[General] Adobe AD0-E117 Exam Dumps - Secret Hacks To Crack AD0-E117 Exam
90
【General】 Adobe AD0-E117 Exam Dumps - Secret Hacks To Crack AD0-E117 Exam
Posted at 2/18/2026 09:55:12      View:131 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Adobe AD0-E117 dumps are available on Google Drive shared by Dumpleader: https://drive.google.com/open?id=1HvY2aoBHQTuIvTupGYwJUkizpWQGfWuu
Additionally, students can take multiple Adobe AD0-E117 exam questions, helping them to check and improve their performance. Three formats are prepared in such a way that by using them, candidates will feel confident and crack the Adobe Experience Manager Architect Master (AD0-E117) actual exam. These three formats suit different preparation styles of AD0-E117 test takers.
Dumpleader AD0-E117 exam dumps are audited by our certified subject matter experts and published authors for development. AD0-E117 exam dumps are one of the highest quality AD0-E117 Q&AS in the world. It covers nearly 96% real questions and answers, including the entire testing scope. Dumpleader guarantees you Pass AD0-E117 Exam at first attempt.
Quiz AD0-E117 - Adobe Experience Manager Architect Master –Professional Exam OverviewsAre you in the condition that you want to make progress but you don't know how to and you are a little lost in the praparation. Perhaps you need help with our AD0-E117 preparation materials. A good product, the most important thing is to seize the user's most concerned part. We can tell you that 99% of those who use our AD0-E117 Exam Questions have already got the certificates they want and they all lead a better life now. Just buy our AD0-E117 trainning braindumps, then you will succeed as well!
Adobe Experience Manager Architect Master Sample Questions (Q41-Q46):NEW QUESTION # 41
A client is modernizing some of their AEM sites to go from static to editable templates so they can use the latest features around has the following parameters:
* The client currently has a dozen static templates that they want to move to editable templates.
* The existing pages use the parsys paragraph system for storing components.
* Each page based on one of the static templates has its own custom properties tab that is unique for that template type.
* The client wants template authors to be able to create the editable templates.
Which approach should an Architect use to meet these requirements?
  • A. 1. Use the same page components for editable templates
    2. Create a new editable template based on each of the existing page components
  • B. 1. Use a new page component for editable templates based on the core components page component
    2. Convert page properties to policies
  • C. 1. Use a new page component for editable templates based on the core components page component
    2. Migrate page properties to respective components dialogues
  • D. 1. Use the same page components for editable templates
    2. Use a new template type for each static template
NEW QUESTION # 42
A customer with an existing AEM implementation wants to enrich product pages with technical data coming from their PIM system. The PIM system sits behind an API Management solution that publicly exposes the PIM API's as RESTful web services with basic authentication as the security mechanism. Data consistency with the PIM and secure access to the APIs are key elements of the integration.
How should the Architect set up the integration between AEM and the PIM?
  • A. Integrate the AEM Publishers directly with the API Management solution
  • B. Use a client-side integration with AJAX from the browser to the API Management
  • C. Import the technical data into the AEM Author and replicate to Publishers
  • D. Convert the technical data to Content Fragments and expose using Content Services
Integrate the AEM Publishers directly with the API Management solution . According to Adobe Experience Manager documentation1, a direct integration between AEM and PIM can enable marketers and creative professionals to manage eCommerce-related product data and photography within AEM. A direct integration can also ensure data consistency with the PIM and secure access to the APIs using basic authentication23.
Option A is the only diagram that shows how AEM Publishers can directly communicate with the API Management solution.
NEW QUESTION # 43
A large AEM enterprise site is implementing authentication and requires a true optimal load balancing across the site's multi AEM publish instances. Which approach should an Architect take to meet this requirement?
  • A. Configure Sticky Connections
  • B. Configure the Dispatcher to run with a Dedicated System Usei
  • C. Enable Encapsulated Token Option
  • D. Enable Round Robin processing in Dispatcher configuration
"enabling Encapsulated Token Option can provide optimal load balancing across multiple AEM publish instances by using a token-based authentication mechanism".
NEW QUESTION # 44
A client's marketing pages are generally slow to load which is causing a significant drop in sales. All other AEM pages load within expected performance guidelines regardless of whether the visitor is being served the desktop or mobile experiences.
The marketing pages typically get slower when multiple external campaigns such as Facebook and AdWords drive traffic to those pages. The page performance tends to dip during high traffic periods. Internal campaign clicks such as those from hero images use similar campaign codes as external campaign traffic.
What should the Architect do to resolve this issue?
  • A. Convert the marketing pages to a responsive design instead of an adaptive design
  • B. Modify the dispatcher.any file's section to ignore campaign-based URL parameters
  • C. Add a new dispatcher farm to assist with the client's marketing pages
  • D. Set AEM to use GZIP compression instead of the web server's compression
NEW QUESTION # 45
AEM Site users report that the web content pages render very slowly. An Architect notices that the CPU usages of the AEM Publish instances are spiking and reviews the following entry in the log:
[Frt Nov 27 23:11:00 2019] [I] [pid 16004 (tid 140134145820416)] Current cache hit ratio: 47.94 % What should the Architect do to increase the dispatcher cache ratio and prevent the AEM Publish CPU usage spikes?
  • A. Add additional dispatcher servers
  • B. Review and optimize the Dispatcher cache configuration
  • C. Create a cron job that will delete the dispatcher cache on a regular basis
  • D. Add additional AEM instances to the Publish Farm
According to Adobe Experience Manager documentation5, dispatcher is a caching and load balancing tool that can be used to improve performance and security of AEM sites. Dispatcher cache configuration can be adjusted using various properties in the dispatcher.any file6. Creating a cron job that will delete the dispatcher cache on a regular basis  is not a good idea as it will reduce the cache hit ratio and increase the load on AEM servers.
NEW QUESTION # 46
The society has an abundance of capable people and there is a keen competition. Don't you feel a lot of pressure? No matter how high your qualifications, it does not mean your strength forever. Qualifications is just a stepping stone, and strength is the cornerstone which can secure your status. Adobe AD0-E117 certification exam is a popular IT certification, and many people want to have it. With it you can secure your career. Dumpleader's Adobe AD0-E117 Exam Training materials is a good training tool. It can help you pass the exam successfully. With this certification, you will get international recognition and acceptance. Then you no longer need to worry about being fired by your boss.
Hottest AD0-E117 Certification: https://www.dumpleader.com/AD0-E117_exam.html
Adobe AD0-E117 Exam Overviews The varieties versions can meet all the customers' requirements, Our AD0-E117 exam braindumps: Adobe Experience Manager Architect Master are always aimed at offering you the best service in the world, Adobe AD0-E117 Exam Overviews Currently, we just provide free PDF demo, Adobe AD0-E117 Exam Overviews And it has most related question & answers with totally hit rate, Adobe AD0-E117 Exam Overviews If you feel your current life is insipid and tasteless, you may do some changes for your life now.
Tony Ng is the Senior Director of Engineering at Yahoo, Implementing Hottest AD0-E117 Certification site quotas as they are created is a recommended best-practice approach and should be considered in most situations.
The varieties versions can meet all the customers' requirements, Our AD0-E117 Exam Braindumps: Adobe Experience Manager Architect Master are always aimed at offering you the best service in the world.
AD0-E117 training exam pdf & AD0-E117 real valid dumpsCurrently, we just provide free PDF demo, And it has most related question AD0-E117 & answers with totally hit rate, If you feel your current life is insipid and tasteless, you may do some changes for your life now.
P.S. Free & New AD0-E117 dumps are available on Google Drive shared by Dumpleader: https://drive.google.com/open?id=1HvY2aoBHQTuIvTupGYwJUkizpWQGfWuu
