New Snowflake ARA-C01 Exam Question | ARA-C01 Sample Exam
Posted at 2/18/2026 00:20:16
2026 Latest PassCollection ARA-C01 PDF Dumps and ARA-C01 Exam Engine Free Share: https://drive.google.com/open?id=1o5cdanuAWIRx51md0YiOlx41028it5-Q
You can free download part of PassCollection's exercises and answers about Snowflake certification ARA-C01 exam as a try, then you will be more confident to choose our PassCollection's products to prepare your Snowflake Certification ARA-C01 Exam. Please add PassCollection's products in you cart quickly.
Snowflake ARA-C01 exam consists of multiple-choice questions that cover a wide range of topics related to data warehousing and cloud computing. ARA-C01 exam is timed, with a total duration of 120 minutes, and candidates must achieve a minimum score of 80% to pass. ARA-C01 Exam is available in multiple languages including English, Japanese, and Spanish.
ARA-C01 Sample Exam & ARA-C01 Reliable Braindumps QuestionsOur company has successfully created ourselves famous brands in the past years, and all of the ARA-C01 valid study guide materials from our company have been authenticated by the international authoritative institutes and cater for the demands of all customers at the same time. We are attested that the quality of the ARA-C01 Test Prep from our company have won great faith and favor of customers. We persist in keeping creating the best helpful and most suitable ARA-C01 study practice question for all customers.
Snowflake SnowPro Advanced Architect Certification Sample Questions (Q113-Q118):NEW QUESTION # 113
An Architect is creating a new database role and is considering using the OR REPLACE keywords in the CREATE DATABASE ROLE command.
What should be considered before using OR REPLACE?
- A. The OR REPLACE keywords are unsupported for database roles.
- B. The database role can only be dropped by a role with MANAGE GRANTS privilege.
- C. The dropped database role cannot be recreated.
- D. Recreating a database role drops it from any shares it is granted to.
Using CREATE OR REPLACE DATABASE ROLE in Snowflake drops and recreates the role if it already exists. While this can simplify deployment scripts, it has important side effects that architects must understand. When a database role is dropped and recreated, all grants associated with that role-including grants to shares-are removed (Answer B). This can unintentionally break data sharing configurations or downstream access.
Although the role itself can be recreated, the loss of grants requires manual remediation, increasing operational risk. The OR REPLACE syntax is supported for database roles, and while privilege requirements matter, they are not the key risk being tested here.
For SnowPro Architect candidates, this question reinforces best practices around role lifecycle management and governance. In production environments, replacing roles should be done cautiously, with a clear understanding of grant dependencies and the potential impact on security and data sharing.
NEW QUESTION # 114
How do you refresh a materialized view?
- A. REFRESH MATERIALIZED VIEW <MV_NAME>
- B. Materialized views are automatically refreshed by snowflake and does not require manual intervention
- C. ALTER VIEW <MV_NAME> REFRESH
NEW QUESTION # 115
It is recommended to assign ACCOUNTADMIN role to atleast two user
NEW QUESTION # 116
Based on the Snowflake object hierarchy, what securable objects belong directly to a Snowflake account? (Select THREE).
- A. Schema
- B. Database
- C. Warehouse
- D. Role
- E. Table
- F. Stage
Answer: B,C,D
NEW QUESTION # 117
An Architect needs to meet a company requirement to ingest files from the company's AWS storage accounts into the company's Snowflake Google Cloud Platform (GCP) account. How can the ingestion of these files into the company's Snowflake account be initiated? (Select TWO).
- A. Configure AWS Simple Notification Service (SNS) to notify Snowpipe when new files have arrived in Amazon S3 storage.
- B. Configure the client application to issue a COPY INTO <TABLE> command to Snowflake when new files have arrived in Amazon S3 Glacier storage.
- C. Configure the client application to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 Glacier storage.
- D. Create an AWS Lambda function to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 storage.
- E. Configure the client application to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 storage.
Answer: D,E
Snowpipe is a feature that enables continuous, near-real-time data ingestion from external sources into Snowflake tables. Snowpipe can ingest files from Amazon S3, Google Cloud Storage, or Azure Blob Storage into Snowflake tables on any cloud platform. Snowpipe can be triggered in two ways: by using the Snowpipe REST API or by using cloud notifications2 To ingest files from the company's AWS storage accounts into the company's Snowflake GCP account, the Architect can use either of these methods:
* Configure the client application to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 storage. This method requires the client application to monitor the S3 buckets for new files and send a request to the Snowpipe REST API with the list of files to ingest. The client application must also handle authentication, error handling, and retry logic3
* Create an AWS Lambda function to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 storage. This method leverages the AWS Lambda service to execute a function that calls the Snowpipe REST API whenever an S3 event notification is received. The AWS Lambda function must be configured with the appropriate permissions, triggers, and code to invoke the Snowpipe REST API4 The other options are not valid methods for triggering Snowpipe:
* Configure the client application to call the Snowpipe REST endpoint when new files have arrived in Amazon S3 Glacier storage. This option is not feasible because Snowpipe does not support ingesting files from Amazon S3 Glacier storage, which is a long-term archival storage service. Snowpipe only supports ingesting files from Amazon S3 standard storage classes5
* Configure AWS Simple Notification Service (SNS) to notify Snowpipe when new files have arrived in Amazon S3 storage. This option is not applicable because Snowpipe does not support cloud notifications from AWS SNS. Snowpipe only supports cloud notifications from AWS SQS, Google Cloud Pub/Sub, or Azure Event Grid6
* Configure the client application to issue a COPY INTO <TABLE> command to Snowflake when new files have arrived in Amazon S3 Glacier storage. This option is not relevant because it does not use Snowpipe, but rather the standard COPY command, which is a batch loading method. Moreover, the COPY command also does not support ingesting files from Amazon S3 Glacier storage7 References:
* 1: SnowPro Advanced: Architect | Study Guide 8
* 2: Snowflake Documentation | Snowpipe Overview 9
* 3: Snowflake Documentation | Using the Snowpipe REST API 10
* 4: Snowflake Documentation | Loading Data Using Snowpipe and AWS Lambda 11
* 5: Snowflake Documentation | Supported File Formats and Compression for Staged Data Files 12
* 6: Snowflake Documentation | Using Cloud Notifications to Trigger Snowpipe 13
* 7: Snowflake Documentation | Loading Data Using COPY into a Table
* : SnowPro Advanced: Architect | Study Guide
* : Snowpipe Overview
* : Using the Snowpipe REST API
* : Loading Data Using Snowpipe and AWS Lambda
* : Supported File Formats and Compression for Staged Data Files
* : Using Cloud Notifications to Trigger Snowpipe
* : Loading Data Using COPY into a Table
NEW QUESTION # 118
When preparing to take the SnowPro Advanced Architect Certification (ARA-C01) exam dumps, knowing where to start can be a little frustrating, but with Snowflake ARA-C01 practice questions, you will feel fully prepared. Using our Snowflake ARA-C01 practice test PassCollection, you can prepare for the increased difficulty on ARA-C01 Exam day. Plus, we have various question types and difficulty levels so that you can tailor your Snowflake ARA-C01 exam dumps preparation to your requirements.
ARA-C01 Sample Exam: https://www.passcollection.com/ARA-C01_real-exams.html
- ARA-C01 Test Dumps 🧸 ARA-C01 Latest Real Exam 🧛 New ARA-C01 Dumps 🔝 Open ⏩ [url]www.testkingpass.com ⏪ and search for ▛ ARA-C01 ▟ to download exam materials for free 📞ARA-C01 Certification Sample Questions[/url]
- ARA-C01 Valid Exam Vce Free 📗 ARA-C01 Valid Exam Vce Free 📢 ARA-C01 Free Brain Dumps 🤭 Search for 《 ARA-C01 》 and easily obtain a free download on ✔ [url]www.pdfvce.com ️✔️ ⏪Hot ARA-C01 Spot Questions[/url]
- Quiz 2026 Snowflake ARA-C01: Newest New SnowPro Advanced Architect Certification Exam Question 🗓 Search on ➠ [url]www.troytecdumps.com 🠰 for ➠ ARA-C01 🠰 to obtain exam materials for free download 🤲ARA-C01 Test Simulator Free[/url]
- Technical ARA-C01 Training 📥 Clearer ARA-C01 Explanation 📏 ARA-C01 Valid Exam Vce Free 🥎 Simply search for ➥ ARA-C01 🡄 for free download on ➡ [url]www.pdfvce.com ️⬅️ 🕰ARA-C01 Exam Introduction[/url]
- Valid ARA-C01 Exam Test 👄 ARA-C01 Latest Real Exam 🧊 Reliable ARA-C01 Mock Test ⬇ Search for ➽ ARA-C01 🢪 and download it for free on ➥ [url]www.examcollectionpass.com 🡄 website 🦐Clearer ARA-C01 Explanation[/url]
- Snowflake New ARA-C01 Exam Question - Authorized ARA-C01 Sample Exam and Perfect SnowPro Advanced Architect Certification Reliable Braindumps Questions ⏬ Download ⮆ ARA-C01 ⮄ for free by simply entering ➡ [url]www.pdfvce.com ️⬅️ website 🍹Technical ARA-C01 Training[/url]
- Snowflake ARA-C01 Exam Dumps - Excellent Tips To Pass Exam 🍈 Search for 《 ARA-C01 》 and download it for free on ▶ [url]www.practicevce.com ◀ website 😲Reliable ARA-C01 Test Cost[/url]
- Pass Guaranteed 2026 Snowflake High-quality New ARA-C01 Exam Question 🆚 Download ⇛ ARA-C01 ⇚ for free by simply entering ⇛ [url]www.pdfvce.com ⇚ website 🕢Excellect ARA-C01 Pass Rate[/url]
- Hot ARA-C01 Spot Questions 🤿 New ARA-C01 Dumps 🔓 ARA-C01 Exam Introduction 🌺 Search for ➠ ARA-C01 🠰 on ▶ [url]www.practicevce.com ◀ immediately to obtain a free download 🕜ARA-C01 Download Free Dumps[/url]
- Snowflake ARA-C01 Exam Dumps - Excellent Tips To Pass Exam 🔻 Simply search for { ARA-C01 } for free download on ▷ [url]www.pdfvce.com ◁ 🏃ARA-C01 Free Brain Dumps[/url]
- 2026 High-quality Snowflake ARA-C01: New SnowPro Advanced Architect Certification Exam Question 🍙 Search for ✔ ARA-C01 ️✔️ and download exam materials for free through { [url]www.practicevce.com } 🆎Reliable ARA-C01 Mock Test[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
What's more, part of that PassCollection ARA-C01 dumps now are free: https://drive.google.com/open?id=1o5cdanuAWIRx51md0YiOlx41028it5-Q
