. Identify the two elements that might need to change. (Choose two.)
  • A. Labels
  • B. Required fields
  • C. Statuses
  • D. Priorities
  • E. Resolutions
When using a bulk move operation to migrate issues between issue types within a company-managed project, certain elements may need to change due to differences in configurations (e.g., workflows, field configurations) associated with the source and target issue types. The two elements that might need to change arestatuses(Option A) andrequired fields(Option C).
* Explanation of the Correct Answers:
* Statuses (Option A):
* Each issue type in a company-managed project can be associated with a different workflow via the project'sworkflow scheme. If the source and target issue types use different workflows, the statuses available in the target workflow may differ from those in the source workflow. During a bulk move, you must map the current status of each issue to a valid status in the target workflow, as the issue's status might not exist in the new workflow.
* Exact Extract from Documentation:
Move issues in Jira Cloud
When moving issues to a different issue type in a company-managed project, you may need to map statuses if the source and target issue types use different workflows.
To move issues:
* Select issues and chooseBulk change>Move issues.
* Choose the target issue type.
* Map statuses from the source workflow to the target workflow if they differ.Note:
Status mapping is required when workflows have different statuses.(Source:
Atlassian Support Documentation, "Move issues in Jira Cloud")
* Why This Fits: If the target issue type's workflow has different statuses, the issues' statuses must be mapped during the move, makingstatusesa potential element that needs to change.
* Required fields (Option C):
* Different issue types can be associated with differentfield configuration schemes, which define whether fields are required, optional, or hidden. If the target issue type requires fields that were not required for the source issuetype (e.g., a custom field or system field likeDue Date), you must provide values for these required fields during the bulk move operation.
Bulk move issues
When moving issues to a different issue type, you may need to update fields if the target issue type's field configuration requires fields that were not required for the source issue type.
During the move:
* The bulk move wizard prompts you to provide values for any newly required fields.
* Ensure all required fields have valid values to complete the move.Note: Field configurations are defined inSettings > Issues > Field configurations.(Source:
* Why This Fits: Required fields may differ between issue types due to field configuration schemes, and the bulk move operation will prompt for values if the target issue type has additional required fields, makingrequired fieldsa potential element that needs to change.
* Why Other Options Are Incorrect:
* Priorities (Option B):
* Thepriorityfield is not typically tied to issue type-specific configurations (e.g., workflows or field configurations). Priorities are managed globally (Settings > Issues > Priorities) and are generally consistent across issue types unless restricted by a custom field configuration or workflow property, which is rare. A bulk move does not require changing priorities unless explicitly prompted by a field configuration, which is covered byrequired fields(Option C).
* Extract from Documentation:
Priorities are global and not issue type-specific. They are only updated during a move if required by the target issue type's field configuration.
(Source: Atlassian Support Documentation, "Manage priorities in Jira Cloud")
* Resolutions (Option D):
* Theresolutionfield is set or cleared based on workflow transitions (e.g., resolving or reopening an issue). Moving issues between issue types within the same project does not inherently require changing the resolution, as it is tied to the issue's status and workflow, not the issue type itself. Any status mapping (covered by Option A) handles resolution indirectly.
Resolution is managed by workflow transitions, not issue type changes. Moving issues does not typically require updating resolution unless a specific transition is involved.
(Source: Atlassian Support Documentation, "Configure advanced work item workflows")
* Labels (Option E):
* Thelabelsfield is a standard field that is not issue type-specific and does not typically require changes during a move unless it is a required field in the target issue type's field configuration (covered by Option C). Labels are preserved during a move unless explicitly modified.
Fields likeLabelsare preserved during a move unless the target issue type's field configuration requires a new value.
(Source: Atlassian Support Documentation, "Move issues in Jira Cloud")
* Additional Notes:
* The bulk move operation is performed viaIssues > Search for issues > Bulkchange > Move issues, requiring theMove Issuespermission.
* The need to changestatusesandrequired fieldsdepends on the differences in workflows and field configurations between the source and target issue types.
* If the issue types share the same workflow and field configuration, no changes may be needed, but the question asks for elements thatmightneed to change.
Atlassian Support Documentation:Move issues in Jira Cloud
Atlassian Support Documentation:Configure advanced work item workflows
Atlassian Support Documentation:Manage priorities in Jira Cloud
NEW QUESTION # 18
You have just deployed a new Support Workflow and Support Notification Scheme. Manager Maria should be receiving notifications when users click the Escalate workflow transition, but she is not.
Identify two possible reasons Maria is not receiving the notifications. (Choose two.)
  • A. The Escalate workflow transition is firing the right event but uses the wrong email template.
  • B. The right custom event has been deleted from the Support Notification Scheme.
  • C. Maria is not listed in the Issue Escalated (System) event of the Support Notification Scheme.
  • D. The Escalate workflow transition is firing the right event, but the event is marked Inactive.
  • E. Maria is not listed in the right custom event of the Support Notification Scheme.
  • F. The Escalate workflow transition is firing the wrong event.
NEW QUESTION # 19
Martin has Create Attachments permission in a software project, but he cannot attach anything to issues in Approved status.
What is the problem?
  • A. He does not have the correct project permission.
  • B. He is not a member of a security level.
  • C. The Attachment field is missing from the screen for that issue type.
  • D. There is a workflow condition configured.
  • E. There is a workflow step property configured.
Reference: https://confluence.atlassian.com ... ents-818578880.html
NEW QUESTION # 20
A team in your company requests a new Jira project that fulfills the following requirements:
* Ability to work on issues in weekly iterations
* Allows the project administrators to create their own fields
The project should fulfill these requirements right after creation without the need to enable additional features.
Which project should you create?
  • A. Company-managed project with Scrum template
  • B. A company-managed project with Kanban template
  • C. Team-managed project with Canban template
  • D. Team-managed project with Scrum template
NEW QUESTION # 21
If you search test practice questions you can find us which is the leading position in this field or you may know us from other candidates about our high-quality ACP-120 training materials as every year thousands of candidates choose us and gain success for their exams. If you want to choose reliable and efficient Latest ACP-120 Questions and answers, we will be your best choice as we have 100% pass rate for ACP-120 exams. Many candidates prefer simulator function of our ACP-120 training materials. And our ACP-120 exam questions won't let you down.
Reliable ACP-120 Exam Preparation: https://www.actual4cert.com/ACP-120-real-questions.html
P.S. Free & New ACP-120 dumps are available on Google Drive shared by Actual4Cert: https://drive.google.com/open?id=1_W-5_FXlY_ikjEWZmQ3o0ddGgyahLLVk
Posted at 2/21/2026 13:39:14        Only Author  2#
I am so grateful for this inspiring article, thank you! Examcode materials are available free of charge. Best of luck to everyone! examinations H12-841_V1.5 actual questions
